Licensing for Cloud Volumes ONTAP 9.8
Contributors netapp-bcammett
Several licensing options are available for Cloud Volumes ONTAP. Each option enables you to choose a configuration that meets your needs.
Licensing overview
The following table provides an overview of the licensing options for Cloud Volumes ONTAP.
Beyond these licensing options, you can also choose the Freemium offering to get started with Cloud Volumes ONTAP without purchasing a license or contract.
Charging method Highlights Support Max system capacity
Capacity-based license:
Essentials package
  • Pay per TiB of capacity for one or more Cloud Volumes ONTAP systems
  • Provides a la carte licensing for Cloud Volumes ONTAP
  • Available by bringing your own license (BYOL) purchased from NetApp
Included
2 PiB
Professional package
  • Provides licensing for any Cloud Volumes ONTAP configuration
  • Includes volume backups using Cloud Backup (for volumes charged against this license)
  • Available through an AWS Marketplace annual contract or by purchasing a license from NetApp (BYOL)
Included
2 PiB
Keystone Flex Subscription
  • Pay-as-you-grow by TiB through a NetApp subscription
  • Charging is based on the size of committed capacity
  • The committed capacity is shared between the Cloud Volumes ONTAP systems deployed with the subscription
  • Available for HA pairs only
Included
2 PiB
PAYGO by node
  • Pay-as-you-go by the hour through a marketplace subscription from your cloud provider
  • Charging is per Cloud Volumes ONTAP node
  • Available in three licensing options: Explore, Standard, and Premium
Included, but you must activate support
  • Explore: 2 TiB
  • Standard: 10 TiB
  • Premium: 368 TiB
Node-based license
  • The previous generation BYOL for Cloud Volumes ONTAP
  • A node-based license is available for license renewals only
Included
368 TiB per license
The following sections provide more details about each of these options.
Freemium offering
  • A new offering that provides all Cloud Volumes ONTAP features free of charge from NetApp (cloud provider charges still apply).
  • No license or contract is needed.
  • Support is not included.
  • You’re limited to 500 GiB of provisioned capacity per Cloud Volumes ONTAP system.
  • You can use up to 10 Cloud Volumes ONTAP systems with the Freemium offering per NetApp account.
  • If the provisioned capacity for a Cloud Volumes ONTAP system exceeds 500 GiB, Cloud Manager converts the system to the Essentials package (which is a capacity-based license) and charging starts.
    Any other systems that have less than 500 GiB of provisioned capacity stay on the Freemium offering (as long as they were deployed using the Freemium offering).
How to get started
Create a new Cloud Volumes ONTAP working environment and select Freemium when prompted to choose a charging method.
Capacity-based licenses
Capacity-based licensing enables you to pay for Cloud Volumes ONTAP per TiB of capacity. The license is associated with your NetApp account and enables you to charge multiple systems against the license, as long as enough capacity is available through the license.
For example, you could purchase a single 20 TiB license, deploy four Cloud Volumes ONTAP systems, and then allocate a 5 TiB volume to each system, for a total of 20 TiB.
Unlike the by-node charging method where a license is purchased per Cloud Volumes ONTAP system, a capacity-based license is issued to a NetApp account. The capacity is then available to the volumes on each Cloud Volumes ONTAP system deployed in that account.
Capacity-based licensing is available in the form of a package. When you deploy a Cloud Volumes ONTAP system, you can choose from the following packages: Essentials or Professional.
This licensing method is available for Cloud Volumes ONTAP 9.7 and later.
Note For each package, there is a minimum 4 TiB capacity charge. Any Cloud Volumes ONTAP instance that has less than 4 TiB of capacity will be charged at a rate of 4 TiB.
Essentials package
  • Provides a la carte licensing for Cloud Volumes ONTAP:
    • A single node or HA system
    • File and block storage or secondary data for disaster recovery (DR)
  • This package is available as a license (BYOL) purchased from NetApp.
  • Support is included for the length of the subscription term.
  • Conversions to another licensing option isn’t supported.
  • Each individual Cloud Volumes ONTAP system supports up to 2 PiB of capacity through disks and tiering to object storage.
  • Provides licensing for any Cloud Volumes ONTAP configuration (single node or HA with any storage type).
  • Includes volume backups using the Cloud Backup Service (only for volumes charged against this license).
  • This package is available as an annual contract from the AWS Marketplace or as a license (BYOL) purchased from NetApp.
    If you have an AWS Marketplace contract, all Cloud Volumes ONTAP systems that you deploy are charged against that contract. You can’t mix and match a Marketplace contract with BYOL.
A pay-as-you-grow subscription-based service that delivers a seamless hybrid cloud experience for those preferring OpEx consumption models to upfront CapEx or leasing.
Charging is based on the size of your committed capacity for one or more Cloud Volumes ONTAP HA pairs in your Keystone Flex Subscription.
The provisioned capacity for each volume is aggregated and compared to the committed capacity on your Keystone Flex Subscription periodically, and any overages are charged as burst on your Keystone Flex Subscription.
Note Keystone Flex Subscriptions aren’t supported with single node systems at this time.
How to get started
  1. If you don’t have a subscription yet, contact NetApp.
  2. Contact NetApp to authorize your Cloud Manager user account with one or more Keystone Flex Subscriptions.
  3. After NetApp authorizes your account, link your subscriptions for use with Cloud Volumes ONTAP.
  4. Select the Keystone Flex Subscription charging method when you create a Cloud Volumes ONTAP system.
PAYGO by node
  • Requires a subscription from a cloud provider’s marketplace for pay-as-you-go pricing at an hourly rate.
  • Charging is per Cloud Volumes ONTAP node.
  • Offers Cloud Volumes ONTAP in three different licensing options: Explore, Standard, and Premium. Each license provides support for different amounts of storage and compute.
  • A 30-day free trial is available for the first Cloud Volumes ONTAP system that you deploy in a cloud provider. Learn more about 30-day free trials.
    • There are no hourly software charges, but cloud provider infrastructure charges still apply (compute, storage, and networking).
    • When the free trial ends, you’ll be charged hourly according to the selected license, as long as you subscribed. If you haven’t subscribed, the system shuts down.
      Cloud Manager prompts you to subscribe to your cloud provider’s marketplace when you create a Cloud Volumes ONTAP system.
  • Basic technical support is offered, but you must register and activate the NetApp serial number associated with your system.
You can view pricing details from your cloud provider’s marketplace:
How to get started
Create a Cloud Volumes ONTAP working environment and subscribe to your cloud provider’s marketplace when prompted.
Node-based licenses
  • The previous generation BYOL for Cloud Volumes ONTAP.
  • A node-based license is available for license renewals only.
  • Each Cloud Volumes ONTAP system supports up to 368 TiB of capacity per license.
If you want to transition to capacity-based licensing, you can purchase a license, deploy a new Cloud Volumes ONTAP system, and then replicate the data to that new system.
