On-premises ONTAP clusters
Learn about on-premises ONTAP cluster management in BlueXP
Contributors netapp-bcammett
BlueXP can discover the ONTAP clusters running on AFF/FAS controllers and ONTAP Select. Adding on-premises ONTAP systems to BlueXP enables you to manage all of your storage and data assets from a single interface.
Features
  • Manage NFS and CIFS volumes
  • Perform advanced management using ONTAP System Manager
  • Get health and performance observability with BlueXP analysis and control
  • Use BlueXP services to replicate, back up, scan, classify, and tier data
  • View hardware and software contract status information in the BlueXP digital wallet
Cost
A cost might be associated, but it depends on the following:
  • Whether you deploy a Connector to discover and manage your clusters.
    You can install the Connector in the cloud or on your premises.
  • Whether you use BlueXP services such as backup and recovery, tiering, and classification.
