Data Infrastructure Insights Data Collector Support Matrix
The Data Collector Support Matrix provides reference for Data Collectors supported by Data Infrastructure Insights , including vendor and model information.
HP Enterprise 3PAR / Alletra 9000 / Primera StoreServ Storage
Models and versions supported by this data collector:
Models | Firmware versions |
HPE Alletra 9080 |
3.1.1 (MU1) |
Products supported by this data collector:
Product | Category | Feature/Attribute | Status | Protocol Used | Additional Information |
foundation |
Device Group |
Name |
Implemented |
SSH |
Storage Management Id |
Implemented |
SSH |
Type |
Gap |
SSH |
Disk |
Capacity (GB) |
Implemented |
SSH |
Used capacity |
Disk Id |
Implemented |
SSH |
Uniquely identifies this disk in the array |
Location |
Gap |
SSH |
Where this disk is physically located in the array |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Role |
Implemented |
SSH |
Role Enum |
Implemented |
SSH |
enum for disk role |
Serial Number |
Implemented |
SSH |
Status |
Implemented |
SSH |
Status Enum |
Implemented |
SSH |
enum for disk status |
Type |
Gap |
SSH |
Type Enum |
Implemented |
SSH |
enum for disk type |
Vendor |
Implemented |
SSH |
Vendor Id |
Implemented |
SSH |
ISCSI Network Portal |
IP |
Implemented |
SSH |
Listening Port |
Implemented |
SSH |
Nic |
Implemented |
SSH |
OID |
Implemented |
SSH |
ISCSI Network Portal Group |
OID |
Implemented |
SSH |
Portal Group Name |
Implemented |
SSH |
Portal Group Tag |
Implemented |
SSH |
ISCSI Node |
Node Name |
Implemented |
SSH |
OID |
Implemented |
SSH |
Type |
Gap |
SSH |
ISCSI Session |
OID |
Implemented |
SSH |
Initiator OID |
Implemented |
SSH |
Portal Group OID |
Implemented |
SSH |
Target Session Id |
Implemented |
SSH |
Number Of Connections |
Implemented |
SSH |
Max Connections |
Implemented |
SSH |
Initiator Ips |
Implemented |
SSH |
Security |
Implemented |
SSH |
Info |
Api Name |
Implemented |
SSH |
Api Version |
Implemented |
SSH |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
Storage |
Display IP |
Implemented |
SSH |
Failed Raw Capacity |
Implemented |
SSH |
Raw capacity of failed disks (sum of all disks that are failed) |
Family |
Implemented |
SSH |
The storage Family could be Clariion, Symmetrix, et al |
IP |
Implemented |
SSH |
Manage URL |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Microcode Version |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Total Raw Capacity |
Implemented |
SSH |
Total raw capacity (sum of all disks on the array) |
Serial Number |
Implemented |
SSH |
Spare Raw Capacity |
Implemented |
SSH |
Raw capacity of spare disks (sum of all disks that are spare) |
Virtual |
Implemented |
SSH |
Is this a storage virtualization device? |
Storage Node |
Memory Size |
Gap |
SSH |
device memory in MB |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Processors Count |
Implemented |
SSH |
device CPU |
State |
Implemented |
SSH |
free text describing the device state |
UUID |
Implemented |
SSH |
Up Time |
Implemented |
SSH |
time in milliseconds |
Version |
Implemented |
SSH |
software version |
Storage Pool |
Auto Tiering |
Implemented |
SSH |
indicates if this storagepool is participating in auto tiering with other pools |
Compression Enabled |
Implemented |
SSH |
Is compression enabled on the storage pool |
Compression Savings |
Implemented |
SSH |
ratio of compression savings in percentage |
Data Allocated Capacity |
Gap |
SSH |
capacity allocated for data |
Data Used Capacity |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Is dedupe enabled on the storage pool |
Dedupe Savings |
Implemented |
SSH |
ratio of dedupe savings in percentage |
Include In Dwh Capacity |
Implemented |
SSH |
A way from ACQ to control which storage pools are interesting in DWH Capacity |
Name |
Implemented |
SSH |
Other Allocated Capacity |
Gap |
SSH |
Capacity allocated for other (not data and not snapshot) |
Other UsedCapacity (MB) |
Implemented |
SSH |
Any capacity other than data and snapshot |
Physical Disk Capacity (MB) |
Implemented |
SSH |
used as raw capacity for storage pool |
Raid Group |
Implemented |
SSH |
indicates whether this storagePool is a raid group |
Raw to Usable Ratio |
Implemented |
SSH |
ratio to convert from usable capacity to raw capacity |
Redundancy |
Implemented |
SSH |
Redundancy level |
Snapshot Allocated Capacity |
Gap |
SSH |
Allocated capacity of snapshots in MB |
Snapshot Used Capacity |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioning Supported |
Implemented |
SSH |
Whether this internal volume supports thin provisioning for the volume layer on top of it |
Total Allocated Capacity |
Implemented |
SSH |
Total Used Capacity |
Implemented |
SSH |
Total capacity in MB |
Type |
Gap |
SSH |
Vendor Tier |
Implemented |
SSH |
Vendor Specific Tier Name |
Virtual |
Implemented |
SSH |
Storage Synchronization |
Mode |
Implemented |
SSH |
Mode Enum |
Implemented |
SSH |
Source Volume |
Implemented |
SSH |
State |
Implemented |
SSH |
State Enum |
Implemented |
SSH |
Target Volume |
Implemented |
SSH |
Technology |
Implemented |
SSH |
technology which causes storage efficiency changed |
Volume |
AutoTier Policy Identifier |
Implemented |
SSH |
Dynamic Tier Policy identifier |
Auto Tiering |
Implemented |
SSH |
Capacity |
Implemented |
SSH |
Snapshot Used capacity in MB |
Name |
Implemented |
SSH |
Implemented |
SSH |
Redundancy |
Implemented |
SSH |
Redundancy level |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioned |
Implemented |
SSH |
Type |
Gap |
SSH |
UUID |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Written Capacity |
Implemented |
SSH |
Total capacity written to this volume by a Host in MB |
Volume Map |
LUN |
Implemented |
SSH |
Name of the backend lun |
Protocol Controller |
Implemented |
SSH |
Storage Port |
Implemented |
SSH |
Type |
Gap |
SSH |
Volume Mask |
Initiator |
Implemented |
SSH |
Implemented |
SSH |
Storage Port |
Implemented |
SSH |
Type |
Gap |
SSH |
Volume Ref |
Name |
Implemented |
SSH |
Storage Ip |
Implemented |
SSH |
WWN Alias |
Host Aliases |
Implemented |
SSH |
Object Type |
Implemented |
SSH |
Source |
Implemented |
SSH |
WWN |
Implemented |
SSH |
performance |
Disk |
IOPs Read |
Implemented |
SMI-S |
Number of read IOPs on the disk |
IOPs Total |
Implemented |
SMI-S |
IOPs Write |
Implemented |
SMI-S |
Throughput Read |
Implemented |
SMI-S |
Throughput Total |
Implemented |
SMI-S |
Average disk total rate (read and write across all disks) in MB/s |
Throughput Write |
Implemented |
SMI-S |
Disk |
IOPs Read |
Implemented |
SMI-S |
IOPs Total |
Implemented |
SMI-S |
IOPs Write |
Implemented |
SMI-S |
Key |
Implemented |
SMI-S |
Server ID |
Implemented |
SMI-S |
Throughput Read |
Implemented |
SMI-S |
Throughput Total |
Implemented |
SMI-S |
Throughput Write |
Implemented |
SMI-S |
Storage |
Cache Hit Ratio Read |
Implemented |
SMI-S |
Cache Hit Ratio Total |
Implemented |
SMI-S |
Cache Hit Ratio Write |
Implemented |
SMI-S |
Implemented |
SMI-S |
Raw Capacity |
Implemented |
SMI-S |
Implemented |
SMI-S |
StoragePools Capacity |
Implemented |
SMI-S |
IOPs other |
Implemented |
SMI-S |
IOPs Read |
Implemented |
SMI-S |
IOPs Total |
Implemented |
SMI-S |
IOPs Write |
Implemented |
SMI-S |
Latency Read |
Implemented |
SMI-S |
Latency Total |
Implemented |
SMI-S |
Latency Write |
Implemented |
SMI-S |
Partial Blocked Ratio |
Implemented |
SMI-S |
Throughput Read |
Implemented |
SMI-S |
Throughput Total |
Implemented |
SMI-S |
Throughput Write |
Implemented |
SMI-S |
Write Pending |
Implemented |
SMI-S |
total write pending |
Storage Node |
Implemented |
SMI-S |
IOPs Read |
Implemented |
SMI-S |
IOPs Total |
Implemented |
SMI-S |
IOPs Write |
Implemented |
SMI-S |
Latency Read |
Implemented |
SMI-S |
Latency Total |
Implemented |
SMI-S |
Latency Write |
Implemented |
SMI-S |
Throughput Read |
Implemented |
SMI-S |
Throughput Total |
Implemented |
SMI-S |
Throughput Write |
Implemented |
SMI-S |
Utilization Total |
Implemented |
SMI-S |
Storage Pool |
Capacity Provisioned |
Implemented |
SMI-S |
Raw Capacity |
Implemented |
SMI-S |
Total Capacity |
Implemented |
SMI-S |
Used Capacity |
Implemented |
SMI-S |
Over Commit Capacity Ratio |
Implemented |
SMI-S |
Reported as a time series |
Capacity Used Ratio |
Implemented |
SMI-S |
Total Data Capacity |
Implemented |
SMI-S |
Implemented |
SMI-S |
Key |
Implemented |
SMI-S |
Other Total Capacity |
Implemented |
SMI-S |
Other Used Capacity |
Implemented |
SMI-S |
Server ID |
Implemented |
SMI-S |
Snapshot Reserved Capacity |
Implemented |
SMI-S |
Implemented |
SMI-S |
Snapshot Used Capacity Ratio |
Implemented |
SMI-S |
StoragePool Disk |
Implemented |
SMI-S |
Raw Capacity |
Implemented |
SMI-S |
Total Capacity |
Implemented |
SMI-S |
Used Capacity |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
IOPs Read |
Implemented |
SMI-S |
IOPs Total |
Implemented |
SMI-S |
IOPs Write |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Throughput Read |
Implemented |
SMI-S |
Throughput Total |
Implemented |
SMI-S |
Throughput Write |
Implemented |
SMI-S |
Volume |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Raw Capacity |
Implemented |
SMI-S |
Total Capacity |
Implemented |
SMI-S |
Used Capacity |
Implemented |
SMI-S |
Implemented |
SMI-S |
CapacityRatio Written |
Implemented |
SMI-S |
IOPs Read |
Implemented |
SMI-S |
IOPs Total |
Implemented |
SMI-S |
IOPs Write |
Implemented |
SMI-S |
Latency Read |
Implemented |
SMI-S |
Latency Total |
Implemented |
SMI-S |
Latency Write |
Implemented |
SMI-S |
Implemented |
SMI-S |
Throughput Read |
Implemented |
SMI-S |
Throughput Total |
Implemented |
SMI-S |
Throughput Write |
Implemented |
SMI-S |
Write Pending |
Implemented |
SMI-S |
Volume |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Raw Capacity |
Implemented |
SMI-S |
Total Capacity |
Implemented |
SMI-S |
Used Capacity |
Implemented |
SMI-S |
Written Capacity |
Implemented |
SMI-S |
Implemented |
SMI-S |
Implemented |
SMI-S |
Total Compression Savings |
Implemented |
SMI-S |
IOPs Read |
Implemented |
SMI-S |
IOPs Total |
Implemented |
SMI-S |
IOPs Write |
Implemented |
SMI-S |
Key |
Implemented |
SMI-S |
Latency Read |
Implemented |
SMI-S |
Latency Total |
Implemented |
SMI-S |
Latency Write |
Implemented |
SMI-S |
Implemented |
SMI-S |
Server ID |
Implemented |
SMI-S |
Throughput Read |
Implemented |
SMI-S |
Throughput Total |
Implemented |
SMI-S |
Throughput Write |
Implemented |
SMI-S |
Write Pending |
Implemented |
SMI-S |
Management APIs used by this data collector:
API | Protocol Used | Transport layer protocol used | Incoming ports used | Outgoing ports used | Supports authentication | Requires only 'Read-only' credentials | Supports Encryption | Firewall friendly (static ports) |
3Par SMI-S |
SMI-S |
HTTP/HTTPS |
5988/5989 |
true |
true |
true |
true |
3Par CLI |
SSH |
SSH |
22 |
true |
false |
true |
true |
Amazon AWS EC2
API versions:
2014-10-01
foundation |
Data Store |
Capacity |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Provisioned Capacity |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
subscription Id |
Implemented |
HTTPS |
Server |
Cluster |
Implemented |
HTTPS |
Cluster name |
DataCenter Name |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
Virtual Disk |
Capacity |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Is Chargeable |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Is Snapshot |
Implemented |
HTTPS |
subscription Id |
Implemented |
HTTPS |
VirtualMachine |
Dns Name |
Implemented |
HTTPS |
Guest State |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OS |
Implemented |
HTTPS |
Power State |
Implemented |
HTTPS |
State Change Time |
Implemented |
HTTPS |
Processors |
Implemented |
HTTPS |
Implemented |
HTTPS |
Instance Type |
Implemented |
HTTPS |
Launch Time |
Implemented |
HTTPS |
LifeCycle |
Implemented |
HTTPS |
public Ips |
Implemented |
HTTPS |
Security Groups |
Implemented |
HTTPS |
subscription Id |
Implemented |
HTTPS |
VirtualMachine Disk |
OID |
Implemented |
HTTPS |
VirtualDisk OID |
Implemented |
HTTPS |
VirtualMachine OID |
Implemented |
HTTPS |
Host |
Host OS |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Info |
Api Description |
Implemented |
HTTPS |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
performance |
Data Store |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
vm |
Total CPU Utilization |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
diskIops.total |
Implemented |
HTTPS |
Disk IOPs write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Disk Throughput Read |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
total disk throughput read |
Disk Throughput Write |
Implemented |
HTTPS |
IP Throughput Read |
Implemented |
HTTPS |
Throughput total |
Implemented |
HTTPS |
IP throughput total |
ipThroughput.write |
Implemented |
HTTPS |
VM |
Total Capacity |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
EC2 API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Amazon AWS S3
S3 |
2010-08-01 |
foundation |
Info |
Api Description |
Implemented |
HTTPS |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Dedupe Enabled |
Implemented |
HTTPS |
Internal Volume Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
unique id of the qtree |
Type |
Gap |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
performance |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Total Objects |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
S3 API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Microsoft Azure NetApp Files
API versions | Models |
2019-06-01 |
Azure NetApp Files |
foundation |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume |
Is Shared |
Implemented |
HTTPS |
whether this fileShare has any shares associated with it |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Path of the fileShare |
Qtree Id |
Implemented |
HTTPS |
Info |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Last Snapshot Time |
Implemented |
HTTPS |
time of last snapshot |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Snapshot Count |
Implemented |
HTTPS |
Number of snapshots on the internal volumes |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Used Capacity (MB) |
Implemented |
HTTPS |
place holder for the used capacity as read from the device |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Comment |
Gap |
HTTPS |
state: free text comment describing the svm |
Implemented |
HTTPS |
QoS - Policy |
Implemented |
HTTPS |
Source Internal Volume |
Implemented |
HTTPS |
Target Internal Volume |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Quota HardCapacity Limit (MB) |
Implemented |
HTTPS |
Maximum amount of disk space, allowed for the quota target |
Security Style |
Implemented |
HTTPS |
Security style of the directory: unix, ntfs, or mixed |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Quota |
Hard Capacity Limit (MB) |
Implemented |
HTTPS |
max amount of disk space, allowed for the quota target (Hard limit) |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Quota Id |
Implemented |
HTTPS |
unique id of the quota |
Type |
Gap |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Share |
IP Interfaces |
Implemented |
HTTPS |
comma separated list of IP addresses on which this share is exposed |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
enum for share protocol |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Permissions for this particular share |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Pool |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Comment |
Gap |
HTTPS |
performance |
Internal Volume |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Implemented |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
StoragePool Disk |
IOPs Read |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Write |
Implemented |
Throughput Total |
Implemented |
IOPs Total |
Implemented |
Azure Netapp Files REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Brocade Fibre Channel Switches
176.51 |
v6.2.2b |
foundation |
FC Name Server Entry |
FC ID |
Implemented |
SSH |
Nx Port WWN |
Implemented |
SSH |
Physical Port WWN |
Implemented |
SSH |
Switch Port WWN |
Implemented |
SSH |
Fabric |
Name |
Implemented |
Manual Entry |
VSAN Enabled |
Implemented |
SSH |
VSANId |
Implemented |
SSH |
WWN |
Implemented |
SSH |
IVR Physical Fabric |
IVR Chassis WWNs |
Implemented |
SSH |
Comma seperated list of IVR enabled chassis WWNs |
Lowest IVR Chassis WWN |
Implemented |
SSH |
identifier of the IVR fabric |
Info |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
Originator Key |
Implemented |
SSH |
Logical Switch |
Chassis WWN |
Implemented |
SSH |
Domain Id |
Implemented |
SSH |
Firmware Version |
Implemented |
SSH |
IP |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
Manual Entry |
Serial Number |
Implemented |
SSH |
Switch Role |
Implemented |
SSH |
Switch State |
Implemented |
SSH |
Switch Status |
Implemented |
SSH |
Type |
Gap |
SSH |
WWN |
Implemented |
SSH |
Port |
Blade |
Implemented |
SSH |
FC4 Protocol |
Implemented |
SSH |
GBIC Type |
Implemented |
SSH |
Generated |
Implemented |
SSH |
Name |
Implemented |
Manual Entry |
Node WWN |
Implemented |
SSH |
Mandatory to report with PortId if WWN is not present |
Port ID |
Implemented |
SSH |
Port Number |
Implemented |
SSH |
Port Speed |
Implemented |
SSH |
Port State |
Implemented |
SSH |
Port Status |
Implemented |
SSH |
Port Type |
Implemented |
SSH |
Raw Port Status |
Implemented |
SSH |
Raw Speed GigaBits |
Implemented |
SSH |
Unknown Connectivity |
Implemented |
SSH |
WWN |
Implemented |
SSH |
Switch |
Domain Id |
Implemented |
SSH |
Firmware Version |
Implemented |
SSH |
IP |
Implemented |
SSH |
Manage URL |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
Manual Entry |
Serial Number |
Implemented |
SSH |
Switch Role |
Implemented |
SSH |
Switch State |
Implemented |
SSH |
Switch Status |
Implemented |
SSH |
Type |
Gap |
SSH |
VSAN Enabled |
Implemented |
SSH |
WWN |
Implemented |
SSH |
Unknown |
Driver |
Implemented |
SSH |
Firmware |
Implemented |
SSH |
Generated |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
Manual Entry |
WWN |
Implemented |
SSH |
WWN Alias |
Host Aliases |
Implemented |
SSH |
Object Type |
Implemented |
SSH |
Source |
Implemented |
SSH |
WWN |
Implemented |
SSH |
Zone |
Zone Name |
Implemented |
SSH |
Zone Member |
Type |
Gap |
SSH |
WWN |
Implemented |
SSH |
Zoning Capabilities |
Active Configuration |
Implemented |
SSH |
Configuration Name |
Implemented |
SSH |
Default Zoning Behavior |
Implemented |
SSH |
WWN |
Implemented |
SSH |
performance |
port |
BB Credit Zero Received |
Implemented |
SNMP |
BB Credit Zero Total |
Implemented |
SNMP |
BB Credit Zero Transmitted |
Implemented |
SNMP |
BB Credit Zero Ms Transmitted |
Implemented |
SNMP |
Port Errors Class3 Discard |
Implemented |
SNMP |
Port Errors Crc |
Implemented |
SNMP |
Port Errors Crc |
Port Errors Enc In |
Implemented |
SNMP |
portErrors.encOut |
Implemented |
SNMP |
Port Error Long Frame |
Implemented |
SNMP |
Port errors due to long frame |
Port Error Short Frame |
Implemented |
SNMP |
Port errors due to short frame |
Port Errors Link Failure |
Implemented |
SNMP |
Port Errors link failure |
Port Errors Link Reset Rx |
Implemented |
SNMP |
Port Error Transmit Link Reset |
Implemented |
SNMP |
Port Error due to link reset |
Port Error Signal Loss |
Implemented |
SNMP |
Port errors signal loss |
Port Error Sync Loss |
Implemented |
SNMP |
Port error sync loss |
Port Error Transmit Discard Timeout |
Implemented |
SNMP |
Port errors timeout discard |
Total Port Errors |
Implemented |
SNMP |
Total port errors |
Traffic Frame Rate |
Implemented |
SNMP |
Total Traffic Frame Rate |
Implemented |
SNMP |
Implemented |
SNMP |
Average Frame Size |
Implemented |
SNMP |
Average Frame size of traffic |
TX Frames |
Implemented |
SNMP |
traffic average frame size |
Traffic Recieved Rate |
Implemented |
SNMP |
Total Traffic Rate |
Implemented |
SNMP |
Traffic Transmit Rate |
Implemented |
SNMP |
Traffic Recieved Utilization |
Implemented |
SNMP |
Total Traffic Utilization |
Implemented |
SNMP |
Total traffic utilization |
Traffic Transmit Utilization |
Implemented |
SNMP |
Port Data |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Key |
Implemented |
SNMP |
Implemented |
SNMP |
Port Errors Crc |
Implemented |
SNMP |
Port Errors Crc |
Implemented |
SNMP |
portErrors.encOut |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Total Port Errors |
Implemented |
SNMP |
Total port errors |
Server ID |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
TX Frames |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Brocade SNMP |
SNMP |
SNMPv1, SNMPv2, SNMPv3 |
161 |
true |
true |
true |
true |
Brocade SSH |
SSH |
SSH |
22 |
false |
false |
true |
true |
Data source wizard configuration |
Manual Entry |
true |
true |
true |
true |
Brocade Network Advisor HTTP
API versions | Models | Firmware versions |
14.4.3 |
Brocade 6520 |
v7.3.0b |
foundation |
Nx Port WWN |
Implemented |
HTTP/S |
Switch Port WWN |
Implemented |
HTTP/S |
FC ID |
Implemented |
HTTP/S |
Physical Port WWN |
Implemented |
HTTP/S |
Fabric |
Name |
Implemented |
HTTP/S |
VSAN Enabled |
Implemented |
HTTP/S |
VSANId |
Implemented |
HTTP/S |
WWN |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
IVR Chassis WWNs |
Implemented |
HTTP/S |
Info |
Api Description |
Implemented |
HTTP/S |
Api Name |
Implemented |
HTTP/S |
Api Version |
Implemented |
HTTP/S |
DataSource Name |
Implemented |
HTTP/S |
Info |
Date |
Implemented |
HTTP/S |
Originator ID |
Implemented |
HTTP/S |
Originator Key |
Implemented |
HTTP/S |
Logical Switch |
WWN |
Implemented |
HTTP/S |
IP |
Implemented |
HTTP/S |
Firmware Version |
Implemented |
HTTP/S |
Manufacturer |
Implemented |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Switch Role |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
Switch State |
Implemented |
HTTP/S |
Switch Status |
Implemented |
HTTP/S |
Domain Id |
Implemented |
HTTP/S |
Chassis WWN |
Implemented |
HTTP/S |
Port |
WWN |
Implemented |
HTTP/S |
Port State |
Implemented |
HTTP/S |
Port Number |
Implemented |
HTTP/S |
Port ID |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Port Speed |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Port Type |
Implemented |
HTTP/S |
Raw Port Status |
Implemented |
HTTP/S |
Port Status |
Implemented |
HTTP/S |
FC4 Protocol |
Implemented |
HTTP/S |
Generated |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Blade |
Implemented |
HTTP/S |
GBIC Type |
Implemented |
HTTP/S |
Switch |
WWN |
Implemented |
HTTP/S |
IP |
Implemented |
HTTP/S |
Firmware Version |
Implemented |
HTTP/S |
Manufacturer |
Implemented |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Switch Role |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
Manage URL |
Implemented |
HTTP/S |
Switch State |
Implemented |
HTTP/S |
Switch Status |
Implemented |
HTTP/S |
Domain Id |
Implemented |
HTTP/S |
VSAN Enabled |
Implemented |
HTTP/S |
Unknown |
WWN |
Implemented |
HTTP/S |
Manufacturer |
Implemented |
HTTP/S |
Firmware |
Implemented |
HTTP/S |
Driver |
Implemented |
HTTP/S |
Model |
Implemented |
HTTP/S |
WWN Alias |
Host Aliases |
Implemented |
HTTP/S |
Object Type |
Implemented |
HTTP/S |
Source |
Implemented |
HTTP/S |
WWN |
Implemented |
HTTP/S |
Zone |
Zone Name |
Implemented |
HTTP/S |
Zone Member |
Type |
Gap |
HTTP/S |
WWN |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
WWN |
Implemented |
HTTP/S |
performance |
port |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Brocade Network Advisor REST API |
HTTP/HTTPS |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
Brocade FOS REST
183.0 |
v8.2.2a |
foundation |
FC ID |
Implemented |
HTTPS |
Nx Port WWN |
Implemented |
HTTPS |
Physical Port WWN |
Implemented |
HTTPS |
Switch Port WWN |
Implemented |
HTTPS |
Fabric |
Name |
Implemented |
HTTPS |
VSAN Enabled |
Implemented |
HTTPS |
VSANId |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
Info |
Api Description |
Implemented |
HTTPS |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Logical Switch |
Chassis WWN |
Implemented |
HTTPS |
Domain Id |
Implemented |
HTTPS |
Firmware Version |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Switch Role |
Implemented |
HTTPS |
Switch State |
Implemented |
HTTPS |
Switch Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
WWN |
Implemented |
HTTPS |
Port |
Blade |
Implemented |
HTTPS |
GBIC Type |
Implemented |
HTTPS |
Generated |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Node WWN |
Implemented |
HTTPS |
Port ID |
Implemented |
HTTPS |
Port Number |
Implemented |
HTTPS |
Port Speed |
Implemented |
HTTPS |
Port State |
Implemented |
HTTPS |
Port Status |
Implemented |
HTTPS |
Port Type |
Implemented |
HTTPS |
Raw Port Status |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
Description |
Implemented |
HTTPS |
Switch |
Domain Id |
Implemented |
HTTPS |
Firmware Version |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Switch Role |
Implemented |
HTTPS |
Switch State |
Implemented |
HTTPS |
Switch Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
VSAN Enabled |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
Unknown |
Driver |
Implemented |
HTTPS |
Firmware |
Implemented |
HTTPS |
Generated |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
WWN Alias |
Host Aliases |
Implemented |
HTTPS |
Object Type |
Implemented |
HTTPS |
Source |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
Zone |
Zone Name |
Implemented |
HTTPS |
Zone Member |
Type |
Gap |
HTTPS |
WWN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
performance |
port |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Port Errors Crc |
Implemented |
HTTPS |
Port Errors Crc |
Implemented |
HTTPS |
portErrors.encOut |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Port Errors |
Implemented |
HTTPS |
Total port errors |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
TX Frames |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Port Data |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Implemented |
HTTPS |
Port Errors Crc |
Implemented |
HTTPS |
Port Errors Crc |
Implemented |
HTTPS |
portErrors.encOut |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Port Errors |
Implemented |
HTTPS |
Total port errors |
Server ID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
TX Frames |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Brocade FOS REST API |
HTTPS |
