Storage limits in AWS
Cloud Volumes ONTAP has storage configuration limits to provide reliable operations. For best performance, do not configure your system at the maximum values.
Maximum system capacity by license
The maximum system capacity for a Cloud Volumes ONTAP system is determined by its license. The maximum system capacity includes disk-based storage plus object storage used for data tiering. NetApp doesn't support exceeding this limit.
For some HA configurations, disk limits prevent you from reaching the capacity limit by using disks alone. In those cases, you can reach the capacity limit by tiering inactive data to object storage. Refer to capacity and disk limits below for more details.
| License | Maximum system capacity (disks + object storage) |
Freemium  |
500 GiB  |
PAYGO Explore  |
2 TiB (data tiering is not supported with Explore)  |
PAYGO Standard  |
10 TiB  |
PAYGO Premium  |
368 TiB  |
Node-based license  |
2 PiB (requires multiple licenses)  |
Capacity-based license  |
2 PiB  |
The capacity limit is for the entire HA pair. It is not per node. For example, if you use the Premium license, you can have up to 368 TiB of capacity between both nodes.
No, it doesn't. Data in an AWS HA pair is synchronously mirrored between the nodes so that the data is available in the event of failure. For example, if you purchase an 8 TiB disk on node A, Cloud Manager also allocates an 8 TiB disk on node B that is used for mirrored data. While 16 TiB of capacity was provisioned, only 8 TiB counts against the license limit.
Disk and tiering limits by EC2 instance
Cloud Volumes ONTAP uses EBS volumes as disks, with a maximum disk size of 16 TiB. The sections below show disk and tiering limits by EC2 instance type because many EC2 instance types have different disk limits. Disk limits are also different between single node systems and HA pairs.
The disk limits below are specific to disks that contain user data. The limits do not include the boot disk and root disk.
You can purchase multiple node-based licenses for a Cloud Volumes ONTAP BYOL single node or HA pair system to allocate more than 368 TiB of capacity, up to the maximum tested and supported system capacity limit of 2 PiB. Be aware that disk limits can prevent you from reaching the capacity limit by using disks alone. You can go beyond the disk limit by tiering inactive data to object storage. Learn how to add additional system licenses to Cloud Volumes ONTAP. Though Cloud Volumes ONTAP supports up to the maximum tested and supported system capacity of 2 PiB, crossing the 2 PiB limit results in an unsupported system configuration.
AWS Secret Cloud and Top Secret Cloud regions support purchases of multiple node-based licenses starting with Cloud Volumes ONTAP 9.12.1.
Single node with a Premium license
| Instance family | Max disks per node | Max system capacity with disks alone | Max system capacity with disks and data tiering |
c5, m5, and r5 instances  |
22  |
352 TiB  |
368 TiB  |
c4, m4, and r4 instances  |
34  |
368 TiB  |
368 TiB  |
Single node with node-based licensing
| Instance family | Max disks per node | Max system capacity with one license | Max system capacity with multiple licenses | ||
Disks alone  |
Disks + data tiering  |
Disks alone  |
22  |
352 TiB  |
368 TiB  |
352 TiB  |
2 PiB  |
34  |
368 TiB  |
368 TiB  |
544 TiB  |
368 TiB x each license  |
Single node with capacity-based licensing
22  |
352 TiB  |
2 PiB  |
34  |
544 TiB  |
2 PiB  |
HA pairs with a Premium license
19  |
304 TiB  |
368 TiB  |
31  |
368 TiB  |
368 TiB  |
HA pairs with node-based licensing
Disks alone  |
Disks alone  |
19  |
304 TiB  |
368 TiB  |
304 TiB  |
2 PiB  |
31  |
368 TiB  |
368 TiB  |
496 TiB  |
HA pairs with capacity-based licensing
19  |
304 TiB  |
2 PiB  |
31  |
496 TiB  |
2 PiB  |
Aggregate limits
Cloud Volumes ONTAP uses AWS volumes as disks and groups them into aggregates. Aggregates provide storage to volumes.
| Parameter | Limit |
Maximum number of aggregates  |
Single node: Same as the disk limit  |
Maximum aggregate size  |
96 TiB of raw capacity 2  |
Disks per aggregate  |
1-6 3  |
Maximum number of RAID groups per aggregate  |
1  |
Notes:
It is not possible to create 19 aggregates on both nodes in an HA pair because doing so would exceed the data disk limit.
The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
All disks in an aggregate must be the same size.
Logical storage limits
| Logical storage | Parameter | Limit | ||
Storage VMs (SVMs)  |
Maximum number for Cloud Volumes ONTAP  |
C5, M5, and R5 instances with BYOL
 An add-on license is required for each additional data-serving SVM beyond the first storage VM that comes with Cloud Volumes ONTAP by default. Contact your account team to obtain an SVM add-on license. Storage VMs that you configure for disaster recovery (DR) don't require an add-on license (they are free of charge), but they do count against the storage VM limit. 1,2 All other configurations A storage VM spans the entire Cloud Volumes ONTAP system (HA pair or single node).  |
Files  |
Maximum size  |
16 TiB  |
Maximum per volume  |
Volume size dependent, up to 2 billion  |
FlexClone volumes  |
Hierarchical clone depth 3  |
499  |
FlexVol volumes  |
Maximum per node  |
500  |
Minimum size  |
20 MB  |
Maximum size  |
100 TiB  |
Qtrees  |
Maximum per FlexVol volume  |
4,995  |
Snapshot copies  |
1,023  |
Notes:
For example, if you have 8 data-serving storage VMs on an HA pair, then you've reached the limit and can't create any additional storage VMs. The same is true for another HA pair that has 8 storage VMs configured for disaster recovery—you've reached the limit and can't create any additional storage VMs.
You can activate a destination storage VM for data access if there’s an outage on the source storage VM. Cloud Manager doesn't provide any setup or orchestration support for storage VM disaster recovery. You must use System Manager or the CLI.
Hierarchical clone depth is the maximum depth of a nested hierarchy of FlexClone volumes that can be created from a single FlexVol volume.
iSCSI storage limits
| iSCSI storage | Parameter | Limit |
LUNs  |
Maximum per node  |
1,024  |
Maximum number of LUN maps  |
1,024  |
Maximum size  |
16 TiB  |
512  |
igroups  |
Maximum per node  |
256  |
Initiators  |
Maximum per node  |
512  |
Maximum per igroup  |
128  |
iSCSI sessions  |
Maximum per node  |
1,024  |
LIFs  |
Maximum per port  |
32  |
Maximum per portset  |
32  |
Portsets  |
Maximum per node  |
256  |
