Cloud Volumes ONTAP
What's new in Cloud Volumes ONTAP
Contributors netapp-manini netapp-shwetav netapp-ahibbard RSS
Learn what's new with Cloud Volumes ONTAP management in the NetApp Console.
The enhancements described on this page are specific to managing Cloud Volumes ONTAP through the Console. To learn about the major releases and patches, refer to Cloud Volumes ONTAP Release Notes.
02 November 2026
Guidance for upgrading ONTAP hotfixes for specific Cloud Volumes ONTAP versions
ONTAP has released the following hotfixes compatible with Cloud Volumes ONTAP versions 9.14.1, 9.15.1, 9.16.1, 9.17.1, 9.18.1, and 9.19.1:
  • 9.14.1P18HF1
  • 9.15.1P20HF1
  • 9.16.1P16HF1
  • 9.17.1P11HF1
  • 9.18.1P8HF1
  • 9.19.1P3HF1
For details, refer to NTAP Security Advisory 20261021-0021.
For your Cloud Volumes ONTAP systems, you might be prompted to upgrade to these hotfixes in the NetApp Console. However, these hotfixes are supported only when the Console agent version is 4.12.0 or later. If the Console agent version is earlier than 4.12.0, ignore the prompt.
14 October 2026
Cloud Volumes ONTAP 9.19.1 in Azure
You can now use the NetApp Console to deploy and manage the General Availability (GA) version of Cloud Volumes ONTAP 9.19.1 in Azure.
The Console has supported Cloud Volumes ONTAP 9.19.1 in AWS and Google Cloud since August 2026.
Azure encryption at host for Cloud Volumes ONTAP
Starting with Cloud Volumes ONTAP 9.19.1 GA, Azure encryption at host is enabled by default for new Azure single-node and high availability (HA) deployments that meet the prerequisites. This feature encrypts data on the physical server that hosts the VM, including the ephemeral disk and associated host-level caches, as data is written to and read from the host.
Before deploying Cloud Volumes ONTAP in Azure, confirm that your environment meets the following prerequisites:
Note these points:
  • No additional configuration is required.
  • If these prerequisites aren't met, Azure encryption at host is not enabled for your Cloud Volumes ONTAP deployment.
  • Encryption at host applies only to Azure, not to AWS or Google Cloud.
Backend network encryption on Cloud Volumes ONTAP clusters in Azure and Google Cloud
Cloud Volumes ONTAP 9.19.1 and later support backend cluster network encryption for HA configurations in Azure and Google Cloud.
Enabling cluster network encryption might affect cluster performance. Exercise caution and verify that your environment can accommodate the additional overhead before enabling this feature.
Ability to reduce disruptions during Azure scheduled maintenance
During scheduled maintenance, Azure can briefly pause a VM in a Cloud Volumes ONTAP HA pair. ONTAP might interpret the pause as a node outage and move storage operations to the partner node, then move them back when the VM resumes (takeover and giveback). This process can disrupt active client connections even when there is no node failure.
With Cloud Volumes ONTAP 9.19.1 and later, you can enable an optional setting that lets the HA pair continue operating through an Azure scheduled-maintenance freeze without automatically initiating takeover and giveback.
Note This feature is available as a public preview with Cloud Volumes ONTAP 9.19.1.
21 September 2026
Support for capacity-based licenses in private-mode deployments
You can now deploy Cloud Volumes ONTAP systems in private mode with capacity-based licenses in AWS, Azure, and Google Cloud.
NetApp supports only the Essentials package for capacity-based licensing in private mode. Purchase a capacity-based Bring-Your-Own License (BYOL) Essentials package from NetApp and assign it to your system during deployment. The first 500 GiB of consumed capacity does not count toward your license charges. You can purchase additional packages as your workload requirements grow.
NetApp recommends capacity-based licensing for all private-mode Cloud Volumes ONTAP deployments. If you have existing private-mode deployments with node-based licenses, you can convert them to capacity-based licensing by purchasing an Essentials package from NetApp. This new deployment capability, combined with the conversion option, supports NetApp's plan to gradually move away from node-based licensing to capacity-based licensing.
02 September 2026
Cloud Volumes ONTAP support in Azure Secret and Top Secret regions (private preview)
Cloud Volumes ONTAP now supports deployment in Azure Government Secret and Top Secret regions in private preview. This capability extends Cloud Volumes ONTAP to Microsoft's classified Azure environments, enabling government and defense customers to use ONTAP for data management, protection, and disaster recovery to support workloads for national security. Contact your NetApp accounts team to participate.
For information, refer to Azure documentation:
25 August 2026
Support for Austria East and Belgium Central regions in Azure
You can now deploy Cloud Volumes ONTAP 9.12.1 GA and later in the Austria East (austriaeast) and Belgium Central (belgiumcentral) regions in Azure. The following deployment types are supported:
  • Single-node
  • HA in a single availability zone using locally redundant storage (LRS)
  • HA in multiple availability zones using zone-redundant storage (ZRS)
For a list of all supported regions, refer to the Global Regions Map under Azure.
10 August 2026
You can now use the NetApp Console to deploy and manage the General Availability (GA) version of Cloud Volumes ONTAP 9.19.1 in Amazon Web Service (AWS) and Google Cloud. This version is unavailable for deployment and upgrade in Microsoft Azure (Azure).
Ability to convert node-based licenses to capacity-based licensing in private mode
NetApp is excited to announce capacity-based licensing for private-mode Cloud Volumes ONTAP deployments. You can now optimize costs for your private-mode Cloud Volumes ONTAP deployments by converting your node-based license to the capacity-based licensing. For your private-mode deployments, you can purchase an Essentials (Bring-Your-Own License or BYOL) package directly from NetApp with a capacity similar to your existing node-based license.
This conversion option supports NetApp's phased plan to move away from node-based licensing in favor of capacity-based licensing. Unlike node-based licensing, which allocates a fixed capacity to each system, capacity-based licensing draws from a shared capacity pool across your Cloud Volumes ONTAP systems, giving you greater flexibility to redistribute workloads as your storage needs change.
03 August 2026
Cloud Volumes ONTAP integration with Microsoft OneLake
Cloud Volumes ONTAP now supports integration with Microsoft OneLake in public preview. This integration allows you to make existing Cloud Volumes ONTAP NAS data available to Microsoft analytics and AI services such as Power BI, Azure AI Search, OpenAI, and Microsoft Copilot. The integration requires no data movement or duplication. The integration uses ONTAP S3 multi-protocol access to connect Cloud Volumes ONTAP to an existing Microsoft Fabric lakehouse.
Fix, dismiss, and reactivate configurations for Cloud Volumes ONTAP in Microsoft Azure
The well-architected dashboard in NetApp Console now allows you to fix configuration recommendations for your Cloud Volumes ONTAP systems.
You can also dismiss one or more configurations from the well-architected analysis. This allows you to ignore specific configurations that don't apply to your environment.
If you want to include a dismissed configuration later, you can reactivate it in the well-architected dashboard. This restores the configuration to the analysis and allows you to get recommendations and fixes for it.
23 July 2026
Support for Chile Central region in Azure
You can now deploy Cloud Volumes ONTAP 9.12.1 GA and later in the Chile Central (chilecentral) region in Azure. The following deployment types are supported:
  • Single-node
20 July 2026
Introducing simplified onboarding of Cloud Volumes ONTAP from AWS Marketplace
NetApp introduces a simplified onboarding flow for Cloud Volumes ONTAP from AWS Marketplace, reducing manual steps and onboarding friction.
Previously, deploying Cloud Volumes ONTAP from AWS Marketplace required navigating multiple screens and manually configuring roles, policies, and credentials. This made onboarding slow and error-prone.
The new onboarding flow simplifies your transition from a marketplace subscription to a fully operational Cloud Volumes ONTAP environment with the following features:
  1. Subscription to the dedicated Cloud Volumes ONTAP listing on AWS Marketplace: You subscribe to the Cloud Volumes ONTAP standalone listing on AWS Marketplace, purchase a subscription, and set up your AWS account (if you don't already have one).
  2. Guided path on the NetApp Console: You set up your account in the NetApp Console, and the Console automatically onboards you to the deployment journey, displaying the guided path on the right side. In case you need to leave the Console, you can resume the guided journey at a later point.
  3. Associating your subscription: You can automatically associate your subscription with the Console, avoiding the manual steps of linking it yourself.
  4. Console agent deployment with AWS credentials configuration: You can automatically create the required AWS roles. The process deploys an AWS CloudFormation stack in your AWS account with the required roles and policies for you to review, then associates them with the NetApp Console, eliminating manual IAM setup. You then continue through agent configuration, networking, and security group settings to begin the agent deployment.
  5. Deploy a new Cloud Volumes ONTAP system in AWS: You navigate directly to the Quick create wizard for a faster, simplified Cloud Volumes ONTAP deployment.
Well-architected configuration analysis for Cloud Volumes ONTAP in Azure
The NetApp Console now supports well-architected configuration analysis for Cloud Volumes ONTAP systems running in Microsoft Azure. The Console analyzes your deployments daily and provides a well-architected status, insights, and recommendations to help you maintain systems that align with NetApp best practices and the well-architected framework.
The well-architected dashboard displays the total number of analyzed systems and categorizes their resources by configuration and severity level. If you are a system administrator, you can view recommendations for any configuration issue within your organization directly from the Console dashboard and download a CSV report of all the recommendations. Configurations are categorized according to:
  • Reliability: Ensures workloads operate correctly and consistently, even in the event of disruptions.
  • Security: Safeguards data, systems, and assets through risk assessments and mitigation.
  • Operational excellence: Optimizes architecture to maximize business value.
  • Cost optimization: Reduces and optimizes costs for greater business value.
14 July 2026
The Cloud Volumes ONTAP 9.19.1 Release Candidate (RC) version is available in only Google Cloud for upgrade to 9.19.1 General Availability (GA).
Support for next-generation Google Cloud VMs in Cloud Volumes ONTAP HA
With 9.19.1, NetApp transitions Cloud Volumes ONTAP high-availability (HA) deployments off N2 VMs to the next-generation Google Cloud C3-series VMs for a faster and more scalable experience.
Note This support applies only to single availability zone (AZ) HA deployments.
You can now take advantage of C3-series VMs while deploying Cloud Volumes ONTAP 9.19.1 and later in Google Cloud. These machines offer improved performance and higher capacity limits. They use Google Virtual NIC (gVNIC) and Hyperdisk Balanced disks for dynamic performance on intensive workloads.
