Command reference
security cluster-network show
Show cluster security configurations
The security cluster-network show command displays the cluster security configuration.
The following example displays the cluster security configuration
cluster1::> security cluster-network show
         Enabled: false
            Mode: tls
          Status: READY
    IPsec-Status: READY