443 |
true |
true |
true |
true |
Cisco MDS & Nexus Fabric Switches
DS-C9124-2-K9 |
3.3(1c) |
foundation |
FC ID |
Implemented |
SNMP |
Nx Port WWN |
Implemented |
SNMP |
Physical Port WWN |
Implemented |
SNMP |
Switch Port WWN |
Implemented |
SNMP |
Fabric |
Name |
Implemented |
SNMP |
VSAN Enabled |
Implemented |
SNMP |
VSANId |
Implemented |
SNMP |
WWN |
Implemented |
SNMP |
IVR Chassis WWNs |
Implemented |
SNMP |
Implemented |
SNMP |
Info |
DataSource Name |
Implemented |
SNMP |
Info |
Date |
Implemented |
SNMP |
Originator ID |
Implemented |
SNMP |
Originator Key |
Implemented |
SNMP |
Logical Switch |
Chassis WWN |
Implemented |
SNMP |
Domain Id |
Implemented |
SNMP |
DomainId Type |
Implemented |
SNMP |
IP |
Implemented |
SNMP |
Manufacturer |
Implemented |
SNMP |
Priority |
Implemented |
SNMP |
Switch Role |
Implemented |
SNMP |
Type |
Gap |
SNMP |
WWN |
Implemented |
SNMP |
Port |
Blade |
Implemented |
SNMP |
GBIC Type |
Implemented |
SNMP |
Generated |
Implemented |
SNMP |
Name |
Implemented |
SNMP |
Port ID |
Implemented |
SNMP |
Port Number |
Implemented |
SNMP |
Port Speed |
Implemented |
SNMP |
Port State |
Implemented |
SNMP |
Port Status |
Implemented |
SNMP |
Port Type |
Implemented |
SNMP |
Raw Port Status |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
WWN |
Implemented |
SNMP |
Switch |
Firmware Version |
Implemented |
SNMP |
IP |
Implemented |
SNMP |
Manage URL |
Implemented |
SNMP |
Manufacturer |
Implemented |
SNMP |
Model |
Implemented |
SNMP |
Name |
Implemented |
SNMP |
SANRoute Enabled |
Implemented |
SNMP |
Indicates if this chassis is enabled for SAN routing (IVR, etc…) |
Serial Number |
Implemented |
SNMP |
Switch Status |
Implemented |
SNMP |
Type |
Gap |
SNMP |
VSAN Enabled |
Implemented |
SNMP |
WWN |
Implemented |
SNMP |
Unknown |
Driver |
Implemented |
SNMP |
Firmware |
Implemented |
SNMP |
Generated |
Implemented |
SNMP |
Manufacturer |
Implemented |
SNMP |
Model |
Implemented |
SNMP |
Name |
Implemented |
SNMP |
WWN |
Implemented |
SNMP |
WWN Alias |
Host Aliases |
Implemented |
SNMP |
Object Type |
Implemented |
SNMP |
Source |
Implemented |
SNMP |
WWN |
Implemented |
SNMP |
Zone |
Zone Name |
Implemented |
SNMP |
Zone Type |
Implemented |
SNMP |
Zone Member |
Type |
Gap |
SNMP |
WWN |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Merge Control |
Implemented |
SNMP |
WWN |
Implemented |
SNMP |
performance |
port |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Port Errors Crc |
Implemented |
SNMP |
Port Errors Crc |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Total Port Errors |
Implemented |
SNMP |
Total port errors |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
TX Frames |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Port Data |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Key |
Implemented |
SNMP |
Implemented |
SNMP |
Port Errors Crc |
Implemented |
SNMP |
Port Errors Crc |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Total Port Errors |
Implemented |
SNMP |
Total port errors |
Server ID |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
TX Frames |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Implemented |
SNMP |
Cisco SNMP |
SNMP |
SNMPv1 (Inventory only), SNMPv2, SNMPv3 |
161 |
true |
true |
true |
true |
Cohesity
C4000 Compute Node |
6.8.1_u1_release-20221022_6f58ed2a |
foundation |
Disk |
Capacity (GB) |
Implemented |
Used capacity |
Disk Id |
Implemented |
Name |
Implemented |
File Share |
Is InternalVolume |
Implemented |
Is Shared |
Implemented |
Name |
Implemented |
Path |
Implemented |
Qtree Id |
Implemented |
Info |
Api Name |
Implemented |
DataSource Name |
Implemented |
Info |
Date |
Implemented |
Originator ID |
Implemented |
Originator Key |
Implemented |
Internal Volume |
Implemented |
Dedupe Enabled |
Implemented |
Dedupe Savings |
Implemented |
Implemented |
Name |
Implemented |
Implemented |
Storage Pool Id |
Implemented |
Thin Provisioned |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Type |
Gap |
QTree |
Name |
Implemented |
Qtree Id |
Implemented |
Type |
Gap |
Share |
IP Interfaces |
Implemented |
Name |
Implemented |
Protocol |
Implemented |
Storage |
Display IP |
Implemented |
Implemented |
Family |
Implemented |
IP |
Implemented |
Manage URL |
Implemented |
Manufacturer |
Implemented |
Microcode Version |
Implemented |
Model |
Implemented |
Name |
Implemented |
Implemented |
Serial Number |
Implemented |
Implemented |
Virtual |
Implemented |
Storage Node |
Model |
Implemented |
Name |
Implemented |
Serial Number |
Implemented |
UUID |
Implemented |
Version |
Implemented |
software version |
Storage Pool |
Implemented |
Dedupe Enabled |
Implemented |
Dedupe Savings |
Implemented |
Implemented |
Name |
Implemented |
Implemented |
Raid Group |
Implemented |
Implemented |
Status |
Implemented |
Storage Pool Id |
Implemented |
Implemented |
Implemented |
Implemented |
Type |
Gap |
Virtual |
Implemented |
Encrypted |
Implemented |
performance |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
Cohesity REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
EMC Celerra (SSH)
NSX |
5.5.38-1 |
foundation |
File Share |
Is InternalVolume |
Implemented |
SSH |
Is Shared |
Implemented |
SSH |
Name |
Implemented |
SSH |
Path |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Status |
Implemented |
SSH |
Info |
Api Name |
Implemented |
SSH |
Api Version |
Implemented |
SSH |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
Originator Key |
Implemented |
SSH |
Internal Volume |
Gap |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Dedupe Savings |
Implemented |
SSH |
GuidKey 1 |
Implemented |
SSH |
GuidKey1 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5. |
GuidKey 2 |
Implemented |
SSH |
GuidKey2 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5. |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Snapshot Count |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioned |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Virtual Storage |
Implemented |
SSH |
Owning virtual storage (vfiler) |
QTree |
GuidKey 1 |
Implemented |
SSH |
GuidKey 2 |
Implemented |
SSH |
Name |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Implemented |
SSH |
Quota SoftCapacity Limit (MB) |
Implemented |
SSH |
Quota UsedCapacity |
Implemented |
SSH |
Space in MB currently used |
Type |
Gap |
SSH |
Quota |
Quota Id |
Implemented |
SSH |
Type |
Gap |
SSH |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Soft File Limit |
Implemented |
SSH |
Max number of files allowed for the quota target |
Implemented |
SSH |
Soft Capacity Limit (MB) |
Implemented |
SSH |
Used Files |
Implemented |
SSH |
Number of files currently used |
Used Capacity |
Implemented |
SSH |
GuidKey 1 |
Implemented |
SSH |
GuidKey 2 |
Implemented |
SSH |
Share |
IP Interfaces |
Implemented |
SSH |
Name |
Implemented |
SSH |
Protocol |
Implemented |
SSH |
Share Initiator |
Initiator |
Implemented |
SSH |
Permission |
Implemented |
SSH |
Storage |
Cpu Count |
Implemented |
SSH |
Cpu Count of the storage |
Display IP |
Implemented |
SSH |
Implemented |
SSH |
Family |
Implemented |
SSH |
IP |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Microcode Version |
Implemented |
SSH |
Model |
Implemented |
SSH |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Storage Pool |
Gap |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Raid Group |
Implemented |
SSH |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Virtual |
Implemented |
SSH |
Celerra CLI |
SSH |
SSH |
true |
false |
true |
true |
EMC CLARiiON (NaviCLI)
6.26 |
CX3-40f |
04.28.000.5.710 |
foundation |
Disk |
Capacity (GB) |
Implemented |
CLI |
Used capacity |
Disk Id |
Implemented |
CLI |
Group |
Implemented |
CLI |
Location |
Gap |
CLI |
Model |
Implemented |
CLI |
Name |
Implemented |
CLI |
Role |
Implemented |
CLI |
Role Enum |
Implemented |
CLI |
Serial Number |
Implemented |
CLI |
Status |
Implemented |
CLI |
Status Enum |
Implemented |
CLI |
Type |
Gap |
CLI |
Type Enum |
Implemented |
CLI |
Vendor |
Implemented |
CLI |
Info |
Api Name |
Implemented |
CLI |
Api Version |
Implemented |
CLI |
Client Api Name |
Implemented |
CLI |
Client Api Version |
Implemented |
CLI |
DataSource Name |
Implemented |
CLI |
Info |
Date |
Implemented |
CLI |
Originator ID |
Implemented |
CLI |
Storage |
Display IP |
Implemented |
CLI |
Implemented |
CLI |
Family |
Implemented |
CLI |
IP |
Implemented |
CLI |
Manage URL |
Implemented |
CLI |
Manufacturer |
Implemented |
CLI |
Microcode Version |
Implemented |
CLI |
Model |
Implemented |
CLI |
Name |
Implemented |
CLI |
Implemented |
CLI |
Serial Number |
Implemented |
CLI |
Implemented |
CLI |
SupportActive Active |
Implemented |
CLI |
Specified if the storage supports active-active configurations |
Virtual |
Implemented |
CLI |
Storage Node |
Name |
Implemented |
CLI |
Serial Number |
Implemented |
CLI |
UUID |
Implemented |
CLI |
ManagementIp Addresses |
Implemented |
CLI |
Storage Pool |
Dedupe Enabled |
Implemented |
CLI |
Implemented |
CLI |
Name |
Implemented |
CLI |
Gap |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Raid Group |
Implemented |
CLI |
Implemented |
CLI |
Redundancy |
Implemented |
CLI |
Redundancy level |
Gap |
CLI |
Implemented |
CLI |
Status |
Implemented |
CLI |
Storage Pool Id |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Type |
Gap |
CLI |
Virtual |
Implemented |
CLI |
Source Volume |
Implemented |
CLI |
Target Volume |
Implemented |
CLI |
Mode |
Implemented |
CLI |
Mode Enum |
Implemented |
CLI |
State |
Implemented |
CLI |
State Enum |
Implemented |
CLI |
Technology |
Implemented |
CLI |
Volume |
Implemented |
CLI |
Auto Tiering |
Implemented |
CLI |
Capacity |
Implemented |
CLI |
DiskGroup |
Implemented |
CLI |
Disk Group Type |
Disk Type |
Not Available |
CLI |
Junction Path |
Implemented |
CLI |
Meta |
Implemented |
CLI |
Flag saying whether this volume is a meta volume with memeber or not. Meta volumes will have DiskGroup empty! |
Name |
Implemented |
CLI |
Implemented |
CLI |
Redundancy |
Implemented |
CLI |
Redundancy level |
Replica Source |
Implemented |
CLI |
Replica Target |
Implemented |
CLI |
Storage Pool Id |
Implemented |
CLI |
Thin Provisioned |
Implemented |
CLI |
Type |
Gap |
CLI |
UUID |
Implemented |
CLI |
Used Capacity |
Implemented |
CLI |
Volume Map |
LUN |
Implemented |
CLI |
Implemented |
CLI |
Storage Port |
Implemented |
CLI |
Type |
Gap |
CLI |
Volume Mask |
Initiator |
Implemented |
CLI |
Implemented |
CLI |
Storage Port |
Implemented |
CLI |
Type |
Gap |
CLI |
Volume Member |
Capacity |
Implemented |
CLI |
Name |
Implemented |
CLI |
Rank |
Implemented |
CLI |
Implemented |
CLI |
Redundancy |
Implemented |
CLI |
Redundancy level |
Storage Pool Id |
Implemented |
CLI |
Used Capacity |
Implemented |
CLI |
WWN Alias |
Host Aliases |
Implemented |
CLI |
IP |
Implemented |
CLI |
Object Type |
Implemented |
CLI |
Source |
Implemented |
CLI |
WWN |
Implemented |
CLI |
performance |
Disk |
IOPs Read |
Implemented |
CLI |
IOPs Total |
Implemented |
CLI |
IOPs Write |
Implemented |
CLI |
Throughput Read |
Implemented |
CLI |
Throughput Total |
Implemented |
CLI |
Throughput Write |
Implemented |
CLI |
Read Utilization |
Implemented |
CLI |
Utilization Total |
Implemented |
CLI |
Utilization Write |
Implemented |
CLI |
Disk |
IOPs Read |
Implemented |
CLI |
IOPs Total |
Implemented |
CLI |
IOPs Write |
Implemented |
CLI |
Key |
Implemented |
CLI |
Server ID |
Implemented |
CLI |
Throughput Read |
Implemented |
CLI |
Throughput Total |
Implemented |
CLI |
Throughput Write |
Implemented |
CLI |
Read Utilization |
Implemented |
CLI |
Utilization Total |
Implemented |
CLI |
Utilization Write |
Implemented |
CLI |
Storage |
Implemented |
CLI |
IOPs Read |
Implemented |
CLI |
Implemented |
CLI |
IOPs other |
Implemented |
CLI |
IOPs Write |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Throughput Read |
Implemented |
CLI |
Throughput Write |
Implemented |
CLI |
Throughput Total |
Implemented |
CLI |
IOPs Total |
Implemented |
CLI |
Latency Total |
Implemented |
CLI |
Latency Read |
Implemented |
CLI |
Latency Write |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Raw Capacity |
Implemented |
CLI |
Implemented |
CLI |
Storage |
Implemented |
CLI |
Raw Capacity |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Key |
Implemented |
CLI |
Server ID |
Implemented |
CLI |
Storage Node |
IOPs Read |
Implemented |
CLI |
IOPs Total |
Implemented |
CLI |
IOPs Write |
Implemented |
CLI |
Utilization Total |
Implemented |
CLI |
StoragePool Disk |
Implemented |
CLI |
Raw Capacity |
Implemented |
CLI |
Total Capacity |
Implemented |
CLI |
Used Capacity |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
IOPs Read |
Implemented |
CLI |
IOPs Total |
Implemented |
CLI |
IOPs Write |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Throughput Read |
Implemented |
CLI |
Throughput Total |
Implemented |
CLI |
Throughput Write |
Implemented |
CLI |
Read Utilization |
Implemented |
CLI |
Utilization Total |
Implemented |
CLI |
Utilization Write |
Implemented |
CLI |
Volume |
Implemented |
CLI |
Implemented |
CLI |
Implemented |
CLI |
Raw Capacity |
Implemented |
CLI |
Total Capacity |
Implemented |
CLI |
Used Capacity |
Implemented |
CLI |
Implemented |
CLI |
IOPs Read |
Implemented |
CLI |
IOPs Total |
Implemented |
CLI |
IOPs Write |
Implemented |
CLI |
Latency Read |
Implemented |
CLI |
Latency Total |
Implemented |
CLI |
Latency Write |
Implemented |
CLI |
Implemented |
CLI |
Throughput Read |
Implemented |
CLI |
Throughput Total |
Implemented |
CLI |
Throughput Write |
Implemented |
CLI |
Navi CLI |
CLI |
6389,2162,2163,443(HTTPS)/80(HTTP) |
true |
true |
true |
false |
EMC Data Domain (SSH)
DD VE |
6.0.2.30-606339 |
foundation |
Disk |
Capacity (GB) |
Implemented |
SSH |
Used capacity |
Disk Id |
Implemented |
SSH |
Group |
Implemented |
SSH |
Location |
Gap |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Role |
Implemented |
SSH |
Role Enum |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Speed |
Implemented |
SSH |
Speed of disk (RPM) |
Status |
Implemented |
SSH |
Status Enum |
Implemented |
SSH |
Type |
Gap |
SSH |
Type Enum |
Implemented |
SSH |
File Share |
Is InternalVolume |
Implemented |
SSH |
Is Shared |
Implemented |
SSH |
Name |
Implemented |
SSH |
Path |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Info |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
Internal Volume |
Gap |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Dedupe Savings |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioned |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
QTree |
Name |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Quota |
Implemented |
SSH |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Quota Id |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Used Capacity |
Implemented |
SSH |
Share |
IP Interfaces |
Implemented |
SSH |
Name |
Implemented |
SSH |
Protocol |
Implemented |
SSH |
Share Initiator |
Initiator |
Implemented |
SSH |
Permission |
Implemented |
SSH |
Storage |
Cpu Count |
Implemented |
SSH |
Display IP |
Implemented |
SSH |
Implemented |
SSH |
Family |
Implemented |
SSH |
IP |
Implemented |
SSH |
Manage URL |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Microcode Version |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Storage Node |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Processors Count |
Implemented |
SSH |
device CPU |
Serial Number |
Implemented |
SSH |
UUID |
Implemented |
SSH |
Version |
Implemented |
SSH |
software version |
Implemented |
SSH |
Storage Pool |
Gap |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Dedupe Savings |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Raid Group |
Implemented |
SSH |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Virtual |
Implemented |
SSH |
Data Domain CLI |
SSH |
SSH |
22 |
true |
true |
true |
true |
EMC ECS
ECS |
3.6.1.3 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Disk Group |
Capacity |
Implemented |
HTTPS |
DiskGroup Id |
Implemented |
HTTPS |
unique id of the disk group |
Name |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Name |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Node Capacity Utilization Total in MB |
Implemented |
HTTPS |
Node Capacity Utilization Usable in MB |
Implemented |
HTTPS |
Node Capacity Utilization Used in MB |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
performance |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Objects |
Implemented |
HTTPS |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Total Objects |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage Node |
IOPs Total |
Implemented |
HTTPS |
Node Capacity Utilization Total |
Implemented |
HTTPS |
Node Capacity Utilization Usable |
Implemented |
HTTPS |
Node Capacity Utilization Used |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage Node Data |
IOPs Total |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
EMC ECS REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Dell EMC Isilon & PowerScale Rest
A100 |
9.1.0.10 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Vendor Id |
Implemented |
HTTPS |
Disk Group |
Capacity |
Implemented |
HTTPS |
DiskGroup Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Status |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Vendor DiskGroup Type |
Implemented |
HTTPS |
vendor's designation of the disk group type |
Vendor Tier |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Quota |
Implemented |
HTTPS |
Hard File Limit |
Implemented |
HTTPS |
max number of files allowed for the quota target |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Quota Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Soft File Limit |
Implemented |
HTTPS |
Threshold (MB) |
Implemented |
HTTPS |
Disk space threshold, for the quota target |
Type |
Gap |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Used Files |
Implemented |
HTTPS |
User/Group Target |
Implemented |
HTTPS |
user/group target this quota refers to |
Share |
Description |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Node |
Memory Size |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Qtree |
Quota Hard Limit |
Implemented |
HTTPS |
Capacity quota hard limit |
Used Capacity |
Implemented |
HTTPS |
Total File Count |
Implemented |
HTTPS |
Quota Capacity |
Implemented |
HTTPS |
Physical used quota capacity |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage Node |
Failed Disks |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Number of read IOPs on file system |
IOPs Write |
Implemented |
HTTPS |
IOPs write of filesystem |
File Throughput Read |
Implemented |
HTTPS |
FileSystem Throughput |
Implemented |
HTTPS |
fileSystem Throughput write |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Node Data |
Failed Disks |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
EMC Isilon & PowerScale REST API |
HTTPS |
443 |
true |
true |
true |
true |
Dell EMC Isilon / PowerScale (CLI)
Models and versions supported by this data collector:
A200 |
9.1.0.18 |
Products supported by this data collector:
Product | Category | Feature/Attribute | Status | Protocol Used | Additional Information |
foundation |
Disk |
Capacity (GB) |
Implemented |
SSH |
Used capacity |
Disk Id |
Implemented |
SSH |
Uniquely identifies this disk in the array |
Group |
Implemented |
SSH |
Location |
Gap |
SSH |
Where this disk is physically located in the array |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Role |
Implemented |
SSH |
Role Enum |
Implemented |
SSH |
enum for disk role |
Serial Number |
Implemented |
SSH |
Speed |
Implemented |
SSH |
Status |
Implemented |
SSH |
Status Enum |
Implemented |
SSH |
enum for disk status |
Type |
Gap |
SSH |
Type Enum |
Implemented |
SSH |
enum for disk type |
Vendor |
Implemented |
SSH |
Vendor Id |
Implemented |
SSH |
Disk Group |
Capacity |
Implemented |
SSH |
DiskGroup Id |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Redundancy |
Implemented |
SSH |
Redundancy level |
Status |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Implemented |
SSH |
Vendor Tier |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Is this a storage virtualization device? |
File Share |
Is InternalVolume |
Implemented |
SSH |
Is Shared |
Implemented |
SSH |
Name |
Implemented |
SSH |
Path |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Info |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
Internal Volume |
Gap |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioned |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
QTree |
Name |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Quota |
Implemented |
SSH |
Hard File Limit |
Implemented |
SSH |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Quota Id |
Implemented |
SSH |
Implemented |
SSH |
Soft File Limit |
Implemented |
SSH |
Threshold (MB) |
Implemented |
SSH |
Type |
Gap |
SSH |
Used Capacity |
Implemented |
SSH |
Used Files |
Implemented |
SSH |
User/Group Target |
Implemented |
SSH |
Share |
Description |
Implemented |
SSH |
IP Interfaces |
Implemented |
SSH |
Name |
Implemented |
SSH |
Protocol |
Implemented |
SSH |
Share Initiator |
Initiator |
Implemented |
SSH |
Permission |
Implemented |
SSH |
Storage |
Display IP |
Implemented |
SSH |
Failed Raw Capacity |
Implemented |
SSH |
Raw capacity of failed disks (sum of all disks that are failed) |
Family |
Implemented |
SSH |
The storage Family could be Clariion, Symmetrix, et al |
IP |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Microcode Version |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Total Raw Capacity |
Implemented |
SSH |
Total raw capacity (sum of all disks on the array) |
Serial Number |
Implemented |
SSH |
Spare Raw Capacity |
Implemented |
SSH |
Raw capacity of spare disks (sum of all disks that are spare) |
Virtual |
Implemented |
SSH |
Storage Node |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
State |
Implemented |
SSH |
free text describing the device state |
UUID |
Implemented |
SSH |
Implemented |
SSH |
Storage Pool |
Data Allocated Capacity |
Gap |
SSH |
capacity allocated for data |
Data Used Capacity |
Implemented |
SSH |
Include In Dwh Capacity |
Implemented |
SSH |
A way from ACQ to control which storage pools are interesting in DWH Capacity |
Name |
Implemented |
SSH |
Physical Disk Capacity (MB) |
Implemented |
SSH |
used as raw capacity for storage pool |
Raid Group |
Implemented |
SSH |
indicates whether this storagePool is a raid group |
Raw to Usable Ratio |
Implemented |
SSH |
ratio to convert from usable capacity to raw capacity |
Snapshot Allocated Capacity |
Gap |
SSH |
Allocated capacity of snapshots in MB |
Snapshot Used Capacity |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioning Supported |
Implemented |
SSH |
Whether this internal volume supports thin provisioning for the volume layer on top of it |
Total Allocated Capacity |
Implemented |
SSH |
Total Used Capacity |
Implemented |
SSH |
Total capacity in MB |
Type |
Gap |
SSH |
Virtual |
Implemented |
SSH |
performance |
Internal Volume |
Total Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Qtree |
Quota Capacity |
Implemented |
SSH |
Qtree |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Quota Capacity |
Implemented |
SSH |
Storage |
Latency Total |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
Number of read IOPs on the disk |
IOPs other |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Average disk total rate (read and write across all disks) in MB/s |
IOPs Total |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Storage |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
StoragePools Capacity |
Implemented |
SSH |
Storage Node |
Latency Total |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Implemented |
SSH |
Storage Node Data |
IOPs Read |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Key |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
StoragePool Disk |
Total Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Capacity Provisioned |
Implemented |
SSH |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Over Commit Capacity Ratio |
Implemented |
SSH |
Reported as a time series |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Isilon SSH |
SSH |
SSH |
22 |
true |
false |
true |
true |
EMC PowerStore REST
PowerStore 1000T |
2.1.0.1 |
foundation |
Disk |
Capacity (GB) |
Implemented |
Used capacity |
Disk Id |
Implemented |
Location |
Gap |
Name |
Implemented |
Serial Number |
Implemented |
Speed |
Implemented |
Status |
Implemented |
Type |
Gap |
Type Enum |
Implemented |
Vendor |
Implemented |
File Share |
Is InternalVolume |
Implemented |
Is Shared |
Implemented |
Name |
Implemented |
Path |
Implemented |
Qtree Id |
Implemented |
ISCSI Network Portal |
IP |
Implemented |
Listening Port |
Implemented |
Nic |
Implemented |
OID |
Implemented |
ISCSI Network Portal Group |
OID |
Implemented |
Portal Group Name |
Implemented |
Portal Group Tag |
Implemented |
ISCSI Node |
Host Aliases |
Implemented |
Node Name |
Implemented |
OID |
Implemented |
Type |
Gap |
ISCSI Session |
OID |
Implemented |
Initiator OID |
Implemented |
Portal Group OID |
Implemented |
Number Of Connections |
Implemented |
Max Connections |
Implemented |
Initiator Ips |
Implemented |
Security |
Implemented |
Info |
Api Name |
Implemented |
DataSource Name |
Implemented |
Info |
Date |
Implemented |
Originator ID |
Implemented |
Originator Key |
Implemented |
Internal Volume |
Dedupe Enabled |
Implemented |
Is dedupe enabled on the storage pool |
Implemented |
Name |
Implemented |
Implemented |
Storage Pool Id |
Implemented |
Thin Provisioned |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Type |
Gap |
Virtual Storage |
Implemented |
QTree |
Name |
Implemented |
Qtree Id |
Implemented |
Type |
Gap |
Share |
IP Interfaces |
Implemented |
Name |
Implemented |
Protocol |
Implemented |
Share Initiator |
Initiator |
Implemented |
Permission |
Implemented |
Storage |
Display IP |
Implemented |
Implemented |
Family |
Implemented |
IP |
Implemented |
Manage URL |
Implemented |
Manufacturer |
Implemented |
Microcode Version |
Implemented |
Model |
Implemented |
Name |
Implemented |
Implemented |
Serial Number |
Implemented |
Implemented |
Implemented |
Virtual |
Implemented |
Storage Node |
Model |
Implemented |
Name |
Implemented |
Partner Node UUID |
Implemented |
HA pair's UUID |
UUID |
Implemented |
Parent Serial Number |
Implemented |
Storage Pool |