If your Cloud Volumes ONTAP system runs 9.19.1 or later, the preconfigured packages that you use for easy deployments in single AZs automatically use C3 VMs, while enabling you to customize the IOPS and throughput parameters based on your workload needs. Similarly, while creating aggregates, you can add Zonal Hyperdisk Balanced disks to achieve better performance and scalability in Google Cloud. You can also select the LSSD variants of the C3 series machines for default Flash Cache support.
Note these points:
  • In your Cloud Volumes ONTAP deployments you can't change C3 VMs to N2-series VMs and vice versa. However, you can switch instance types among different variants within the C3 family.
    Note Changing the instance type within the C3 family might take longer based on the number of data disks attached. Plan your configuration ahead of time to avoid performance impacts.
  • When changing the instance type, if you select c3-standard-44 or c3-standard-88 and their local SSD (LSSD) variants as the target VM, the Google network service egress network tier Tier-1 is applied automatically. If you switch back to any other C3 variant, the egress network tier is set to Standard.
    Note Changing the egress network tier to Tier-1 incurs additional costs. Plan the deployment and upgrade accordingly.
  • If you select the LSSD variants of C3, Flash Cache gets enabled by default. You can't switch between C3 LSSD variants in your Cloud Volumes ONTAP deployment, even if the target variant supports Flash Cache.
  • On your C3 VMs, you can add volumes to both new and existing aggregates.
  • When replicating a Cloud Volumes ONTAP system with an N2 VM type to a C3 VM type, the disk type is set by default to Hyperdisk Balanced.
  • You can change the IOPS and throughput settings when adding aggregates through the NetApp Console or by using the PUT /gcp/ha/aggregates/{workingEnvironmentId}/{aggregateName} API.
Simplified Cloud Volumes ONTAP deployment in Google Cloud
You can now use the Quick create wizard to deploy Cloud Volumes ONTAP in Google Cloud for both single-node and high-availability (HA) configurations. This streamlined process reduces steps, sets default values automatically on a single page, and minimizes navigation for faster and easier deployment.
Introducing access roles for Cloud Volumes ONTAP
NetApp introduces identity and access management (IAM) roles for Cloud Volumes ONTAP, enabling role-based access control (RBAC) for better security and easier compliance. Users can continue to log in to the NetApp Console using their existing credentials for Cloud Volumes ONTAP operations. However, authentication is now routed through identity federation, enabling the Console administrator to have more granular control over these functions. The Console agent must be running version 4.9.0 or later before enabling Cloud Volumes ONTAP roles.
Every user must have one of the following roles for performing any operation on Cloud Volumes ONTAP. Without a role, users can't view or access Cloud Volumes ONTAP instances.
  • Cloud Volumes ONTAP viewer: Grants read-only access to Cloud Volumes ONTAP screens and tabs. Certain screens and action buttons are disabled in this role.
  • Cloud Volumes ONTAP operator: Enables day-to-day management tasks, such as adding volumes, managing storage, and configuring replication.
  • Cloud Volumes ONTAP admin: Provides full access to all Cloud Volumes ONTAP operations.
The Console administrator assigns roles to Cloud Volumes ONTAP users from Administration > Identity. Role permissions are based on a user's organization and apply across all Cloud Volumes ONTAP systems in that organization.
Cloud Volumes ONTAP enforces RBAC using a local cache of each user's permissions, which is refreshed automatically once every hour. When a user is assigned a new role or their existing role is changed, it may take up to one hour for that change to take effect, after which, all workflows permitted by the roles are enabled.
Note When a Console agent is deployed for the first time, or an existing Console agent is upgraded to Console 4.9.0 or later, a one-time seeding process automatically assigns Cloud Volumes ONTAP roles to all existing users in the organization. This process can take up to 30 minutes to complete. When complete, the Console assigns appropriate roles to existing users. The seeding process doesn't occur unless there's an agent running.
Cloud Volumes ONTAP roles apply to Amazon Web Service (AWS), Microsoft Azure (Azure), and Google Cloud environments. The roles do not apply to private and restricted modes of deployment.
11 June 2026
Support for a new Azure region in Cloud Volumes ONTAP
You can now deploy Cloud Volumes ONTAP 9.12.1 GA and later in single and multiple availability zones in Azure in the Malaysia West (malaysiawest) region. This includes support for both single-node and high-availability (HA) deployments.
For a list of all regions, refer to the Global Regions Map under Azure.
08 June 2026
Support for new EC2 instances for Cloud Volumes ONTAP in AWS
Cloud Volumes ONTAP 9.16.1 and later support M6id and M6idn EC2 instance families for both new and existing single-node and high-availability (HA) pair deployments in AWS. These 6th-generation instances offer faster processing power, stronger networking capabilities, and higher performance compared to the 5th generation general purpose systems.
  • M6id instances: Provide a balance of compute and memory with high-speed, low-latency local NVMe storage. All M6id instance sizes support Flash Cache. These instances are well suited for workloads such as data logging and media processing.
  • M6idn instances: Provide the same local NVMe storage capabilities as M6id instances. All M6idn instance sizes support Flash Cache.
We do not recommend the smaller-sized m6id.xlarge, m6id.2xlarge, m6idn.xlarge, and m6idn.2xlarge instance types for high-performance or memory-intensive workloads. For these workloads, use an instance type with a higher core count and larger memory.
18 May 2026
Simplified Cloud Volumes ONTAP deployment in Azure
You can now use Quick create to deploy Cloud Volumes ONTAP in Azure for both single-node and high-availability (HA) configurations. This streamlined process reduces the number of steps compared to the advanced method, automatically sets default values on a single page, and minimizes navigation, making deployment faster and easier.
12 May 2026
Flexible billing for Cloud Volumes ONTAP and data services in AWS
NetApp offers enhanced billing options for your Cloud Volumes ONTAP subscriptions in AWS, giving you more control over how you pay for Cloud Volumes ONTAP capacity and NetApp data services, such as NetApp Backup and Recovery.
Previously, all Cloud Volumes ONTAP and data services usage were billed together through the NetApp Intelligent Services (NIS) listing in the AWS marketplace.
Due to changes in AWS Enterprise Discount Program (EDP), NetApp has introduced a standalone Cloud Volumes ONTAP subscription in the AWS marketplace that allows you to separate the billing of Cloud Volumes ONTAP capacity from data services. This separation gives you more flexibility in managing your EDP credits and costs. NetApp recommends using the standalone subscription for better cost management of your Cloud Volumes ONTAP usage, while continuing to use the NIS subscription for billing data services after July 31, 2026, when the EDP requirements take effect.
The standalone Cloud Volumes ONTAP subscription in AWS supports only valid capacity-based Essentials or Freemium license packages. The Professional package is not supported. You can select the billing method that best suits your needs:
  • Standalone Cloud Volumes ONTAP subscription (Recommended): Pay for your Cloud Volumes ONTAP usage through the standalone subscription in the AWS marketplace, while continuing to bill data services through the NIS subscription. This is the recommended option for most customers who have both standalone and NIS subscriptions associated with their AWS account in the NetApp Console.
  • Combined NIS subscription: Pay for both Cloud Volumes ONTAP and data services together through the existing NIS listing. The combined approach will be valid for existing customers who have only NIS subscriptions associated with their AWS account in the NetApp Console. However, NetApp recommends that you set your billing preference for your Cloud Volumes ONTAP usage and switch to the standalone subscription for better cost management.
Depending on your subscription type, you get these scenarios:
Standalone subscription only (new customers)
If you have only a standalone AWS subscription associated with your AWS account in the NetApp Console and no NIS subscriptions, you can select only the Essentials license package during deployment. The data services Backup and Recovery option is unavailable to you.
Both standalone and NIS subscriptions (existing customers)
If you have both NIS and standalone subscriptions associated with your AWS account, and you haven't set a billing preference through the Billing preferences tab in the NetApp Console, Cloud Volumes ONTAP usage continues to bill through NIS by default. This is also the default for any Cloud Volumes ONTAP instance running the Professional package, because the standalone listing does not support Professional. You can set a billing preference and choose how to bill each service:
  • Set the standalone subscription as the preferred billing account for Cloud Volumes ONTAP (with Essentials package). If you have only the Professional package, you can convert it to an Essentials package and charge your Cloud Volumes ONTAP usage by setting the billing preference. We recommend this approach because it helps you manage your Cloud Volumes ONTAP EDP credits more effectively.
  • Use the NIS subscription for billing data services, or the Cloud Volumes ONTAP usage through the Professional package. During deployment, enable the Backup and Recovery data service and select the Professional license package to bill data services through the NIS subscription.
NIS subscription only (existing customers)
This is applicable if you are an existing customer with NIS subscriptions associated with the AWS account. You can continue billing both Cloud Volumes ONTAP and data services together as you do now. However, NetApp recommends switching to the standalone subscription approach for better cost management of your Cloud Volumes ONTAP usage:
  • Subscribe to a new standalone listing on the AWS portal.
  • Link the standalone subscription to your AWS account.
  • Set your billing preference to the standalone subscription for Cloud Volumes ONTAP usage with the Essentials package.
  • (If applicable) Convert your Professional package to an Essentials package and set the billing preference.
  • Continue billing data services through your NIS subscription.
Note No duplicate metering occurs when you use multiple subscription types or migrate between listings.
13 April 2026
Improved Cloud Volumes ONTAP support with Google Cloud C3 VMs
Cloud Volumes ONTAP now has enhanced support for the Google Cloud C3 series VMs, enabling these additional capabilities:
  • In your Cloud Volumes ONTAP deployments, you can switch instance types among different variants within the C3 family.
  • When changing the instance type, if you select c3-standard-44 or c3-standard-88 and their LSSD variants as the target VM, the Google network service egress network tier Tier-1 is applied automatically. If you switch to any other C3 variant, the egress network tier is set to Standard.
  • If you select the local SSD (LSSD) variants of C3, Flash Cache gets enabled by default. You can't switch between C3 LSSD variants in your Cloud Volumes ONTAP deployment, even if the target variant supports Flash Cache.
  • On your C3 VMs, you can now add volumes to both new and existing aggregates.
  • You can change the IOPS and throughput settings when adding volumes through the NetApp Console or by using the PUT /gcp/vsa/aggregates/{workingEnvironmentId}/{aggregateName} API.
10 March 2026
Ability to manage Console agent proxy settings for Cloud Volumes ONTAP
You can now manage proxy settings on the NetApp Console agent for Cloud Volumes ONTAP, even if you lose connection or the proxy is set up incorrectly. Previously, if the Console agent could not connect to Cloud Volumes ONTAP for 20 minutes, it overwrote your manual proxy settings with default settings. This caused communication failures, including issues with AutoSupport messages. To retain your proxy settings for existing systems, run the following API call:
PUT /occm/config
Include the following parameter in the request body:
  "proxyMode": "No_Overwrites"
The default mode is standard, which means the Console agent overwrites your proxy settings with defaults if it cannot connect to Cloud Volumes ONTAP for 20 minutes.
