Learn about billing preferences for licenses and subscriptions
Billing preferences allows you to determine how you handle payments and renewal behavior for your active licenses and subscriptions.
You can apply these preferences globally, so they affect all billing relationships, or at the individual subscription level when a specific contract requires its own configuration.
Marketplace subscriptions correspond to cloud marketplace contracts (AWS, Azure, or Google Cloud) where usage charges are through a cloud provider account
Direct licenses represent licenses purchased directly from NetApp, managed in NetApp Console through license keys, invoice recipients, and renewal options.
You can configure how your organization allocates and pays for services depending on your procurement model.
Permissions
The management of licenses and subscriptions within the NetApp Console is controlled through user roles. These roles provide distinct access levels, enabling or restricting specific actions that users can take for this feature.
| Role | Description |
Admin |
Users with this role have full control over licenses and subscriptions. Admin users can:
Viewer |
Users with this role have read-only access. Viewer users can:
Billing preferences
Billing preferences ensure that usage charges and renewals are applied correctly. Configuring them properly reduces billing disputes and makes it easier to manage hybrid licensing models that combine NetApp-owned and marketplace-purchased capacity.
For example, global billing preferences can unify your invoice contact list so all services share a single billing administrator. You can also use cost center tags to align usage across departments or regions, and enable automatic renewal to prevent service interruptions.
New Cloud Volumes ONTAP deployments automatically inherit the billing mode you define here, which keeps your organization's chargeback model consistent as new systems are added.
Billing preferences are configured in the Licenses and subscriptions section of NetApp Console.
From there, you can:
Set billing preferences for your organization
Enable advanced mapping of Cloud Volumes ONTAP instances to marketplace subscriptions
Edit or update marketplace subscription details
Flexible billing for Cloud Volumes ONTAP and data services in AWS
In AWS, Cloud Volumes ONTAP capacity and NetApp data services can be billed through different AWS marketplace subscriptions. For details on AWS Enterprise Discount Program (EDP) changes and recommendations, see the Cloud Volumes ONTAP release notes.
When subscribing through AWS marketplace, you can choose from four offerings:
| Offering | Description |
Cloud Volumes ONTAP only (annual contract) |
Standalone Cloud Volumes ONTAP offering with annual billing. Recommended for new Cloud Volumes ONTAP deployments. |
Cloud Volumes ONTAP only (PAYGO) |
Standalone Cloud Volumes ONTAP offering with flexible usage-based billing. Recommended for new Cloud Volumes ONTAP deployments. |
NetApp Intelligent Services (annual contract) |
NetApp data services with annual billing. Supports Cloud Volumes ONTAP for existing contracts only. |
NetApp Intelligent Services (PAYGO) |
NetApp data services with flexible usage-based billing. Supports Cloud Volumes ONTAP for existing contracts only. |
If more than one of these subscriptions is associated with your AWS account, use Billing preferences to select which subscription is used for Cloud Volumes ONTAP capacity billing.
Billing behavior depends on whether you have existing Cloud Volumes ONTAP systems already running and billed through a NetApp Intelligent Services subscription, or you are deploying new systems after adding a Cloud Volumes ONTAP only subscription. For existing systems, adding a Cloud Volumes ONTAP only subscription does not change billing unless you update Billing preferences. For new deployments, a Cloud Volumes ONTAP only subscription is used by default for Cloud Volumes ONTAP capacity billing (Essentials/Freemium), unless you override it in Billing preferences.
The Cloud Volumes ONTAP only offerings support only capacity-based Essentials and Freemium packages. The Professional package is not supported on either Cloud Volumes ONTAP only offering and continues to bill through a NetApp Intelligent Services subscription. If you have only a Cloud Volumes ONTAP only subscription associated, you can deploy Cloud Volumes ONTAP using Essentials, but configuring Backup and Recovery requires a NetApp Intelligent Services subscription.