Compression Savings |
Implemented |
ratio of compression savings in percentage |
Implemented |
Name |
Implemented |
Implemented |
Raid Group |
Implemented |
Implemented |
Storage Pool Id |
Implemented |
Implemented |
Implemented |
Implemented |
Type |
Gap |
Virtual |
Implemented |
Volume |
Capacity |
Implemented |
Snapshot Used capacity in MB |
Junction Path |
Implemented |
Name |
Implemented |
Implemented |
Storage Pool Id |
Implemented |
Thin Provisioned |
Implemented |
Type |
Gap |
UUID |
Implemented |
Used Capacity |
Implemented |
QoS - Policy |
Implemented |
Volume Map |
LUN |
Implemented |
Name of the backend lun |
Masking Required |
Implemented |
Protocol Controller |
Implemented |
Storage Port |
Implemented |
Type |
Gap |
Volume Mask |
Initiator |
Implemented |
Implemented |
Type |
Gap |
WWN Alias |
Host Aliases |
Implemented |
Object Type |
Implemented |
Source |
Implemented |
WWN |
Implemented |
performance |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage Node |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
Storage Pool |
Key |
Implemented |
Server ID |
Implemented |
StoragePool Disk |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Capacity Used Ratio |
Implemented |
Total Compression Savings |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Volume |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Volume |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Management APIs used by this data collector:
API | Protocol Used | Transport layer protocol used | Incoming ports used | Outgoing ports used | Supports authentication | Requires only 'Read-only' credentials | Supports Encryption | Firewall friendly (static ports) |
EMC PowerStore REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
EMC RecoverPoint (HTTP)
RecoverPoint |
5.1.SP4.P1(h.89) |
foundation |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Memory Size |
Gap |
HTTPS |
device memory in MB |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Storage Synchronization |
Mode |
Implemented |
HTTPS |
Mode Enum |
Implemented |
HTTPS |
Source Storage |
Implemented |
HTTPS |
Source Volume |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
State Enum |
Implemented |
HTTPS |
Target Storage |
Implemented |
HTTPS |
Target Volume |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
technology which causes storage efficiency changed |
RecoverPoint REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
EMC ScaleIO & PowerFlex REST
ScaleIO |
R3_5.1201.101 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Info |
Api Version |
Implemented |
HTTPS |
Client Api Description |
Implemented |
HTTPS |
Client Api Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Name |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Host IPs |
Implemented |
HTTPS |
performance |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
EMC ScaleIO & PowerFlex REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
EMC Symmetrix CLI
V10.0.0.0 |
PMax8000 |
5876.286.194(16F40000) build 115 |
foundation |
Device Group |
Name |
Implemented |
Storage Management Id |
Implemented |
Type |
Gap |
Disk |
Capacity (GB) |
Implemented |
Used capacity |
Disk Id |
Implemented |
Group |
Implemented |
Model |
Implemented |
Name |
Implemented |
Role |
Implemented |
Role Enum |
Implemented |
Serial Number |
Implemented |
Status |
Implemented |
Status Enum |
Implemented |
Type Enum |
Implemented |
Vendor |
Implemented |
Disk Group |
Capacity |
Implemented |
DiskGroup Id |
Implemented |
Name |
Implemented |
Implemented |
Redundancy |
Implemented |
Redundancy level |
Used Capacity |
Implemented |
Implemented |
Virtual |
Implemented |
OID |
Implemented |
IP |
Implemented |
Nic |
Implemented |
Listening Port |
Implemented |
OID |
Implemented |
Portal Group Name |
Implemented |
Portal Group Tag |
Implemented |
ISCSI Node |
OID |
Implemented |
Node Name |
Implemented |
Type |
Gap |
ISCSI Node Map |
OID |
Implemented |
Portal Group OID |
Implemented |
ISCSI Session |
OID |
Implemented |
Initiator OID |
Implemented |
Portal Group OID |
Implemented |
Implemented |
Max Connections |
Implemented |
Initiator Ips |
Implemented |
Security |
Implemented |
Info |
Api Description |
Implemented |
Api Name |
Implemented |
Api Version |
Implemented |
Implemented |
Client Api Name |
Implemented |
Implemented |
DataSource Name |
Implemented |
Info |
Date |
Implemented |
Originator ID |
Implemented |
Originator Key |
Implemented |
Network Pipe |
Auto Recover |
Implemented |
Bidirectional |
Implemented |
Operational Status |
Implemented |
Source Id |
Implemented |
Target Id |
Implemented |
Network Pipe Port Wwn |
WWN |
Implemented |
Protocol EndPoint |
ID |
Implemented |
Name |
Implemented |
Storage Ip |
Implemented |
Storage |
Display IP |
Implemented |
Implemented |
Family |
Implemented |
IP |
Implemented |
Manufacturer |
Implemented |
Microcode Version |
Implemented |
Model |
Implemented |
Name |
Implemented |
Implemented |
Serial Number |
Implemented |
Implemented |
Virtual |
Implemented |
Storage Node |
Name |
Implemented |
UUID |
Implemented |
Storage Pool |
Auto Tiering |
Implemented |
indicates if this storagepool is participating in auto tiering with other pools |
Compression Enabled |
Implemented |
Is compression enabled on the storage pool |
Implemented |
Gap |
Implemented |
Dedupe Enabled |
Implemented |
Implemented |
Name |
Implemented |
Other UsedCapacity (MB) |
Implemented |
Any capacity other than data and snapshot |
Implemented |
Raid Group |
Implemented |
Implemented |
Redundancy |
Implemented |
Redundancy level |
Implemented |
Soft Limit (MB) |
Implemented |
logical volume size that is defined during volume creation or resizing operations |
Storage Pool Id |
Implemented |
Implemented |
Implemented |
Implemented |
Type |
Gap |
Vendor Tier |
Implemented |
Vendor Specific Tier Name |
Virtual |
Implemented |
Effective Used Capacity Percent |
Implemented |
Mode |
Implemented |
Mode Enum |
Implemented |
Source Storage |
Implemented |
Source Volume |
Implemented |
State |
Implemented |
State Enum |
Implemented |
Target Storage |
Implemented |
Target Volume |
Implemented |
Technology |
Implemented |
Volume |
AutoTier Policy Identifier |
Implemented |
Dynamic Tier Policy identifier |
Auto Tiering |
Implemented |
Capacity |
Implemented |
Disk Size |
Implemented |
comma seperated list of disk sizes (GB) |
Disk Type |
Not Available |
Mainframe |
Implemented |
indicates if this volume is a Mainframe Volume |
Meta |
Implemented |
Name |
Implemented |
Implemented |
Redundancy |
Implemented |
Redundancy level |
Replica Source |
Implemented |
Replica Target |
Implemented |
Snapshot |
Implemented |
Storage Pool Id |
Implemented |
Thin Provisioned |
Implemented |
Type |
Gap |
UUID |
Implemented |
Used Capacity |
Implemented |
Virtual |
Implemented |
Written Capacity |
Implemented |
Total capacity written to this volume by a Host in MB |
storage Groups |
Implemented |
Volume Map |
LUN |
Implemented |
Implemented |
Storage Port |
Implemented |
Type |
Gap |
Volume Mask |
Initiator |
Implemented |
Implemented |
Storage Port |
Implemented |
Type |
Gap |
Volume Member |
Auto Tiering |
Implemented |
Capacity |
Implemented |
Cylinders |
Implemented |
Name |
Implemented |
Rank |
Implemented |
Implemented |
Redundancy |
Implemented |
Redundancy level |
Storage Pool Id |
Implemented |
UUID |
Implemented |
Volume Ref |
Name |
Implemented |
Storage Ip |
Implemented |
WWN Alias |
Host Aliases |
Implemented |
Object Type |
Implemented |
Source |
Implemented |
WWN |
Implemented |
performance |
Disk |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage |
Cache Hit Ratio Read |
Implemented |
Cache Hit Ratio Total |
Implemented |
Cache Hit Ratio Write |
Implemented |
Cache Utilization Total |
Implemented |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Write Pending |
Implemented |
total write pending |
Storage |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Write Pending |
Implemented |
Storage Node |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
StoragePool Disk |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
Total Data Capacity |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Other Used Capacity |
Implemented |
Implemented |
Snapshot Used Capacity Ratio |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Volume |
Implemented |
Implemented |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Written Capacity |
Implemented |
Implemented |
CapacityRatio Written |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Write Pending |
Implemented |
Volume |
Implemented |
Implemented |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Written Capacity |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Write Pending |
Implemented |
symcli |
CLI |
2707 |
true |
true |
true |
true |
Symmetrix SMI-S |
SMI-S |
HTTP/HTTPS |
5988/5989 |
true |
false |
false |
true |
Dell Unisphere REST
API versions | Models | Firmware versions |
V10.0.0.5 |
PowerMax_2000 |
5977.1131.1131 build 615 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Info |
Api Description |
Implemented |
HTTPS |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
Implemented |
HTTPS |
Client Api Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Name |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Implemented |
HTTPS |
Mode |
Implemented |
HTTPS |
Mode Enum |
Implemented |
HTTPS |
Source Storage |
Implemented |
HTTPS |
Source Volume |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
State Enum |
Implemented |
HTTPS |
Target Storage |
Implemented |
HTTPS |
Target Volume |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
Volume |
Implemented |
HTTPS |
Auto Tiering |
Implemented |
HTTPS |
Capacity |
Implemented |
HTTPS |
Disk Type |
Not Available |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Written Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
storage Groups |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
WWN Alias |
Host Aliases |
Implemented |
HTTPS |
Object Type |
Implemented |
HTTPS |
Source |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Write Pending |
Implemented |
HTTPS |
Storage Node |
Latency Total |
Implemented |
HTTPS |
Total Disk Read Replaced |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Node Data |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Compression Savings Space |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Snapshot Reserved Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Volume |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dell Unisphere API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
EMC VNX (SSH)
VNX5300 |
05.32.000.5.216 |
foundation |
Disk |
Disk Id |
Implemented |
SSH |
Name |
Implemented |
SSH |
Capacity (GB) |
Implemented |
SSH |
Used capacity |
Location |
Gap |
SSH |
Role Enum |
Implemented |
SSH |
Role |
Implemented |
SSH |
Status |
Implemented |
SSH |
Status Enum |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Vendor |
Implemented |
SSH |
Model |
Implemented |
SSH |
Type |
Gap |
SSH |
Type Enum |
Implemented |
SSH |
Group |
Implemented |
SSH |
File Share |
Name |
Implemented |
SSH |
Path |
Implemented |
SSH |
Path of the fileShare |
Qtree Id |
Implemented |
SSH |
unique id of the qtree |
Is InternalVolume |
Implemented |
SSH |
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume |
Is Shared |
Implemented |
SSH |
whether this fileShare has any shares associated with it |
Status |
Implemented |
SSH |
Info |
DataSource Name |
Implemented |
SSH |
Info |
Originator ID |
Implemented |
SSH |
Date |
Implemented |
SSH |
Originator Key |
Implemented |
SSH |
Api Name |
Implemented |
SSH |
Api Version |
Implemented |
SSH |
Client Api Name |
Implemented |
SSH |
Implemented |
SSH |
Internal Volume |
Internal Volume Id |
Implemented |
SSH |
Name |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Type |
Gap |
SSH |
Thin Provisioned |
Implemented |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Last Snapshot Time |
Implemented |
SSH |
time of last snapshot |
Snapshot Count |
Implemented |
SSH |
Number of snapshots on the internal volumes |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Total Used Capacity (MB) |
Implemented |
SSH |
place holder for the used capacity as read from the device |
Implemented |
SSH |
Implemented |
SSH |
Other Allocated Capacity |
Gap |
SSH |
Capacity allocated for other (not data and not snapshot) |
Implemented |
SSH |
GuidKey 1 |
Implemented |
SSH |
GuidKey 2 |
Implemented |
SSH |
Virtual Storage |
Implemented |
SSH |
QTree |
Qtree Id |
Implemented |
SSH |
Name |
Implemented |
SSH |
Type |
Gap |
SSH |
GuidKey 1 |
Implemented |
SSH |
GuidKey 2 |
Implemented |
SSH |
Quota HardCapacity Limit (MB) |
Implemented |
SSH |
Maximum amount of disk space, allowed for the quota target |
Implemented |
SSH |
Implemented |
SSH |
Quota |
Quota Id |
Implemented |
SSH |
unique id of the quota |
Type |
Gap |
SSH |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Soft File Limit |
Implemented |
SSH |
Hard Capacity Limit (MB) |
Implemented |
SSH |
max amount of disk space, allowed for the quota target (Hard limit) |
Implemented |
SSH |
Used Files |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
GuidKey 1 |
Implemented |
SSH |
GuidKey 2 |
Implemented |
SSH |
Share |
Name |
Implemented |
SSH |
Protocol |
Implemented |
SSH |
enum for share protocol |
IP Interfaces |
Implemented |
SSH |
comma separated list of IP addresses on which this share is exposed |
Share Initiator |
Initiator |
Implemented |
SSH |
Permission |
Implemented |
SSH |
Permissions for this particular share |
Storage |
IP |
Implemented |
SSH |
Display IP |
Implemented |
SSH |
Name |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Model |
Implemented |
SSH |
Family |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Microcode Version |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Manage URL |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Cpu Count |
Implemented |
SSH |
Storage Node |
UUID |
Implemented |
SSH |
Name |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Implemented |
SSH |
Storage Pool |
Storage Pool Id |
Implemented |
SSH |
Name |
Implemented |
SSH |
Type |
Gap |
SSH |
Status |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Raid Group |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Redundancy |
Implemented |
SSH |
Redundancy level |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Gap |
SSH |
Implemented |
SSH |
Gap |
SSH |
Volume |
Name |
Implemented |
SSH |
Junction Path |
Implemented |
SSH |
Type |
Gap |
SSH |
Disk Type |
Not Available |
SSH |
Thin Provisioned |
Implemented |
SSH |
Capacity |
Implemented |
SSH |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Redundancy |
Implemented |
SSH |
Redundancy level |
Meta |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
UUID |
Implemented |
SSH |
DiskGroup |
Implemented |
SSH |
Disk Group Type |
Volume Map |
LUN |
Implemented |
SSH |
Storage Port |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Volume Mask |
Storage Port |
Implemented |
SSH |
Initiator |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Volume Member |
Name |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Rank |
Implemented |
SSH |
Capacity |
Implemented |
SSH |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Redundancy |
Implemented |
SSH |
Redundancy level |
WWN Alias |
Source |
Implemented |
SSH |
Host Aliases |
Implemented |
SSH |
WWN |
Implemented |
SSH |
Object Type |
Implemented |
SSH |
IP |
Implemented |
SSH |
performance |
Disk |
Utilization Write |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
Read Utilization |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Disk |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Read Utilization |
Implemented |
SSH |
Utilization Write |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Storage |
Latency Total |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
Implemented |
SSH |
IOPs other |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Partial Blocked Ratio |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Storage |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Storage Node |
IOPs Read |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
StoragePool Disk |
Utilization Write |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
Read Utilization |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Total Capacity |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Volume |
Latency Total |
Implemented |
SSH |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
VNX SSH and CLI |
SSH |
SSH |
22 |
true |
false |
true |
true |
EMC VNXe & Unity Unisphere (CLI)
Unity 300 |
3.1.17.10229825 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Disk Group |
Capacity |
Implemented |
HTTPS |
DiskGroup Id |
Implemented |
HTTPS |
Disk Type |
Not Available |
HTTPS |
Name |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
ratio of dedupe savings in percentage |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Snapshot Count |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Share |
Description |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Memory Size |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Soft Limit (MB) |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Mode |
Implemented |
HTTPS |
Mode Enum |
Implemented |
HTTPS |
Source Storage |
Implemented |
HTTPS |
Source Volume |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
State Enum |
Implemented |
HTTPS |
Target Storage |
Implemented |
HTTPS |
Target Volume |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Node |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Capacity Soft Limit |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
VNXe & Unisphere CLI |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
EMC VPLEX
VPLEX |
6.2.0.04.00.07 |
foundation |
Info |
DataSource Name |
Implemented |
HTTP/S |
Info |
Date |
Implemented |
HTTP/S |
Originator ID |
Implemented |
HTTP/S |
Originator Key |
Implemented |
HTTP/S |
Storage |
Display IP |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Family |
Implemented |
HTTP/S |
IP |
Implemented |
HTTP/S |
Manage URL |
Implemented |
HTTP/S |
Manufacturer |
Implemented |
HTTP/S |
Microcode Version |
Implemented |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Storage Node |
Name |
Implemented |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
State |
Implemented |
HTTP/S |
UUID |
Implemented |
HTTP/S |
Storage Pool |
Dedupe Enabled |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Gap |
HTTP/S |
Implemented |
HTTP/S |
Raid Group |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Redundancy |
Implemented |
HTTP/S |
Redundancy level |
Status |
Implemented |
HTTP/S |
Storage Pool Id |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Volume |
Capacity |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Redundancy |
Implemented |
HTTP/S |
Redundancy level |
Storage Pool Id |
Implemented |
HTTP/S |
Thin Provisioned |
Implemented |
HTTP/S |
UUID |
Implemented |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Volume Map |
LUN |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Storage Port |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Volume Mask |
Initiator |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Storage Port |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
performance |
Storage |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Key |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Storage Node |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Key |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Storage Node Data |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
StoragePool Disk |
Implemented |
SSH |
Total Capacity |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Other Total Capacity |
Implemented |
SSH |
Implemented |
SSH |
Volume |
Raw Capacity |
Implemented |
SSH |
Total Capacity |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Key |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Volume |
Raw Capacity |
Implemented |
SSH |
Total Capacity |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
Key |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
EMC VPLEX CLI |
SSH |
SSH |
22 |
true |
true |
true |
true |
EMC VPLEX API |
HTTP/HTTPS |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
EMC XtremIO (HTTP)
6.2.1 |
1 Bricks & 125TB |
4.0.27-1 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Potential Transfer Rate |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Seek Time |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Speed of disk (RPM) |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Vendor Id |
Implemented |
HTTPS |
Info |
Api Version |
Implemented |
HTTPS |
Implemented |
HTTPS |
Client Api Name |
Implemented |
HTTPS |
Client Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Storage |
Cpu Count |
Implemented |
HTTPS |
Cpu Count of the storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
SupportActive Active |
Implemented |
HTTPS |
Specified if the storage supports active-active configurations |
Virtual |
Implemented |
HTTPS |
Storage Node |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
ManagementIp Addresses |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Mode |
Implemented |
HTTPS |
Mode Enum |
Implemented |
HTTPS |
Source Volume |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
State Enum |
Implemented |
HTTPS |
Target Volume |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Disk Size |
Implemented |
HTTPS |
Disk Speed |
Implemented |
HTTPS |
comma seperated list of disk speeds (rpm) |
Disk Type |
Not Available |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Storage Node |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage Node Data |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
EMC XtremIO REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
NetApp E-Series
2660 |
08.40.60.01 |
foundation |
Disk |
Capacity (GB) |
Implemented |
RMI |
Used capacity |
Disk Id |
Implemented |
RMI |
Group |
Implemented |
RMI |
Location |
Gap |
RMI |
Model |
Implemented |
RMI |
Name |
Implemented |
RMI |
Role |
Implemented |
RMI |
Role Enum |
Implemented |
RMI |
Serial Number |
Implemented |
RMI |
Speed |
Implemented |
RMI |
Status |
Implemented |
RMI |
Status Enum |
Implemented |
RMI |
Type |
Gap |
RMI |
Type Enum |
Implemented |
RMI |
Vendor |
Implemented |
RMI |
Vendor Id |
Implemented |
RMI |
IP |
Implemented |
RMI |
Listening Port |
Implemented |
RMI |
Nic |
Implemented |
RMI |
OID |
Implemented |
RMI |
OID |
Implemented |
RMI |
Portal Group Name |
Implemented |
RMI |
Portal Group Tag |
Implemented |
RMI |
ISCSI Node |
Host Aliases |
Implemented |
RMI |
Node Name |
Implemented |
RMI |
OID |
Implemented |
RMI |
Type |
Gap |
RMI |
ISCSI Session |
Initiator Ips |
Implemented |
RMI |
Initiator OID |
Implemented |
RMI |
Max Connections |
Implemented |
RMI |
Implemented |
RMI |
OID |
Implemented |
RMI |
Portal Group OID |
Implemented |
RMI |
Security |
Implemented |
RMI |
Target Session Id |
Implemented |
RMI |
Info |
DataSource Name |
Implemented |
RMI |
Info |
Date |
Implemented |
RMI |
Originator ID |
Implemented |
RMI |
Storage |
Display IP |
Implemented |
RMI |
Implemented |
RMI |
Family |
Implemented |
RMI |
IP |
Implemented |
RMI |
Manufacturer |
Implemented |
RMI |
Microcode Version |
Implemented |
RMI |
Model |
Implemented |
RMI |
Name |
Implemented |
RMI |
Implemented |
RMI |
Serial Number |
Implemented |
RMI |
Implemented |
RMI |
Virtual |
Implemented |
RMI |
Storage Node |
Cache Size |
Implemented |
RMI |
device cache size in MB |
Memory Size |
Gap |
RMI |
Model |
Implemented |
RMI |
Name |
Implemented |
RMI |
Serial Number |
Implemented |
RMI |
State |
Implemented |
RMI |
UUID |
Implemented |
RMI |
Up Time |
Implemented |
RMI |
time in milliseconds |
Storage Pool |
Gap |
RMI |
Implemented |
RMI |
Dedupe Enabled |
Implemented |
RMI |
Implemented |
RMI |
Name |
Implemented |
RMI |
Gap |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Raid Group |
Implemented |
RMI |
Implemented |
RMI |
Redundancy |
Implemented |
RMI |
Redundancy level |
Status |
Implemented |
RMI |
Storage Pool Id |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Type |
Gap |
RMI |
Virtual |
Implemented |
RMI |
Volume |
Capacity |
Implemented |
RMI |
Disk Type |
Not Available |
RMI |
Name |
Implemented |
RMI |
Implemented |
RMI |
Redundancy |
Implemented |
RMI |
Redundancy level |
Storage Pool Id |
Implemented |
RMI |
Thin Provisioned |
Implemented |
RMI |
Type |
Gap |
RMI |
UUID |
Implemented |
RMI |
Used Capacity |
Implemented |
RMI |
Virtual |
Implemented |
RMI |
Written Capacity |
Implemented |
RMI |
Volume Map |
LUN |
Implemented |
RMI |
Storage Port |
Implemented |
RMI |
Type |
Gap |
RMI |
Volume Mask |
Initiator |
Implemented |
RMI |
Storage Port |
Implemented |
RMI |
Type |
Gap |
RMI |
performance |
Disk |
IOPs Read |
Implemented |
RMI |
IOPs Total |
Implemented |
RMI |
IOPs Write |
Implemented |
RMI |
Throughput Read |
Implemented |
RMI |
Throughput Total |
Implemented |
RMI |
Throughput Write |
Implemented |
RMI |
Read Utilization |
Implemented |
RMI |
Utilization Total |
Implemented |
RMI |
Utilization Write |
Implemented |
RMI |
Disk |
IOPs Read |
Implemented |
RMI |
IOPs Total |
Implemented |
RMI |
IOPs Write |
Implemented |
RMI |
Key |
Implemented |
RMI |
Server ID |
Implemented |
RMI |
Throughput Read |
Implemented |
RMI |
Throughput Total |
Implemented |
RMI |
Throughput Write |
Implemented |
RMI |
Read Utilization |
Implemented |
RMI |
Utilization Total |
Implemented |
RMI |
Utilization Write |
Implemented |
RMI |
Storage |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Raw Capacity |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
IOPs other |
Implemented |
RMI |
IOPs Read |
Implemented |
RMI |
IOPs Total |
Implemented |
RMI |
IOPs Write |
Implemented |
RMI |
Latency Read |
Implemented |
RMI |
Latency Total |
Implemented |
RMI |
Latency Write |
Implemented |
RMI |
Throughput Read |
Implemented |
RMI |
Throughput Total |
Implemented |
RMI |
Throughput Write |
Implemented |
RMI |
Storage |
Implemented |
RMI |
Raw Capacity |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Key |
Implemented |
RMI |
Server ID |
Implemented |
RMI |
Storage Node |
Implemented |
RMI |
IOPs Read |
Implemented |
RMI |
IOPs Total |
Implemented |
RMI |
IOPs Write |
Implemented |
RMI |
Latency Read |
Implemented |
RMI |
Latency Total |
Implemented |
RMI |
Latency Write |
Implemented |
