NetApp Data Classification
Install NetApp Data Classification on a Linux host with no internet access
Contributors netapp-ahibbard
Installing NetApp Data Classification on a Linux host in an on-premises site that doesn't have internet access is known as private mode. This type of installation, which uses an installation script, has no connectivity to the NetApp Console SaaS layer.
Tip For on-premises VMware vSphere deployments, Data Classification supports a simplified deployment with OVA.
The Data Classification installation script starts by checking if the system and environment meet the required prerequisites. If the prerequisites are all met, then the installation starts. If you would like to verify the prerequisites independently of running the Data Classification installation, there is a separate software package you can download that only tests for the prerequisites. See how to check if your Linux host is ready to install Data Classification.
Supported data sources
When installed private mode (sometimes called an "offline" or "dark" site), Data Classification can only scan data from data sources that are also local to the on-premises site. At this time, Data Classification can scan the following local data sources:
  • On-premises ONTAP systems
  • Database schemas
There is no support currently for scanning Cloud Volumes ONTAP, Azure NetApp Files, or FSx for ONTAP accounts when Data Classification is deployed in private mode.
Limitations
Most Data Classification features work when it is deployed in a site with no internet access. However, certain features that require internet access are not supported, for example:
  • Setting Console roles for different users (for example, Account Admin or Compliance Viewer)
  • Copying and synchronizing source files using NetApp Copy and Sync
  • Automated software upgrades from the Console
    Both the Console agent and Data Classification require periodic manual upgrades to enable new features. You can see the Data Classification version at the bottom of the Data Classification UI pages. Check the Data Classification Release Notes to see the new features in each release and whether you want those features. Then you can follow the steps to upgrade the Console agent and upgrade your Data Classification software.
Quick start
Get started quickly by following these steps, or scroll down to the remaining sections for full details.
One Install the Console agent
If you don't already have a Console agent installed in private mode, deploy the Console agent on a Linux host now.
Two Review Data Classification prerequisites
Ensure that your Linux system meets the host requirements, that it has all required software installed, and that your offline environment meets the required permissions and connectivity.
Three Download and deploy Data Classification
Download the Data Classification software from the NetApp Support Site and copy the installer file to the Linux host you plan to use. Then launch the installation wizard and follow the prompts to deploy the Data Classification instance.
If you don't already have a Console agent installed in private mode, deploy the Console agent on a Linux host in your offline site.
Prepare the Linux host system
Data Classification software must run on a host that meets specific operating system requirements, RAM requirements, software requirements, and so on.
  • Data Classification must be on a dedicated host. The host can't be shared with other applications or third-party software such as antivirus.
  • Choose the size that aligns with the data set you plan to scan with Data Classification.
    System size CPU RAM (swap memory must be disabled) Disk
    Extra Large
    32 CPUs
    128 GB RAM
    • 1 TiB SSD on /, or 100 GiB available on /opt
    • 895 GiB available on /var/lib/docker
    • 5 GiB on /tmp
    • For Podman, 30 GB on /var/tmp
    Large
    16 CPUs
    64 GB RAM
    • 500 GiB SSD on /, or 100 GiB available on /opt
    • 400 GiB available on /var/lib/docker or for Podman /var/lib/containers
    • 5 GiB on /tmp
  • When deploying a compute instance in the cloud for your Data Classification installation, it's recommended you use a system that meets the "Large" system requirements above:
  • UNIX folder permissions: The following minimum UNIX permissions are required:
    Folder Minimum permissions
    /tmp
    rwxrwxrwt
    /opt
    rwxr-xr-x
    /var/lib/docker
    rwx------
    /usr/lib/systemd/system
    rwxr-xr-x
  • Operating system:
    • The following operating systems require using the Docker container engine:
      • Red Hat Enterprise Linux version 7.8 and 7.9
      • Ubuntu 22.04 (requires Data Classification version 1.23 or greater)
      • Ubuntu 24.04 (requires Data Classification version 1.23 or greater)
    • The following operating systems require using the Podman container engine, and they require Data Classification version 1.30 or greater:
      • Red Hat Enterprise Linux version 8.8, 8.10, 9.0, 9.1, 9.2, 9.3, 9.4, 9.5, 9.6, and 9.7.
    • Advanced Vector Extensions (AVX2) must be enabled on the host system.
  • Red Hat Subscription Management: The host must be registered with Red Hat Subscription Management. If it's not registered, the system can't access repositories to update required 3rd-party software during installation.
