Cloud Volumes ONTAP
Supported configurations in AWS
Contributors netapp-asubhas netapp-revathid netapp-bcammett
Several Cloud Volumes ONTAP configurations are supported in AWS.
Supported number of nodes
Cloud Volumes ONTAP is available in AWS as a single node system and as a high-availability (HA) pair of nodes for fault tolerance and nondisruptive operations.
Upgrading a single node system to an HA pair is not supported. If you want to switch between a single node system and an HA pair, then you need to deploy a new system and replicate data from the existing system to the new system.
Supported storage
Cloud Volumes ONTAP supports several types of EBS disks, and S3 object storage for data tiering. The maximum storage capacity is determined by the license that you choose.
Storage support by license
Each license supports a different maximum system capacity. The maximum system capacity includes disk-based storage plus object storage used for data tiering. NetApp doesn’t support exceeding this limit.
Freemium Capacity-based license PAYGO Explore PAYGO Standard PAYGO Premium Node-based BYOL
Maximum system capacity
(disks + object storage) 1
500 GiB
2 PiB 2
2 TiB
10 TiB
368 TiB 2
368 TiB per license 2
Supported disk types
  • General Purpose SSD (gp3 and gp2) 3
  • Provisioned IOPS SSD (io1) 3
  • Throughput Optimized HDD (st1) 4
Cold data tiering to S3
Supported
Not supported
Supported
  1. For an HA pair, the capacity limit is for the entire HA pair. It's not per node. For example, if you use the Premium license, you can have up to 368 TiB of capacity between both nodes.
  2. For some configurations, disk limits prevent you from reaching the capacity limit by using disks alone. In those cases, you can reach the capacity limit by tiering inactive data to object storage. For information about disk limits, refer to storage limits.
  3. Enhanced write performance is enabled when using SSDs with all Cloud Volumes ONTAP configurations, except for PAYGO Explore.
  4. Tiering data to object storage is not recommended when using Throughput Optimized HDDs (st1).
Supported disk sizes
In AWS, an aggregate can contain up to 6 disks that are all the same size. But if you have a configuration that supports the Amazon EBS Elastic Volumes feature, then an aggregate can contain up to 8 disks. Learn more about support for Elastic Volumes
General Purpose SSDs (gp3 and gp2) Provisioned IOPS SSDs (io1) Throughput Optimized HDDs (st1)
  • 100 GiB
  • 500 GiB
  • 1 TiB
  • 2 TiB
  • 4 TiB
  • 6 TiB
  • 8 TiB
  • 16 TiB
  • 100 GiB
  • 500 GiB
  • 1 TiB
  • 2 TiB
  • 4 TiB
  • 6 TiB
  • 8 TiB
  • 16 TiB
  • 500 GiB
  • 1 TiB
  • 2 TiB
  • 4 TiB
  • 6 TiB
  • 8 TiB
  • 16 TiB
Supported EC2 compute
Each Cloud Volumes ONTAP license supports different EC2 instance types. For your convenience, the table below shows the vCPU, RAM, and bandwidth for each supported instance type. You should refer to AWS for the latest and complete details about EC2 instance types.
The bandwidths shown in the table below match the documented AWS limits for each instance type. These limits don't completely align with what Cloud Volumes ONTAP can provide. For the expected performance, refer to NetApp Technical Report 4383: Performance Characterization of Cloud Volumes ONTAP in Amazon Web Services with Application Workloads.
License Supported instance vCPU RAM Flash Cache 1 Network bandwidth (Gbps) EBS bandwidth (Mbps) High write speed 2
Explore or any other license
m5.xlarge
4
16
Not supported
Up to 10
Up to 4,750
Supported (single node only)
Standard or any other license
r5.xlarge
4
32
Not supported
Up to 10
Up to 4,750
m5a.2xlarge
8
32
Not supported
Up to 10
Up to 2,880
Supported
m5.2xlarge
8
32
Not supported
Up to 10
Up to 4,750
Supported
Premium or any other license
m5n.2xlarge
8
32
Not supported
Up to 25
Up to 4,750
Supported
r5.2xlarge
8
64
Not supported
Up to 10
Up to 4,750
Supported
r5d.2xlarge
8
64
Supported
Up to 10
Up to 4,750
Supported
c5d.4xlarge
16
32
Supported
Up to 10
4,570
Supported
m5.4xlarge
16
64
Not supported
Up to 10
4,750
Supported
m5dn.4xlarge
16
64
Supported
Up to 25
4,750
Supported
m5d.8xlarge
32
128
Supported
10
6,800
Supported
r5.8xlarge
32
256
Not supported
10
6,800
Supported
c5.9xlarge
36
72
Not supported
10
9,500
Supported
c5d.9xlarge
36
72
Supported
10
9,500
Supported
c5n.9xlarge
36
96
Not supported
50
9,500
Supported
c5a.12xlarge
48 4
96
Not supported
12
4,750
Supported
c5.18xlarge
48 4
144
Not supported
25
19,000
Supported
c5d.18xlarge
48 4
144
Supported
25
19,000
Supported
m5d.12xlarge
48
192
Supported
12
9,500
Supported
m5dn.12xlarge
48
192
Supported
50
9,500
Supported
c5n.18xlarge
48 4
192
Not supported
100
19,000
Supported
m5a.16xlarge
48 4
256
Not supported
12
9,500
Supported
m5.16xlarge
48 4
256
Not supported
20
13,600
Supported
r5.12xlarge 3
48
384
Not supported
10
9,500
Supported
m5dn.24xlarge
48 4
384
Supported
100
19,000
Supported
  1. Some instance types include local NVMe storage, which Cloud Volumes ONTAP uses as Flash Cache. Flash Cache speeds access to data through real-time intelligent caching of recently read user data and NetApp metadata. It's effective for random read-intensive workloads, including databases, email, and file services. Compression must be disabled on all volumes to take advantage of the Flash Cache performance improvements. Learn more about Flash Cache.
  2. Cloud Volumes ONTAP supports high write speed with most instance types when using an HA pair. High write speed is supported with all instance types when using a single node system. Learn more about choosing a write speed.
  3. The r5.12xlarge instance type has a known limitation with supportability. If a node unexpectedly reboots due to a panic, the system might not collect core files used to troubleshoot and root cause the problem. The customer accepts the risks and limited support terms and bears all support responsibility if this condition occurs. This limitation affects newly deployed HA pairs and HA pairs upgraded from 9.8. The limitation does not affect newly deployed single node systems.
  4. While these EC2 instance types support more than 48 vCPUs, Cloud Volumes ONTAP supports up to 48 vCPUs.
  5. When you choose an EC2 instance type, you can specify whether it is a shared instance or a dedicated instance.
  6. Cloud Volumes ONTAP can run on either a Reserved or On-demand EC2 instance. Solutions that use other instance types aren't supported.
Supported regions
For AWS region support, see Cloud Volumes Global Regions.