RMI |
Throughput Read |
Implemented |
RMI |
Throughput Total |
Implemented |
RMI |
Throughput Write |
Implemented |
RMI |
StoragePool Disk |
Implemented |
RMI |
Raw Capacity |
Implemented |
RMI |
Total Capacity |
Implemented |
RMI |
Used Capacity |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
IOPs Read |
Implemented |
RMI |
IOPs Total |
Implemented |
RMI |
IOPs Write |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Throughput Read |
Implemented |
RMI |
Throughput Total |
Implemented |
RMI |
Throughput Write |
Implemented |
RMI |
Read Utilization |
Implemented |
RMI |
Utilization Total |
Implemented |
RMI |
Utilization Write |
Implemented |
RMI |
Volume |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
Raw Capacity |
Implemented |
RMI |
Total Capacity |
Implemented |
RMI |
Used Capacity |
Implemented |
RMI |
Written Capacity |
Implemented |
RMI |
Implemented |
RMI |
Implemented |
RMI |
IOPs Read |
Implemented |
RMI |
IOPs Total |
Implemented |
RMI |
IOPs Write |
Implemented |
RMI |
Latency Read |
Implemented |
RMI |
Latency Total |
Implemented |
RMI |
Latency Write |
Implemented |
RMI |
Throughput Read |
Implemented |
RMI |
Throughput Total |
Implemented |
RMI |
Throughput Write |
Implemented |
RMI |
SANtricity API |
RMI |
TCP |
true |
true |
false |
false |
Pure Storage FlashBlade REST
Models and versions supported by this data collector:
FlashBlade |
Purity//FB 4.1.5 |
Products supported by this data collector:
Product | Category | Feature/Attribute | Status | Protocol Used | Additional Information |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Uniquely identifies this disk in the array |
Location |
Gap |
HTTPS |
Where this disk is physically located in the array |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
enum for disk type |
Vendor |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Share |
Description |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Failed Raw Capacity |
Implemented |
HTTPS |
Raw capacity of failed disks (sum of all disks that are failed) |
Family |
Implemented |
HTTPS |
The storage Family could be Clariion, Symmetrix, et al |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Total Raw Capacity |
Implemented |
HTTPS |
Total raw capacity (sum of all disks on the array) |
Serial Number |
Implemented |
HTTPS |
Spare Raw Capacity |
Implemented |
HTTPS |
Raw capacity of spare disks (sum of all disks that are spare) |
Virtual |
Implemented |
HTTPS |
Is this a storage virtualization device? |
UUID |
Implemented |
HTTPS |
Storage Node |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
free text describing the device state |
UUID |
Implemented |
HTTPS |
Node Capacity Utilization Total in MB |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Data Used Capacity |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Include In Dwh Capacity |
Implemented |
HTTPS |
A way from ACQ to control which storage pools are interesting in DWH Capacity |
Name |
Implemented |
HTTPS |
Physical Disk Capacity (MB) |
Implemented |
HTTPS |
used as raw capacity for storage pool |
Raid Group |
Implemented |
HTTPS |
indicates whether this storagePool is a raid group |
Raw to Usable Ratio |
Implemented |
HTTPS |
ratio to convert from usable capacity to raw capacity |
Snapshot Used Capacity |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioning Supported |
Implemented |
HTTPS |
Whether this internal volume supports thin provisioning for the volume layer on top of it |
Total Allocated Capacity |
Implemented |
HTTPS |
Total Used Capacity |
Implemented |
HTTPS |
Total capacity in MB |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
performance |
Internal Volume |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Average disk total rate (read and write across all disks) in MB/s |
Latency Read |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Number of read IOPs on the disk |
IOPs Write |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
StoragePools Capacity |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Pure Storage FlashBlade API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Google Cloud Compute
API versions:
v1
foundation |
Data Store |
Capacity |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Provisioned Capacity |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
subscription Id |
Implemented |
HTTPS |
Server |
DataCenter Name |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
Virtual Disk |
Capacity |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
subscription Id |
Implemented |
HTTPS |
VirtualMachine |
Guest State |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OS |
Implemented |
HTTPS |
Power State |
Implemented |
HTTPS |
State Change Time |
Implemented |
HTTPS |
Processors |
Implemented |
HTTPS |
Implemented |
HTTPS |
Instance Type |
Implemented |
HTTPS |
Launch Time |
Implemented |
HTTPS |
public Ips |
Implemented |
HTTPS |
subscription Id |
Implemented |
HTTPS |
VirtualMachine Disk |
OID |
Implemented |
HTTPS |
VirtualDisk OID |
Implemented |
HTTPS |
VirtualMachine OID |
Implemented |
HTTPS |
Host |
Host OS |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Info |
Api Description |
Implemented |
HTTPS |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
performance |
vm |
Total Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total CPU Utilization |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
diskIops.total |
Implemented |
HTTPS |
Disk IOPs write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Disk Throughput Read |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
total disk throughput read |
Disk Throughput Write |
Implemented |
HTTPS |
IP Throughput Read |
Implemented |
HTTPS |
Throughput total |
Implemented |
HTTPS |
IP throughput total |
ipThroughput.write |
Implemented |
HTTPS |
Total Memory Utilization |
Implemented |
HTTPS |
swapRate.inRate |
Implemented |
HTTPS |
Swap Rate |
Implemented |
HTTPS |
Total Swap Rate |
Implemented |
HTTPS |
Schedule wait time |
Implemented |
HTTPS |
Waiting to be scheduled time in percent |
VM |
Total Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Google Compute Platform REST API |
HTTPS |
443 |
true |
true |
true |
true |
Google Cloud Netapp Volumes
foundation |
File Share |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Is InternalVolume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Security Type |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Originator ID |
Implemented |
HTTPS |
Date |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Is dedupe enabled on the storage pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Snapshot Count |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Protection Type |
Implemented |
HTTPS |
Implemented |
HTTPS |
Snapshot Allocated Capacity |
Gap |
HTTPS |
Allocated capacity of snapshots in MB |
Implemented |
HTTPS |
Data Allocated Capacity |
Gap |
HTTPS |
capacity allocated for data |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Tiering Minimum Cooling Days |
Implemented |
HTTPS |
QoS - Policy |
Implemented |
HTTPS |
Implemented |
HTTPS |
Comment |
Gap |
HTTPS |
state: free text comment describing the svm |
Qos Limit Raw |
Implemented |
HTTPS |
QTree |
Qtree Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Security Style |
Implemented |
HTTPS |
Security style of the directory: unix, ntfs, or mixed |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Share |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Storage |
IP |
Implemented |
HTTPS |
Display IP |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool |
Storage Pool Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Status |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Vendor Tier |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
performance |
Internal Volume |
Latency Total |
Implemented |
HTTPS |
Object Store Space Used |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
Reported as a time series |
Latency Write |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Capacity Used Ratio |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage |
Latency Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Capacity Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Over Commit Capacity Ratio |
Implemented |
HTTPS |
Management APIs used by this data collector:
API | Protocol Used | Transport layer protocol used | Incoming ports used | Outgoing ports used | Supports authentication | Requires only 'Read-only' credentials | Supports Encryption | Firewall friendly (static ports) |
HTTPS |
443 |
true |
true |
true |
true |
HDS HCP (HTTPS)
Hitachi Content Platform |
9.6.2.37 |
foundation |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Name |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Soft Limit (MB) |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
performance |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Storage Node Data |
Key |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
HDS HCP REST API |
HTTPS |
HTTPS |
9090 |
true |
true |
true |
true |
HiCommand Device Manager
7.6.1 |
DF850MH |
0983/A-H |
foundation |
Disk |
Capacity (GB) |
Implemented |
HDS XML API |
Used capacity |
Disk Id |
Implemented |
HDS XML API |
Group |
Implemented |
HDS XML API |
Location |
Gap |
HDS XML API |
Model |
Implemented |
HDS XML API |
Name |
Implemented |
HDS XML API |
Role |
Implemented |
HDS XML API |
Role Enum |
Implemented |
HDS XML API |
enum for disk role |
Serial Number |
Implemented |
HDS XML API |
Speed |
Implemented |
HDS XML API |
Type |
Gap |
HDS XML API |
Type Enum |
Implemented |
HDS XML API |
Vendor |
Implemented |
HDS XML API |
Vendor Id |
Implemented |
HDS XML API |
Disk Group |
Capacity |
Implemented |
HDS XML API |
Snapshot Used capacity in MB |
DiskGroup Id |
Implemented |
HDS XML API |
unique id of the disk group |
Disk Type |
Not Available |
HDS XML API |
Name |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Redundancy |
Implemented |
HDS XML API |
Redundancy level |
Status |
Implemented |
HDS XML API |
Used Capacity |
Implemented |
HDS XML API |
Vendor DiskGroup Type |
Implemented |
HDS XML API |
vendor's designation of the disk group type |
Vendor Tier |
Implemented |
HDS XML API |
Virtual |
Implemented |
HDS XML API |
Info |
Api Name |
Implemented |
HDS XML API |
Api Version |
Implemented |
HDS XML API |
DataSource Name |
Implemented |
HDS XML API |
Info |
Date |
Implemented |
HDS XML API |
Originator ID |
Implemented |
HDS XML API |
Originator Key |
Implemented |
HDS XML API |
Network Pipe |
Source Id |
Implemented |
HDS XML API |
Target Id |
Implemented |
HDS XML API |
Bidirectional |
Implemented |
HDS XML API |
Protocol EndPoint |
ID |
Implemented |
HDS XML API |
Name |
Implemented |
HDS XML API |
Storage Ip |
Implemented |
HDS XML API |
Storage |
Display IP |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Family |
Implemented |
HDS XML API |
IP |
Implemented |
HDS XML API |
Manage URL |
Implemented |
HDS XML API |
Manufacturer |
Implemented |
HDS XML API |
Microcode Version |
Implemented |
HDS XML API |
Model |
Implemented |
HDS XML API |
Name |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Serial Number |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Virtual |
Implemented |
HDS XML API |
Storage Node |
Name |
Implemented |
HDS XML API |
UUID |
Implemented |
HDS XML API |
Storage Pool |
Auto Tiering |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Compression Savings |
Implemented |
HDS XML API |
ratio of compression savings in percentage |
Dedupe Enabled |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Name |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Raid Group |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Redundancy |
Implemented |
HDS XML API |
Redundancy level |
Soft Limit (MB) |
Implemented |
HDS XML API |
Status |
Implemented |
HDS XML API |
Storage Pool Id |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Type |
Gap |
HDS XML API |
Virtual |
Implemented |
HDS XML API |
Storage Synchronization |
Mode |
Implemented |
HDS XML API |
Mode Enum |
Implemented |
HDS XML API |
Source Storage |
Implemented |
HDS XML API |
Source Volume |
Implemented |
HDS XML API |
State |
Implemented |
HDS XML API |
State Enum |
Implemented |
HDS XML API |
Target Storage |
Implemented |
HDS XML API |
Target Volume |
Implemented |
HDS XML API |
Technology |
Implemented |
HDS XML API |
technology which causes storage efficiency changed |
Volume |
Implemented |
HDS XML API |
Auto Tiering |
Implemented |
HDS XML API |
indicates if this storagepool is participating in auto tiering with other pools |
Capacity |
Implemented |
HDS XML API |
Junction Path |
Implemented |
HDS XML API |
Mainframe |
Implemented |
HDS XML API |
Meta |
Implemented |
HDS XML API |
Flag saying whether this volume is a meta volume with memeber or not. Meta volumes will have DiskGroup empty! |
Name |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Redundancy |
Implemented |
HDS XML API |
Redundancy level |
Replica Source |
Implemented |
HDS XML API |
Replica Target |
Implemented |
HDS XML API |
Storage Pool Id |
Implemented |
HDS XML API |
Thin Provisioned |
Implemented |
HDS XML API |
Type |
Gap |
HDS XML API |
Used Capacity |
Implemented |
HDS XML API |
Volume Map |
LUN |
Implemented |
HDS XML API |
Name of the backend lun |
Masking Required |
Implemented |
HDS XML API |
Protocol Controller |
Implemented |
HDS XML API |
Storage Port |
Implemented |
HDS XML API |
Volume Mask |
Initiator |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Storage Port |
Implemented |
HDS XML API |
Volume Member |
Capacity |
Implemented |
HDS XML API |
Cylinders |
Implemented |
HDS XML API |
Name |
Implemented |
HDS XML API |
Rank |
Implemented |
HDS XML API |
Implemented |
HDS XML API |
Storage Pool Id |
Implemented |
HDS XML API |
Used Capacity |
Implemented |
HDS XML API |
WWN Alias |
Host Aliases |
Implemented |
HDS XML API |
Object Type |
Implemented |
HDS XML API |
Source |
Implemented |
HDS XML API |
WWN |
Implemented |
HDS XML API |
performance |
Disk |
Utilization Total |
Implemented |
Export/CLI |
IOPs Read |
Implemented |
Export/CLI |
IOPs Write |
Implemented |
Export/CLI |
Throughput Read |
Implemented |
Export/CLI |
Throughput Write |
Implemented |
Export/CLI |
Throughput Total |
Implemented |
Export/CLI |
IOPs Total |
Implemented |
Export/CLI |
Disk |
IOPs Read |
Implemented |
Export/CLI |
IOPs Total |
Implemented |
Export/CLI |
IOPs Write |
Implemented |
Export/CLI |
Key |
Implemented |
Export/CLI |
Server ID |
Implemented |
Export/CLI |
Throughput Read |
Implemented |
Export/CLI |
Throughput Total |
Implemented |
Export/CLI |
Throughput Write |
Implemented |
Export/CLI |
Utilization Total |
Implemented |
Export/CLI |
Storage |
Latency Total |
Implemented |
Export/CLI |
Latency Read |
Implemented |
Export/CLI |
IOPs other |
Implemented |
Export/CLI |
IOPs Write |
Implemented |
Export/CLI |
Throughput Read |
Implemented |
Export/CLI |
IOPs Total |
Implemented |
Export/CLI |
Latency Write |
Implemented |
Export/CLI |
IOPs Read |
Implemented |
Export/CLI |
Write Pending |
Implemented |
Export/CLI |
total write pending |
Cache Hit Ratio Read |
Implemented |
Export/CLI |
Cache Utilization Total |
Implemented |
Export/CLI |
Cache Hit Ratio Total |
Implemented |
Export/CLI |
Cache Hit Ratio Write |
Implemented |
Export/CLI |
Throughput Write |
Implemented |
Export/CLI |
Throughput Total |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Raw Capacity |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Storage |
Key |
Implemented |
Export/CLI |
Server ID |
Implemented |
Export/CLI |
Raw Capacity |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Storage Node |
Latency Total |
Implemented |
Export/CLI |
Throughput Total |
Implemented |
Export/CLI |
IOPs Total |
Implemented |
Export/CLI |
Storage Node Data |
Key |
Implemented |
Export/CLI |
Server ID |
Implemented |
Export/CLI |
StoragePool Disk |
Implemented |
Export/CLI |
Raw Capacity |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Total Capacity |
Implemented |
Export/CLI |
Used Capacity |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
IOPs Read |
Implemented |
Export/CLI |
IOPs Total |
Implemented |
Export/CLI |
IOPs Write |
Implemented |
Export/CLI |
Throughput Read |
Implemented |
Export/CLI |
Throughput Total |
Implemented |
Export/CLI |
Throughput Write |
Implemented |
Export/CLI |
Utilization Total |
Implemented |
Export/CLI |
Volume |
Latency Total |
Implemented |
Export/CLI |
IOPs Read |
Implemented |
Export/CLI |
Latency Read |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
IOPs Write |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Throughput Read |
Implemented |
Export/CLI |
Throughput Write |
Implemented |
Export/CLI |
Throughput Total |
Implemented |
Export/CLI |
IOPs Total |
Implemented |
Export/CLI |
Latency Write |
Implemented |
Export/CLI |
Total Capacity |
Implemented |
Export/CLI |
Raw Capacity |
Implemented |
Export/CLI |
Used Capacity |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Volume |
Key |
Implemented |
Export/CLI |
Server ID |
Implemented |
Export/CLI |
Total Capacity |
Implemented |
Export/CLI |
Raw Capacity |
Implemented |
Export/CLI |
Used Capacity |
Implemented |
Export/CLI |
Implemented |
Export/CLI |
Export utility (USPV) / SNM CLI (AMS) |
Export/CLI |
false |
false |
false |
false |
HiCommand Device Manager XML API |
HDS XML API |
HTTP/HTTPS |
2001 |
true |
true |
true |
true |
Hitachi Ops Center
Models | Firmware versions |
VSP 5100 |
80-06-91-00/00:01-71-03/02 |
foundation |
Disk |
Capacity (GB) |
Implemented |
Used capacity |
Disk Id |
Implemented |
Group |
Implemented |
Location |
Gap |
Model |
Implemented |
Name |
Implemented |
Implemented |
Role |
Implemented |
Role Enum |
Implemented |
Seek Time |
Implemented |
Serial Number |
Implemented |
Speed |
Implemented |
Status Enum |
Implemented |
enum for disk status |
Type Enum |
Implemented |
Vendor |
Implemented |
Disk Group |
Capacity |
Implemented |
DiskGroup Id |
Implemented |
Disk Type |
Not Available |
Name |
Implemented |
Implemented |
Redundancy |
Implemented |
Redundancy level |
Status |
Implemented |
Used Capacity |
Implemented |
Implemented |
Virtual |
Implemented |
ISCSI Network Portal |
IP |
Implemented |
Listening Port |
Implemented |
Nic |
Implemented |
OID |
Implemented |
ISCSI Network Portal Group |
OID |
Implemented |
Portal Group Name |
Implemented |
Portal Group Tag |
Implemented |
ISCSI Node |
Node Name |
Implemented |
OID |
Implemented |
Type |
Gap |
ISCSI Node Map |
OID |
Implemented |
Portal Group OID |
Implemented |
ISCSI Session |
Initiator Ips |
Implemented |
Initiator OID |
Implemented |
Max Connections |
Implemented |
Number Of Connections |
Implemented |
OID |
Implemented |
Portal Group OID |
Implemented |
Security |
Implemented |
Info |
DataSource Name |
Implemented |
Info |
Date |
Implemented |
Originator ID |
Implemented |
Originator Key |
Implemented |
Storage |
Display IP |
Implemented |
Implemented |
Family |
Implemented |
IP |
Implemented |
Manage URL |
Implemented |
Manufacturer |
Implemented |
Microcode Version |
Implemented |
Model |
Implemented |
Name |
Implemented |
Implemented |
Serial Number |
Implemented |
Implemented |
Implemented |
Virtual |
Implemented |
Storage Node |
Name |
Implemented |
UUID |
Implemented |
Storage Pool |
Compression Enabled |
Implemented |
Is compression enabled on the storage pool |
Implemented |
Dedupe Enabled |
Implemented |
Implemented |
Name |
Implemented |
Implemented |
Raid Group |
Implemented |
Implemented |
Redundancy |
Implemented |
Redundancy level |
Soft Limit (MB) |
Implemented |
logical volume size that is defined during volume creation or resizing operations |
Status |
Implemented |
Storage Pool Id |
Implemented |
Implemented |
Implemented |
Implemented |
Type |
Gap |
Virtual |
Implemented |
Encrypted |
Implemented |
Mode |
Implemented |
Mode Enum |
Implemented |
Source Storage |
Implemented |
Source Volume |
Implemented |
State |
Implemented |
State Enum |
Implemented |
Target Storage |
Implemented |
Target Volume |
Implemented |
Technology |
Implemented |
Volume |
Capacity |
Implemented |
Junction Path |
Implemented |
Name |
Implemented |
Protection Type |
Implemented |
Implemented |
Storage Pool Id |
Implemented |
Thin Provisioned |
Implemented |
Type |
Gap |
Used Capacity |
Implemented |
Implemented |
Volume Map |
LUN |
Implemented |
Masking Required |
Implemented |
Implemented |
Storage Port |
Implemented |
Type |
Gap |
Volume Mask |
Initiator |
Implemented |
Implemented |
Storage Port |
Implemented |
Type |
Gap |
performance |
Disk |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage |
Implemented |
Implemented |
Implemented |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage |
Implemented |
Implemented |
Implemented |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage Node |
IOPs Total |
Implemented |
Throughput Total |
Implemented |
Storage Node Data |
IOPs Total |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Throughput Total |
Implemented |
StoragePool Disk |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
Volume |
Latency Total |
Implemented |
Total Capacity |
Implemented |
Latency Read |
Implemented |
IOPs Write |
Implemented |
Raw Capacity |
Implemented |
Used Capacity |
Implemented |
Throughput Read |
Implemented |
IOPs Total |
Implemented |
Latency Write |
Implemented |
IOPs Read |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Throughput Write |
Implemented |
Throughput Total |
Implemented |
Volume |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Hitachi Ops Center REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
HDS HNAS (CLI)
File 34 |
14.6.7520.04 |
foundation |
Disk Group |
Capacity |
Implemented |
SSH |
DiskGroup Id |
Implemented |
SSH |
Name |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Vendor Tier |
Implemented |
SSH |
Vendor Specific Tier Name |
Virtual |
Implemented |
SSH |
File Share |
Is InternalVolume |
Implemented |
SSH |
Is Shared |
Implemented |
SSH |
Name |
Implemented |
SSH |
Path |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Info |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
Originator Key |
Implemented |
SSH |
Internal Volume |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Status |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioned |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Virtual Storage |
Implemented |
SSH |
Owning virtual storage (vfiler) |
QTree |
Name |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Implemented |
SSH |
Quota SoftCapacity Limit (MB) |
Implemented |
SSH |
Quota UsedCapacity |
Implemented |
SSH |
Space in MB currently used |
Type |
Gap |
SSH |
Quota |
Implemented |
SSH |
Hard File Limit |
Implemented |
SSH |
max number of files allowed for the quota target |
Implemented |
SSH |
Qtree Id |
Implemented |
SSH |
Quota Id |
Implemented |
SSH |
Soft Capacity Limit (MB) |
Implemented |
SSH |
Soft File Limit |
Implemented |
SSH |
Max number of files allowed for the quota target |
Type |
Gap |
SSH |
Used Capacity |
Implemented |
SSH |
Used Files |
Implemented |
SSH |
Number of files currently used |
User/Group Target |
Implemented |
SSH |
user/group target this quota refers to |
Share |
Description |
Implemented |
SSH |
IP Interfaces |
Implemented |
SSH |
Name |
Implemented |
SSH |
Protocol |
Implemented |
SSH |
Share Initiator |
Initiator |
Implemented |
SSH |
Permission |
Implemented |
SSH |
Storage |
Cpu Count |
Implemented |
SSH |
Display IP |
Implemented |
SSH |
Implemented |
SSH |
Family |
Implemented |
SSH |
IP |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Microcode Version |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Storage Node |
Memory Size |
Gap |
SSH |
device memory in MB |
Name |
Implemented |
SSH |
Processors Count |
Implemented |
SSH |
device CPU |
Serial Number |
Implemented |
SSH |
State |
Implemented |
SSH |
UUID |
Implemented |
SSH |
Version |
Implemented |
SSH |
software version |
Storage Pool |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Raid Group |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Virtual |
Implemented |
SSH |
HDS HNAS CLI |
SSH |
SSH |
22 |
true |
true |
true |
true |
HPE Nimble / Alletra 6000 Storage
API versions | Models | Firmware versions |
v1 |
5050 |
5.0.8.0-677726-opt |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Seek Time |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Info |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Name |
Implemented |
HTTPS |
Partner Node UUID |
Implemented |
HTTPS |
HA pair's UUID |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Parent Serial Number |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Reserved Capacity |
Implemented |
HTTPS |
Reserved Capacity in MB |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Masking Required |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
WWN Alias |
Host Aliases |
Implemented |
HTTPS |
Object Type |
Implemented |
HTTPS |
Source |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
performance |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
StoragePool Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Compression Savings |
Implemented |
HTTPS |
Compression Savings Space |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
HP Nimble REST API |
HTTPS |
HTTPS |
5392 |
true |
false |
true |
true |
Huawei OceanStor (REST/HTTPS)
18800 V5 |
V300R001C01 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
File Share |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Path of the fileShare |
Qtree Id |
Implemented |
HTTPS |
unique id of the qtree |
Is InternalVolume |
Implemented |
HTTPS |
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume |
Is Shared |
Implemented |
HTTPS |
whether this fileShare has any shares associated with it |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Internal Volume Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
QTree |
Qtree Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Quota HardCapacity Limit (MB) |
Implemented |
HTTPS |
Maximum amount of disk space, allowed for the quota target |
Implemented |
HTTPS |
Implemented |
HTTPS |
Quota |
Quota Id |
Implemented |
HTTPS |
unique id of the quota |
Type |
Gap |
HTTPS |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Hard File Limit |
Implemented |
HTTPS |
Soft File Limit |
Implemented |
HTTPS |
Hard Capacity Limit (MB) |
Implemented |
HTTPS |
max amount of disk space, allowed for the quota target (Hard limit) |
