Uninstalling BlueXP classification
You can uninstall the BlueXP classification software to troubleshoot issues or to permanently remove the software from the host. Deleting the instance also deletes the associated disks where the indexed data resides - all the information BlueXP classification has scanned will be permanently deleted.
The steps that you need to use depend on whether you deployed BlueXP classification in the cloud or on an on-premises host.
Uninstall BlueXP classification from a cloud deployment
You can uninstall and delete the BlueXP classification instance from the cloud provider if you no longer want to use BlueXP classification.
  1. At the top of the BlueXP classification page, click More button and then click Uninstall Data Sense.
    A screenshot of the button to uninstall BlueXP classification software.
  2. In the Uninstall Data Sense dialog, type uninstall to confirm that you want to delete the instance and all associated data, and then click Uninstall.
Note that you can go to your cloud provider’s console and delete the BlueXP classification instance from there as well. The instance is named CloudCompliance with a generated hash (UUID) concatenated to it. For example: CloudCompliance-16bb6564-38ad-4080-9a92-36f5fd2f71c7
Uninstall BlueXP classification from an on-premises deployment
You can uninstall BlueXP classification from a host if you no longer want to use BlueXP classification, or if you had an issue that requires reinstallation.
  2. In the Uninstall Data Sense dialog, type uninstall to confirm that you want to clear all the configuration information, and then click Uninstall.
  3. To complete the uninstallation from the host, run the uninstall script on the host machine, for example:
    uninstall.sh