26 February 2026
Support for Google Infrastructure Manager for private-mode deployments
Cloud Volumes ONTAP 9.16.1 and later now support Google Cloud Infrastructure Manager (IM) instead of Cloud Deployment Manager (DM) for new private-mode deployments in Google Cloud. Google is deprecating Deployment Manager as an infrastructure service in favor of the more advanced Infrastructure Manager.
Beginning February 25, 2026, Cloud Volumes ONTAP uses Infrastructure Manager for new and existing private-mode deployments. The basic workflow depends on your scenario:
Scenario Action New APIs for the agent New permissions for the agent New Google Cloud APIs for Cloud Volumes ONTAP Doc resources
Existing agent and existing deployment in private mode
Upgrade to the latest version of the Console agent by downloading the installer from the NetApp Support Site and then manually installing the agent on your host, so that it can use Infrastructure Manager APIs. Then, convert the existing Cloud Volumes ONTAP systems to use Infrastructure Manager.
  • Cloud Infrastructure Manager API
  • Cloud Quotas API
  • Cloud Build API
All the permissions listed for the Console release on:
  • https://cloudbuild.googleapis.com/v1
  • https://www.googleapis.com/upload/storage/v1
  • https://config.googleapis.com/v1
Configure existing Cloud Volumes ONTAP deployments for Google Cloud Infrastructure Manager
New agent and new deployment
Create a new agent and deploy a new Cloud Volumes ONTAP system in private mode.
In private-mode deployments, you need to make a few configuration changes for Cloud Volumes ONTAP to start using Infrastructure Manager. Refer to Infrastructure Manager configuration in private mode or protected environments.
19 February 2026
New regions supported in Azure
You can now deploy Cloud Volumes ONTAP 9.12.1 GA and later in single and multiple availability zones in Azure in the following regions. This includes support for both single-node and high-availability (HA) deployments.
  • Japan West (japanwest)
  • Indonesia Central (indonesiacentral)
17 February 2026
Cloud Volumes ONTAP support for next-generation Google Cloud VMs
With 9.18.1, NetApp transitions new Cloud Volumes ONTAP deployments off N2 VMs to the next-generation Google Cloud C3 series VMs for a faster and more scalable experience. You can now take advantage of C3 series VMs while deploying Cloud Volumes ONTAP 9.18.1 and later in Google Cloud. The C3 series machines offer improved performance and higher capacity limits by using Google Virtual NIC (gVNIC) and Hyperdisk Balanced disks that ensure dynamic performance for intensive workloads.
Note For now, Cloud Volumes ONTAP supports the C3 series only in single-node deployments.
If your Cloud Volumes ONTAP system runs 9.18.1 or later, the preconfigured packages that you use for easy single node deployments automatically use C3 VMs, while enabling you to customize the IOPS and throughput parameters based on your workload needs. Similarly, while creating aggregates, you can add Hyperdisk Balanced disks to achieve better performance and scalability in Google Cloud. Additionally, you can select the LSSD variants of the C3 series machines for default Flash Cache support.
You can't change the disk type for C3 VMs when adding volumes to aggregates because C3 supports only Hyperdisk Balanced disks. Similarly, when replicating a system with N2 VM types to a C3 VM, the disk type is set by default to Hyperdisk Balanced.
VNet security for Cloud Volumes ONTAP in Azure
Cloud Volumes ONTAP 9.18.1 and later deployments in Azure single and multiple availability zones support Azure Virtual Network (VNet) encryption as part of its layered security strategy to protect data in transit. Cloud Volumes ONTAP leverages Azure's native Datagram Transport Layer Security (DTLS) protocol to secure communication between ONTAP nodes, management interfaces, and other Azure services, preventing interception and unauthorized access. This network-level encryption complements ONTAP's built-in storage and data-at-rest protections to deliver end-to-end security of your data.
12 February 2026
Support for Ebdsv5 and E104ids_v5 VMs in Azure
Beginning with Cloud Volumes ONTAP 9.18.1, you can deploy Ebdsv5 and E104ids_v5 VMs for single-node and high-availability (HA) deployments and upgrades.
Ebdsv5 VMs within the Eb family of Azure virtual machines are optimized for higher remote storage performance. You can use these VMs for memory-intensive and I/O-heavy enterprise workloads, such as relational databases, in-memory analytics, and other demanding business-critical applications.
E104ids_v5 is an isolated VM instance that helps you better handle scheduled maintenance windows. Compared to E80ids_v4, it offers much higher disk throughput and IOPS, along with better overall network performance.
10 February 2026
Cloud Volumes ONTAP 9.18.1 GA
You can now use the NetApp Console to deploy and manage the General Availability (GA) version of Cloud Volumes ONTAP 9.18.1 in AWS, Azure, and Google Cloud.
9 February 2026
Support for Google Cloud Infrastructure Manager
Cloud Volumes ONTAP 9.16.1 and later now support Google Cloud Infrastructure Manager (IM) instead of Cloud Deployment Manager (DM) for new deployments in Google Cloud. Google will deprecate Deployment Manager as an infrastructure service in the near future for the more advanced Infrastructure Manager.
Beginning February 09, 2026, Cloud Volumes ONTAP uses Infrastructure Manager for new and existing deployments. This table explains a few workflows for you:
Existing agent and existing Cloud Volumes ONTAP deployment
Add new APIs and permissions to the existing agent and convert the existing Cloud Volumes ONTAP system.
  • Cloud Quotas API
Existing agent and new Cloud Volumes ONTAP deployment
Add new APIs and permissions to the existing agent and deploy a new Cloud Volumes ONTAP system.
  • Cloud Quotas API
All the steps for new deployment
Create a new agent and deploy a new Cloud Volumes ONTAP system.
Now, deploy Cloud Volumes ONTAP to automatically use Infrastructure Manager or switch your existing deployments in Deployment Manager to Infrastructure Manager by running a conversion tool. The conversion is a one-time process, after which your systems will start using Infrastructure Manager. Refer to Configure existing Cloud Volumes ONTAP deployments for Google Cloud Infrastructure Manager for instructions on running the conversion tool.
Cloud Volumes ONTAP systems that use Infrastructure Manager use Google Cloud Storage buckets to store data and records in the zone of the first deployment to store deployment records, which are reused for subsequent deployments. You might incur extra costs for these buckets, but do not edit or delete the buckets or their content:
  • gs://netapp-cvo-infrastructure-manager-<project id>: for ONTAP versions and SVM Terraform Templates used for new Cloud Volumes ONTAP deployments. Inside this, the dm-to-im-convert bucket contains the Cloud Volumes ONTAP Terraform files.
  • <gcp project number>-<region>-blueprint-config: for storing Google Cloud Terraform artifacts.
12 January 2026
Preferred billing option for Cloud Volumes ONTAP
You can now select a preferred billing option for calculating your Cloud Volumes ONTAP usage and overages. Since the limited availability of the Bring Your Own Licenses (BYOL) licensing model on June 25, 2025, NetApp has added preferred charging methods in the Licensing and Subscriptions section of the NetApp Console. You can use either your annual marketplace subscription for billing and overages or the existing BYOL model as the preferred option. This gives you the flexibility to choose the charging method that best fits your organization's financial strategy and usage patterns.
10 December 2025
Ability to enhance performance of Premium SSD v2 disks in Azure
You can now enhance the performance of Premium SSD v2 Managed Disks in Azure by modifying the IOPS and throughput parameters. Using this capability, you can optimize the storage performance of your systems based on your workload requirements.
Overage charging for Essentials licenses simplified
For Cloud Volumes ONTAP marketplace annual contracts/private offers, overage calculations for Essentials licenses is now aligned with Bring-Your-Own License (BYOL) packages. Previously, overages were billed at hourly marketplace rates for the exact Essentials package. Now, if your marketplace annual contract includes multiple Essentials packages, the NetApp Console charges overages for an Essentials package against the available capacity of a higher-priced Essentials package in your subscription. This simplifies overage calculations for Essentials packages and ensures a smooth transition from BYOL licensing to a subscription-based model.
Support for Azure Edsv6 sizes series
Beginning with Cloud Volumes ONTAP 9.17.1, you can deploy Azure Edsv6 series VMs through the NetApp Console for new Cloud Volumes ONTAP instances. Cloud Volumes ONTAP 9.17.1 and later will support only Generation 2 VMs for new deployments. These Generation 2 machines are compatible with the latest technologies, such as Unified Extensible Firmware Interface (UEFI), Azure Boost systems, and NVMe. They are ideal for memory-intensive systems and applications that need fast, local storage, such as database servers and analytics engines.
10 November 2025
Enhanced NVMe-TCP Support
Earlier, when deploying Cloud Volumes ONTAP instances over NVMe-TCP, you would have to to manually obtain and apply NVMe licenses before deployment. With this update, Cloud Volumes ONTAP now automatically installs the required NVMe licenses during deployment, simplifying the setup process.
For existing NVMe-TCP deployments that lack licenses, Cloud Volumes ONTAP applies the licenses automatically. You must restart the system for the licenses to take effect.
17 October 2025
Cloud Volumes ONTAP in Azure now limited to latest supported versions
Cloud Volumes ONTAP deployments and upgrades in Azure through the NetApp Console are now restricted to the latest supported versions. This ensures compatibility with the latest generation hardware supported by Microsoft and provides the newest features and security enhancements. The Console will prompt you to upgrade to the supported versions.
For more details, refer to:
06 October 2025
BlueXP is now NetApp Console
The NetApp Console, built on the enhanced and restructured BlueXP foundation, provides centralized management of NetApp storage and NetApp Data Services across on-premises and cloud environments at enterprise grade—delivering real-time insights, faster workflows, and simplified administration, that is highly secure and compliant.
For details on what has changed, see the NetApp Console release notes.
Simplified Cloud Volumes ONTAP deployment in AWS
You can now deploy Cloud Volumes ONTAP in AWS using a quick deployment method for both single-node and high-availability (HA) configurations. This streamlined process reduces the number of steps compared to the advanced method, automatically sets default values on a single page, and minimizes navigation, making deployment faster and easier.
04 September 2025
Cloud Volumes ONTAP 9.17.1 RC
You can now use BlueXP to deploy and manage the Release Candidate 1 of Cloud Volumes ONTAP 9.17.1 in Azure and Google Cloud. However, this version is not available for deployment and upgrade in AWS.