Implemented |
HTTPS |
Used Files |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
User/Group Target |
Implemented |
HTTPS |
Share |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
enum for share protocol |
Description |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
comma separated list of IP addresses on which this share is exposed |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Permissions for this particular share |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Name |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Internal Volume |
Latency Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Snapshot Used Capacity Ratio |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage Node |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Node Data |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Volume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Volume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Huawei OceanStor REST API |
HTTPS |
HTTPS |
8088 |
true |
true |
true |
true |
Huawei OceanStor Performance REST API |
HTTPS |
HTTPS |
8088 |
true |
false |
true |
true |
IBM Cleversafe
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Protection Type |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Comment |
Gap |
HTTPS |
Status |
Implemented |
HTTPS |
QTree |
Qtree Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
IBM Cleversafe REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
IBM DS 8K (DSCLI)
2107-951 |
foundation |
Disk |
Capacity (GB) |
Implemented |
DSNI |
Used capacity |
Disk Id |
Implemented |
DSNI |
Group |
Implemented |
DSNI |
Location |
Gap |
DSNI |
Model |
Implemented |
DSNI |
Name |
Implemented |
Manual Entry |
Role |
Implemented |
DSNI |
Role Enum |
Implemented |
DSNI |
Speed |
Implemented |
DSNI |
Speed of disk (RPM) |
Status |
Implemented |
DSNI |
Type |
Gap |
DSNI |
Type Enum |
Implemented |
DSNI |
Vendor |
Implemented |
DSNI |
Vendor Id |
Implemented |
DSNI |
Info |
DataSource Name |
Implemented |
DSNI |
Info |
Date |
Implemented |
DSNI |
Originator ID |
Implemented |
DSNI |
Originator Key |
Implemented |
DSNI |
Storage |
Display IP |
Implemented |
DSNI |
Implemented |
DSNI |
Family |
Implemented |
DSNI |
IP |
Implemented |
DSNI |
Manage URL |
Implemented |
DSNI |
Manufacturer |
Implemented |
DSNI |
Microcode Version |
Implemented |
DSNI |
Model |
Implemented |
DSNI |
Name |
Implemented |
Manual Entry |
Implemented |
DSNI |
Serial Number |
Implemented |
DSNI |
Implemented |
DSNI |
Virtual |
Implemented |
DSNI |
Storage Pool |
Gap |
DSNI |
Implemented |
DSNI |
Dedupe Enabled |
Implemented |
DSNI |
Implemented |
DSNI |
Name |
Implemented |
Manual Entry |
Implemented |
DSNI |
Raid Group |
Implemented |
DSNI |
Implemented |
DSNI |
Redundancy |
Implemented |
DSNI |
Redundancy level |
Status |
Implemented |
DSNI |
Storage Pool Id |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Type |
Gap |
DSNI |
Virtual |
Implemented |
DSNI |
Volume |
Capacity |
Implemented |
DSNI |
Disk Type |
Not Available |
DSNI |
Junction Path |
Implemented |
DSNI |
Name |
Implemented |
Manual Entry |
Implemented |
DSNI |
Storage Pool Id |
Implemented |
DSNI |
Thin Provisioned |
Implemented |
DSNI |
Type |
Gap |
DSNI |
Used Capacity |
Implemented |
DSNI |
Volume Map |
LUN |
Implemented |
DSNI |
Implemented |
DSNI |
Storage Port |
Implemented |
DSNI |
Volume Mask |
Initiator |
Implemented |
DSNI |
Implemented |
DSNI |
Storage Port |
Implemented |
DSNI |
WWN Alias |
Host Aliases |
Implemented |
DSNI |
Host OS |
Implemented |
DSNI |
Object Type |
Implemented |
DSNI |
Source |
Implemented |
DSNI |
WWN |
Implemented |
DSNI |
performance |
Disk |
Utilization Write |
Implemented |
DSNI |
IOPs Read |
Implemented |
DSNI |
Read Utilization |
Implemented |
DSNI |
IOPs Write |
Implemented |
DSNI |
Throughput Read |
Implemented |
DSNI |
Throughput Write |
Implemented |
DSNI |
Throughput Total |
Implemented |
DSNI |
IOPs Total |
Implemented |
DSNI |
Utilization Total |
Implemented |
DSNI |
Disk |
IOPs Read |
Implemented |
DSNI |
IOPs Total |
Implemented |
DSNI |
IOPs Write |
Implemented |
DSNI |
Key |
Implemented |
DSNI |
Server ID |
Implemented |
DSNI |
Throughput Read |
Implemented |
DSNI |
Throughput Total |
Implemented |
DSNI |
Throughput Write |
Implemented |
DSNI |
Read Utilization |
Implemented |
DSNI |
Utilization Total |
Implemented |
DSNI |
Utilization Write |
Implemented |
DSNI |
Storage |
Latency Total |
Implemented |
DSNI |
Latency Read |
Implemented |
DSNI |
IOPs other |
Implemented |
DSNI |
IOPs Write |
Implemented |
DSNI |
Throughput Read |
Implemented |
DSNI |
IOPs Total |
Implemented |
DSNI |
Latency Write |
Implemented |
DSNI |
IOPs Read |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Throughput Write |
Implemented |
DSNI |
Throughput Total |
Implemented |
DSNI |
Storage |
Implemented |
DSNI |
Raw Capacity |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Key |
Implemented |
DSNI |
Server ID |
Implemented |
DSNI |
StoragePool Disk |
Utilization Write |
Implemented |
DSNI |
IOPs Read |
Implemented |
DSNI |
Read Utilization |
Implemented |
DSNI |
IOPs Write |
Implemented |
DSNI |
Throughput Read |
Implemented |
DSNI |
Throughput Write |
Implemented |
DSNI |
Throughput Total |
Implemented |
DSNI |
IOPs Total |
Implemented |
DSNI |
Utilization Total |
Implemented |
DSNI |
Total Capacity |
Implemented |
DSNI |
Used Capacity |
Implemented |
DSNI |
Raw Capacity |
Implemented |
DSNI |
Implemented |
DSNI |
Total Data Capacity |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Volume |
Latency Total |
Implemented |
DSNI |
IOPs Read |
Implemented |
DSNI |
Latency Read |
Implemented |
DSNI |
Implemented |
DSNI |
IOPs Write |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Throughput Read |
Implemented |
DSNI |
Throughput Write |
Implemented |
DSNI |
Throughput Total |
Implemented |
DSNI |
IOPs Total |
Implemented |
DSNI |
Latency Write |
Implemented |
DSNI |
Total Capacity |
Implemented |
DSNI |
Raw Capacity |
Implemented |
DSNI |
Used Capacity |
Implemented |
DSNI |
Implemented |
DSNI |
Volume |
Implemented |
DSNI |
Implemented |
DSNI |
Implemented |
DSNI |
Raw Capacity |
Implemented |
DSNI |
Total Capacity |
Implemented |
DSNI |
Used Capacity |
Implemented |
DSNI |
Implemented |
DSNI |
IOPs Read |
Implemented |
DSNI |
IOPs Total |
Implemented |
DSNI |
IOPs Write |
Implemented |
DSNI |
Key |
Implemented |
DSNI |
Latency Read |
Implemented |
DSNI |
Latency Total |
Implemented |
DSNI |
Latency Write |
Implemented |
DSNI |
Server ID |
Implemented |
DSNI |
Throughput Read |
Implemented |
DSNI |
Throughput Total |
Implemented |
DSNI |
Throughput Write |
Implemented |
DSNI |
Data source wizard configuration |
Manual Entry |
true |
true |
true |
true |
IBM DS CLI |
DSNI |
DSNI |
true |
true |
true |
true |
IBM PowerVM (SSH)
foundation |
Data Store |
Capacity |
Implemented |
SSH |
MOID |
Implemented |
SSH |
Name |
Implemented |
SSH |
OID |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Virtual Center Ip |
Implemented |
SSH |
LUN |
Disk Name |
Implemented |
SSH |
DataStore OID |
Implemented |
SSH |
Host OID |
Implemented |
SSH |
Number |
Implemented |
SSH |
OID |
Implemented |
SSH |
Path |
Active |
Implemented |
SSH |
Lun OID |
Implemented |
SSH |
Host Port WWPN |
Implemented |
SSH |
OID |
Implemented |
SSH |
Storage Port WWPN |
Implemented |
SSH |
Type |
Gap |
SSH |
Server |
Host OID |
Implemented |
SSH |
MOID |
Implemented |
SSH |
OID |
Implemented |
SSH |
Virtual Center Ip |
Implemented |
SSH |
Virtual Disk |
Capacity |
Implemented |
SSH |
DataStore OID |
Implemented |
SSH |
Lun OID |
Implemented |
SSH |
Name |
Implemented |
SSH |
OID |
Implemented |
SSH |
Type |
Gap |
SSH |
VirtualMachine |
Dns Name |
Implemented |
SSH |
Guest State |
Implemented |
SSH |
Host OID |
Implemented |
SSH |
IPs |
Implemented |
SSH |
MOID |
Implemented |
SSH |
Memory |
Implemented |
SSH |
Name |
Implemented |
SSH |
OID |
Implemented |
SSH |
OS |
Implemented |
SSH |
Power State |
Implemented |
SSH |
State Change Time |
Implemented |
SSH |
Processors |
Implemented |
SSH |
OID |
Implemented |
SSH |
VirtualDisk OID |
Implemented |
SSH |
Implemented |
SSH |
Host |
Host Cpu Count |
Implemented |
SSH |
Host Installed Memory |
Implemented |
SSH |
Host Model |
Implemented |
SSH |
NIC count |
Implemented |
SSH |
IPs |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Name |
Implemented |
SSH |
OID |
Implemented |
SSH |
Platform Type |
Implemented |
SSH |
Info |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
IBM Hardware Management Console SSH access |
SSH |
SSH |
22 |
true |
false |
true |
true |
IBM SVC (CLI)
2072-12F |
1.5.2.7 |
foundation |
Disk |
Capacity (GB) |
Implemented |
SSH |
Used capacity |
Disk Id |
Implemented |
SSH |
Group |
Implemented |
SSH |
Location |
Gap |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Role |
Implemented |
SSH |
Role Enum |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Speed |
Implemented |
SSH |
Status |
Implemented |
SSH |
Type |
Gap |
SSH |
Type Enum |
Implemented |
SSH |
Vendor |
Implemented |
SSH |
Vendor Id |
Implemented |
SSH |
Info |
DataSource Name |
Implemented |
SSH |
Info |
Date |
Implemented |
SSH |
Originator ID |
Implemented |
SSH |
Storage |
Display IP |
Implemented |
SSH |
Implemented |
SSH |
Family |
Implemented |
SSH |
IP |
Implemented |
SSH |
Manage URL |
Implemented |
SSH |
Manufacturer |
Implemented |
SSH |
Microcode Version |
Implemented |
SSH |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Serial Number |
Implemented |
SSH |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Storage Node |
Model |
Implemented |
SSH |
Name |
Implemented |
SSH |
Partner Node UUID |
Implemented |
SSH |
HA pair's UUID |
Serial Number |
Implemented |
SSH |
State |
Implemented |
SSH |
UUID |
Implemented |
SSH |
Implemented |
SSH |
Storage Pool |
Implemented |
SSH |
Implemented |
SSH |
Dedupe Enabled |
Implemented |
SSH |
Implemented |
SSH |
Name |
Implemented |
SSH |
Implemented |
SSH |
Raid Group |
Implemented |
SSH |
Implemented |
SSH |
Redundancy |
Implemented |
SSH |
Redundancy level |
Status |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Type |
Gap |
SSH |
Uses FlashPools |
Implemented |
SSH |
indicate if this storagepool uses Flash Pools(NetApp specific) |
Virtual |
Implemented |
SSH |
Encrypted |
Implemented |
SSH |
Mode |
Implemented |
SSH |
Mode Enum |
Implemented |
SSH |
Source Storage |
Implemented |
SSH |
Source Volume |
Implemented |
SSH |
State |
Implemented |
SSH |
State Enum |
Implemented |
SSH |
Target Storage |
Implemented |
SSH |
Target Volume |
Implemented |
SSH |
Technology |
Implemented |
SSH |
Volume |
AutoTier Policy Identifier |
Implemented |
SSH |
Dynamic Tier Policy identifier |
Auto Tiering |
Implemented |
SSH |
Capacity |
Implemented |
SSH |
DiskGroup |
Implemented |
SSH |
Disk Group Type |
Head |
Implemented |
SSH |
Specify the head (in netapp) for this volume |
Junction Path |
Implemented |
SSH |
Name |
Implemented |
SSH |
Protection Type |
Implemented |
SSH |
Implemented |
SSH |
Storage Pool Id |
Implemented |
SSH |
Thin Provisioned |
Implemented |
SSH |
Type |
Gap |
SSH |
UUID |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Virtual |
Implemented |
SSH |
Written Capacity |
Implemented |
SSH |
Total capacity written to this volume by a Host in MB |
Implemented |
SSH |
Encrypted |
Implemented |
SSH |
Volume Map |
LUN |
Implemented |
SSH |
Implemented |
SSH |
Storage Port |
Implemented |
SSH |
Volume Mask |
Initiator |
Implemented |
SSH |
Implemented |
SSH |
Storage Port |
Implemented |
SSH |
Type |
Gap |
SSH |
WWN Alias |
Host Aliases |
Implemented |
SSH |
Object Type |
Implemented |
SSH |
Source |
Implemented |
SSH |
WWN |
Implemented |
SSH |
performance |
Disk |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Read Utilization |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Utilization Write |
Implemented |
SSH |
Disk |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Read Utilization |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Utilization Write |
Implemented |
SSH |
Storage |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
IOPs other |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Storage |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Storage Node |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Storage Node Data |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Key |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Storage Pool |
Key |
Implemented |
SSH |
Server ID |
Implemented |
SSH |
Total Capacity |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
StoragePool Disk |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Total Capacity |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
Read Utilization |
Implemented |
SSH |
Utilization Total |
Implemented |
SSH |
Utilization Write |
Implemented |
SSH |
Volume |
Implemented |
SSH |
Implemented |
SSH |
Implemented |
SSH |
Raw Capacity |
Implemented |
SSH |
Total Capacity |
Implemented |
SSH |
Used Capacity |
Implemented |
SSH |
Written Capacity |
Implemented |
SSH |
Implemented |
SSH |
CapacityRatio Written |
Implemented |
SSH |
IOPs Read |
Implemented |
SSH |
IOPs Total |
Implemented |
SSH |
IOPs Write |
Implemented |
SSH |
Latency Read |
Implemented |
SSH |
Latency Total |
Implemented |
SSH |
Latency Write |
Implemented |
SSH |
Throughput Read |
Implemented |
SSH |
Throughput Total |
Implemented |
SSH |
Throughput Write |
Implemented |
SSH |
IBM SVC CLI |
SSH |
SSH |
22 |
true |
false |
true |
true |
IBM XIV & A9000 (XIVCLI)
Models and versions supported by this data collector:
A14 |
10.2.4.e |
Products supported by this data collector:
Product | Category | Feature/Attribute | Status | Protocol Used | Additional Information |
foundation |
Disk |
Disk Id |
Implemented |
XIV CLI |
Uniquely identifies this disk in the array |
Name |
Implemented |
XIV CLI |
Speed |
Implemented |
XIV CLI |
Capacity (GB) |
Implemented |
XIV CLI |
Used capacity |
Role Enum |
Implemented |
XIV CLI |
Role |
Implemented |
XIV CLI |
Status |
Implemented |
XIV CLI |
Serial Number |
Implemented |
XIV CLI |
Vendor |
Implemented |
XIV CLI |
Model |
Implemented |
XIV CLI |
Type |
Gap |
XIV CLI |
Type Enum |
Implemented |
XIV CLI |
enum for disk type |
Info |
DataSource Name |
Implemented |
XIV CLI |
Info |
Originator ID |
Implemented |
XIV CLI |
Date |
Implemented |
XIV CLI |
Originator Key |
Implemented |
XIV CLI |
Client Api Name |
Implemented |
XIV CLI |
Client Api Version |
Implemented |
XIV CLI |
Storage |
IP |
Implemented |
XIV CLI |
Display IP |
Implemented |
XIV CLI |
Name |
Implemented |
XIV CLI |
Manufacturer |
Implemented |
XIV CLI |
Model |
Implemented |
XIV CLI |
Family |
Implemented |
XIV CLI |
The storage Family could be Clariion, Symmetrix, et al |
Serial Number |
Implemented |
XIV CLI |
Microcode Version |
Implemented |
XIV CLI |
Virtual |
Implemented |
XIV CLI |
Is this a storage virtualization device? |
Total Raw Capacity |
Implemented |
XIV CLI |
Total raw capacity (sum of all disks on the array) |
Spare Raw Capacity |
Implemented |
XIV CLI |
Raw capacity of spare disks (sum of all disks that are spare) |
Failed Raw Capacity |
Implemented |
XIV CLI |
Raw capacity of failed disks (sum of all disks that are failed) |
Storage Pool |
Storage Pool Id |
Implemented |
XIV CLI |
Name |
Implemented |
XIV CLI |
Type |
Gap |
XIV CLI |
Thin Provisioning Supported |
Implemented |
XIV CLI |
Whether this internal volume supports thin provisioning for the volume layer on top of it |
Include In Dwh Capacity |
Implemented |
XIV CLI |
A way from ACQ to control which storage pools are interesting in DWH Capacity |
Virtual |
Implemented |
XIV CLI |
Raid Group |
Implemented |
XIV CLI |
indicates whether this storagePool is a raid group |
Snapshot Used Capacity |
Implemented |
XIV CLI |
Gap |
XIV CLI |
Data Used Capacity |
Implemented |
XIV CLI |
Gap |
XIV CLI |
Total Used Capacity |
Implemented |
XIV CLI |
Total capacity in MB |
Total Allocated Capacity |
Implemented |
XIV CLI |
Other UsedCapacity (MB) |
Implemented |
XIV CLI |
Any capacity other than data and snapshot |
Physical Disk Capacity (MB) |
Implemented |
XIV CLI |
used as raw capacity for storage pool |
Raw to Usable Ratio |
Implemented |
XIV CLI |
ratio to convert from usable capacity to raw capacity |
Redundancy |
Implemented |
XIV CLI |
Redundancy level |
Soft Limit (MB) |
Implemented |
XIV CLI |
Volume |
Name |
Implemented |
XIV CLI |
Storage Pool Id |
Implemented |
XIV CLI |
Type |
Gap |
XIV CLI |
Disk Type |
Not Available |
XIV CLI |
DiskGroup |
Implemented |
XIV CLI |
Disk Group Type |
Thin Provisioned |
Implemented |
XIV CLI |
Capacity |
Implemented |
XIV CLI |
Implemented |
XIV CLI |
Used Capacity |
Implemented |
XIV CLI |
Redundancy |
Implemented |
XIV CLI |
Redundancy level |
Implemented |
XIV CLI |
Volume Map |
LUN |
Implemented |
XIV CLI |
Implemented |
XIV CLI |
Volume Mask |
Initiator |
Implemented |
XIV CLI |
Implemented |
XIV CLI |
WWN Alias |
Source |
Implemented |
XIV CLI |
Host Aliases |
Implemented |
XIV CLI |
WWN |
Implemented |
XIV CLI |
Object Type |
Implemented |
XIV CLI |
Host OS |
Implemented |
XIV CLI |
IBM DS CLI |
DSNI |
DSNI |
true |
true |
true |
true |
IBM XIV CLI |
XIV CLI |
TCP |
7778 |
true |
false |
true |
false |
Infinidat Infinibox (HTTP)
F4303 |
6.0.20.40 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Where this disk is physically located in the array |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Other Allocated Capacity |
Gap |
HTTPS |
Capacity allocated for other (not data and not snapshot) |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Share |
IP Interfaces |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
SupportActive Active |
Implemented |
HTTPS |
Specified if the storage supports active-active configurations |
Virtual |
Implemented |
HTTPS |
Storage Node |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
free text describing the device state |
UUID |
Implemented |
HTTPS |
Storage Pool |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Reserved Capacity |
Implemented |
HTTPS |
Soft Limit (MB) |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Mode |
Implemented |
HTTPS |
Mode Enum |
Implemented |
HTTPS |
Source Storage |
Implemented |
HTTPS |
Source Volume |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
State Enum |
Implemented |
HTTPS |
Target Storage |
Implemented |
HTTPS |
Target Volume |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Replica Source |
Implemented |
HTTPS |
Replica Target |
Implemented |
HTTPS |
Snapshot |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
WWN Alias |
Host Aliases |
Implemented |
HTTPS |
Object Type |
Implemented |
HTTPS |
Source |
Implemented |
HTTPS |
WWN |
Implemented |
HTTPS |
Infinidat REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Microsoft Azure Compute
API versions:
2018-06-01
foundation |
Data Store |
Capacity |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Provisioned Capacity |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
subscription Id |
Implemented |
HTTPS |
Server |
Cluster |
Implemented |
HTTPS |
Cluster name |
DataCenter Name |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
Virtual Disk |
Capacity |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Lun OID |
Implemented |
HTTPS |
Is Chargeable |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
subscription Id |
Implemented |
HTTPS |
VirtualMachine |
Guest State |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OS |
Implemented |
HTTPS |
Power State |
Implemented |
HTTPS |
State Change Time |
Implemented |
HTTPS |
Processors |
Implemented |
HTTPS |
Implemented |
HTTPS |
Instance Type |
Implemented |
HTTPS |
Launch Time |
Implemented |
HTTPS |
public Ips |
Implemented |
HTTPS |
Security Groups |
Implemented |
HTTPS |
subscription Id |
Implemented |
HTTPS |
VirtualMachine Disk |
OID |
Implemented |
HTTPS |
VirtualDisk OID |
Implemented |
HTTPS |
VirtualMachine OID |
Implemented |
HTTPS |
Host |
Host OS |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Info |
Api Description |
Implemented |
HTTPS |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
performance |
Data Store |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Reported as a time series |
Virtual Disk |
Total Capacity |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Number of read IOPs on the disk |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Average disk total rate (read and write across all disks) in MB/s |
Throughput Write |
Implemented |
HTTPS |
vm |
Total Capacity |
Implemented |
HTTPS |
Total CPU Utilization |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
diskIops.total |
Implemented |
HTTPS |
Disk IOPs write |
Implemented |
HTTPS |
Disk Throughput Read |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
total disk throughput read |
Disk Throughput Write |
Implemented |
HTTPS |
IP Throughput Read |
Implemented |
HTTPS |
Throughput total |
Implemented |
HTTPS |
IP throughput total |
ipThroughput.write |
Implemented |
HTTPS |
VM |
Total Capacity |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Management APIs used by this data collector:
API | Protocol Used | Transport layer protocol used | Incoming ports used | Outgoing ports used | Supports authentication | Requires only 'Read-only' credentials | Supports Encryption | Firewall friendly (static ports) |
Microsoft Azure Compute REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Microsoft Hyper-V
foundation |
Data Store |
Capacity |
Implemented |
WMI |
MOID |
Implemented |
WMI |
Name |
Implemented |
WMI |
OID |
Implemented |
WMI |
Implemented |
WMI |
Used Capacity |
Implemented |
WMI |
Virtual Center Ip |
Implemented |
WMI |
NasShare DataStore |
DataStore OID |
Implemented |
WMI |
Nas Share OID |
Implemented |
WMI |
OID |
Implemented |
WMI |
NasShare Host |
Nas Share OID |
Implemented |
WMI |
Host OID |
Implemented |
WMI |
OID |
Implemented |
WMI |
Read Only |
Implemented |
WMI |
LUN |
Disk Name |
Implemented |
WMI |
DataStore OID |
Implemented |
WMI |
Host OID |
Implemented |
WMI |
Number |
Implemented |
WMI |
OID |
Implemented |
WMI |
TID |
Implemented |
WMI |
NAS Share |
Capacity |
Implemented |
WMI |
Allocated capacity in MB |
Filer Ip |
Implemented |
WMI |
Filer Name |
Implemented |
WMI |
OID |
Implemented |
WMI |
Share Path |
Implemented |
WMI |
For a HvNasShare to be matched to a Share |
Type |
Gap |
WMI |
Path |
Active |
Implemented |
WMI |
Lun OID |
Implemented |
WMI |
Host Port WWPN |
Implemented |
WMI |
OID |
Implemented |
WMI |
Storage Port WWPN |
Implemented |
WMI |
Type |
Gap |
WMI |
Server |
Cluster |
Implemented |
WMI |
Cluster name |
DataCenter Name |
Implemented |
WMI |
Host OID |
Implemented |
WMI |
MOID |
Implemented |
WMI |
OID |
Implemented |
WMI |
Virtual Center Ip |
Implemented |
WMI |
Virtual Disk |
Capacity |
Implemented |
WMI |
DataStore OID |
Implemented |
WMI |
Name |
Implemented |
WMI |
OID |
Implemented |
WMI |
Type |
Gap |
WMI |
Used Capacity |
Implemented |
WMI |
used capacity for reporting (MB) |
Used Capacity |
Implemented |
WMI |
VirtualMachine |
Dns Name |
Implemented |
WMI |
Guest State |
Implemented |
WMI |
DataStore OID |
Implemented |
WMI |
Host OID |
Implemented |
WMI |
IPs |
Implemented |
WMI |
MOID |
Implemented |
WMI |
Memory |
Implemented |
WMI |
Name |
Implemented |
WMI |
OID |
Implemented |
WMI |
OS |
Implemented |
WMI |
Power State |
Implemented |
WMI |
State Change Time |
Implemented |
WMI |
Processors |
Implemented |
WMI |
Implemented |
WMI |
Used Capacity |
Implemented |
WMI |
OID |
Implemented |
WMI |
VirtualDisk OID |
Implemented |
WMI |
Implemented |
WMI |
Host |
Host Cpu Count |
Implemented |
WMI |
Host Cpu Speed |
Implemented |
WMI |
Host Domain |
Implemented |
WMI |
Implemented |
WMI |
Host Model |
Implemented |
WMI |
NIC count |
Implemented |
WMI |
NIC speed |
Implemented |
WMI |
IPs |
Implemented |
WMI |
Manufacturer |
Implemented |
WMI |
Name |
Implemented |
WMI |
OID |
Implemented |
WMI |
Platform Type |
Implemented |
WMI |
ISCSI Node |
Host Aliases |
Implemented |
WMI |
Node Name |
Implemented |
WMI |
OID |
Implemented |
WMI |
Type |
Gap |
WMI |
Info |
DataSource Name |
Implemented |
WMI |
Info |
Date |
Implemented |
WMI |
Originator ID |
Implemented |
WMI |
performance |
DataStore |
Key |
Implemented |
WS-Management |
Server ID |
Implemented |
WS-Management |
Total Capacity |
Implemented |
WS-Management |
Capacity Provisioned |
Implemented |
WS-Management |
Used Capacity |
Implemented |
WS-Management |
Capacity Used Ratio |
Implemented |
WS-Management |
Over Commit Capacity Ratio |
Implemented |
WS-Management |
Data Store |
Implemented |
WS-Management |
Total Capacity |
Implemented |
WS-Management |
Used Capacity |
Implemented |
WS-Management |
Implemented |
WS-Management |
Implemented |
WS-Management |
Host |
Implemented |
WS-Management |
IOPs Read |
Implemented |
WS-Management |
diskIops.total |
Implemented |
WS-Management |
Disk IOPs write |
Implemented |
WS-Management |
Latency Read |
Implemented |
WS-Management |
Latency Total |
Implemented |
WS-Management |
Latency Write |
Implemented |
WS-Management |
Implemented |
WS-Management |
Throughput Read |
Implemented |
WS-Management |
Implemented |
WS-Management |
Implemented |
WS-Management |
Throughput total |
Implemented |
WS-Management |
Implemented |
WS-Management |
Total Memory Utilization |
Implemented |
WS-Management |
Host |
Implemented |
WS-Management |
IOPs Read |
Implemented |
WS-Management |
diskIops.total |
Implemented |
WS-Management |
Disk IOPs write |
Implemented |
WS-Management |
Latency Read |
Implemented |
WS-Management |
Latency Total |
Implemented |
WS-Management |
Latency Write |
Implemented |
WS-Management |
Implemented |
WS-Management |
Throughput Read |
Implemented |
WS-Management |
Implemented |
WS-Management |
Implemented |
WS-Management |
Throughput total |
Implemented |
WS-Management |
Implemented |
WS-Management |
Key |
Implemented |
WS-Management |
Implemented |
WS-Management |
Server ID |
Implemented |
WS-Management |
Virtual Disk |
Total Capacity |
Implemented |
WS-Management |
Used Capacity |
Implemented |
WS-Management |
Implemented |
WS-Management |
IOPs Read |
Implemented |
WS-Management |
IOPs Total |
Implemented |
WS-Management |
IOPs Write |
Implemented |
WS-Management |
Latency Total |
Implemented |
WS-Management |
Throughput Read |
Implemented |
WS-Management |
Throughput Total |
Implemented |
WS-Management |
Throughput Write |
Implemented |
WS-Management |
