NetApp Console setup and administration
Permissions summary for NetApp Console
Contributors netapp-tonias
You'll need to provide the Console agent appropriate permissions so that it can perform operations in your cloud environment. Use the links on this page to quickly access the permissions that you need based on your goal.
AWS permissions
The NetApp Console requires AWS permissions for a Console agent and for individual services.
Console agents
Goal Description Link
Deploy a Console agent from the Console
To deploy a Console agent in AWS, the user needs specific permissions.
Set up AWS permissions
Provide permissions for a Console agent
NetApp Backup and Recovery
Back up on-premises ONTAP clusters to Amazon S3 with NetApp Backup and Recovery
When activating backups on your ONTAP volumes, NetApp Backup and Recovery prompts you to enter an access key and secret for an IAM user that has specific permissions.
Set up S3 permissions for backups
Cloud Volumes ONTAP
Provide permissions for Cloud Volumes ONTAP nodes
An IAM role must be attached to each Cloud Volumes ONTAP node in AWS. The same is true for the HA mediator. The default option is to let the Console create the IAM roles for you, but you can use your own when creating the system in the Console.
Learn how to set up the IAM roles yourself
NetApp Copy and Sync
Deploy the data broker in AWS
The AWS user account you use to deploy the data broker must have the needed permissions.
Permissions required to deploy the data broker in AWS
Provide permissions for the data broker
When NetApp Copy and Sync deploys the data broker, it creates an IAM role for the data broker instance. You can deploy the data broker using your own IAM role, if you prefer.
Requirements to use your own IAM role with the AWS data broker
Enable AWS access for a manually installed data broker
If you use the data broker with a sync relationship that includes an S3 bucket, then you should prepare the Linux host for AWS access. When you install the data broker, you'll need to provide AWS keys for an IAM user that has programmatic access and specific permissions.
Enabling access to AWS
FSx for ONTAP
Create and manage FSx for ONTAP
To create or manage an Amazon FSx for NetApp ONTAP system, you need to add AWS credentials to the Console by providing the ARN of an IAM role that gives the Console the permissions needed.
Learn how to set up AWS credentials for FSx
NetApp Cloud Tiering
Note
NetApp Cloud Tiering is no longer available for purchase or license renewal as of April 26, 2026.
Existing customers can continue to use and receive support for NetApp Cloud Tiering until their subscription or license contract expires. After the subscription expires, customers will no longer have access to NetApp Cloud Tiering features or support.
NetApp recommends that customers work with their NetApp representative to transition their existing tiering licenses to ONTAP FabricPool licenses, which provide the functionality for data tiering in ONTAP. For more information on how to set up data tiering in ONTAP using FabricPool, see Install a FabricPool license on an ONTAP cluster.
Tier on-premises ONTAP clusters to Amazon S3
When you enable NetApp Cloud Tiering to AWS, you enter an access key and secret key. These credentials are passed to the ONTAP cluster so that ONTAP can tier data to the S3 bucket.
Set up S3 permissions for tiering
Azure permissions
The Console requires Azure permissions for a Console agent and for individual services.
Console agent
When you deploy a Console agent from the Console, you need to use an Azure account or service principal that has permissions to deploy a Console agent VM in Azure.
Set up Azure permissions
When the Console deploys a Console agent VM in Azure, it creates a custom role that provides the permissions required to manage resources and processes within that Azure subscription.
You need to set up the custom role yourself if you launch a Console agent from the marketplace, if you manually install a Console agent, or if you add more Azure credentials to a Console agent.
Keep the policy up to date as new permissions are added in later releases.
Back up Cloud Volumes ONTAP to Azure blob storage
When using NetApp Backup and Recovery to back up Cloud Volumes ONTAP, you need to add permissions to a Console agent in the following scenarios:
  • You want to use "Search & Restore" functionality
  • You want to use customer-managed encryption keys (CMEK)
Back up on-premises ONTAP clusters to Azure blob storage
When using NetApp Backup and Recovery to back up on-premises ONTAP clusters, you need to add permissions to a Console agent to use the "Search & Restore" functionality.
Back up on-premises ONTAP data to Azure Blob storage with Backup and Recovery
NetApp Copy and sync
Deploy the data broker in Azure
The Azure user account that you use to deploy the data broker must have the required permissions.
Permissions required to deploy the data broker in Azure
Google Cloud permissions
The Console requires Google Cloud permissions for a Console agent and for individual services.
Console agents
The Google Cloud user who deploys a Console agent from the Console needs specific permissions to deploy a Console agent in Google Cloud.
Set up permissions to create a Console agent
The service account for a Console agent must have specific permissions for day-to-day operations. You need to associate the service account with a Console agent during deployment.
Set up permissions for a Console agent
Back up Cloud Volumes ONTAP to Google Cloud
Back up on-premises ONTAP clusters to Google Cloud
Back up on-premises ONTAP data to Google Cloud Storage with Backup and Recovery
Deploy the data broker in Google Cloud
Ensure that the Google Cloud user who deploys the data broker has the required permissions.
Permissions required to deploy the data broker in Google Cloud
Enable Google Cloud access for a manually installed data broker
If you plan to use the data broker with a sync relationship that includes a Google Cloud Storage bucket, then you should prepare the Linux host for Google Cloud access. When you install the data broker, you'll need to provide a key for a service account that has specific permissions.
Enabling access to Google Cloud
StorageGRID permissions
The Console requires StorageGRID permissions for two services.
Back up on-premises ONTAP clusters to StorageGRID
When you prepare StorageGRID as a backup target for ONTAP clusters, NetApp Backup and Recovery prompts you to enter an access key and secret for an IAM user that has specific permissions.
Prepare StorageGRID as your backup target
Note
Tier on-premises ONTAP clusters to StorageGRID
When you set up NetApp Cloud Tiering to StorageGRID, you need to provide Cloud Tiering with an S3 access key and secret key. Cloud tiering uses the keys to access your buckets.
Prepare tiering to StorageGRID
