Discover workloads in NetApp Ransomware Resilience
Before you can use NetApp Ransomware Resilience, it first needs to discover workload data. During discovery, Ransomware Resilience analyzes all volumes and files in systems across all Console agents and projects within an organization.
In the Discovery dashboard, Ransomware Resilience displays supported and unsupported system configurations. Ransomware Resilience assesses Oracle applications, VMware datastores, file shares, and block storage.
Ransomware Resilience does not discover workloads with volumes using FlexGroup. |
Ransomware Resilience checks your current backup protection, snapshot copies, and NetApp Autonomous Ransomware Protection options. Ransomware Resilience also detects protection information from SnapCenter for VMware for VM datastores, SnapCenter for Oracle, and NetApp Backup and Recovery for file shares and VM file shares. It then recommends ways to improve your ransomware protection.
Required Console role
To perform this task, you need the Organization admin, Folder or project admin, or Ransomware Resilience admin role. Learn about Ransomware Resilience roles for NetApp Console.
Select workloads to discover and protect
Within each Console agent, select the systems where you want to discover workloads.
From the NetApp Console, select Protection > Ransomware protection.
If this is your first login, the landing page appears.
If you started the free trial, the Start 30-day free trial button label changes to Start by discovering workloads. -
From the initial landing page, select Start by discovering workloads.
Ransomware Resilience finds both supported and unsupported systems. This process might take a few minutes.
To discover workloads for a specific Console agent, select Select systems next to the Console agent where you want to discover workloads.
Select the systems where you want to discover workloads.
Select Discover.
Ransomware Resilience only discovers workload data when you select system. The discovery process can take several minutes.
To download the list of discovered workloads, select Download results.
To display the Ransomware Resilience dashboard, select Go to Dashboard.
The Dashboard shows data protection health. The number of at-risk or protected workloads updates as new workloads are discovered.
Discover newly created workloads for previously selected systems
If you've added workloads to a previously discovered system, you need to reinitiate discovery to protect the new workloads.
To identify the time of the last discovery, look at the date and time stamp next to Refresh icon at the top right of the Ransomware Resilience dashboard.
From the Dashboard, select the Refresh icon to find new workloads.
If you find there are volumes not displaying for the system you've discovered, the volumes might be unsupported. To find a list of unsupported volumes, go to the Settings menu then select the action menu in the Workload discovery card to download a JSON report of supported and unsupported volumes. |
Discover new systems
If you have already discovered systems, you can find new or previously unselected ones.
From the Ransomware Resilience menu, select the vertical
…option at the top right. From the drop-down menu, select Settings. -
In the Workload discovery card, select Discover workloads. Discovery can take a few minutes. A loading icon displays the progress.
Ransomware Resilience discovers both supported and unsupported systems. It does not support a system if its ONTAP version is below the required version. When you hover over an unsupported system, a tooltip displays the reason. Select the systems where you want to discover workloads.
Select Discover.
Exclude workloads
Ransomware Resilience allows your to exclude specific workloads in a system from ransomware protection and detection.
You can only exclude workloads that are supported and have been discovered successfully. You can modify the list of excluded workloads at any time. You aren't billed for workloads excluded from Ransomware Resilience.
In Ransomware Resilience, select Settings.
In the Settings dashboard, locate the Workload discovery dashboard. The card identifies the number of excluded workloads. To add workloads, next to the excluded workloads, select Manage.
In the Excluded workloads page, select Add.
Select the workloads you want to exclude then Add.
Review the excluded workloads in the Excluded workloads page. While the workload is being added, a progress indicator displays next to its name. If a workload was not excluded successfully, it doesn't display on the page.
In the Settings dashboard, locate the Workload discovery dashboard. The card identifies the number of excluded workloads. Next to the excluded workloads, select Manage.
To remove an individual workload, select the action menu for the workload you want to remove from the excluded list.
To remove multiple workloads, select the checkbox next to the workloads you want to remove then Remove from excluded.
In the dialog, select Remove to confirm that you want to remove the workloads from the exclude list.
If the workload is removed from the exluded workload list successfully, a success message appears on the Excluded workload page and the workload no longer appears in the list of excluded workloads. If the action fails, an error message appears; attempt the operation again.