vm |
Total Capacity |
Implemented |
WS-Management |
Used Capacity |
Implemented |
WS-Management |
Implemented |
WS-Management |
Implemented |
WS-Management |
IOPs Read |
Implemented |
WS-Management |
diskIops.total |
Implemented |
WS-Management |
Disk IOPs write |
Implemented |
WS-Management |
Latency Total |
Implemented |
WS-Management |
Implemented |
WS-Management |
Throughput Read |
Implemented |
WS-Management |
Implemented |
WS-Management |
Implemented |
WS-Management |
Throughput total |
Implemented |
WS-Management |
Implemented |
WS-Management |
VM |
Total Capacity |
Implemented |
WS-Management |
Used Capacity |
Implemented |
WS-Management |
Implemented |
WS-Management |
Key |
Implemented |
WS-Management |
Server ID |
Implemented |
WS-Management |
PowerShell |
WS-Management |
HTTP |
5985 |
true |
false |
false |
true |
WMI |
WMI |
WMI |
135 |
true |
false |
true |
true |
NetApp 7 Mode
1.12 |
FAS2040 |
8.1.1 7-Mode |
foundation |
Capability |
Active |
Implemented |
Licensed |
Implemented |
Type |
Gap |
Used |
Implemented |
Disk |
Capacity (GB) |
Implemented |
Used capacity |
Disk Id |
Implemented |
Group |
Implemented |
Location |
Gap |
Model |
Implemented |
Name |
Implemented |
Role |
Implemented |
Role Enum |
Implemented |
enum for disk role |
Serial Number |
Implemented |
Speed |
Implemented |
Status |
Implemented |
Status Enum |
Implemented |
Type |
Gap |
Type Enum |
Implemented |
Vendor |
Implemented |
File Share |
Is InternalVolume |
Implemented |
Is Oplocks Enabled |
Implemented |
whether opportunistic locks are enabled on the FileShare |
Is Shared |
Implemented |
Name |
Implemented |
Path |
Implemented |
Qtree Id |
Implemented |
Security Type |
Implemented |
Status |
Implemented |
IP |
Implemented |
Listening Port |
Implemented |
Nic |
Implemented |
OID |
Implemented |
OID |
Implemented |
Portal Group Name |
Implemented |
Portal Group Tag |
Implemented |
ISCSI Node |
Host Aliases |
Implemented |
Node Name |
Implemented |
OID |
Implemented |
Type |
Gap |
ISCSI Node Map |
OID |
Implemented |
Portal Group OID |
Implemented |
ISCSI Security Info |
OID |
Implemented |
Initiator Node Name |
Implemented |
Target Node Name |
Implemented |
Auth Type |
Implemented |
ISCSI Session |
OID |
Implemented |
Initiator OID |
Implemented |
Portal Group OID |
Implemented |
Target Session Id |
Implemented |
Initiator Session Id |
Implemented |
Implemented |
Max Connections |
Implemented |
Initiator Ips |
Implemented |
Security |
Implemented |
Info |
Api Name |
Implemented |
Api Version |
Implemented |
DataSource Name |
Implemented |
Info |
Date |
Implemented |
Originator ID |
Implemented |
Originator Key |
Implemented |
Internal Volume |
Implemented |
Implemented |
ratio of compression savings in percentage |
Data Allocated Capacity |
Gap |
capacity allocated for data |
Implemented |
Dedupe Enabled |
Implemented |
Is dedupe enabled on the storage pool |
Dedupe Savings |
Implemented |
ratio of dedupe savings in percentage |
Implemented |
Last Known Access Time |
Implemented |
Last know access to the volume |
Last Snapshot Time |
Implemented |
time of last snapshot |
Name |
Implemented |
Protection Type |
Implemented |
Implemented |
Snapshot Allocated Capacity |
Gap |
Allocated capacity of snapshots in MB |
Snapshot Count |
Implemented |
Number of snapshots on the internal volumes |
Implemented |
Space Guarantee |
Implemented |
Space Guatantee policy (file, volume or none) |
Status |
Implemented |
Storage Pool Id |
Implemented |
Thin Provisioned |
Implemented |
Implemented |
Implemented |
Implemented |
Total Used Capacity (MB) |
Implemented |
place holder for the used capacity as read from the device |
Type |
Gap |
Virtual Storage |
Implemented |
Storage Synchronization |
Source Internal Volume |
Implemented |
Target Internal Volume |
Implemented |
Technology |
Implemented |
technology which causes storage efficiency changed |
QTree |
Name |
Implemented |
Oplocks |
Implemented |
Indicates whether opportunistic locks are enabled on the Qtree |
Qtree Id |
Implemented |
Implemented |
Implemented |
Implemented |
Security Style |
Implemented |
Security style of the directory: unix, ntfs, or mixed |
Status |
Implemented |
Type |
Gap |
Quota |
Implemented |
Hard File Limit |
Implemented |
Implemented |
Qtree Id |
Implemented |
Quota Id |
Implemented |
Implemented |
Soft File Limit |
Implemented |
Threshold (MB) |
Implemented |
Disk space threshold, for the quota target |
Type |
Gap |
Used Capacity |
Implemented |
Used Files |
Implemented |
User/Group Target |
Implemented |
Share |
Description |
Implemented |
IP Interfaces |
Implemented |
Name |
Implemented |
Protocol |
Implemented |
Share Initiator |
Initiator |
Implemented |
Permission |
Implemented |
Storage |
Cpu Count |
Implemented |
Cpu Count of the storage |
Display IP |
Implemented |
Implemented |
Family |
Implemented |
IP |
Implemented |
Manage URL |
Implemented |
Manufacturer |
Implemented |
Memory |
Implemented |
Microcode Version |
Implemented |
Model |
Implemented |
Name |
Implemented |
Implemented |
Serial Number |
Implemented |
Implemented |
Virtual |
Implemented |
Storage Node |
Cache Size |
Implemented |
device cache size in MB |
Memory Size |
Gap |
Model |
Implemented |
Name |
Implemented |
Processors Count |
Implemented |
device CPU |
Partner Node UUID |
Implemented |
HA pair's UUID |
Serial Number |
Implemented |
UUID |
Implemented |
Version |
Implemented |
software version |
ManagementIp Addresses |
Implemented |
Storage Pool |
Gap |
Implemented |
Implemented |
Name |
Implemented |
Implemented |
Raid Group |
Implemented |
Implemented |
Redundancy |
Implemented |
Redundancy level |
Gap |
Implemented |
Status |
Implemented |
Storage Pool Id |
Implemented |
Implemented |
Implemented |
Implemented |
Type |
Gap |
Uses FlashPools |
Implemented |
Virtual |
Implemented |
Volume |
Capacity |
Implemented |
Snapshot Used capacity in MB |
DiskGroup |
Implemented |
Disk Group Type |
Disk Size |
Implemented |
comma seperated list of disk sizes (GB) |
Disk Speed |
Implemented |
comma seperated list of disk speeds (rpm) |
Disk Type |
Not Available |
Junction Path |
Implemented |
Implemented |
Name |
Implemented |
Protection Type |
Implemented |
Qtree Id |
Implemented |
Implemented |
Storage Pool Id |
Implemented |
Thin Provisioned |
Implemented |
Type |
Gap |
Used Capacity |
Implemented |
Volume Map |
LUN |
Implemented |
Name of the backend lun |
Protocol Controller |
Implemented |
Type |
Gap |
Volume Mask |
Initiator |
Implemented |
Implemented |
Storage Port |
Implemented |
Type |
Gap |
performance |
Disk |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Read Utilization |
Implemented |
Utilization Total |
Implemented |
Utilization Write |
Implemented |
Disk |
Key |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Write |
Implemented |
Throughput Total |
Implemented |
IOPs Read |
Implemented |
IOPs Write |
Implemented |
IOPs Total |
Implemented |
Read Utilization |
Implemented |
Utilization Write |
Implemented |
Utilization Total |
Implemented |
Internal Volume |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
Implemented |
IO Density Read |
Implemented |
IO Density Total |
Implemented |
Write IO Density |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Snapshot Reserved Capacity |
Implemented |
Implemented |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Qtree |
Quota Hard Limit |
Implemented |
Capacity quota hard limit |
Quota Soft Limit |
Implemented |
Capacity Quota soft Limit |
Used Capacity |
Implemented |
Total File Count |
Implemented |
IOPs Total |
Implemented |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
StoragePools Capacity |
Implemented |
IO Density Read |
Implemented |
IO Density Total |
Implemented |
Write IO Density |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage Node |
Cache Hit Ratio Total |
Implemented |
Total Disk Read Replaced |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
Storage Node Data |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
Storage Pool |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Implemented |
Implemented |
Implemented |
StoragePool Disk |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Implemented |
Implemented |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Read Utilization |
Implemented |
Utilization Total |
Implemented |
Utilization Write |
Implemented |
Volume |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
IO Density Read |
Implemented |
IO Density Total |
Implemented |
Write IO Density |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Partial Blocked Ratio |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Write Pending |
Implemented |
total write pending |
NetApp 7 Mode ZAPI |
ZAPI |
ZAPI |
true |
true |
true |
true |
NetApp E-Series REST
2800B |
08.71.03.00 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
enum for disk status |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Vendor Id |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
ISCSI Network Portal |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
ISCSI Network Portal Group |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Number Of Connections |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Target Session Id |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Cache Size |
Implemented |
HTTPS |
Memory Size |
Gap |
HTTPS |
device memory in MB |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Up Time |
Implemented |
HTTPS |
time in milliseconds |
Storage Pool |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Disk Type |
Not Available |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Storage |
Cache Hit Ratio Read |
Implemented |
HTTPS |
Implemented |
HTTPS |
Cache Hit Ratio Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
NetApp E-Series REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Amazon FSx for NetApp ONTAP
Models | Firmware versions |
FSx for ONTAP |
Data ONTAP |
foundation |
Capability |
Active |
Implemented |
HTTPS |
Licensed |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used |
Implemented |
HTTPS |
Disk Group |
Capacity |
Implemented |
HTTPS |
DiskGroup Id |
Implemented |
HTTPS |
unique id of the disk group |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Security Type |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Node Map |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Auth Type |
Implemented |
HTTPS |
Inbound Keyword |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Outbound Keyword |
Implemented |
HTTPS |
Target Node Name |
Implemented |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Target Session Id |
Implemented |
HTTPS |
Info |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Compression Enabled |
Implemented |
HTTPS |
Is compression enabled on the storage pool |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey1 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5. |
GuidKey 2 |
Implemented |
HTTPS |
GuidKey2 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5. |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protection Type |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Snapshot Count |
Implemented |
HTTPS |
Implemented |
HTTPS |
Space Guarantee |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Clone Saved Capacity in MB |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Virtual Storage |
Implemented |
HTTPS |
Owning virtual storage (vfiler) |
Adaptive Qos Policy |
Implemented |
HTTPS |
Comment |
Gap |
HTTPS |
state: free text comment describing the svm |
Group Id |
Implemented |
HTTPS |
Group Name |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Qos Limit IOPS |
Implemented |
HTTPS |
Qos Limit MBPS |
Implemented |
HTTPS |
Qos Limit Raw |
Implemented |
HTTPS |
QoS - Policy |
Implemented |
HTTPS |
Tiering Minimum Cooling Days |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
QTree |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey 2 |
Implemented |
HTTPS |
GuidKey 3 |
Implemented |
HTTPS |
GuidKey3 is implicit for all objects whose GUID key has not changed since OCI version 7.3.5. |
Name |
Implemented |
HTTPS |
Oplocks |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Quota SoftCapacity Limit (MB) |
Implemented |
HTTPS |
Quota UsedCapacity |
Implemented |
HTTPS |
Space in MB currently used |
Security Style |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Quota |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey 2 |
Implemented |
HTTPS |
GuidKey 3 |
Implemented |
HTTPS |
Implemented |
HTTPS |
Hard File Limit |
Implemented |
HTTPS |
max number of files allowed for the quota target |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Quota Id |
Implemented |
HTTPS |
Soft Capacity Limit (MB) |
Implemented |
HTTPS |
Soft File Limit |
Implemented |
HTTPS |
Max number of files allowed for the quota target |
Threshold (MB) |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Used Files |
Implemented |
HTTPS |
Number of files currently used |
User/Group Target |
Implemented |
HTTPS |
user/group target this quota refers to |
Share |
Description |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Storage |
Cluster |
Not Available |
HTTPS |
Whether this storage is a cluster |
Cpu Count |
Implemented |
HTTPS |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Node |
Cache Size |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Compression Savings |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Reserved Capacity |
Implemented |
HTTPS |
Reserved Capacity in MB |
Gap |
HTTPS |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Uses FlashPools |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage VirtualMachine |
Allocated capacity (MB) |
Implemented |
HTTPS |
Allocated capacity of snapshots |
Comment |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Guid Key |
Implemented |
HTTPS |
Globally Unique Key of the storage virtual machine |
IP Space |
Implemented |
HTTPS |
Internal Volume Limit |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocols |
Implemented |
HTTPS |
csv of svm enabled protocols (fcp, iscsi, nfs, cifs…) |
State |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
VirtualMachine Internal Volume Ref |
Internal Volume Id |
Implemented |
HTTPS |
VirtualMachine StoragePool lRef |
Storage Pool Id |
Implemented |
HTTPS |
VirtualMachine Volume Ref |
Volume Name |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
DiskGroup |
Implemented |
HTTPS |
Disk Group Type |
Junction Path |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
unique id of the qtree |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Clone Saved Capacity Total |
Implemented |
HTTPS |
Total Compression Savings |
Implemented |
HTTPS |
Compression Savings Space |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
deduplicationSavingsPercent.total |
Implemented |
HTTPS |
Deduplication Savings Space |
Implemented |
HTTPS |
File System Capacity Logical Used |
Implemented |
HTTPS |
File System Capacity Physical Available |
Implemented |
HTTPS |
File System Capacity Physical Used |
Implemented |
HTTPS |
IO Density Read |
Implemented |
HTTPS |
IO Density Total |
Implemented |
HTTPS |
Write IO Density |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Object Store Space Used |
Implemented |
HTTPS |
QOS Wait |
Implemented |
HTTPS |
Total qos wait time |
Server ID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Snapshot Used Capacity Ratio |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
Storage |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
Storage Node |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
StoragePool Disk |
Total Capacity |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Reserved Capacity |
Implemented |
HTTPS |
Fractional reserved (included in data allocated capacity) |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
VirtualMachine |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
NetApp ONTAP API |
HTTP/HTTPS |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
NetApp Clustered Data ONTAP 8.1.1+
AFF-A150 |
foundation |
Capability |
Active |
Implemented |
HTTPS |
Licensed |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used |
Implemented |
HTTPS |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Disk Group |
Capacity |
Implemented |
HTTPS |
DiskGroup Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
whether this fileShare has any shares associated with it |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Path of the fileShare |
Qtree Id |
Implemented |
HTTPS |
Security Type |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Node Map |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Auth Type |
Implemented |
HTTPS |
Inbound Keyword |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Outbound Keyword |
Implemented |
HTTPS |
Target Node Name |
Implemented |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Target Session Id |
Implemented |
HTTPS |
Info |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
FlashPool Eligibility |
Implemented |
HTTPS |
Whether the internal volume can participate in hybrid caching |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey 2 |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Gap |
HTTPS |
Protection Type |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Snapshot Count |
Implemented |
HTTPS |
Implemented |
HTTPS |
Space Guarantee |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Virtual Storage |
Implemented |
HTTPS |
Implemented |
HTTPS |
Comment |
Gap |
HTTPS |
Group Id |
Implemented |
HTTPS |
Group Name |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Qos Limit IOPS |
Implemented |
HTTPS |
Qos Limit MBPS |
Implemented |
HTTPS |
Qos Limit Raw |
Implemented |
HTTPS |
QoS - Policy |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
QTree |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey 2 |
Implemented |
HTTPS |
GuidKey 3 |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Oplocks |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Quota HardCapacity Limit (MB) |
Implemented |
HTTPS |
Maximum amount of disk space, allowed for the quota target |
Implemented |
HTTPS |
Implemented |
HTTPS |
Security Style |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Quota |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey 2 |
Implemented |
HTTPS |
GuidKey 3 |
Implemented |
HTTPS |
Hard Capacity Limit (MB) |
Implemented |
HTTPS |
max amount of disk space, allowed for the quota target (Hard limit) |
Hard File Limit |
Implemented |
HTTPS |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Quota Id |
Implemented |
HTTPS |
unique id of the quota |
Implemented |
HTTPS |
Soft File Limit |
Implemented |
HTTPS |
Threshold (MB) |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Used Files |
Implemented |
HTTPS |
User/Group Target |
Implemented |
HTTPS |
Share |
Description |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
comma separated list of IP addresses on which this share is exposed |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
enum for share protocol |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Permissions for this particular share |
Storage |
Cluster |
Not Available |
HTTPS |
Cpu Count |
Implemented |
HTTPS |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Node |
Cache Size |
Implemented |
HTTPS |
Memory Size |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Partner Node UUID |
Implemented |
HTTPS |
HA pair's UUID |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Up Time |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Reserved Capacity |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Uses FlashPools |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
CompactionSavings Enabled |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
License Used Percent |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Comment |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Guid Key |
Implemented |
HTTPS |
IP Space |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocols |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Volume Name |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
DiskGroup |
Implemented |
HTTPS |
Disk Group Type |
Disk Size |
Implemented |
HTTPS |
Disk Speed |
Implemented |
HTTPS |
Disk Type |
Not Available |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Qos Limit IOPS |
Implemented |
HTTPS |
Qos Limit MBPS |
Implemented |
HTTPS |
Qos Limit Raw |
Implemented |
HTTPS |
QoS - Policy |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Read Utilization |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Utilization Write |
Implemented |
HTTPS |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Read Utilization |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Utilization Write |
Implemented |
HTTPS |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Data Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IO Density Read |
Implemented |
HTTPS |
IO Density Total |
Implemented |
HTTPS |
Write IO Density |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Other Total Capacity |
Implemented |
HTTPS |
QOS Wait |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Internal Volume |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IO Density Read |
Implemented |
HTTPS |
IO Density Total |
Implemented |
HTTPS |
Write IO Density |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
QOS Wait |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Qtree |
Quota Hard Limit |
Implemented |
HTTPS |
Quota Soft Limit |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Total File Count |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
IO Density Read |
Implemented |
HTTPS |
IO Density Total |
Implemented |
HTTPS |
Write IO Density |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage Node |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
Failed Fans |
Implemented |
HTTPS |
Failed Power Units |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Optimal Utilization |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Reserved Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
compactionSavingsPercent.total |
Implemented |
HTTPS |
Total Compaction Space |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Object Store Space Physical Space Used |
Implemented |
HTTPS |
Object Store Space Referenced Space |
Implemented |
HTTPS |
Object Store Space SIS Space Saved |
Implemented |
HTTPS |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Read Utilization |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Utilization Write |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Reserved Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Read Utilization |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Utilization Write |
Implemented |
HTTPS |
Virtual Machine |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
IO Density Read |
Implemented |
HTTPS |
IO Density Total |
Implemented |
HTTPS |
Write IO Density |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
VirtualMachine |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
IO Density Read |
Implemented |
HTTPS |
IO Density Total |
Implemented |
HTTPS |
Write IO Density |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
NetApp ONTAP API |
HTTP/HTTPS |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
ASA
ASA-A1K |
NetApp Release 9.16.1: Sat Jan 18 19:31:15 UTC 2025 |
foundation |
Capability |
Active |
Implemented |
HTTPS |
Licensed |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used |
Implemented |
HTTPS |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Speed of disk (RPM) |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
File Share |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Is InternalVolume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Security Type |
Implemented |
HTTPS |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Node Map |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Auth Type |
Implemented |
HTTPS |
Inbound Keyword |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Outbound Keyword |
Implemented |
HTTPS |
Target Node Name |
Implemented |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Target Session Id |
Implemented |
HTTPS |
Info |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Space Guarantee |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Snapshot Count |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Virtual Storage |
Implemented |
HTTPS |
Protection Type |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
QTree |
Qtree Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Security Style |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Status |
Implemented |
HTTPS |
Oplocks |
Implemented |
HTTPS |
Storage |
Cluster |
Not Available |
HTTPS |
Cpu Count |
Implemented |
HTTPS |
Display IP |
Implemented |
HTTPS |
Failed Raw Capacity |
Implemented |
HTTPS |
Raw capacity of failed disks (sum of all disks that are failed) |
Family |
Implemented |
HTTPS |
The storage Family could be Clariion, Symmetrix, et al |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Total Raw Capacity |
Implemented |
HTTPS |
Total raw capacity (sum of all disks on the array) |
Serial Number |
Implemented |
HTTPS |
Spare Raw Capacity |
Implemented |
HTTPS |
Raw capacity of spare disks (sum of all disks that are spare) |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Is this a storage virtualization device? |
UUID |
Implemented |
HTTPS |
Storage Node |
Cache Size |
Implemented |
HTTPS |
Memory Size |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Partner Node UUID |
Implemented |
HTTPS |
HA pair's UUID |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Up Time |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Data Used Capacity |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Include In Dwh Capacity |
Implemented |
HTTPS |
A way from ACQ to control which storage pools are interesting in DWH Capacity |
Name |
Implemented |
HTTPS |
Physical Disk Capacity (MB) |
Implemented |
HTTPS |
used as raw capacity for storage pool |
Raid Group |
Implemented |
HTTPS |
indicates whether this storagePool is a raid group |
Raw to Usable Ratio |
Implemented |
HTTPS |
ratio to convert from usable capacity to raw capacity |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Gap |
HTTPS |
Snapshot Used Capacity |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioning Supported |
Implemented |
HTTPS |
Whether this internal volume supports thin provisioning for the volume layer on top of it |
