Supported configurations
Cloud Volumes ONTAP is available in AWS and Azure in two pricing options: pay-as-you-go and Bring Your Own License (BYOL). For pay-as-you-go, you can choose from three configurations: Explore, Standard, or Premium.
Cloud Volumes ONTAP for AWS
In AWS, you can deploy Cloud Volumes ONTAP as a single system or an HA pair.
| Explore | Standard | Premium | BYOL | |
EC2 instance types |
m4.xlarge |
Underlying storage |
General Purpose SSDs, Provisioned IOPS SSDs, Throughput Optimized HDDs, and Cold HDDs, up to 16 TiB per disk |
Maximum system capacity |
2 TiB |
10 TiB |
368 TiB |
368 TiB per license |
Notes:
If you enable data tiering, a system’s capacity limit stays the same. The capacity limit includes both disks and object storage.
Data tiering is supported with Cloud Volumes ONTAP Standard, Premium, and BYOL.
When you choose an EC2 instance type, you can specify whether it is a shared instance or a dedicated instance.
Enhanced write performance is supported when using EBS SSDs with Cloud Volumes ONTAP Standard, Premium, and BYOL.
For AWS region support, see Cloud Volumes Global Regions.
Cloud Volumes ONTAP for Azure
In Azure, you can deploy Cloud Volumes ONTAP as a single node system.
Virtual machine types |
DS3_v2 |
Standard HDD Managed Disks, Standard SSD Managed Disks, and Premium SSD Managed Disks, up to 32 TiB per disk |
2 TiB |
10 TiB |
368 TiB |
Notes:
Data tiering is not supported with the DS3_v2 virtual machine type.
Enhanced write performance is enabled when using Azure Premium Storage disks, but not when using the DS3_v2 virtual machine type.
For Azure region support, see Cloud Volumes Global Regions.
