Supported sync relationships
Cloud Sync enables you to sync data from a source to a target. This is called a sync relationship. You should understand the supported relationships before you get started.
Source location | Supported target locations |
Amazon EFS |
Amazon FSx for ONTAP |
Amazon S3 |
Azure Blob |
Azure NetApp Files |
Box 1 |
Cloud Volumes ONTAP |
Cloud Volumes Service |
Google Cloud Storage |
IBM Cloud Object Storage |
NFS server |
On-prem ONTAP cluster |
ONTAP S3 Storage |
SFTP 2 |
S3 |
SMB server |
StorageGRID |
Notes:
Box support is available as a preview.
Sync relationships with this source/target are supported by using the Cloud Sync API only.
You can choose a specific Azure Blob storage tier when a Blob container is the target:
Hot storage
Cool storage
You can choose a specific S3 storage class when Amazon S3 is the target:
Standard (this is the default class)
Intelligent-Tiering
Standard-Infrequent Access
One Zone-Infrequent Access
Glacier
Glacier Deep Archive
You can choose a specific storage class when a Google Cloud Storage bucket is the target:
Standard
Nearline
Coldline
Archive