11 August 2025
End of availability of Optimized licenses
Beginning on August 11, 2025, the Cloud Volumes ONTAP Optimized license will be deprecated and will no longer be available for purchase or renewal in the Azure and Google Cloud marketplaces for pay-as-you-go (PAYGO) subscriptions. If you have an existing annual contract with an Optimized license, you can continue to use the license until the end of your contract. When your Optimized license expires, you can opt for Cloud Volumes ONTAP Essentials or Professional licenses in BlueXP.
However, the ability to add or renew Optimized licenses will be available through the APIs.
For information about licensing packages, refer to Licensing for Cloud Volumes ONTAP.
For information about switching to a different charging method, refer to Manage capacity-based licensing.
14 July 2025
Support for transparent proxy
BlueXP now supports transparent proxy servers in addition to the existing explicit proxy connections. When creating or modifying the BlueXP Connector, you can configure a transparent proxy server to securely manage network traffic to and from Cloud Volumes ONTAP.
For more information about the use of proxy servers in Cloud Volumes ONTAP, refer to:
New VM type supported for Cloud Volumes ONTAP in Azure
Beginning with Cloud Volumes ONTAP 9.13.1, L8s_v3 is supported as a VM type in Azure single and multiple availability zones, for both new and existing high-availability (HA) pair deployments.
For more information, refer to
Supported configurations in Azure.
25 June 2025
Restricted availability of BYOL licensing for Cloud Volumes ONTAP
Beginning June 25, 2025, NetApp has restricted the Bring-Your-Own License (BYOL) licensing model for Cloud Volumes ONTAP. The restriction applies to all customers and Cloud Volumes ONTAP deployments in AWS, Azure, and Google Cloud. The only exemptions are the U.S. Public Sector customers and China region deployments.
NetApp support and services will continue until your BYOL contract expires, but your expired licenses will not be renewed or extended. When your BYOL licenses expire, you must replace them with capacity-based licenses purchased through your cloud marketplace subscriptions. A capacity-based licensing model through hyperscaler marketplaces streamlines the licensing experience and delivers greater business benefits. Contact your NetApp accounts team or customer success representatives to discuss your options of conversion.
For more information, refer to this customer communiqué: CPC-00661: Changes to Cloud Volumes ONTAP BYOL Policy.
29 May 2025
private-mode deployments enabled for Cloud Volumes ONTAP 9.15.1
You can now deploy Cloud Volumes ONTAP 9.15.1 in private mode in AWS, Azure, and Google Cloud. Private mode is enabled for both single-node and high-availability (HA) deployments of Cloud Volumes ONTAP 9.15.1.
For more information about private-mode deployments refer to
Learn about BlueXP deployment modes.
12 May 2025
Discovery of deployments made through the Azure marketplace in BlueXP
BlueXP now has the capability of discovering the Cloud Volumes ONTAP systems deployed directly through the Azure marketplace. This means that you can now add and manage these systems as working environments in BlueXP, just like any other Cloud Volumes ONTAP system.
16 April 2025
  • Spain Central
  • Mexico Central
14 April 2025
Storage VM creation automated through the APIs in Google Cloud
You can now use the BlueXP APIs to automate the storage VM creation in Google Cloud. You have been using this feature in Cloud Volumes ONTAP high-availability (HA) configurations, and now you can also use it in single node deployments. By using the BlueXP APIs, you can easily create, rename, and delete additional data-serving storage VMs in your Google Cloud environment, without the need to manually configure the required network interfaces, LIFs, and management LIFs. This automation simplifies the process of managing storage VMs.
03 April 2025
Support for China regions for Cloud Volumes ONTAP 9.13.1 in AWS
You can now deploy Cloud Volumes ONTAP 9.13.1 in AWS in China regions. This includes support for both single-node and high-availability (HA) deployments. Only licenses purchased directly from NetApp are supported.
For regional availability, refer to the Global Regions Maps for Cloud Volumes ONTAP.
28 March 2025
private-mode deployments enabled for Cloud Volumes ONTAP 9.14.1
You can now deploy Cloud Volumes ONTAP 9.14.1 in private mode in AWS, Azure, and Google Cloud. Private mode is enabled for both single-node and high-availability (HA) deployments of Cloud Volumes ONTAP 9.14.1.
12 March 2025
New regions supported for multiple availability zone deployments in Azure
The following regions now support HA multiple availability zone deployments in Azure for Cloud Volumes ONTAP 9.12.1 GA and later:
  • Central US
  • US Gov Virginia (US Government Region - Virginia)
10 March 2025
Storage VM creation automated through the APIs in Azure
You can now use the BlueXP APIs to create, rename, and delete additional data-serving storage VMs for Cloud Volumes ONTAP in Azure. Using the APIs automates the process of storage VM creation, including the configuration of the required network interfaces, LIFs, and a management LIF, if you need to use a storage VM for management purposes.
06 March 2025
Cloud Volumes ONTAP 9.16.1 GA
You can now use BlueXP to deploy and manage the Cloud Volumes ONTAP 9.16.1 General Availability release in Azure and Google Cloud. However, this version is not available for deployment and upgrade in AWS.
03 March 2025
Support for New Zealand North region in Azure
The New Zealand North region is now supported in Azure for single node and high-availability (HA) configurations of Cloud Volumes ONTAP 9.12.1 GA and later. Note that the Lsv3 instance type is not supported in this region.
18 February 2025
Introducing Azure marketplace direct deployment
You can now take advantage of Azure marketplace direct deployment to easily and quickly deploy Cloud Volumes ONTAP directly from the Azure marketplace. Using this streamlined method, you can explore the core features and capabilities of Cloud Volumes ONTAP in your environment without the need to set up the BlueXP Connector or meet other onboarding criteria required for deploying Cloud Volumes ONTAP through BlueXP.
10 February 2025
User authentication enabled for accessing System Manager from BlueXP
As a BlueXP administrator, you can now activate authentication for ONTAP users accessing ONTAP System Manager from BlueXP. You can enable this option by editing the BlueXP Connector settings. This option is available for standard and private modes.
BlueXP Advanced View renamed to System Manager
The option for advanced management of Cloud Volumes ONTAP from BlueXP through ONTAP System Manager has been renamed from Advanced View to System Manager.
Introducing a simpler way to manage licenses with the BlueXP digital wallet
Now, you can experience simplified management of Cloud Volumes ONTAP licenses by using improved navigation points within the BlueXP digital wallet:
  • Access your Cloud Volumes ONTAP license information easily through the Administration > Licenses and subscriptions > Overview/Direct Licenses tabs.
  • Select View on the Cloud Volume ONTAP panel in the Overview tab to gain a comprehensive understanding of your capacity-based licenses. This advanced view offers detailed insight into your licenses and subscriptions.
  • If you prefer the previous interface, you can select the Switch to legacy view button to view license details by type and modify charging methods for your licenses.
09 December 2024
List of supported VMs updated for Azure to align with the best practices
The DS_v2 and Es_v3 machine families are no longer available for selection on BlueXP when deploying new instances of Cloud Volumes ONTAP in Azure. These families will be retained and supported only in older, existing systems. New deployments of Cloud Volumes ONTAP are supported in Azure only from the 9.12.1 release. We recommend that you switch to either Es_v4 or any other series compatible with Cloud Volumes ONTAP 9.12.1 and later. The DS_v2 and Es_v3 series machines, however, will be available for new deployments made through the API.
11 November 2024
End of availability for node-based licenses
NetApp has planned the end of availability (EOA) and end of support (EOS) of Cloud Volumes ONTAP node-based licensing. Beginning with 11 November, 2024, the limited availability of node-based licenses has been terminated. The support for node-based licensing ends on 31 December, 2024. After the EOA of your node-based licenses, you should transition to capacity-based licensing by using the BlueXP license conversion tool.
For annual or longer-term commitments, NetApp recommends that you contact your NetApp representative prior to the EOA date or license expiration date to ensure that the prerequisites for the transition are in place. If you don't have a long-term contract for a Cloud Volumes ONTAP node and run your system against an on-demand pay-as-you-go (PAYGO) subscription, it is important to plan your conversion before the EOS date. For both long-term contracts and PAYGO subscriptions, you can use the BlueXP license conversion tool for a seamless conversion.
Removal of node-based deployments from BlueXP
The option to deploy Cloud Volumes ONTAP systems by using node-based licenses is deprecated on BlueXP. Except for a few special cases, you cannot use node-based licenses for Cloud Volumes ONTAP deployments for any cloud provider.
NetApp recognizes the following unique licensing requirements in compliance with contractual obligations and operational needs, and will continue to support node-based licenses in these situations:
  • U.S. Public Sector customers
  • Deployments in private mode
  • China region deployments of Cloud Volumes ONTAP in AWS
  • If you have a valid, non-expired by-node Bring-Your-Own License (BYOL) package
Addition of a cold tier for Cloud Volumes ONTAP data on Azure Blob storage
BlueXP now enables you to select a cold tier to store the inactive capacity tier data on Azure Blob storage. Adding the cold tier to the existing hot and cool tiers provides you with a more affordable storage option and improved cost efficiency.
Option to restrict public access to storage account for Azure
You now have the option to restrict public access to your storage account for Cloud Volumes ONTAP systems in Azure. By disabling access, you can secure your private IP address from exposure even within the same VNet, should there be a need to comply with your organization's security policies. This option also disables data tiering for your Cloud Volumes ONTAP systems, and is applicable to both single node and high-availability pairs.
WORM enablement after deploying Cloud Volumes ONTAP
You now have the ability to activate write once, read many (WORM) storage on an existing Cloud Volumes ONTAP system using BlueXP. This functionality provides you with the flexibility of enabling WORM on a working environment, even if WORM was not enabled on it during its creation. Once enabled, you cannot disable WORM.
25 October 2024
List of supported VMs updated for Google Cloud to align with the best practices
The n1 series machines are no longer available for selection on BlueXP when deploying new instances of Cloud Volumes ONTAP in Google Cloud. The n1 series machines will be retained and supported only in older, existing systems. New deployments of Cloud Volumes ONTAP are supported in Google Cloud only from the 9.8 release. We recommend that you switch to the n2 series machine types that are compatible with Cloud Volumes ONTAP 9.8 and later. The n1 series machines, however, will be available for new deployments performed through the API.
Local Zones support for Amazon Web Services in private mode
BlueXP now supports AWS Local Zones for Cloud Volumes ONTAP high availability (HA) deployments in private mode. The support that was earlier limited to only standard mode has now been extended to include private mode.