Total Allocated Capacity |
Implemented |
HTTPS |
Total Used Capacity |
Implemented |
HTTPS |
Total capacity in MB |
Type |
Gap |
HTTPS |
Uses FlashPools |
Implemented |
HTTPS |
indicate if this storagepool uses Flash Pools(NetApp specific) |
Virtual |
Implemented |
HTTPS |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Guid Key |
Implemented |
HTTPS |
IP Space |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocols |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Volume Name |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
DiskGroup |
Implemented |
HTTPS |
Disk Group Type |
Disk Size |
Implemented |
HTTPS |
Disk Speed |
Implemented |
HTTPS |
Disk Type |
Not Available |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Read Utilization |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Utilization Write |
Implemented |
HTTPS |
NetApp ASA API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
NetApp ONTAP REST
Models and versions supported by this data collector:
AFF-A150 |
Products supported by this data collector:
Product | Category | Feature/Attribute | Status | Protocol Used | Additional Information |
foundation |
Capability |
Active |
Implemented |
HTTPS |
Licensed |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used |
Implemented |
HTTPS |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Uniquely identifies this disk in the array |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Where this disk is physically located in the array |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
enum for disk type |
Vendor |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Security Type |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Node Map |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Auth Type |
Implemented |
HTTPS |
Inbound Keyword |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Outbound Keyword |
Implemented |
HTTPS |
Target Node Name |
Implemented |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Target Session Id |
Implemented |
HTTPS |
Info |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Other Allocated Capacity |
Gap |
HTTPS |
Capacity allocated for other (not data and not snapshot) |
Protection Type |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Snapshot Count |
Implemented |
HTTPS |
Implemented |
HTTPS |
Space Guarantee |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Virtual Storage |
Implemented |
HTTPS |
Implemented |
HTTPS |
Comment |
Gap |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Qos Limit IOPS |
Implemented |
HTTPS |
Qos Limit MBPS |
Implemented |
HTTPS |
QoS - Policy |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Oplocks |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Security Style |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Quota |
Implemented |
HTTPS |
Hard File Limit |
Implemented |
HTTPS |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Quota Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Soft File Limit |
Implemented |
HTTPS |
Threshold (MB) |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Used Files |
Implemented |
HTTPS |
User/Group Target |
Implemented |
HTTPS |
Share |
Description |
Implemented |
HTTPS |
IP Interfaces |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Storage |
Cluster |
Not Available |
HTTPS |
Cpu Count |
Implemented |
HTTPS |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
SupportActive Active |
Implemented |
HTTPS |
Specified if the storage supports active-active configurations |
Virtual |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Node |
Cache Size |
Implemented |
HTTPS |
Memory Size |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Partner Node UUID |
Implemented |
HTTPS |
HA pair's UUID |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
free text describing the device state |
UUID |
Implemented |
HTTPS |
Up Time |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Gap |
HTTPS |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Uses FlashPools |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Comment |
Implemented |
HTTPS |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Guid Key |
Implemented |
HTTPS |
IP Space |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocols |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Volume Name |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
DiskGroup |
Implemented |
HTTPS |
Disk Group Type |
Disk Size |
Implemented |
HTTPS |
Disk Speed |
Implemented |
HTTPS |
Disk Type |
Not Available |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
Number of read IOPs on the disk |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Average disk total rate (read and write across all disks) in MB/s |
Throughput Write |
Implemented |
HTTPS |
Read Utilization |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Utilization Write |
Implemented |
HTTPS |
Storage Pool |
Capacity Provisioned |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Over Commit Capacity Ratio |
Implemented |
HTTPS |
Reported as a time series |
Capacity Used Ratio |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Failed Disks |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Management APIs used by this data collector:
API | Protocol Used | Transport layer protocol used | Incoming ports used | Outgoing ports used | Supports authentication | Requires only 'Read-only' credentials | Supports Encryption | Firewall friendly (static ports) |
NetApp ONTAP REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
NetApp SolidFire 8.1+
H410S-2 |
11.1.0.72 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Group |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Potential Transfer Rate |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Seek Time |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Node Map |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Storage |
Cpu Count |
Implemented |
HTTPS |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Memory Size |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Serial Number |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Dedupe Savings |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Gap |
HTTPS |
Other UsedCapacity (MB) |
Implemented |
HTTPS |
Any capacity other than data and snapshot |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Status |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Replica Source |
Implemented |
HTTPS |
Replica Target |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Account Identifier |
Implemented |
HTTPS |
Account Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Qos Burst IOPS |
Implemented |
HTTPS |
Qos Limit IOPS |
Implemented |
HTTPS |
qos Min IOPS |
Implemented |
HTTPS |
QoS - Policy |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Masking Required |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage |
Key |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Node |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Implemented |
HTTPS |
Other Used Capacity |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
StoragePool Disk |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Volume |
Raw Capacity |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
SolidFire REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
NetApp StorageGRID (HTTPS)
API versions | Models | Firmware versions |
3.2 |
Webscale |
11.4.0 |
foundation |
Info |
Api Name |
Implemented |
HTTPS |
Api Version |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Internal Volume |
Dedupe Enabled |
Implemented |
HTTPS |
Is dedupe enabled on the storage pool |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey 2 |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Total Used Capacity (MB) |
Implemented |
HTTPS |
place holder for the used capacity as read from the device |
Type |
Gap |
HTTPS |
QTree |
GuidKey 1 |
Implemented |
HTTPS |
GuidKey 2 |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Cache Size |
Implemented |
HTTPS |
device cache size in MB |
Memory Size |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
ManagementIp Addresses |
Implemented |
HTTPS |
Node Capacity Utilization Allowed Meta Data in MB |
Implemented |
HTTPS |
Node Capacity Utilization Total in MB |
Implemented |
HTTPS |
Node Capacity Utilization Usable in MB |
Implemented |
HTTPS |
Node Capacity Utilization Used in MB |
Implemented |
HTTPS |
Node Capacity Utilization Used Meta Data in MB |
Implemented |
HTTPS |
Site Name |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
performance |
Internal Volume |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Total Objects |
Implemented |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
StoragePools Capacity |
Implemented |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Storage Node |
Node Capacity Utilization Allowed Meta Data |
Implemented |
Node Capacity Utilization Total |
Implemented |
Node Capacity Utilization Usable |
Implemented |
Node Capacity Utilization Used |
Implemented |
Node Capacity Utilization Used Meta Data |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage Node Data |
Key |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
StoragePool Disk |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
StorageGrid REST API |
HTTPS |
HTTPS |
443 |
true |
false |
true |
true |
Nutanix Storage (REST)
NX-3170-G7 |
5.20.1.1 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
enum for disk role |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
enum for disk status |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
Is Shared |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
ISCSI Network Portal |
IP |
Implemented |
HTTPS |
Listening Port |
Implemented |
HTTPS |
Nic |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
ISCSI Network Portal Group |
OID |
Implemented |
HTTPS |
Portal Group Name |
Implemented |
HTTPS |
Portal Group Tag |
Implemented |
HTTPS |
ISCSI Node |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
ISCSI Node Map |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
ISCSI Session |
Initiator Ips |
Implemented |
HTTPS |
Initiator OID |
Implemented |
HTTPS |
Max Connections |
Implemented |
HTTPS |
Number Of Connections |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Portal Group OID |
Implemented |
HTTPS |
Security |
Implemented |
HTTPS |
Info |
Api Name |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Implemented |
HTTPS |
ratio of compression savings in percentage |
Dedupe Enabled |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Synchronization |
Source Internal Volume |
Implemented |
HTTPS |
Target Internal Volume |
Implemented |
HTTPS |
Technology |
Implemented |
HTTPS |
technology which causes storage efficiency changed |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Share |
IP Interfaces |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Storage |
Cluster |
Not Available |
HTTPS |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Memory Size |
Gap |
HTTPS |
device memory in MB |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Pool |
Auto Tiering |
Implemented |
HTTPS |
indicates if this storagepool is participating in auto tiering with other pools |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Reserved Capacity |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Volume |
Capacity |
Implemented |
HTTPS |
Snapshot Used capacity in MB |
Junction Path |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Redundancy |
Implemented |
HTTPS |
Redundancy level |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Volume Map |
LUN |
Implemented |
HTTPS |
Name of the backend lun |
Protocol Controller |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Volume Mask |
Initiator |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Port |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
performance |
Storage |
Latency Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
StoragePool Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Volume |
Latency Total |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Nutanix REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
OpenStack (REST API / SSH)
foundation |
Data Store |
Capacity |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Provisioned Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
NasShare DataStore |
DataStore OID |
Implemented |
HTTPS |
Nas Share OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
NasShare Host |
Nas Share OID |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Read Only |
Implemented |
HTTPS |
LUN |
OID |
Implemented |
HTTPS |
Number |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
Disk Name |
Implemented |
HTTPS |
TID |
Implemented |
HTTPS |
NAS Share |
Capacity |
Implemented |
HTTPS |
Allocated capacity in MB |
Filer Ip |
Implemented |
HTTPS |
Filer Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Share Path |
Implemented |
HTTPS |
For a HvNasShare to be matched to a Share |
Type |
Gap |
HTTPS |
Path |
OID |
Implemented |
HTTPS |
Lun OID |
Implemented |
HTTPS |
Host Port WWPN |
Implemented |
HTTPS |
Storage Port WWPN |
Implemented |
HTTPS |
Active |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Server |
Cluster |
Implemented |
HTTPS |
Cluster name |
DataCenter Name |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Virtual Center Ip |
Implemented |
HTTPS |
Virtual Disk |
Capacity |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Lun OID |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
VirtualMachine |
Guest State |
Implemented |
HTTPS |
DataStore OID |
Implemented |
HTTPS |
Host OID |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
MOID |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Power State |
Implemented |
HTTPS |
State Change Time |
Implemented |
HTTPS |
Processors |
Implemented |
HTTPS |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
VirtualMachine Disk |
OID |
Implemented |
HTTPS |
VirtualDisk OID |
Implemented |
HTTPS |
VirtualMachine OID |
Implemented |
HTTPS |
Host |
Host Cpu Count |
Implemented |
HTTPS |
Host Domain |
Implemented |
HTTPS |
Host Installed Memory |
Implemented |
HTTPS |
Host OS |
Implemented |
HTTPS |
IPs |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
ISCSI Node |
Host Aliases |
Implemented |
HTTPS |
Node Name |
Implemented |
HTTPS |
OID |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
performance |
Host |
Total CPU Utilization |
Implemented |
Key |
Implemented |
Total Memory Utilization |
Implemented |
Server ID |
Implemented |
OpenStack REST API |
HTTPS |
HTTPS |
443 |
true |
false |
true |
true |
OpenStack SSH |
SSH |
SSH |
22 |
true |
false |
true |
true |
Oracle ZFS (HTTPS)
Sun ZFS Storage 7120 |
1-1.1 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTP/S |
Used capacity |
Disk Id |
Implemented |
HTTP/S |
Location |
Gap |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Role |
Implemented |
HTTP/S |
Role Enum |
Implemented |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
Speed |
Implemented |
HTTP/S |
Status |
Implemented |
HTTP/S |
Status Enum |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Type Enum |
Implemented |
HTTP/S |
Vendor |
Implemented |
HTTP/S |
Info |
DataSource Name |
Implemented |
HTTP/S |
Info |
Date |
Implemented |
HTTP/S |
Originator ID |
Implemented |
HTTP/S |
Originator Key |
Implemented |
HTTP/S |
Internal Volume |
Compression Enabled |
Implemented |
HTTP/S |
Is compression enabled on the storage pool |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Dedupe Enabled |
Implemented |
HTTP/S |
Dedupe Savings |
Implemented |
HTTP/S |
ratio of dedupe savings in percentage |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Protection Type |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Storage Pool Id |
Implemented |
HTTP/S |
Thin Provisioned |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
QTree |
Name |
Implemented |
HTTP/S |
Qtree Id |
Implemented |
HTTP/S |
Quota UsedCapacity |
Implemented |
HTTP/S |
Space in MB currently used |
Type |
Gap |
HTTP/S |
Quota |
Implemented |
HTTP/S |
Qtree Id |
Implemented |
HTTP/S |
Quota Id |
Implemented |
HTTP/S |
Soft Capacity Limit (MB) |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Used Capacity |
Implemented |
HTTP/S |
User/Group Target |
Implemented |
HTTP/S |
user/group target this quota refers to |
Storage |
Display IP |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Family |
Implemented |
HTTP/S |
IP |
Implemented |
HTTP/S |
Manufacturer |
Implemented |
HTTP/S |
Microcode Version |
Implemented |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Storage Node |
Memory Size |
Gap |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Processors Count |
Implemented |
HTTP/S |
device CPU |
Serial Number |
Implemented |
HTTP/S |
State |
Implemented |
HTTP/S |
UUID |
Implemented |
HTTP/S |
Version |
Implemented |
HTTP/S |
software version |
Storage Pool |
Auto Tiering |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Data Allocated Capacity |
Gap |
HTTP/S |
capacity allocated for data |
Implemented |
HTTP/S |
Dedupe Enabled |
Implemented |
HTTP/S |
Dedupe Savings |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Raid Group |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Redundancy |
Implemented |
HTTP/S |
Redundancy level |
Implemented |
HTTP/S |
Status |
Implemented |
HTTP/S |
Storage Pool Id |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Volume |
Auto Tiering |
Implemented |
HTTP/S |
Capacity |
Implemented |
HTTP/S |
Disk Size |
Implemented |
HTTP/S |
comma seperated list of disk sizes (GB) |
Disk Speed |
Implemented |
HTTP/S |
comma seperated list of disk speeds (rpm) |
Disk Type |
Not Available |
HTTP/S |
Junction Path |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Redundancy |
Implemented |
HTTP/S |
Redundancy level |
Storage Pool Id |
Implemented |
HTTP/S |
Thin Provisioned |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
UUID |
Implemented |
HTTP/S |
Used Capacity |
Implemented |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Volume Map |
LUN |
Implemented |
HTTP/S |
Masking Required |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Storage Port |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Volume Mask |
Initiator |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Storage Port |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
performance |
Disk |
IOPs Total |
Implemented |
Internal Volume |
IOPs Total |
Implemented |
Total Capacity |
Implemented |
Implemented |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
Snapshot Used Capacity Ratio |
Implemented |
Qtree |
Used Capacity |
Implemented |
Total File Count |
Implemented |
Storage |
IOPs Read |
Implemented |
IOPs other |
Implemented |
IOPs Write |
Implemented |
Cache Hit Ratio Total |
Implemented |
Throughput Read |
Implemented |
Throughput Write |
Implemented |
Throughput Total |
Implemented |
IOPs Total |
Implemented |
Implemented |
Implemented |
Implemented |
Raw Capacity |
Implemented |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Storage Node |
IOPs Read |
Implemented |
IOPs Write |
Implemented |
IOPs Total |
Implemented |
Implemented |
Throughput Total |
Implemented |
Utilization Total |
Implemented |
Throughput Write |
Implemented |
Throughput Read |
Implemented |
Storage Node Data |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Utilization Total |
Implemented |
StoragePool Disk |
IOPs Total |
Implemented |
Oracle ZFS REST API |
HTTP/HTTPS |
HTTP/HTTPS |
215 |
true |
true |
true |
true |
Pure Storage FlashArray (HTTP)
DFSC1 |
5.3.14 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTP/S |
Used capacity |
Disk Id |
Implemented |
HTTP/S |
Location |
Gap |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Role |
Implemented |
HTTP/S |
Role Enum |
Implemented |
HTTP/S |
Seek Time |
Implemented |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
Speed |
Implemented |
HTTP/S |
Status |
Implemented |
HTTP/S |
Status Enum |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Type Enum |
Implemented |
HTTP/S |
Vendor |
Implemented |
HTTP/S |
IP |
Implemented |
HTTP/S |
Listening Port |
Implemented |
HTTP/S |
Nic |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Portal Group Name |
Implemented |
HTTP/S |
Portal Group Tag |
Implemented |
HTTP/S |
ISCSI Node |
Node Name |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
ISCSI Node Map |
OID |
Implemented |
HTTP/S |
Portal Group OID |
Implemented |
HTTP/S |
ISCSI Session |
Initiator Ips |
Implemented |
HTTP/S |
Initiator OID |
Implemented |
HTTP/S |
Max Connections |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Portal Group OID |
Implemented |
HTTP/S |
Security |
Implemented |
HTTP/S |
Info |
DataSource Name |
Implemented |
HTTP/S |
Info |
Date |
Implemented |
HTTP/S |
Originator ID |
Implemented |
HTTP/S |
Originator Key |
Implemented |
HTTP/S |
Storage |
Display IP |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Family |
Implemented |
HTTP/S |
IP |
Implemented |
HTTP/S |
Manage URL |
Implemented |
HTTP/S |
Manufacturer |
Implemented |
HTTP/S |
Microcode Version |
Implemented |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Serial Number |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Storage Node |
Memory Size |
Gap |
HTTP/S |
Model |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
State |
Implemented |
HTTP/S |
UUID |
Implemented |
HTTP/S |
Version |
Implemented |
HTTP/S |
software version |
Storage Pool |
Gap |
HTTP/S |
Implemented |
HTTP/S |
Dedupe Enabled |
Implemented |
HTTP/S |
Dedupe Savings |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Raid Group |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Redundancy |
Implemented |
HTTP/S |
Redundancy level |
Implemented |
HTTP/S |
Storage Pool Id |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Mode |
Implemented |
HTTP/S |
Mode Enum |
Implemented |
HTTP/S |
Source Storage |
Implemented |
HTTP/S |
Source Volume |
Implemented |
HTTP/S |
State |
Implemented |
HTTP/S |
State Enum |
Implemented |
HTTP/S |
Target Storage |
Implemented |
HTTP/S |
Target Volume |
Implemented |
HTTP/S |
Technology |
Implemented |
HTTP/S |
Volume |
Capacity |
Implemented |
HTTP/S |
Disk Size |
Implemented |
HTTP/S |
Disk Speed |
Implemented |
HTTP/S |
Disk Type |
Not Available |
HTTP/S |
Name |
Implemented |
HTTP/S |
Protection Type |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Redundancy |
Implemented |
HTTP/S |
Redundancy level |
Storage Pool Id |
Implemented |
HTTP/S |
Thin Provisioned |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
UUID |
Implemented |
HTTP/S |
Used Capacity |
Implemented |
HTTP/S |
Virtual |
Implemented |
HTTP/S |
Written Capacity |
Implemented |
HTTP/S |
Total capacity written to this volume by a Host in MB |
Implemented |
HTTP/S |
Volume Map |
LUN |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Storage Port |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Volume Mask |
Initiator |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Storage Port |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
WWN Alias |
Host Aliases |
Implemented |
HTTP/S |
Object Type |
Implemented |
HTTP/S |
Source |
Implemented |
HTTP/S |
WWN |
Implemented |
HTTP/S |
performance |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Storage |
Implemented |
Raw Capacity |
Implemented |
Implemented |
Implemented |
IOPs other |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Key |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Server ID |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
StoragePool Disk |
Implemented |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Implemented |
Volume |
Raw Capacity |
Implemented |
Total Capacity |
Implemented |
Used Capacity |
Implemented |
Implemented |
IOPs Read |
Implemented |
IOPs Total |
Implemented |
IOPs Write |
Implemented |
Latency Read |
Implemented |
Latency Total |
Implemented |
Latency Write |
Implemented |
Throughput Read |
Implemented |
Throughput Total |
Implemented |
Throughput Write |
Implemented |
Pure Storage REST API |
HTTP/HTTPS |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
Red Hat RHV (REST)
foundation |
Data Store |
Capacity |
Implemented |
HTTP/S |
MOID |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Used Capacity |
Implemented |
HTTP/S |
Virtual Center Ip |
Implemented |
HTTP/S |
DataStore OID |
Implemented |
HTTP/S |
Nas Share OID |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
NasShare Host |
Host OID |
Implemented |
HTTP/S |
Nas Share OID |
Implemented |
HTTP/S |
Read Only |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
LUN |
DataStore OID |
Implemented |
HTTP/S |
Host OID |
Implemented |
HTTP/S |
Number |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
NAS Share |
Filer Name |
Implemented |
HTTP/S |
Filer Ip |
Implemented |
HTTP/S |
Share Path |
Implemented |
HTTP/S |
Capacity |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
OID |
Implemented |
HTTP/S |
Path |
Active |
Implemented |
HTTP/S |
Lun OID |
Implemented |
HTTP/S |
Host Port WWPN |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Storage Port WWPN |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Server |
Cluster |
Implemented |
HTTP/S |
Cluster name |
DataCenter Name |
Implemented |
HTTP/S |
Host OID |
Implemented |
HTTP/S |
MOID |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Virtual Center Ip |
Implemented |
HTTP/S |
Virtual Disk |
Capacity |
Implemented |
HTTP/S |
DataStore OID |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Used Capacity |
Implemented |
HTTP/S |
VirtualMachine |
Guest State |
Implemented |
HTTP/S |
DataStore OID |
Implemented |
HTTP/S |
Host OID |
Implemented |
HTTP/S |
MOID |
Implemented |
HTTP/S |
Memory |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
OS |
Implemented |
HTTP/S |
Power State |
Implemented |
HTTP/S |
State Change Time |
Implemented |
HTTP/S |
Processors |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Used Capacity |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
VirtualDisk OID |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Host |
Host Cpu Count |
Implemented |
HTTP/S |
Host Cpu Speed |
Implemented |
HTTP/S |
Implemented |
HTTP/S |
Host Model |
Implemented |
HTTP/S |
NIC count |
Implemented |
HTTP/S |
NIC speed |
Implemented |
HTTP/S |
IPs |
Implemented |
HTTP/S |
Manufacturer |
Implemented |
HTTP/S |
Name |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Platform Type |
Implemented |
