Command reference
security cluster-network modify
Modify cluster security configurations
The security cluster-network modify command modifies the cluster security configurations.
[-enabled {true|false}] - Enable Cluster Security?
Choose whether to enable cluster security or to disable it. The default state is false.
[-mode {tls|tls_ipsec}] - Cluster Security Mode
Cluster security mode.
[-force {true|false}] - Force Disable (privilege: advanced)
If true, forces the disable of IPsec to bring the cluster to a quiescent state. This is an advanced-privilege parameter.
The following example enables the cluster security feature and sets the mode.
cluster1::> security cluster-network modify -enabled true -mode tls