Note AWS Local Zones are not supported when using BlueXP in restricted mode.
For more information on AWS Local Zones with HA Deployments, refer to AWS Local Zones.
07 October 2024
Enhanced user experience in version selection for upgrade
Beginning with this release, when you try to upgrade Cloud Volumes ONTAP using the BlueXP notification, you will receive guidance on the default, latest, and compatible versions to use. Also, now you can select the latest patch or major version compatible with your Cloud Volumes ONTAP instance, or manually enter a version for upgrade.
09 September 2024
WORM and ARP functionalities are no longer chargeable
The built-in data protection and security features of WORM (Write Once Read Many) and ARP (Autonomous Ransomware Protection) will be offered with Cloud Volumes ONTAP licenses at no extra cost. The new pricing model applies to both new and existing BYOL and PAYGO/marketplace subscriptions of AWS, Azure, and Google Cloud. Both capacity-based and node-based licenses will contain ARP and WORM for all configurations, including single node and high-availability (HA) pairs, at no additional cost.
The simplified pricing brings you these benefits:
  • Accounts that currently include WORM and ARP will no longer incur charges for these features. Going forward, your billing will only have charges for capacity usage, as it was before this change. WORM and ARP will no longer be included in your future bills.
  • If your current accounts do not include these features, you can now opt for WORM and ARP at no additional cost.
  • All Cloud Volumes ONTAP offerings for any new accounts will exclude charges for WORM and ARP.
Learn more about these features:
23 August 2024
Canada West region now supported in AWS
The Canada West region is now supported in AWS for Cloud Volumes ONTAP 9.12.1 GA and later.
For a list of all regions, see the Global Regions Map under AWS.
22 August 2024
Cloud Volumes ONTAP 9.15.1 GA
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.15.1 General Availability release in AWS, Azure, and Google Cloud.
This release includes the following features and enhancements for Azure.
Support for Premium SSD v2 Managed Disks in Azure
Premium SSD v2 Managed Disks are now supported in Cloud Volumes ONTAP systems on Azure. These premium disks provide higher performance with lower latency at a lower cost for both single node and high-availability (HA) pairs, as compared to Premium SSD Managed Disks. Like other managed disks, the maximum disk size is 32 TiB. You can configure the performance (capacity, throughput, and IOPS) of Premium SSD v2 Managed Disks to keep workloads cost effective while meeting changing performance needs.
Deploy HA pairs in single availability zones in Azure
Beginning with Cloud Volumes ONTAP 9.15.1, you can deploy virtual machine (VM) instances in HA mode in single availability zones (AZs) in Azure. Unlike the previous non-zonal deployments, Cloud Volumes ONTAP 9.15.1 uses Microsoft Virtual Machines Scale Sets in Flexible orchestration mode to deploy all resources, including separate fault domains within the same AZ, guaranteeing optimal availability. This deployment mode, by default, uses Premium SSD v2 Managed Disks when the following conditions are met:
If any of these criteria are not met, the previous non-zonal deployment mode for locally redundant storage (LRS) applies.
Support for Virtual Machines Scale Sets to unify all Azure HA types
Cloud Volumes ONTAP 9.15.1 uses Virtual Machines Scale Sets in Flexible orchestration mode on Azure for deploying virtual machine (VM) instances in single availability zones for high-availability (HA) pairs. This support covers all HA types: page blob, LRS, zone-redundant storage (ZRS) or multi-zonal, and LRS zonal (single AZ).
Support for FlexCache write-back
Beginning with Cloud Volumes ONTAP 9.15.1, FlexCache write-back is supported as an alternate mode of operation for writing at a cache.
For more information about this feature, refer to the ONTAP documentation FlexCache write-back overview.
For information about how BlueXP manages FlexCache volumes, refer to the BlueXP volume caching documents.
08 August 2024
Edge Cache licensing packages deprecated
Edge Cache capacity-based licensing packages will no longer be available for future deployments of Cloud Volumes ONTAP. However, you can use the API to access this functionality.
Minimum version support for Flash Cache in Azure
The minimum Cloud Volumes ONTAP version required for configuring Flash Cache in Azure is 9.13.1 GA. You can only use ONTAP 9.13.1 GA and later versions for deploying Flash Cache on Cloud Volumes ONTAP systems in Azure.
For supported configurations, refer to Supported configurations in Azure.
Free trials for marketplace subscriptions deprecated
The 30-day automatic free trial or evaluation license for pay-as-you-go subscriptions in the cloud provider's marketplace will no longer be available in Cloud Volumes ONTAP. Charging for any type of marketplace subscription (PAYGO or annual contract) starts from the first use, without any free trial period.
10 June 2024
Cloud Volumes ONTAP 9.15.0
BlueXP can now deploy and manage the Cloud Volumes ONTAP 9.15.0 in AWS, Azure, and Google Cloud.
17 May 2024
Amazon Web Services Local Zones support
Support for AWS Local Zones is now available for Cloud Volumes ONTAP HA deployments. AWS Local Zones are an infrastructure deployment where storage, compute, database, and other select AWS services are located close to large cities and industry areas.
Note AWS Local Zones are supported when using BlueXP in standard mode. At this time, AWS Local Zones are not supported when using BlueXP in restricted mode or private mode.
23 April 2024
  • Germany West Central
  • Poland Central
  • West US 3
  • Israel Central
  • Italy North
  • Canada Central
Johannesburg region now supported in Google Cloud
The Johannesburg region (africa-south1 region) is now supported in Google Cloud for Cloud Volumes ONTAP 9.12.1 GA and later.
For a list of all regions, refer to the Global Regions Map under Google Cloud.
Volume templates and tags no longer supported
You can no longer create a volume from a template or edit a volume's tags. These actions were associated with the BlueXP remediation service, which is no longer available.
08 March 2024
Amazon Instance Metadata Service v2 support
In AWS, Cloud Volumes ONTAP, the Mediator, and the Connector now support Amazon Instance Metadata Service v2 (IMDSv2) for all functions. IMDSv2 provides enhanced protection against vulnerabilities. Only IMDSv1 was previously supported.
If required by your security policies, you can configure your EC2 instances to use IMDSv2. For instructions, refer to BlueXP setup and administration documentation for managing existing Connectors.
05 March 2024
Cloud Volumes ONTAP 9.14.1 GA
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.14.1 General Availability release in AWS, Azure, and Google Cloud.
02 February 2024
Support for Edv5-series VMs in Azure
Cloud Volumes ONTAP now supports the following Edv5-series VMs starting with the 9.14.1 release.
  • E4ds_v5
  • E8ds_v5
  • E20s_v5
  • E32ds_v5
  • E48ds_v5
  • E64ds_v5
16 January 2024
Patch releases in BlueXP
Patch releases are available in BlueXP only for the latest three versions of Cloud Volumes ONTAP.
08 January 2024
New VMs for Azure multiple availability zones
Starting from Cloud Volumes ONTAP 9.13.1, the following VM types support Azure multiple availability zones for new and existing high-availability pair deployments:
  • L16s_v3
  • L32s_v3
  • L48s_v3
  • L64s_v3
06 December 2023
Cloud Volumes ONTAP 9.14.1 RC1
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.14.1 in AWS, Azure, and Google Cloud.
300 TiB FlexVol volume max limit
You can now create a FlexVol volume up to the maximum size of 300 TiB with System Manager and the ONTAP CLI starting from Cloud Volumes ONTAP 9.12.1 P2 and 9.13.0 P2, and in BlueXP starting from Cloud Volumes ONTAP 9.13.1.
05 December 2023
The following changes were introduced.
New region support in Azure
Single availability zone region support
The following regions now support highly available single availability zone deployments in Azure for Cloud Volumes ONTAP 9.12.1 GA and later:
  • Tel Aviv
  • Milan
Multiple availability zone region support
The following regions now support highly available multiple availability zone deployments in Azure for Cloud Volumes ONTAP 9.12.1 GA and later:
  • Central India
  • Norway East
  • Switzerland North
  • South Africa North
  • United Arab Emirates North
10 November 2023
The following change was introduced with the 3.9.35 release of the Connector.
Berlin region now supported in Google Cloud
The Berlin region is now supported in Google Cloud for Cloud Volumes ONTAP 9.12.1 GA and later.
08 November 2023
Tel Aviv region now supported in AWS
The Tel Aviv region is now supported in AWS for Cloud Volumes ONTAP 9.12.1 GA and later.
For a list of all regions, refer to the Global Regions Map under AWS.
01 November 2023
The following change was introduced with the 3.9.34 release of the Connector.
Saudi Arabia region now supported in Google Cloud
The Saudi Arabia region is now supported in Google Cloud for Cloud Volumes ONTAP and the Connector for Cloud Volumes ONTAP 9.12.1 GA and later.
23 October 2023
New regions supported for HA multiple availability zone deployments in Azure
The following regions in Azure now support highly available multiple availability zone deployments for Cloud Volumes ONTAP 9.12.1 GA and later:
  • Australia East
  • East Asia
  • France Central
  • North Europe
  • Qatar Central
  • Sweden Central
  • West Europe
  • West US 2
For a list of all regions that support multiple availability zones, refer to the Global Regions Map under Azure.
06 October 2023
Cloud Volumes ONTAP 9.14.0
BlueXP can now deploy and manage the Cloud Volumes ONTAP 9.14.0 General Availability release in AWS, Azure, and Google Cloud.
10 September 2023
The following change was introduced with the 3.9.33 release of the Connector.
Support for Lsv3-series VMs in Azure
The L48s_v3 and L64s_v3 instance types are now supported with Cloud Volumes ONTAP in Azure for single node and high-availability pair deployments with shared managed disks in single and multiple availability zones, starting with the 9.13.1 release. These instance types support Flash Cache.
30 July 2023
The following changes were introduced with the 3.9.32 release of the Connector.
Flash Cache and high write speed support in Google Cloud
Flash Cache and high write speed can be enabled separately in Google Cloud for Cloud Volumes ONTAP 9.13.1 and later. High write speed is available on all supported instance types. Flash Cache is supported on the following instance types:
  • n2-standard-16
  • n2-standard-32
  • n2-standard-48
  • n2-standard-64
You can use these features separately or together on both single node and high-availability pair deployments.
Usage reports enhancements
Various improvements to the displayed information within the usage reports are now available. The usage reports include these enhancements:
  • The TiB unit is now included in the name of columns.
  • A new "node(s)" field for serial numbers is now included.
  • A new “Workload Type” column is now included under the Storage VMs usage report.
  • Working environment names are now included in Storage VMs and Volume usage reports.
