security cluster-network modify
Modify cluster security configurations
The security cluster-network modify command modifies the cluster security configurations.
[-enabled {true|false}]- Enable Cluster Security?-
Choose whether to enable cluster security or to disable it. The default state is false.
[-mode <cluster security mode>]- Cluster Security Mode-
Cluster security mode.
The following example enables the cluster security feature and sets the mode.
cluster1::> security cluster-network modify -enabled true -mode tls
