BlueXP classification
Assign policies to your data
Contributors netapp-tonacki amgrissino
Policies are like a favorites list of custom filters that provide search results in the Investigation page for commonly requested compliance queries. BlueXP classification provides a set of predefined Policies based on common customer requests. You can create custom Policies that provide results for searches specific to your organization.
Policies provide the following functionality:
  • Predefined Policies from NetApp based on user requests
  • Ability to create your own custom Policies
  • Launch the Investigation page with the results from your Policies in one click
  • Send email alerts to BlueXP users, or any other email addresses, when certain critical Policies return results so you can get notifications to protect your data
  • Assign AIP (Azure Information Protection) labels automatically to all files that match the criteria defined in a Policy
  • Delete files automatically (once per day) when certain Policies return results so you can protect your data automatically
The Policies tab in the Compliance Dashboard lists all the predefined and custom Policies available on this instance of BlueXP classification.
A screenshot of the Policies tab in the BlueXP classification dashboard.
In addition, Policies appear in the list of Filters in the Investigation page.
View Policy results in the Investigation page
To display the results for a Policy in the Investigation page, click the More button button for a specific Policy, and then select Investigate Results.
A screenshot of selecting Investigate Results for a specific Policy from the Policies tab.
Create custom Policies
You can create your own custom Policies that provide results for searches specific to your organization. Results are returned for all files and directories (shares and folders) that match the search criteria.
Note that the actions for deleting data and assigning AIP labels based on the policy results are valid only for files. Directories that match the search criteria can't be deleted automatically or assigned AIP labels.
Steps
  1. From the Data Investigation page, define your search by selecting all the filters you want to use. See Filtering data in the Data Investigation page for details.
  2. Once you have all the filter characteristics just the way you want them, click Create Policy from this search.
    A screenshot showing how to save a filtered query as a Policy.
  3. Name the Policy and select other actions that can be performed by the Policy:
    1. Enter a unique name and description.
    2. Optionally, check the box to automatically delete files that match the Policy parameters. Learn more about deleting source files using a policy.
    3. Optionally, check the box if you want notification emails sent to BlueXP users in your account, and choose the interval at which the email is sent. Learn more about sending email alerts based on policy results.
    4. Optionally, check the box if you want notification emails sent to other users, enter up to 20 email addresses, and choose the interval at which the email is sent.
    5. Optionally, check the box to automatically assign AIP labels to files that match the Policy parameters, and select the label. (Only if you have already integrated AIP labels. Learn more about AIP labels.)
    6. Click Create Policy.
      A screenshot that shows how to configure the Policy and save it.
Result
The new Policy appears in the Policies tab.
Send email alerts when non-compliant data is found
BlueXP classification can send email alerts to BlueXP users in your account when certain critical Policies return results so you can get notifications to protect your data. You can choose to send the email notifications on a daily, weekly, or monthly basis. You can also choose to send email alerts to any other email address - up to 20 email addresses - not in your BlueXP account.
You can configure this setting when creating the Policy or when editing any Policy.
Follow these steps to add email updates to an existing Policy.
Steps
  1. From the Policies List page, click Edit for the Policy where you want to add (or change) the email setting.
    A screenshot showing how to edit an existing Policy.
  2. In the Edit Policy page:
    1. Check the "Email all the users in this account" box if you want notification emails sent to users in your BlueXP account, and choose the interval at which the email is sent (for example, Every Day).
    2. Check the "Send Email" box if you want notification emails sent to additional users, choose the interval at which the email is sent, and enter up to 20 email addresses.
      A screenshot showing how to choose the email criterial to be sent for the Policy.
  3. Click Save Policy and the interval at which the email is sent appears in the Policy description.
Result
The first email is sent now if there are any results from the Policy - but only if any files meet the Policy criteria. No personal information is sent in the notification emails. The email indicates that there are files that match the Policy criteria, and it provides a link to the Policy results.
Delete source files automatically using Policies
You can create a custom Policy to delete files that match the policy. For example, you may want to delete files that contain sensitive information and were discovered by BlueXP classification in the past 30 days.
Only Account Admins can create a policy to automatically delete files.
Note All files that match the policy will be permanently deleted once a day.
Steps
    2. Check the box to "Automatically delete files that match this policy" and type permanently delete to confirm that you want files permanently deleted by this policy.