  • Volume type “file” is now labeled “Primary (Read/Write)”.
  • Volume type “secondary” is now labeled “Secondary (DP)”.
For more information on usage reports, refer to Download usage reports.
26 July 2023
The following changes were introduced with the 3.9.31 release of the Connector.
Cloud Volumes ONTAP 9.13.1 GA
BlueXP can now deploy and manage the Cloud Volumes ONTAP 9.13.1 General Availability release in AWS, Azure, and Google Cloud.
02 July 2023
Support for HA multiple availability zone deployments in Azure
The Japan East and Korea Central regions in Azure now support HA multiple availability zone deployments for Cloud Volumes ONTAP 9.12.1 GA and later.
Autonomous Ransomware Protection support
Autonomous Ransomware Protection (ARP) is now supported on Cloud Volumes ONTAP. ARP support is available on Cloud Volumes ONTAP version 9.12.1 and higher.
To learn more about ARP with Cloud Volumes ONTAP, refer to Autonomous Ransomware Protection.
26 June 2023
The following change was introduced with the 3.9.30 release of the Connector.
Cloud Volumes ONTAP 9.13.1 RC1
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.13.1 in AWS, Azure, and Google Cloud.
04 June 2023
Cloud Volumes ONTAP upgrade version selector update
Through the Upgrade Cloud Volumes ONTAP page, you can now choose to upgrade to the latest available version of Cloud Volumes ONTAP or an older version.
To learn more about upgrading Cloud Volumes ONTAP through BlueXP, refer to Upgrade Cloud Volumes ONTAP.
07 May 2023
The following changes were introduced with the 3.9.29 release of the Connector.
Qatar region now supported in Google Cloud
The Qatar region is now supported in Google Cloud for Cloud Volumes ONTAP and the Connector for Cloud Volumes ONTAP 9.12.1 GA and later.
Sweden Central region now supported in Azure
The Sweden Central region is now supported in Azure for Cloud Volumes ONTAP and the Connector for Cloud Volumes ONTAP 9.12.1 GA and later.
Support for HA multiple availability zone deployments in Azure Australia East
The Australia East region in Azure now supports HA multiple availability zone deployments for Cloud Volumes ONTAP 9.12.1 GA and later.
Charging usage breakdown
Now you can find out what you're being charged for when you're subscribed to capacity-based licenses. The following types of usage reports are available for download from the digital wallet in BlueXP. The usage reports provide capacity details of your subscriptions and tell you how you're being charged for the resources in your Cloud Volumes ONTAP subscriptions. The downloadable reports can be easily shared with others.
  • Cloud Volumes ONTAP package usage
  • High-level usage
  • Storage VMs usage
  • Volumes usage
For more information, refer to Manage capacity-based licenses.
Notification now displays when accessing BlueXP without a marketplace subscription
A notification now displays whenever you access Cloud Volumes ONTAP in BlueXP without a marketplace subscription. The notification states "a marketplace subscription for this working environment is required to be compliant with Cloud Volumes ONTAP terms and conditions."
New permissions added to AWS IAM policy for HA mediators
These new AWS permissions have been added to the IAM policy for HA mediators in Cloud Volumes ONTAP high-availability (HA) environments:
  • sts:AssumeRole
  • ec2:DescribeSubnets
04 April 2023
Support for China regions for AWS
Starting with Cloud Volumes ONTAP 9.12.1 GA, China regions are now supported in AWS as follows.
  • Single-node systems are supported.
  • Licenses purchased directly from NetApp are supported.
3 April 2023
The following changes were introduced with the 3.9.28 release of the Connector.
Turin region now supported in Google Cloud
The Turin region is now supported in Google Cloud for Cloud Volumes ONTAP and the Connector for Cloud Volumes ONTAP 9.12.1 GA and later.
BlueXP digital wallet enhancement
The BlueXP digital wallet now shows the licensed capacity that you purchased with marketplace private offers.
Support for comments during volume creation
This release enables you to add comments when you create a Cloud Volumes ONTAP FlexGroup volume or FlexVol volume by using the API.
BlueXP user interface redesign for Cloud Volumes ONTAP Overview, Volumes, and Aggregates pages
BlueXP now has a redesigned user interface for Cloud Volumes ONTAP Overview, Volumes, and Aggregates pages. The tile-based design presents more comprehensive information in each tile for a better user experience.
This screenshot shows the redesigned BlueXP user interface on the Cloud Volumes ONTAP overview page. Various tiles show storage efficiency
FlexGroup Volumes viewable through Cloud Volumes ONTAP
FlexGroup volumes created through ONTAP System Manager or the ONTAP CLI directly are now viewable through the redesigned Volumes tile in BlueXP. Identical to the information provided for FlexVol volumes, BlueXP provides detailed information for created FlexGroup volumes through a dedicated Volumes tile.
Note Currently, you can only view existing FlexGroup volumes under BlueXP. The ability to create FlexGroup volumes in BlueXP is not available but planned for a future release.
A screenshot that shows the FlexGroup volume icon hover text under the Volumes tile.
13 March 2023
Support for China regions in Azure
China North 3 region is now supported for single node deployments of Cloud Volumes ONTAP 9.12.1 GA and 9.13.0 GA in Azure. Only licenses purchased directly from NetApp (BYOL licenses) are supported in these regions.
Note Fresh deployments of Cloud Volumes ONTAP in China regions are supported only in 9.12.1 GA and 9.13.0 GA. You can upgrade these versions to later patches and releases of Cloud Volumes ONTAP. If you want to deploy later Cloud Volumes ONTAP versions in China regions, contact NetApp Support.
05 March 2023
The following changes were introduced with the 3.9.27 release of the Connector.
Cloud Volumes ONTAP 9.13.0
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.13.0 in AWS, Azure, and Google Cloud.
16 TiB and 32 Tib support in Azure
Cloud Volumes ONTAP now supports 16 TiB and 32 TiB disk sizes for high-availability deployments running on managed disks in Azure.
Learn more about supported disk sizes in Azure.
MTEKM license
The Multi-tenant Encryption Key Management (MTEKM) license is now included with new and existing Cloud Volumes ONTAP systems running version 9.12.1 GA or later.
Multi-tenant external key management enables individual storage VMs (SVMs) to maintain their own keys through a KMIP server when using NetApp Volume Encryption.
Support for environments without internet
Cloud Volumes ONTAP is now supported in any cloud environment that has complete isolation from the internet. Only node-based licensing (BYOL) is supported in these environments. Capacity-based licensing is not supported. To get started, manually install the Connector software, log in to the BlueXP console that's running on the Connector, add your BYOL license to the BlueXP digital wallet, and then deploy Cloud Volumes ONTAP.
Flash Cache and high write speed in Google Cloud
Support for Flash Cache, high write speed, and a high maximum transmission unit (MTU) of 8,896 bytes is now available for select instances with the Cloud Volumes ONTAP 9.13.0 release.
05 February 2023
The following changes were introduced with the 3.9.26 release of the Connector.
Placement group creation in AWS
A new configuration setting is now available for placement group creation with AWS HA single availability zone (AZ) deployments. Now you can choose to bypass failed placement group creations and allow AWS HA single AZ deployments to complete successfully.
For detailed information on how to configure the placement group creation setting, refer to Configure placement group creation for AWS HA Single AZ.
Private DNS zone configuration update
A new configuration setting is now available so that you can avoid creating a link between a private DNS zone and a virtual network when using Azure Private Links. Creation is enabled by default.
WORM storage and data tiering
You can now enable both data tiering and WORM storage together when you create a Cloud Volumes ONTAP 9.8 system or later. Enabling data tiering with WORM storage allows you to tier the data to an object store in the cloud.
1 January 2023
The following changes were introduced with the 3.9.25 release of the Connector.
Licensing packages available in Google Cloud
Optimized and Edge Cache capacity-based licensing packages are available for Cloud Volumes ONTAP in the Google Cloud Marketplace as a pay-as-you-go offering or as an annual contract.
Default configuration for Cloud Volumes ONTAP
The Multi-tenant Encryption Key Management (MTEKM) license is no longer included in new Cloud Volumes ONTAP deployments.
For more information on the ONTAP feature licenses automatically installed with Cloud Volumes ONTAP, refer to Default Configuration for Cloud Volumes ONTAP.
15 December 2022
Cloud Volumes ONTAP 9.12.0
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.12.0 in AWS and Google Cloud.
08 December 2022
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.12.1, which includes support for new features and additional cloud provider regions.
04 December 2022
The following changes were introduced with the 3.9.24 release of the Connector.
WORM + Cloud Backup now available during Cloud Volumes ONTAP creation
The ability to activate both write once, read many (WORM) and Cloud Backup features is now available during the Cloud Volumes ONTAP creation process.
Israel region now supported in Google Cloud
The Israel region is now supported in Google Cloud for Cloud Volumes ONTAP and the Connector for Cloud Volumes ONTAP 9.11.1 P3 and later.
15 November 2022
The following changes were introduced with the 3.9.23 release of the Connector.
ONTAP S3 license in Google Cloud
An ONTAP S3 license is now included on new and existing Cloud Volumes ONTAP systems running version 9.12.1 or later in Google Cloud Platform.
06 November 2022
Moving resource groups in Azure
You can now move a working environment from one resource group to a different resource group in Azure within the same Azure subscription.
For more information, refer to Moving resource groups.
NDMP-copy certification
NDMP-copy is now certified for use with Cloud Volume ONTAP.
For information on how to configure and use NDMP, refer to the ONTAP documentation: NDMP configuration overview.
Managed disk encryption support for Azure
A new Azure permission has been added that now allows you to encrypt all managed disks upon creation.
For more information on this new functionality, refer to Set up Cloud Volumes ONTAP to use a customer-managed key in Azure.
18 September 2022
The following changes were introduced with the 3.9.22 release of the Connector.
Digital Wallet enhancements
  • The Digital Wallet now shows a summary of the Optimized I/O licensing package and the provisioned WORM capacity for Cloud Volumes ONTAP systems across your account.
    These details can help you better understand how you're being charged and whether you need to purchase additional capacity.
  • You can now change from one charging method to the Optimized charging method.
Optimize cost and performance
You can now optimize the cost and performance of a Cloud Volumes ONTAP system directly from the Canvas.
After you select a working environment, you can choose the Optimize Cost & Performance option to change the instance type for Cloud Volumes ONTAP. Choosing a smaller-sized instance can help you reduce costs, while changing to a larger-sized instance can help you optimize performance.
