Cloud Volumes ONTAP
Storage limits
Contributors netapp-bcammett
Cloud Volumes ONTAP has storage configuration limits to provide reliable operations. For best performance, do not configure your system at the maximum values.
Maximum system capacity by license
The maximum system capacity for a Cloud Volumes ONTAP system is determined by its license. The maximum system capacity includes disk-based storage plus object storage used for data tiering. NetApp doesn't support exceeding this limit.
In Azure, disk limits prevent you from reaching the 368 TiB capacity limit by using disks alone. In those cases, you can reach the 368 TiB capacity limit by tiering inactive data to object storage. Refer to capacity and disk limits by Azure VM size for more details.
License Maximum system capacity (disks + object storage)
Explore
2 TiB (data tiering is not supported with Explore)
Standard
10 TiB
Premium
368 TiB
BYOL
368 TiB per license
For HA, is the license capacity limit per node or for the entire HA pair?
The capacity limit is for the entire HA pair. It is not per node. For example, if you use the Premium license, you can have up to 368 TiB of capacity between both nodes.
For an HA system in AWS, does mirrored data count against the capacity limit?
No, it doesn't. Data in an AWS HA pair is synchronously mirrored between the nodes so that the data is available in the event of failure. For example, if you purchase an 8 TiB disk on node A, Cloud Manager also allocates an 8 TiB disk on node B that is used for mirrored data. While 16 TiB of capacity was provisioned, only 8 TiB counts against the license limit.
Aggregate and disk limits for Cloud Volumes ONTAP in AWS
In Cloud Volumes ONTAP 9.4, all EC2 instance types can reach the 368 TiB capacity limit using EBS storage alone, or by using EBS storage and tiering to S3 (both single node and HA).
Physical storage Parameter Limit
Aggregates and disks
Maximum number of aggregates
34 for single-node configurations
18 per node in an HA configuration 1
Maximum aggregate size
96 TiB of raw capacity 2
Disks per aggregate
1-6 3
Maximum disk size
16 TiB
Maximum number of data disks across all aggregates 4
31 per node in an HA configuration
RAID groups
Maximum per aggregate
1
Notes:
  1. It is not possible to create 18 aggregates on both nodes in an HA pair because doing so would exceed the data disk limit.
  2. The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
  3. All disks in an aggregate must be the same size.
  4. The data disk limit is specific to disks that contain user data. The boot disk and root disk for each node are not included in this limit.
Aggregate and disk limits for Cloud Volumes ONTAP in Azure
Same as the disk limit
200 TiB of raw capacity 1
Disks per aggregate
1-12 2
Maximum disk size
32 TiB
Maximum number of data disks across all aggregates 3
Depends on VM size. See below.
RAID groups
1
Notes:
  1. The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
  2. All disks in an aggregate must be the same size.
  3. The data disk limit is specific to disks that contain user data. The boot disk and root disk for each node are not included in this limit.
Capacity and disk limits by Azure VM size
In Azure, single node systems can use Standard HDD Managed Disks, Standard SSD Managed Disks, and Premium SSD Managed Disks, with up to 32 TiB per disk. The number of supported disks varies by VM size.
The tables below show the maximum system capacity by VM size with disks alone, and with disks and cold data tiering to object storage.
Disk limits are shown by VM size for Premium and BYOL licenses only because disk limits can’t be reached with Explore or Standard licenses due to system capacity limits.
Single node with a Premium license
VM size Max disks per node Max system capacity with disks alone Max system capacity with disks and data tiering
DS3_v2
15
368 TiB
Tiering not supported
DS4_v2
31
368 TiB
368 TiB
DS5_v2
63
368 TiB
368 TiB
DS13_v2
31
368 TiB
368 TiB
DS14_v2
63
368 TiB
368 TiB
Single node with one or more BYOL licenses
Note For some VM types, you'll need several BYOL licenses to reach the max system capacity listed below. For example, you'd need 6 BYOL licenses to reach 2 PiB with DS5_v2.
VM size Max disks per node Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks + data tiering
Disks alone
DS3_v2
15
368 TiB
480 TiB
DS4_v2
31
368 TiB
368 TiB
896 TiB
368 TiB x each license
DS5_v2
63
368 TiB
368 TiB
896 TiB
DS13_v2
31
368 TiB
368 TiB
896 TiB
DS14_v2
63
368 TiB
368 TiB
896 TiB
Logical storage limits
Logical storage Parameter Limit
Storage virtual machines (SVMs)
Maximum number for Cloud Volumes ONTAP
(HA pair or single node)
One data-serving SVM and one destination SVM used for disaster recovery. You can activate the destination SVM for data access if there’s an outage on the source SVM. 1
The one data-serving SVM spans the entire Cloud Volumes ONTAP system (HA pair or single node).
Files
Maximum size
16 TiB
Maximum per volume
Volume size dependent, up to 2 billion
FlexClone volumes
Hierarchical clone depth 2
499
FlexVol volumes
Maximum per node
500
Minimum size
20 MB
Maximum size
AWS: Dependent on the size of the aggregate 3
Azure: 100 TiB
Qtrees
Maximum per FlexVol volume
4,995
Snapshot copies
1,023
Notes:
  1. Cloud Manager does not provide any setup or orchestration support for SVM disaster recovery. It also does not support storage-related tasks on an additional SVM. You must use System Manager or the CLI for SVM disaster recovery.
  2. Hierarchical clone depth is the maximum depth of a nested hierarchy of FlexClone volumes that can be created from a single FlexVol volume.
  3. Less than 100 TiB is supported because aggregates for this configuration are limited to 96 TiB of raw capacity.
iSCSI storage limits
iSCSI storage Parameter Limit
LUNs
Maximum per node
1,024
Maximum number of LUN maps
1,024
Maximum size
16 TiB
Maximum per volume
512
igroups
Maximum per node
256
Initiators
Maximum per node
512
Maximum per igroup
128
iSCSI sessions
Maximum per node
1,024
LIFs
Maximum per port
32
Maximum per portset
32
Portsets
Maximum per node
256