HTTP/S |
ISCSI Node |
Node Name |
Implemented |
HTTP/S |
OID |
Implemented |
HTTP/S |
Type |
Gap |
HTTP/S |
Info |
DataSource Name |
Implemented |
HTTP/S |
Info |
Date |
Implemented |
HTTP/S |
Originator ID |
Implemented |
HTTP/S |
Red Hat RHEV REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
Rubrik Storage
Firmware versions:
8.1.3-p12-25506
8.1.3-p13-25544
8.1.3-p2-24912
9.0.3-p10-25744
9.0.3-p5-25595
9.0.3-p6-25611
9.1.1-27527
9.1.2-27824
9.1.2-p1-27870
9.1.2-p1-27870_HP1473894
9.1.3-p1-28075
9.1.3-p8-28434
9.2.2-p1-29213
9.2.3-29313
9.2.3-p1-29368
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Info |
Api Description |
Implemented |
HTTPS |
Api Name |
Implemented |
HTTPS |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Originator Key |
Implemented |
HTTPS |
Storage |
Cluster |
Not Available |
HTTPS |
Whether this storage is a cluster |
Cpu Count |
Implemented |
HTTPS |
Cpu Count of the storage |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Memory |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
Storage Node |
Memory Size |
Gap |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Site Name |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Effective Used Capacity Percent |
Implemented |
HTTPS |
performance |
Storage |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Storage Node |
IOPs Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
Storage Node Data |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Utilization Total |
Implemented |
HTTPS |
StoragePool Disk |
IOPs Read |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
Total Capacity |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Rubrik Storage REST API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
VAST DataStore
VA2437096 |
Build version :release-5.0.0-sp24-1389206 |
foundation |
Disk |
Capacity (GB) |
Implemented |
HTTPS |
Used capacity |
Disk Id |
Implemented |
HTTPS |
Location |
Gap |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Role |
Implemented |
HTTPS |
Role Enum |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Speed |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Status Enum |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Type Enum |
Implemented |
HTTPS |
Vendor |
Implemented |
HTTPS |
File Share |
Is InternalVolume |
Implemented |
HTTPS |
whether the file share represents an internal volume (netapp volume) or is it a qtree/folder within the internal volume |
Is Oplocks Enabled |
Implemented |
HTTPS |
whether opportunistic locks are enabled on the FileShare |
Is Shared |
Implemented |
HTTPS |
whether this fileShare has any shares associated with it |
Name |
Implemented |
HTTPS |
Path |
Implemented |
HTTPS |
Path of the fileShare |
Qtree Id |
Implemented |
HTTPS |
unique id of the qtree |
Security Type |
Implemented |
HTTPS |
Status |
Implemented |
HTTPS |
Info |
DataSource Name |
Implemented |
HTTPS |
Info |
Date |
Implemented |
HTTPS |
Originator ID |
Implemented |
HTTPS |
Internal Volume |
Implemented |
HTTPS |
Compression Savings |
Implemented |
HTTPS |
Dedupe Enabled |
Implemented |
HTTPS |
Internal Volume Id |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Thin Provisioned |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Virtual Storage |
Implemented |
HTTPS |
Owning virtual storage (vfiler) |
Implemented |
HTTPS |
QTree |
Name |
Implemented |
HTTPS |
Qtree Id |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Quota |
Hard Capacity Limit (MB) |
Implemented |
HTTPS |
max amount of disk space, allowed for the quota target (Hard limit) |
Implemented |
HTTPS |
Quota Id |
Implemented |
HTTPS |
unique id of the quota |
Implemented |
HTTPS |
Maximum amount of disk space, allowed for the quota target |
Soft File Limit |
Implemented |
HTTPS |
Max number of files allowed for the quota target |
Type |
Gap |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
Used Files |
Implemented |
HTTPS |
Number of files currently used |
User/Group Target |
Implemented |
HTTPS |
Share |
IP Interfaces |
Implemented |
HTTPS |
comma separated list of IP addresses on which this share is exposed |
Name |
Implemented |
HTTPS |
Protocol |
Implemented |
HTTPS |
enum for share protocol |
Share Initiator |
Initiator |
Implemented |
HTTPS |
Permission |
Implemented |
HTTPS |
Permissions for this particular share |
Storage |
Cpu Count |
Implemented |
HTTPS |
Display IP |
Implemented |
HTTPS |
Implemented |
HTTPS |
Family |
Implemented |
HTTPS |
IP |
Implemented |
HTTPS |
Manage URL |
Implemented |
HTTPS |
Manufacturer |
Implemented |
HTTPS |
Microcode Version |
Implemented |
HTTPS |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Serial Number |
Implemented |
HTTPS |
Implemented |
HTTPS |
Virtual |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Storage Node |
Model |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Processors Count |
Implemented |
HTTPS |
device CPU |
Serial Number |
Implemented |
HTTPS |
State |
Implemented |
HTTPS |
UUID |
Implemented |
HTTPS |
Version |
Implemented |
HTTPS |
software version |
Implemented |
HTTPS |
Parent Serial Number |
Implemented |
HTTPS |
Site Name |
Implemented |
HTTPS |
Storage Pool |
Implemented |
HTTPS |
Implemented |
HTTPS |
Gap |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Name |
Implemented |
HTTPS |
Implemented |
HTTPS |
Raid Group |
Implemented |
HTTPS |
Implemented |
HTTPS |
Reserved Capacity |
Implemented |
HTTPS |
Reserved Capacity in MB |
Snapshot Allocated Capacity |
Gap |
HTTPS |
Allocated capacity of snapshots in MB |
Implemented |
HTTPS |
Storage Pool Id |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
Virtual |
Implemented |
HTTPS |
Encrypted |
Implemented |
HTTPS |
Storage VirtualMachine |
Allocated capacity (MB) |
Implemented |
HTTPS |
Allocated capacity of snapshots |
Comment |
Implemented |
HTTPS |
Guid Key |
Implemented |
HTTPS |
Globally Unique Key of the storage virtual machine |
Name |
Implemented |
HTTPS |
Type |
Gap |
HTTPS |
UUID |
Implemented |
HTTPS |
Used Capacity |
Implemented |
HTTPS |
VirtualMachine Internal Volume Ref |
Implemented |
HTTPS |
performance |
Storage |
Implemented |
HTTPS |
Raw Capacity |
Implemented |
HTTPS |
Implemented |
HTTPS |
Implemented |
HTTPS |
IO Density Read |
Implemented |
HTTPS |
IO Density Total |
Implemented |
HTTPS |
Write IO Density |
Implemented |
HTTPS |
IOPs other |
Implemented |
HTTPS |
IOPs Read |
Implemented |
HTTPS |
IOPs Total |
Implemented |
HTTPS |
IOPs Write |
Implemented |
HTTPS |
Key |
Implemented |
HTTPS |
Latency Read |
Implemented |
HTTPS |
Latency Total |
Implemented |
HTTPS |
Latency Write |
Implemented |
HTTPS |
Server ID |
Implemented |
HTTPS |
Throughput Read |
Implemented |
HTTPS |
Throughput Total |
Implemented |
HTTPS |
Throughput Write |
Implemented |
HTTPS |
VAST DataStore API |
HTTPS |
HTTPS |
443 |
true |
true |
true |
true |
NetApp HCI Virtual Center
API versions:
VMware vCenter Server 6.7.0 build-10244857
VMware vCenter Server 7.0.3 build-20395099
foundation |
Data Store |
OID |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Implemented |
Web Services |
Virtual Center Ip |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
Type |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Nas Share OID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
NasShare Host |
Host OID |
Implemented |
Web Services |
Nas Share OID |
Implemented |
Web Services |
Read Only |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
LUN |
Disk Name |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
Number |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Policy |
Implemented |
Web Services |
TID |
Implemented |
Web Services |
Volume Uuid |
Implemented |
Web Services |
NAS Share |
Filer Name |
Implemented |
Web Services |
Filer Ip |
Implemented |
Web Services |
Share Path |
Implemented |
Web Services |
Capacity |
Implemented |
Web Services |
Type |
Gap |
Web Services |
OID |
Implemented |
Web Services |
Path |
Active |
Implemented |
Web Services |
Lun OID |
Implemented |
Web Services |
Host Port WWPN |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Storage Port WWPN |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Server |
Cluster |
Implemented |
Web Services |
Cluster name |
DataCenter Name |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Virtual Center Ip |
Implemented |
Web Services |
Virtual Disk |
OID |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
used capacity for reporting (MB) |
Type |
Gap |
Web Services |
Lun OID |
Implemented |
Web Services |
VirtualMachine |
OID |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
Dns Name |
Implemented |
Web Services |
OS |
Implemented |
Web Services |
Processors |
Implemented |
Web Services |
Memory |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Power State |
Implemented |
Web Services |
State Change Time |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
IPs |
Implemented |
Web Services |
Guest State |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Implemented |
Web Services |
VirtualDisk OID |
Implemented |
Web Services |
Host |
Host Cpu Count |
Implemented |
Web Services |
Host Cpu Speed |
Implemented |
Web Services |
Host Domain |
Implemented |
Web Services |
Implemented |
Web Services |
Host Model |
Implemented |
Web Services |
NIC count |
Implemented |
Web Services |
NIC speed |
Implemented |
Web Services |
IPs |
Implemented |
Web Services |
Manufacturer |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Platform Type |
Implemented |
Web Services |
ISCSI Node |
Host Aliases |
Implemented |
Web Services |
Node Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Info |
Api Description |
Implemented |
Web Services |
Api Name |
Implemented |
Web Services |
Api Version |
Implemented |
Web Services |
Client Api Name |
Implemented |
Web Services |
Client Api Version |
Implemented |
Web Services |
DataSource Name |
Implemented |
Web Services |
Info |
Date |
Implemented |
Web Services |
Originator ID |
Implemented |
Web Services |
performance |
Data Store |
Latency Total |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
IOPs Write |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Throughput Write |
Implemented |
Web Services |
Throughput Total |
Implemented |
Web Services |
IOPs Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Total Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Host |
Latency Write |
Implemented |
Web Services |
Throughput total |
Implemented |
Web Services |
IP throughput total |
Swap Rate |
Implemented |
Web Services |
Disk IOPs write |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
ipThroughput.write |
Implemented |
Web Services |
IP Throughput Read |
Implemented |
Web Services |
Disk Throughput Read |
Implemented |
Web Services |
swapRate.inRate |
Implemented |
Web Services |
Disk Throughput Write |
Implemented |
Web Services |
Implemented |
Web Services |
diskIops.total |
Implemented |
Web Services |
Total Swap Rate |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
total disk throughput read |
Host |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
diskIops.total |
Implemented |
Web Services |
Disk IOPs write |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput total |
Implemented |
Web Services |
Implemented |
Web Services |
Key |
Implemented |
Web Services |
Implemented |
Web Services |
Server ID |
Implemented |
Web Services |
swapRate.inRate |
Implemented |
Web Services |
Swap Rate |
Implemented |
Web Services |
Total Swap Rate |
Implemented |
Web Services |
Virtual Disk |
Latency Total |
Implemented |
Web Services |
Total Capacity |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
IOPs Write |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Throughput Write |
Implemented |
Web Services |
Throughput Total |
Implemented |
Web Services |
IOPs Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
vm |
Latency Write |
Implemented |
Web Services |
Throughput total |
Implemented |
Web Services |
Swap Rate |
Implemented |
Web Services |
Disk IOPs write |
Implemented |
Web Services |
cpuCoSchedulingDelayTimePercent.total |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
Implemented |
Web Services |
Idle CPU Time |
Implemented |
Web Services |
idle time in percent |
Latency Read |
Implemented |
Web Services |
cpuDemandToEntitlementPercent.total |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
CPU Wait Time |
Implemented |
Web Services |
total cpu wait time in percent |
swapRate.inRate |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Schedule wait time |
Implemented |
Web Services |
Waiting to be scheduled time in percent |
diskIops.total |
Implemented |
Web Services |
Total Swap Rate |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
VMware REST API |
Web Services |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
VMware Cloud on AWS
Models and versions supported by this data collector:
API versions:
VMware vCenter Server 7.0.3 build-21477706
VMware vCenter Server 7.0.3 build-24322018
VMware vCenter Server 8.0.0 build-22877852
VMware vCenter Server 8.0.1 build-22161730
VMware vCenter Server 8.0.1 build-23525738
VMware vCenter Server 8.0.3 build-24322831
Products supported by this data collector:
Product | Category | Feature/Attribute | Status | Protocol Used | Additional Information |
foundation |
Data Store |
Capacity |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Virtual Center Ip |
Implemented |
Web Services |
Type |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Nas Share OID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
NasShare Host |
Nas Share OID |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Read Only |
Implemented |
Web Services |
LUN |
OID |
Implemented |
Web Services |
Number |
Implemented |
Web Services |
Policy |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
Disk Name |
Implemented |
Web Services |
TID |
Implemented |
Web Services |
NAS Share |
Capacity |
Implemented |
Web Services |
Filer Ip |
Implemented |
Web Services |
Filer Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Share Path |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Path |
OID |
Implemented |
Web Services |
Lun OID |
Implemented |
Web Services |
Host Port WWPN |
Implemented |
Web Services |
Storage Port WWPN |
Implemented |
Web Services |
Active |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Server |
Cluster |
Implemented |
Web Services |
Cluster name |
DataCenter Name |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Virtual Center Ip |
Implemented |
Web Services |
Virtual Disk |
Capacity |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Used Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
VirtualMachine |
Dns Name |
Implemented |
Web Services |
Guest State |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
IPs |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
Memory |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
OS |
Implemented |
Web Services |
Power State |
Implemented |
Web Services |
State Change Time |
Implemented |
Web Services |
Processors |
Implemented |
Web Services |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
UUID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
VirtualDisk OID |
Implemented |
Web Services |
Implemented |
Web Services |
Host |
Host Cpu Count |
Implemented |
Web Services |
Host Cpu Speed |
Implemented |
Web Services |
Host Domain |
Implemented |
Web Services |
Implemented |
Web Services |
Host Model |
Implemented |
Web Services |
NIC count |
Implemented |
Web Services |
NIC speed |
Implemented |
Web Services |
IPs |
Implemented |
Web Services |
Manufacturer |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Platform Type |
Implemented |
Web Services |
Info |
Api Description |
Implemented |
Web Services |
Api Name |
Implemented |
Web Services |
Api Version |
Implemented |
Web Services |
Client Api Name |
Implemented |
Web Services |
Implemented |
Web Services |
DataSource Name |
Implemented |
Web Services |
Info |
Date |
Implemented |
Web Services |
Originator ID |
Implemented |
Web Services |
performance |
Host |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
diskIops.total |
Implemented |
Web Services |
Disk IOPs write |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput total |
Implemented |
Web Services |
Implemented |
Web Services |
Key |
Implemented |
Web Services |
Implemented |
Web Services |
Server ID |
Implemented |
Web Services |
swapRate.inRate |
Implemented |
Web Services |
Swap Rate |
Implemented |
Web Services |
Total Swap Rate |
Implemented |
Web Services |
VMware REST API |
Web Services |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
VMware vSphere (Web Services)
API versions:
VMware ESXi 6.0.0 build-10474991
VMware ESXi 6.0.0 build-10719132
VMware ESXi 6.0.0 build-13635687
VMware ESXi 6.0.0 build-2494585
VMware ESXi 6.0.0 build-3620759
VMware ESXi 6.0.0 build-5050593
VMware ESXi 6.0.0 build-5224934
VMware ESXi 6.0.0 build-9239799
VMware ESXi 6.5.0 build-5310538
VMware ESXi 7.0.3 build-20036589
VMware ESXi 7.0.3 build-20328353
VMware ESXi 8.0.0 build-21203435
VMware ESXi 8.0.1 build-21495797
VMware vCenter Server 5.0.0 build-623373
VMware vCenter Server 5.5.0 build-1750787
VMware vCenter Server 5.5.0 build-2442329
VMware vCenter Server 5.5.0 build-3252642
VMware vCenter Server 5.5.0 build-6516310
VMware vCenter Server 5.5.0 build-9911218
VMware vCenter Server 6.0.0 build-13638472
VMware vCenter Server 6.0.0 build-14510545
VMware vCenter Server 6.0.0 build-2776511
VMware vCenter Server 6.0.0 build-3634793
VMware vCenter Server 6.0.0 build-5183551
VMware vCenter Server 6.0.0 build-9313458
VMware vCenter Server 6.5.0 build-10964411
VMware vCenter Server 6.5.0 build-12863991
VMware vCenter Server 6.5.0 build-15259038
VMware vCenter Server 6.5.0 build-17994927
VMware vCenter Server 6.5.0 build-18499837
VMware vCenter Server 6.5.0 build-18711281
VMware vCenter Server 6.5.0 build-20510539
VMware vCenter Server 6.5.0 build-22499743
VMware vCenter Server 6.5.0 build-5973321
VMware vCenter Server 6.7.0 build-11727113
VMware vCenter Server 6.7.0 build-14070654
VMware vCenter Server 6.7.0 build-14792544
VMware vCenter Server 6.7.0 build-15679289
VMware vCenter Server 6.7.0 build-17137232
VMware vCenter Server 6.7.0 build-17137327
VMware vCenter Server 6.7.0 build-18010560
VMware vCenter Server 6.7.0 build-18010599
VMware vCenter Server 6.7.0 build-18485185
VMware vCenter Server 6.7.0 build-18831049
VMware vCenter Server 6.7.0 build-19299595
VMware vCenter Server 6.7.0 build-19832280
VMware vCenter Server 6.7.0 build-20504301
VMware vCenter Server 6.7.0 build-20504362
VMware vCenter Server 6.7.0 build-22509751
VMware vCenter Server 6.7.0 build-24323669
VMware vCenter Server 6.7.0 build-8170161
VMware vCenter Server 7.0.2 build-17958471
VMware vCenter Server 7.0.2 build-18356314
VMware vCenter Server 7.0.2 build-18455184
VMware vCenter Server 7.0.2 build-22781136
VMware vCenter Server 7.0.3 build-18778458
VMware vCenter Server 7.0.3 build-19234570
VMware vCenter Server 7.0.3 build-19480866
VMware vCenter Server 7.0.3 build-19717403
VMware vCenter Server 7.0.3 build-20150588
VMware vCenter Server 7.0.3 build-20845200
VMware vCenter Server 7.0.3 build-20990077
VMware vCenter Server 7.0.3 build-21290409
VMware vCenter Server 7.0.3 build-21784236
VMware vCenter Server 7.0.3 build-21958406
VMware vCenter Server 7.0.3 build-22357613
VMware vCenter Server 7.0.3 build-22837322
VMware vCenter Server 7.0.3 build-23085514
VMware vCenter Server 7.0.3 build-23788036
VMware vCenter Server 7.0.3 build-24026615
VMware vCenter Server 7.0.3 build-24201990
VMware vCenter Server 8.0.0 build-20519528
VMware vCenter Server 8.0.0 build-20920323
VMware vCenter Server 8.0.0 build-21216066
VMware vCenter Server 8.0.0 build-21457384
VMware vCenter Server 8.0.1 build-21560480
VMware vCenter Server 8.0.1 build-21815093
VMware vCenter Server 8.0.1 build-21860503
VMware vCenter Server 8.0.1 build-22088981
VMware vCenter Server 8.0.1 build-22368047
VMware vCenter Server 8.0.1 build-24005165
VMware vCenter Server 8.0.2 build-22385739
VMware vCenter Server 8.0.2 build-22617221
VMware vCenter Server 8.0.2 build-23319993
VMware vCenter Server 8.0.2 build-23504390
VMware vCenter Server 8.0.2 build-23929136
VMware vCenter Server 8.0.2 build-24321653
VMware vCenter Server 8.0.3 build-24022515
VMware vCenter Server 8.0.3 build-24091160
VMware vCenter Server 8.0.3 build-24262322
VMware vCenter Server 8.0.3 build-24305161
foundation |
Data Store |
Capacity |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Virtual Center Ip |
Implemented |
Web Services |
Type |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Nas Share OID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
NasShare Host |
Nas Share OID |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Read Only |
Implemented |
Web Services |
LUN |
Disk Name |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
Number |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Policy |
Implemented |
Web Services |
TID |
Implemented |
Web Services |
Volume Uuid |
Implemented |
Web Services |
NAS Share |
Capacity |
Implemented |
Web Services |
Filer Ip |
Implemented |
Web Services |
Filer Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Share Path |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Path |
Active |
Implemented |
Web Services |
Lun OID |
Implemented |
Web Services |
Host Port WWPN |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Storage Port WWPN |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Server |
Cluster |
Implemented |
Web Services |
Cluster name |
DataCenter Name |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Virtual Center Ip |
Implemented |
Web Services |
Virtual Disk |
Capacity |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Lun OID |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Used Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
VirtualMachine |
Dns Name |
Implemented |
Web Services |
Guest State |
Implemented |
Web Services |
DataStore OID |
Implemented |
Web Services |
Host OID |
Implemented |
Web Services |
IPs |
Implemented |
Web Services |
MOID |
Implemented |
Web Services |
Memory |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
OS |
Implemented |
Web Services |
Power State |
Implemented |
Web Services |
State Change Time |
Implemented |
Web Services |
Processors |
Implemented |
Web Services |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
UUID |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
VirtualDisk OID |
Implemented |
Web Services |
Implemented |
Web Services |
Host |
Host Cpu Count |
Implemented |
Web Services |
Host Cpu Speed |
Implemented |
Web Services |
Host Domain |
Implemented |
Web Services |
Implemented |
Web Services |
Host Model |
Implemented |
Web Services |
NIC count |
Implemented |
Web Services |
NIC speed |
Implemented |
Web Services |
IPs |
Implemented |
Web Services |
Manufacturer |
Implemented |
Web Services |
Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Platform Type |
Implemented |
Web Services |
ISCSI Node |
Host Aliases |
Implemented |
Web Services |
Node Name |
Implemented |
Web Services |
OID |
Implemented |
Web Services |
Type |
Gap |
Web Services |
Info |
Api Description |
Implemented |
Web Services |
Api Name |
Implemented |
Web Services |
Api Version |
Implemented |
Web Services |
Client Api Name |
Implemented |
Web Services |
Implemented |
Web Services |
DataSource Name |
Implemented |
Web Services |
Info |
Date |
Implemented |
Web Services |
Originator ID |
Implemented |
Web Services |
performance |
Data Store |
Capacity Provisioned |
Implemented |
Web Services |
Total Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Over Commit Capacity Ratio |
Implemented |
Web Services |
Reported as a time series |
Capacity Used Ratio |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
Number of read IOPs on the disk |
IOPs Total |
Implemented |
Web Services |
IOPs Write |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Throughput Total |
Implemented |
Web Services |
Average disk total rate (read and write across all disks) in MB/s |
Throughput Write |
Implemented |
Web Services |
Host |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
diskIops.total |
Implemented |
Web Services |
Disk IOPs write |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput total |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
swapRate.inRate |
Implemented |
Web Services |
Swap Rate |
Implemented |
Web Services |
Total Swap Rate |
Implemented |
Web Services |
Host |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
diskIops.total |
Implemented |
Web Services |
Disk IOPs write |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput total |
Implemented |
Web Services |
Implemented |
Web Services |
Key |
Implemented |
Web Services |
Implemented |
Web Services |
Server ID |
Implemented |
Web Services |
swapRate.inRate |
Implemented |
Web Services |
Swap Rate |
Implemented |
Web Services |
Total Swap Rate |
Implemented |
Web Services |
Virtual Disk |
Total Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
IOPs Total |
Implemented |
Web Services |
IOPs Write |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Throughput Total |
Implemented |
Web Services |
Throughput Write |
Implemented |
Web Services |
vm |
Total Capacity |
Implemented |
Web Services |
Used Capacity |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Idle CPU Time |
Implemented |
Web Services |
CPU Wait Time |
Implemented |
Web Services |
Implemented |
Web Services |
IOPs Read |
Implemented |
Web Services |
diskIops.total |
Implemented |
Web Services |
Disk IOPs write |
Implemented |
Web Services |
Latency Read |
Implemented |
Web Services |
Latency Total |
Implemented |
Web Services |
Latency Write |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput Read |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
Throughput total |
Implemented |
Web Services |
Implemented |
Web Services |
Implemented |
Web Services |
swapRate.inRate |
Implemented |
Web Services |
Swap Rate |
Implemented |
Web Services |
Total Swap Rate |
Implemented |
Web Services |
Implemented |
Web Services |
Management APIs used by this data collector:
API | Protocol Used | Transport layer protocol used | Incoming ports used | Outgoing ports used | Supports authentication | Requires only 'Read-only' credentials | Supports Encryption | Firewall friendly (static ports) |
VMware REST API |
Web Services |
HTTP/HTTPS |
80/443 |
true |
true |
true |
true |