Where to configure it
You associate AWS marketplace subscriptions under Administration > Licenses and subscriptions > Marketplace subscriptions, and you choose the marketplace subscription used for Cloud Volumes ONTAP capacity billing under Administration > Licenses and subscriptions > Billing preferences. You can verify charging details using Cloud Volumes ONTAP usage reports.
No duplicate metering occurs when you use multiple subscription types or migrate between listings. |
Fields
Billing fields store metadata about how each license or subscription is billed.
They describe who is billed, how renewals occur, and which account or cost center each service belongs to.
Marketplace fields
Marketplace fields describe contracts that originate from a cloud provider such as AWS, Azure, or Google Cloud.
These fields define how NetApp Console connects your subscriptions with the billing information stored in the provider's marketplace.
They also control how renewals, regional assignments, and billing accounts are managed.
Marketplace provider — Identifies the cloud platform where billing is handled.
The provider determines the supported features, contract types, and renewal rules.
For example, AWS marketplace subscriptions use account-based billing, while Azure may support both account and tenant-based models. -
Billing account or subscription ID — Specifies the unique identifier for the account used to process charges.
This ensures that usage data is billed to the correct cloud billing profile. -
Contract term — Defines the subscription duration and renewal settings.
Direct license fields
Direct license fields apply to NetApp-managed contracts purchased directly rather than through a cloud marketplace.
They define how NetApp invoices you, where the charges are sent, and what legal entity appears on the invoice.
These fields are critical for organizations using purchase orders or centralized corporate billing.
Keystone fields
Keystone fields apply to usage that falls under a NetApp Keystone subscription agreement.
They allow you to connect metered service usage to your Keystone billing profile, aligning subscription data with other capacity-based licensing models.
Agreement ID — A unique identifier for the Keystone contract.
It links the billing record in NetApp Console with your Keystone agreement and allows synchronization of usage reporting. -
Service scope — Lists the services or capacity pools that fall under the Keystone agreement.
This field clarifies which workloads or deployments are included in the contract and ensures that only eligible resources are billed through Keystone.
Billing options and definitions
Billing options define how NetApp Console prioritizes and applies usage charges when multiple billing sources are connected.
They control which account is charged first and how billing switches between NetApp licenses and marketplace subscriptions when capacity limits are reached.
Terms and options
You can choose between billing modes depending on your organization's procurement strategy:
NetApp licenses first — Prioritizes billing through active NetApp licenses.
When capacity from these licenses is exhausted, usage automatically rolls over to the linked marketplace subscription. -
Marketplace subscriptions only — Directs all billing through marketplace contracts, bypassing NetApp licenses.
This is common for organizations that standardize procurement through cloud provider billing. -
PAYGO (Pay-As-You-Go) — Bills only for actual usage.
Annual contract — Locks in a defined subscription term.
Auto-renew — Enables automatic continuation of licenses or marketplace contracts when they expire.
Disabling this option requires manual renewal to prevent service interruption. -
Custom Cloud Volumes ONTAP configuration — Allows mapping multiple marketplace subscriptions to a cloud provider.
This might be useful when different business units or projects require distinct billing accounts within the same cloud environment.
Typical configuration paths
The following examples illustrate how different billing setups align with common cases:
| Scenario | Recommended billing option |
Your organization purchased NetApp capacity directly |
NetApp licenses first |
All usage is billed through marketplace contracts |
Marketplace subscriptions only |
You bill multiple projects under one cloud provider |
Enable Custom CVO configuration |
You want to revert to a simple single-source billing setup |
Disable Custom CVO configuration |
For instance, consider an organization that combines both direct NetApp licenses and marketplace subscriptions.
A typical configuration would set NetApp licenses first as the default billing mode to use prepaid capacity before marketplace billing.
Then, under Custom CVO configuration, each cloud provider (AWS, Azure, Google Cloud) would be assigned its corresponding subscription ID.
After saving these settings, administrators can review the mappings under Licenses and subscriptions to verify that each service points to the correct account.
For additional validation, they can compare usage data in NetApp Console against cloud billing dashboards and adjust cost center tags or contacts as needed to maintain reporting consistency.
