Finding the system ID for a Connector
To help you get started, your NetApp representative might ask you for the system ID for a Connector. The ID is typically used for licensing and troubleshooting purposes.
Steps
In the upper right of the Cloud Manager console, click the Help icon.
Click Support > Connector.
The system ID appears at the top.
Example
