Cloud Volumes ONTAP
Enable backend cluster network encryption for Cloud Volumes ONTAP
Contributors netapp-manini netapp-ahibbard
Beginning Cloud Volumes ONTAP 9.19.1 and later, you can enable backend cluster network encryption to protect internal Cloud Volumes ONTAP nodes traffic in Azure and Google Cloud high-availability (HA) configurations. This setting protects traffic in transit, it doesn't encrypt volume data at rest.
ONTAP uses Cluster Session Management (CSM) over Kernel TLS (kTLS) and software IPsec to secure traffic on backend networks for HA configurations. Cloud Volumes ONTAP 9.19.1 and later extend this protection to backend cluster traffic.
Note Enabling cluster network encryption might impact your cluster's performance. Exercise caution and verify that your environment can accommodate the additional overhead before enabling this feature.
Before you begin
  • You must be running Cloud Volumes ONTAP 9.19.1 or later.
  • You must have cluster administrator privileges.
  • You must verify that your Cloud Volumes ONTAP deployment uses a supported configuration.
Steps
  1. Use the ONTAP CLI to connect to the Cloud Volumes ONTAP cluster.
  2. Verify that the configuration for the cluster network encryption is correct:
    security cluster-network show
        Enabled: false
        Mode: tls
        Status: READY
  3. Enable cluster network encryption in TLS and IPsec mode:
    security cluster-network modify -enabled true -mode tls_ipsec
  4. Verify that cluster network encryption is enabled:
        Enabled: true
        Mode: tls_ipsec
        Status: READY
    Note When you enable tls_ipsec mode, CSM traffic uses TLS, while other cluster network traffic uses IPsec. ONTAP generates and manages the required certificates and backend IPsec policies.