AutoSupport notifications
BlueXP will now generate a notification if a Cloud Volumes ONTAP system is unable to send AutoSupport messages. The notification includes a link to instructions that you can use to troubleshoot networking issues.
31 July 2022
The following changes were introduced with the 3.9.21 release of the Connector.
MTEKM license
The Multi-tenant Encryption Key Management (MTEKM) license is now included with new and existing Cloud Volumes ONTAP systems running version 9.11.1 or later.
Proxy server
BlueXP now automatically configures your Cloud Volumes ONTAP systems to use the Connector as a proxy server, if an outbound internet connection isn't available to send AutoSupport messages.
AutoSupport proactively monitors the health of your system and sends messages to NetApp technical support.
The only requirement is to ensure that the security group for the Connector allows inbound connections over port 3128. You'll need to open this port after you deploy the Connector.
Change charging method
You can now change the charging method for a Cloud Volumes ONTAP system that uses capacity-based licensing. For example, if you deployed a Cloud Volumes ONTAP system with the Essentials package, you can change it to the Professional package if your business needs changed. This feature is available from the Digital Wallet.
Security group enhancement
When you create a Cloud Volumes ONTAP working environment, the user interface now enables you to choose whether you want the predefined security group to allow traffic within the selected network only (recommended) or all networks.
18 July 2022
New licensing packages in Azure
Two new capacity-based licensing packages are available for Cloud Volumes ONTAP in Azure when you pay through an Azure Marketplace subscription:
  • Optimized: Pay for provisioned capacity and I/O operations separately
  • Edge Cache: Licensing for Cloud Volumes Edge Cache
3 July 2022
The following changes were introduced with the 3.9.20 release of the Connector.
Digital Wallet
The Digital Wallet now shows you the total consumed capacity in your account and the consumed capacity by licensing package. This information can help you understand how you're being charged and whether you need to purchase additional capacity.
Elastic Volumes enhancement
BlueXP now supports the Amazon EBS Elastic Volumes feature when creating a Cloud Volumes ONTAP working environment from the user interface. The Elastic Volumes feature is enabled by default when using gp3 or io1 disks. You can choose the initial capacity based on your storage needs and revise it after Cloud Volumes ONTAP is deployed.
ONTAP S3 license in AWS
An ONTAP S3 license is now included on new and existing Cloud Volumes ONTAP systems running version 9.11.0 or later in AWS.
New Azure Cloud region support
Starting with the 9.10.1 release, Cloud Volumes ONTAP is now supported in the Azure West US 3 region.
ONTAP S3 license in Azure
An ONTAP S3 license is now included on new and existing Cloud Volumes ONTAP systems running version 9.9.1 or later in Azure.
07 June 2022
The following changes were introduced with the 3.9.19 release of the Connector.
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.11.1, which includes support for new features and additional cloud provider regions.
New Advanced View
If you need to perform advanced management of Cloud Volumes ONTAP, you can do so using ONTAP System Manager, which is a management interface that’s provided with an ONTAP system. We have included the System Manager interface directly inside BlueXP so that you don’t need to leave BlueXP for advanced management.
This Advanced View is available as a Preview with Cloud Volumes ONTAP 9.10.0 and later. Send us feedback by using the in-product chat.
Support for Amazon EBS Elastic Volumes
Support for the Amazon EBS Elastic Volumes feature with a Cloud Volumes ONTAP aggregate provides better performance and additional capacity, while enabling BlueXP to automatically increase the underlying disk capacity as needed.
Support for Elastic Volumes is available starting with new Cloud Volumes ONTAP 9.11.0 systems and with gp3 and io1 EBS disk types.
Note that support for Elastic Volumes requires new AWS permissions for the Connector:
"ec2:DescribeVolumesModifications",
"ec2:ModifyVolume",
Be sure to provide these permissions to each set of AWS credentials that you've added to BlueXP. View the latest Connector policy for AWS.
Support for deploying HA pairs in shared AWS subnets
Cloud Volumes ONTAP 9.11.1 includes support for AWS VPC sharing. This release of the Connector enables you to deploy an HA pair in an AWS shared subnet when using the API.
Limited network access when using service endpoints
BlueXP now limits network access when using a VNet service endpoint for connections between Cloud Volumes ONTAP and storage accounts. BlueXP uses a service endpoint if you disable Azure Private Link connections.
Support for creating storage VMs in Google Cloud
Multiple storage VMs are now supported with Cloud Volumes ONTAP in Google Cloud, starting with the 9.11.1 release. Starting with this release of the Connector, BlueXP enables you to create storage VMs on Cloud Volumes ONTAP HA pairs in Google Cloud by using the API.
Support for creating storage VMs requires new Google Cloud permissions for the Connector:
- compute.instanceGroups.get
- compute.addresses.get
Note that you must use the ONTAP CLI or System Manager to create a storage VM on a single-node system.
02 May 2022
The following changes were introduced with the 3.9.18 release of the Connector.
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.11.0.
Enhancement to mediator upgrades
When BlueXP upgrades the mediator for an HA pair, it now validates that a new mediator image is available before it deletes the boot disk. This change ensures that the mediator can continue to operate successfully if the upgrade process is unsuccessful.
K8s tab has been removed
The K8s tab was deprecated in a previous release, and has now been removed.
Annual contract in Azure
The Essentials and Professional packages are now available in Azure through an annual contract. You can contact your NetApp sales representative to purchase an annual contract. The contract is available as a private offer in the Azure Marketplace.
After NetApp shares the private offer with you, you can select the annual plan when you subscribe from the Azure Marketplace during working environment creation.
S3 Glacier Instant Retrieval
You can now store tiered data in the Amazon Simple Storage Service (Amazon S3) Glacier Instant Retrieval storage class.
New AWS permissions required for the Connector
The following permissions are now required to create an AWS spread placement group when deploying an HA pair in a single Availability Zone (AZ):
"ec2:DescribePlacementGroups",
"iam:GetRolePolicy",
These permissions are now required to optimize how BlueXP creates the placement group.
New Google Cloud region support
Cloud Volumes ONTAP is now supported in the following Google Cloud regions starting with the 9.10.1 release:
  • Delhi (asia-south2)
  • Melbourne (australia-southeast2)
  • Milan (europe-west8) - single node only
  • Santiago (southamerica-west1) - single node only
Support for n2-standard-16 in Google Cloud
The n2-standard-16 machine type is now supported with Cloud Volumes ONTAP in Google Cloud, starting with the 9.10.1 release.
Enhancements to Google Cloud firewall policies
  • When you create a Cloud Volumes ONTAP HA pair in Google Cloud, BlueXP will now display all existing firewall policies in a VPC.
    Previously, BlueXP wouldn't display any policies in VPC-1, VPC-2, or VPC-3 that didn't have a target tag.
  • When you create a Cloud Volumes ONTAP single-node system in Google Cloud, you can now choose whether you want the predefined firewall policy to allow traffic within the selected VPC only (recommended) or all VPCs.
Enhancement to Google Cloud service accounts
When you select the Google Cloud service account to use with Cloud Volumes ONTAP, BlueXP now displays the email address that's associated with each service account. Viewing the email address can make it easier to distinguish between service accounts that share the same name.
3 April 2022
We have removed the System Manager link that was previously available from within a Cloud Volumes ONTAP working environment.
You can still connect to System Manager by entering the cluster management IP address in a web browser that has a connection to the Cloud Volumes ONTAP system. Learn more about connecting to System Manager.
Charging for WORM storage
Now that the introductory special rate has expired, you will be charged for using WORM storage. Charging is hourly, according to the total provisioned capacity of WORM volumes. This applies to new and existing Cloud Volumes ONTAP systems.
27 February 2022
The following changes were introduced with the 3.9.16 release of the Connector.
Redesigned volume wizard
The create new volume wizard that we recently introduced is now available when creating a volume on a specific aggregate from the Advanced allocation option.
09 February 2022
Marketplace updates
  • The Essentials package and Professional package are now available in all cloud provider marketplaces.
    These by-capacity charging methods enable you to pay by the hour or to purchase an annual contract directly from your cloud provider. You still have the option to purchase a by-capacity license directly from NetApp.
    If you have an existing subscription in a cloud marketplace, you're automatically subscribed to these new offerings as well. You can choose by-capacity charging when you deploy a new Cloud Volumes ONTAP working environment.
    If you're a new customer, BlueXP will prompt you to subscribe when you create a new working environment.
  • By-node licensing from all cloud provider marketplaces is deprecated and no longer available for new subscribers. This includes annual contracts and hourly subscriptions (Explore, Standard, and Premium).
    This charging method is still available for existing customers who have an active subscription.
06 February 2022
Exchange unassigned licenses
If you have an unassigned node-based license for Cloud Volumes ONTAP that you haven't used, you can now exchange the license by converting it to a Cloud Backup license, Cloud Data Sense license, or Cloud Tiering license.
This action revokes the Cloud Volumes ONTAP license and creates a dollar-equivalent license for the service with the same expiry date.
30 January 2022
The following changes were introduced with the 3.9.15 release of the Connector.
Redesigned licensing selection
We redesigned the licensing selection screen when creating a new Cloud Volumes ONTAP working environment. The changes highlight the by-capacity charging methods that were introduced in July 2021 and support offerings through the cloud provider marketplaces.
Digital Wallet update
We updated the Digital Wallet by consolidating Cloud Volumes ONTAP licenses in a single tab.
02 January 2022
The following changes were introduced with the 3.9.14 release of the Connector.
Support for additional Azure VM types
Cloud Volumes ONTAP is now supported with the following VM types in Microsoft Azure, starting with the 9.10.1 release:
  • E4ds_v4
  • E8ds_v4
  • E32ds_v4
  • E48ds_v4
Go to the Cloud Volumes ONTAP Release Notes for more details about supported configurations.
FlexClone charging update
If you use a capacity-based license for Cloud Volumes ONTAP, you are no longer charged for the capacity used by FlexClone volumes.
Charging method now displayed
BlueXP now shows the charging method for each Cloud Volumes ONTAP working environment in the right panel of the Canvas.
A screenshot that shows the charging method for a Cloud Volumes ONTAP working environment which appears in the right panel after selecting a working environment from the Canvas.
Choose your user name
When you create a Cloud Volumes ONTAP working environment, you now have the option to enter your preferred user name, instead of the default admin user name.
A screenshot of the Details and Credentials page in the working environment wizard where you can specify a user name.
Volume creation enhancements
We made a few enhancements to volume creation:
  • We redesigned the create volume wizard for ease of use.
  • You can now choose a custom export policy for NFS.
A screenshot that shows the Protocol page when creating a new volume.
28 November 2021
The following changes were introduced with the 3.9.13 release of the Connector.
