NetApp Console setup and administration
Quick start for NetApp Console in private mode
Contributors netapp-tonias netapp-ahibbard
You can install NetApp Console on-premises or in a secure cloud environment. Private mode is typically used with on-premises environments that have no internet connection and with secure cloud regions, which include AWS Secret Cloud, AWS Top Secret Cloud, and Azure IL6.
  1. Prepare a dedicated Linux host that meets requirements for CPU, RAM, disk space, container orchestration tool, and more.
  2. Set up networking that provides access to the target networks.
  3. For cloud deployments, set up permissions in your cloud provider so that you can associate those permissions with the Console agent after you install the software.
  1. Install the Console agent on your own Linux host.
  2. Set up NetApp Console by opening a web browser and entering the Linux host's IP address.
  3. For cloud deployments, provide NetApp Console with the permissions that you previously set up.
Supported features and services for NetApp Console in private mode
The following table lists the storage management features, data services, and administrative features available in NetApp Console when you install it in private mode. Features differ when you install the NetApp Console in the cloud versus your premises.
Private mode installed in the cloud
Product area NetApp service or feature Console agent required
Storage systems management
This portion of the table lists support for managing storage systems from the NetApp Console. It does not indicate the supported backup destinations for NetApp Backup and Recovery.
Cloud Volumes ONTAP
Yes, but because there's no internet access, the following features aren't available: automated software upgrades and AutoSupport.
On-premises ONTAP clusters
  • Requires connectivity from the cloud (where the Console agent is installed) to the on-premises environment.
    You must have an installed Console agent to discover on-premises ONTAP clusters.
You can use direct discovery without a Console agent, but you need an agent to use management features.
Data Services
Backup and Recovery
Yes
NetApp Classification
Yes
NetApp Replication
Yes* (not needed if replicating from ONTAP on-premises to ONTAP on-premises)
NetApp support contract features
None
Administrative features
Audit
No
Licenses and subscriptions management
  • Only BYOL is supported with private mode.
No
Identity and access management
Yes
Manage cloud provider credentials
No
Read-only mode
No
Notifications
No
Private mode installed on-premises
Data Services
Backup and Recovery
Yes
Yes
NetApp Replication
None
N/A
Audit
No
No
Yes
No
Read-only mode
No
Notifications
No