    3. Click Create Policy.
Result
The new Policy appears in the Policies tab. Files that match the policy are deleted once per day when the policy runs.
You can view the list of files that have been deleted in the Actions Status pane.
Assign AIP labels automatically with Policies
You can assign an AIP label to all the files that meet the criteria of the Policy. You can specify the AIP label when creating the Policy, or you can add the label when editing any Policy.
Labels are added or updated in files continuously as BlueXP classification scans your files.
Depending on whether a label is already applied to a file, and the classification level of the label, the following actions are taken when changing a label:
If the file…​ Then…​
Has no label
The label is added
Has an existing label of a lower level of classification
The higher level label is added
Has an existing label of a higher level of classification
The higher level label is retained
Is assigned a label both manually and by a Policy
Is assigned two different labels by two Policies
Follow these steps to add an AIP label to an existing Policy.
Steps
  1. From the Policies List page, click Edit for the Policy where you want to add (or change) the AIP label.
  2. In the Edit Policy page, check the box to enable automatic labels for files that match the Policy parameters, and select the label (for example, General).
    A screenshot showing how to select the label to be assigned to files that match the Policy.
  3. Click Save Policy and the label appears in the Policy description.
Note If a Policy was configured with a label, but the label has since been removed from AIP, the label name is turned to OFF and the label is not assigned anymore.
Edit Policies
You can modify any criteria for an existing policy that you previously created. This can be especially useful if you want to change the query (the items you defined using Filters) to add or remove certain parameters.
Note that for Predefined Policies that you can only modify whether email notifications are sent and whether AIP labels are added. No other values can be changed.
Steps
  1. From the Policies List page, click Edit for the Policy that you want to change.
    A screenshot showing how to initiate an edit to an existing Policy.
  2. If you just want to change the items on this page (the Name, Description, whether email notifications are sent, and whether AIP labels are added), make the change and click Save Policy.
    If you want to change the filters for the saved query, click Edit Query.
    A screenshot of selecting the Edit Query button on the Edit Policy page.
  3. In the Investigation page that defines that query, edit the query by adding, removing, or customizing the filters, and click Save Changes .
    A screenshot showing how to edit the query by changing filter settings.
Result
The policy is changed immediately. Any actions defined for that policy to send an email, add AIP labels, or delete files will occur at the next internal.
Delete Policies
You can delete any custom Policy that you created if you no longer need it. You can't delete any of the predefined Policies.
To delete a Policy, click the More button button for a specific Policy, click Delete Policy, and then click Delete Policy again in the confirmation dialog.
List of predefined Policies
BlueXP classification provides the following system-defined Policies:
Name Description Logic
S3 publicly - Exposed private data
S3 Objects containing personal or sensitive personal information, with open Public read access.
S3 Public AND contains personal OR sensitive personal info
PCI DSS - Stale data over 30 days
Files containing Credit Card information, last modified over 30 days ago.
Contains credit card AND last modified over 30 days
HIPAA - Stale data over 30 days
Files containing Health information, last modified over 30 days ago.
Contains health data (defined same way as in HIPAA report) AND last modified over 30 days
Private data - Stale over 7 years
Files containing personal or sensitive personal information, last modified over 7 years ago.
GDPR - European citizens
Files containing more than 5 identifiers of an EU country's citizens or DB Tables containing identifiers of an EU country's citizens.
Files containing over 5 identifiers of an (one) EU citizens or DB Tables containing rows with over 15% of columns with one country's EU identifiers. (any one of the national identifiers of the European countries. Does not include Brazil, California, USA SSN, Israel, South Africa)
CCPA - California residents
Files containing over 10 California Driver's License identifiers or DB Tables with this identifier.
Files containing over 10 California Driver's License identifiers OR DB Tables containing California Driver's license
Data Subject names - High risk
Files with over 50 Data Subject names.
Email Addresses - High risk
Files with over 50 Email Addresses, or DB Columns with over 50% of their rows containing Email Addresses
Personal data - High risk
Files with over 20 Personal data identifiers, or DB Columns with over 50% of their rows containing Personal data identifiers.
Files with over 20 personal, or DB Columns with over 50% of their rows containing personal
Sensitive Personal data - High risk
Files with over 20 Sensitive Personal data identifiers, or DB Columns with over 50% of their rows containing Sensitive Personal data.
Files with over 20 sensitive personal, or DB Columns with over 50% of their rows containing sensitive personal