Cloud Volumes ONTAP 9.10.1
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.10.1.
NetApp Keystone Subscriptions
You can now use Keystone Subscriptions to pay for Cloud Volumes ONTAP HA pairs.
A Keystone Subscription is a pay-as-you-grow subscription-based service that delivers a seamless hybrid cloud experience for customers who prefer OpEx consumption models over upfront CapEx or leasing.
A Keystone Subscription is supported with all new versions of Cloud Volumes ONTAP that you can deploy from BlueXP.
New AWS region support
Cloud Volumes ONTAP is now supported in the AWS Asia Pacific (Osaka) region (ap-northeast-3).
Port reduction
Ports 8023 and 49000 are no longer open on Cloud Volumes ONTAP systems in Azure for both single-node systems and HA pairs.
This change applies to new Cloud Volumes ONTAP systems starting with the 3.9.13 release of the Connector.
04 October 2021
The following changes were introduced with the 3.9.11 release of the Connector.
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.10.0.
Reduced deployment time
We reduced the amount of time that it takes to deploy a Cloud Volumes ONTAP working environment in Microsoft Azure or in Google Cloud when normal write speed is enabled. The deployment time is now 3-4 minutes shorter on average.
02 September 2021
The following changes were introduced with the 3.9.10 release of the Connector.
Customer-managed encryption key in Azure
Data is automatically encrypted on Cloud Volumes ONTAP in Azure using Azure Storage Service Encryption with a Microsoft-managed key. But you can now use your own customer-managed encryption key instead by completing the following steps:
  1. From Azure, create a key vault and then generate a key in that vault.
  2. From BlueXP, use the API to create a Cloud Volumes ONTAP working environment that uses the key.
07 July 2021
The following changes were introduced with the 3.9.8 release of the Connector.
New charging methods
New charging methods are available for Cloud Volumes ONTAP.
  • Capacity-based BYOL: A capacity-based license enables you to pay for Cloud Volumes ONTAP per TiB of capacity. The license is associated with your NetApp account and enables you to create multiple Cloud Volumes ONTAP systems, as long as enough capacity is available through your license. Capacity-based licensing is available in the form of a package, either Essentials or Professional.
  • Freemium offering: Freemium enables you to use all Cloud Volumes ONTAP features free of charge from NetApp (cloud provider charges still apply). You're limited to 500 GiB of provisioned capacity per system and there's no support contract. You can have up to 10 Freemium systems.
    Here's an example of the charging methods that you can choose from:
    A screenshot of the Cloud Volumes ONTAP working environment wizard where you can choose a charging method.
WORM storage available for general use
Write once, read many (WORM) storage is no longer in Preview and is now available for general use with Cloud Volumes ONTAP. Learn more about WORM storage.
Support for m5dn.24xlarge in AWS
Starting with the 9.9.1 release, Cloud Volumes ONTAP now supports the m5dn.24xlarge instance type with the following charging methods: PAYGO Premium, Bring-Your-Own License (BYOL), and Freemium.
Select existing Azure resource groups
When creating a Cloud Volumes ONTAP system in Azure, you now have the option to select an existing resource group for the VM and its associated resources.
A screenshot of the Create Working Environment wizard where you can select an existing resource group.
The following permissions enable BlueXP to remove Cloud Volumes ONTAP resources from a resource group, in case of deployment failure or deletion:
"Microsoft.Network/privateEndpoints/delete",
"Microsoft.Compute/availabilitySets/delete",
Be sure to provide these permissions to each set of Azure credentials that you've added to BlueXP. View the latest Connector policy for Azure.
Blob public access now disabled in Azure
As a security enhancement, BlueXP now disables Blob public access when creating a storage account for Cloud Volumes ONTAP.
By default, BlueXP now enables an Azure Private Link connection on the boot diagnostics storage account for new Cloud Volumes ONTAP systems.
This means all storage accounts for Cloud Volumes ONTAP will now use a private link.
Balanced persistent disks in Google Cloud
Starting with the 9.9.1 release, Cloud Volumes ONTAP now supports Balanced persistent disks (pd-balanced).
These SSDs balance performance and cost by providing lower IOPS per GiB.
custom-4-16384 no longer supported in Google Cloud
The custom-4-16384 machine type is no longer supported with new Cloud Volumes ONTAP systems.
If you have an existing system running on this machine type, you can keep using it, but we recommend switching to the n2-standard-4 machine type.
30 May 2021
The following changes were introduced with the 3.9.7 release of the Connector.
New Professional Package in AWS
A new Professional Package enables you to bundle Cloud Volumes ONTAP and Cloud Backup Service by using an annual contract from the AWS Marketplace. Payment is per TiB. This subscription doesn't enable you to back up on-premises data.
If you choose this payment option, you can provision up to 2 PiB per Cloud Volumes ONTAP system through EBS disks and tiering to S3 object storage (single node or HA).
Go to the AWS Marketplace page to view pricing details and go to the Cloud Volumes ONTAP Release Notes to learn more about this licensing option.
Tags on EBS volumes in AWS
BlueXP now adds tags to EBS volumes when it creates a new Cloud Volumes ONTAP working environment. The tags were previously created after Cloud Volumes ONTAP was deployed.
This change can help if your organization uses service control policies (SCPs) to manage permissions.
Minimum cooling period for auto tiering policy
If you enabled data tiering on a volume using the auto tiering policy, you can now adjust the minimum cooling period using the API.
Enhancement to custom export policies
When you create a new NFS volume, BlueXP now displays custom export policies in ascending order, making it easier for you to find the export policy that you need.
Deletion of old cloud snapshots
BlueXP now deletes older cloud snapshots of root and boot disks that are created when a Cloud Volumes ONTAP system is deployed and every time it is powered down. Only the two most recent snapshots are retained for both the root and boot volumes.
This enhancement helps reduce cloud provider costs by removing snapshots that are no longer needed.
Note that a Connector requires a new permission to delete Azure snapshots. View the latest Connector policy for Azure.
"Microsoft.Compute/snapshots/delete"
24 May 2021
Cloud Volumes ONTAP 9.9.1
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.9.1.
11 Apr 2021
The following changes were introduced with the 3.9.5 release of the Connector.
Logical space reporting
BlueXP now enables logical space reporting on the initial storage VM that it creates for Cloud Volumes ONTAP.
When space is reported logically, ONTAP reports the volume space such that all the physical space saved by the storage efficiency features is also reported as used.
Support for gp3 disks in AWS
Cloud Volumes ONTAP now supports General Purpose SSD (gp3) disks, starting with the 9.7 release. gp3 disks are the lowest-cost SSDs that balance cost and performance for a broad range of workloads.
Cold HDD disks no longer supported in AWS
Cloud Volumes ONTAP no longer supports Cold HDD (sc1) disks.
TLS 1.2 for Azure storage accounts
When BlueXP creates storage accounts in Azure for Cloud Volumes ONTAP, the TLS version for the storage account is now version 1.2.
08 Mar 2021
The following changes were introduced with the 3.9.4 release of the Connector.
Cloud Volumes ONTAP 9.9.0
BlueXP can now deploy and manage Cloud Volumes ONTAP 9.9.0.
Support for the AWS C2S environment
You can now deploy Cloud Volumes ONTAP 9.8 in the AWS Commercial Cloud Services (C2S) environment.
AWS encryption with customer-managed CMKs
BlueXP has always enabled you to encrypt Cloud Volumes ONTAP data using the AWS Key Management Service (KMS). Starting with Cloud Volumes ONTAP 9.9.0, data on EBS disks and data tiered to S3 are encrypted if you select a customer-managed CMK. Previously, only EBS data would be encrypted.
Note that you'll need to provide the Cloud Volumes ONTAP IAM role with access to use the CMK.
Support for Azure DoD
You can now deploy Cloud Volumes ONTAP 9.8 in the Azure Department of Defense (DoD) Impact Level 6 (IL6).
IP address reduction in Google Cloud
We've reduced the number of IP addresses that are required for Cloud Volumes ONTAP 9.8 and later in Google Cloud. By default, one less IP address is required (we unified the intercluster LIF with the node management LIF). You also have the option to skip the creation of the SVM management LIF when using the API, which would reduce the need for an additional IP address.
Shared VPC support in Google Cloud
When you deploy a Cloud Volumes ONTAP HA pair in Google Cloud, you can now choose shared VPCs for VPC-1, VPC-2, and VPC-3. Previously, only VPC-0 could be a shared VPC. This change is supported with Cloud Volumes ONTAP 9.8 and later.
04 January 2021
The following changes were introduced with the 3.9.2 release of the Connector.
AWS Outposts
A few months ago, we announced that Cloud Volumes ONTAP had achieved the Amazon Web Services (AWS) Outposts Ready designation. We've validated BlueXP and Cloud Volumes ONTAP with AWS Outposts.
If you have an AWS Outpost, you can deploy Cloud Volumes ONTAP in that Outpost by selecting the Outpost VPC in the Working Environment wizard. The experience is the same as any other VPC that resides in AWS. Note that you will need to first deploy a Connector in your AWS Outpost.
There are a few limitations to point out:
  • Only single node Cloud Volumes ONTAP systems are supported at this time
  • The EC2 instances that you can use with Cloud Volumes ONTAP are limited to what's available in your Outpost
  • Only General Purpose SSDs (gp2) are supported at this time
Ultra SSD VNVRAM in supported Azure regions
Cloud Volumes ONTAP can now use an Ultra SSD as VNVRAM when you use the E32s_v3 VM type with a single-node system in any supported Azure region.
VNVRAM provides better write performance.
Choose an Availability Zone in Azure
You can now choose the Availability Zone in which you'd like to deploy a single node Cloud Volumes ONTAP system. If you don't select an AZ, BlueXP will select one for you.
A screenshot of the Availability Zone drop-down list that's available after choosing a region.
Larger disks in Google Cloud
Cloud Volumes ONTAP now supports 64 TB disks in Google Cloud.
Note The maximum system capacity with disks alone remains at 256 TB due to Google Cloud limits.
New machine types in Google Cloud
Cloud Volumes ONTAP now supports the following machine types with these PAYGO licenses in Google Cloud:
  • n2-standard-4 with the Explore license and with BYOL
  • n2-standard-8 with the Standard license and with BYOL
  • n2-standard-32 with the Premium license and with BYOL
03 Nov 2020
The following changes were introduced with the 3.9.0 release of the Connector.
By default, BlueXP now enables an Azure Private Link connection between Cloud Volumes ONTAP and its associated storage accounts. A Private Link secures connections between endpoints in Azure.