  • Additional software: You must install the following software on the host before you install Data Classification:
    • Depending on the OS you are using, you need to install one of the container engines:
      • Docker Engine version 19.3.1 or greater. View installation instructions.
      • Podman version 4 or greater. To install Podman, enter (sudo yum install podman netavark -y).
  • Python version 3.6 or greater. View installation instructions.
    • NTP considerations: NetApp recommends configuring the Data Classification system to use a Network Time Protocol (NTP) service. The time must be synchronized between the Data Classification system and the Console agent system.
  • Firewalld considerations: If you are planning to use firewalld, we recommend that you enable it before installing Data Classification. Run the following commands to configure firewalld so that it is compatible with Data Classification:
    firewall-cmd --permanent --add-service=http
    firewall-cmd --permanent --add-service=https
    firewall-cmd --permanent --add-port=80/tcp
    firewall-cmd --permanent --add-port=8080/tcp
    firewall-cmd --permanent --add-port=443/tcp
    firewall-cmd --reload
    Note that you must restart Docker or Podman whenever you enable or update firewalld settings.
Tip The IP address of the Data Classification host system can't be changed after installation.
Note The Data Classification installer reserves UID 4321 and GID 4321. Before you start the installation, ensure that UID 4321 and GID 4321 aren't in use on the host machine. If they are in use, the installation will fail with an "invalid user" error message.
Verify Console and Data Classification prerequisites
Review the following prerequisites to make sure that you have a supported configuration before you deploy Data Classification.
  • Ensure that the Console agent has permissions to deploy resources and create security groups for the Data Classification instance. You can find the latest Console permissions in the policies provided by NetApp.
  • Ensure that you can keep Data Classification running. The Data Classification instance needs to stay on to continuously scan your data.
  • Ensure web browser connectivity to Data Classification. After Data Classification is enabled, ensure that users access the Console interface from a host that has a connection to the Data Classification instance.
    The Data Classification instance uses a private IP address to ensure that the indexed data isn't accessible to others. As a result, the web browser that you use to access the Console must have a connection to that private IP address. That connection can come from a host that's inside the same network as the Data Classification instance.
Verify that all required ports are enabled
You must ensure that all required ports are open for communication between the Console agent, Data Classification, Active Directory, and your data sources.
Connection Type Ports Description
Console agent <> Data Classification
8080 (TCP), 6000 (TCP), 443 (TCP), and 80. 9000
The security group for the Console agent must allow inbound and outbound traffic over ports 6000 and 443 to and from the Data Classification instance.
  • Port 6000 is required so that the Data Classification BYOL license works in a dark site.
  • Port 8080 should be open so you can see the installation progress in the Console.
  • If a firewall is used on the Linux host, port 9000 is required for internal processes within an Ubuntu server.
Console agent <> ONTAP cluster (NAS)
443 (TCP)
The Console discovers ONTAP clusters using HTTPS. If you use custom firewall policies, they must meet the following requirements:
  • The Console agent host must allow outbound HTTPS access through port 443. If the Console agent is in the cloud, all outbound communication is allowed by the predefined security group.
  • The ONTAP cluster must allow inbound HTTPS access through port 443. The default "mgmt" firewall policy allows inbound HTTPS access from all IP addresses. If you modified this default policy, or if you created your own firewall policy, you must associate the HTTPS protocol with that policy and enable access from the Console agent host.
Data Classification <> ONTAP cluster
  • For NFS - 111 (TCP\UDP) and 2049 (TCP\UDP)
  • For CIFS - 139 (TCP\UDP) and 445 (TCP\UDP)
Data Classification needs a network connection to each Cloud Volumes ONTAP subnet or on-prem ONTAP system. Security groups for Cloud Volumes ONTAP must allow inbound connections from the Data Classification instance.
Make sure these ports are open to the Data Classification instance:
  • For NFS - 111 and 2049
  • For CIFS - 139 and 445
NFS volume export policies must allow access from the Data Classification instance.
Data Classification <> Active Directory
389 (TCP & UDP), 636 (TCP), 3268 (TCP), and 3269 (TCP)
You must have an Active Directory already set up for the users in your company. Additionally, Data Classification needs Active Directory credentials to scan CIFS volumes.
You must have the information for the Active Directory:
  • DNS Server IP Address, or multiple IP Addresses
  • User Name and Password for the server
  • Domain Name (Active Directory Name)
  • Whether you are using secure LDAP (LDAPS) or not
  • LDAP Server Port (typically 389 for LDAP, and 636 for secure LDAP)
If a firewall used on Linux host
9000
Needed for internal processes within an Ubuntu server.
Install Data Classification on the on-premises Linux host
In most situations, you install Data Classification on a single-host system. This is not the same VM host as the Console agent.
A diagram showing the location of the data sources you can scan when using a single Data Classification instance deployed on-prem without internet access.
Follow these steps when installing Data Classification software on a single on-premises host in an offline environment.
Note that all installation activities are logged when installing Data Classification. If you run into any issues during installation, you can view the contents of the installation audit log. It is written to /opt/netapp/install_logs/.
Before you begin
  • Verify that your Linux system meets the host requirements.
  • Verify that you have installed the two prerequisite software packages (Docker Engine or Podman, and Python 3).
  • Make sure you have root privileges on the Linux system.
  • Verify that your offline environment meets the required permissions and connectivity.
Steps
  1. On an internet-configured system, download the Data Classification software from the NetApp Support Site. The file you should select is named DataSense-offline-bundle-<version>.tar.gz.
  2. Copy the installer bundle to the Linux host you plan to use in private mode.
  3. Unzip the installer bundle on the host machine, for example:
    tar -xzf DataSense-offline-bundle-v1.25.0.tar.gz
    This extracts required software and the actual installation file cc_onprem_installer.tar.gz.
  4. Unzip the installation file on the host machine, for example:
    tar -xzf cc_onprem_installer.tar.gz
  5. From Data Classification, select Deploy Classification On-Premises or Cloud.
    A screenshot of selecting the button to activate Data Classification.
  6. Select Deploy to start the on-prem installation.
  7. The Deploy Data Classification On Premises dialog is displayed. Copy the provided command (for example: sudo ./install.sh -a 12345 -c 27AG75 -t 2198qq --darksite) and paste it in a text file so you can use it later. Then select Close to dismiss the dialog.
  8. On the host machine, enter the command you copied and then follow a series of prompts, or you can provide the full command including all required parameters as command line arguments.
    Note that the installer performs a pre-check to make sure your system and networking requirements are in place for a successful installation.
    Enter parameters as prompted: Enter the full command:
    1. Paste the information you copied from step 8:
      sudo ./install.sh -a <account_id> -c <client_id> -t <user_token> --darksite
    2. Enter the IP address or host name of the Data Classification host machine so it can be accessed by the Console agent system.
    3. Enter the IP address or host name of the Console agent host machine so it can be accessed by the Data Classification system.
    Alternatively, you can create the whole command in advance, providing the necessary host parameters:
    sudo ./install.sh -a <account_id> -c <client_id> -t <user_token> --host <ds_host> --manager-host <cm_host> --no-proxy --darksite
    Variable values:
    • account_id = NetApp Account ID
    • client_id = Console agent Client ID (add the suffix "clients" to the client ID if it not already there)
    • user_token = JWT user access token
    • ds_host = IP address or host name of the Data Classification system.
    • cm_host = IP address or host name of the Console agent system.
Result
The Data Classification installer installs packages, registers the installation, and installs Data Classification. Installation can take 10 to 20 minutes.
If there is connectivity over port 8080 between the host machine and the Console agent instance, you'll see the installation progress in the Data Classification tab.
What's Next
From the Configuration page you can select the local on-prem ONTAP clusters and databases that you want to scan.
Upgrade Data Classification software
Since Data Classification software is updated with new features on a regular basis, you should get into a routine to check for new versions periodically to make sure you're using the newest software and features. You'll need to upgrade Data Classification software manually because there's no internet connectivity to perform the upgrade automatically.
Before you begin
  • We recommend that your Console agent software is upgraded to the newest available version. See the Console agent upgrade steps.
  • Starting with Data Classification version 1.24 you can perform upgrades to any future version of software.
    If your Data Classification software is running a version prior to 1.24, you can upgrade only one major version at a time. For example, if you have version 1.21.x installed, you can upgrade only to 1.22.x. If you are a few major versions behind, you'll need to upgrade the software multiple times.
Steps
  2. Copy the software bundle to the Linux host where Data Classification is installed in the dark site.
  3. Unzip the software bundle on the host machine, for example:
    tar -xvf DataSense-offline-bundle-v1.25.0.tar.gz
    This extracts the installation file cc_onprem_installer.tar.gz.
    This extracts the upgrade script start_darksite_upgrade.sh and any required third-party software.
  5. Run the upgrade script on the host machine, for example:
Result
The Data Classification software is upgraded on your host. The update can take 5 to 10 minutes.
You can verify that the software has been updated by checking the version at the bottom of the Data Classification UI pages.
