NetApp Console setup and administration
Learn about NetApp Console deployment modes
Contributors netapp-tonias netapp-ml94669 netapp-dbagwell
You can use NetApp Console through the SaaS application or install it yourself in your own environment (cloud or on-premises).
NetApp refers to these use cases as deployment modes. Each mode offers different connectivity, features, and services for your business and security needs.
Standard mode (SaaS)
The NetApp Console SaaS (software-as-a-service) application enables access to all NetApp data services, automated updates, and flexible authentication options such as identity federation and NetApp Support Site logins. This mode supports marketplace subscriptions and BYOL licensing. This mode is ideal for most users and organizations, especially those who want the most features and services available with NetApp Console.
Restricted mode (installed in your own public cloud)
Restricted mode is for organizations needing enhanced security and limited connectivity, such as governments and regulated companies. You install the NetApp Console in your own public cloud (in a government, sovereign, or commercial region), and it has limited outbound connectivity to the NetApp Console API endpoints (hosted in the SaaS application). Restricted mode provides access to key data services including AI Data Engine, Cloud Volumes ONTAP, Azure NetApp Files, NetApp Backup and Recovery (in government and commercial regions), and data classification, along with automated software upgrades and identity federation.
Private mode (installed on your premises or in the cloud)
Private mode is for organizations with strict security needs, such as those in AWS Secret Cloud, AWS Top Secret Cloud, Azure IL6, or air-gapped environments. It does not connect to the NetApp Console SaaS application or NetApp cloud-based APIs, giving you full control and blocking outside communication. Supported data services include NetApp Backup and Recovery, NetApp Data Classification, NetApp Replication, and Cloud Volumes ONTAP. All storage and authentication remain local, keeping data within your environment. Use this mode for defense contractors, financial institutions with strict data residency rules, and government agencies with classified systems.
Note NetApp Console limits data flow in restricted and private modes, but you must ensure your environment complies with your regulations.
Each deployment mode differs in outbound connectivity, location, installation, authentication, data services, and charging methods.
The following table compares these modes.
Standard mode Restricted mode Private mode
Connection required to NetApp Console SaaS application?
Yes
Outbound only
No
Connection required to your cloud provider?
Yes
Yes, within the region
Yes, within the region (if using Cloud Volumes ONTAP)
Console agent installation
From the Console, cloud marketplace, or manual install
Cloud marketplace or manual install
Manual install
Console agent upgrades
Automatic upgrades of Console agent software
Manual upgrade required
UI access
From the Console SaaS application
Locally from an agent VM
Locally from the agent VM
API endpoint
The Console SaaS application
An agent
An agent
Authentication
Through SaaS using auth0, NSS login, or identity federation
Through SaaS using auth0 or identity federation
Local user authentication
Multi-factor authentication
Available for local users
Not available
Not available
Storage and data services
All are supported
Many are supported
Several are supported
Data service licensing options
Marketplace subscriptions and BYOL
Bring-your-own-license (BYOL)
See the following sections for details about supported features and services in each mode.
NetApp Console in standard mode (Saas application)
The following image shows a standard mode deployment.
A conceptual image that shows the public internet where the web-based console, SaaS application and auth0 authentication are available, a virtual network in the cloud where an agent is running and managing Cloud Volumes ONTAP and an AFF cluster in an on-premises data center.
Supported features and services for NetApp Console in standard mode
The following table lists the storage management features, data services, and administrative features available in the NetApp Console SaaS application (standard mode).
Note
NetApp Cloud Tiering is no longer available for purchase or license renewal as of April 26, 2026.
Existing customers can continue to use and receive support for NetApp Cloud Tiering until their subscription or license contract expires. After the subscription expires, customers will no longer have access to NetApp Cloud Tiering features or support.
NetApp recommends that customers work with their NetApp representative to transition their existing tiering licenses to ONTAP FabricPool licenses, which provide the functionality for data tiering in ONTAP. For more information on how to set up data tiering in ONTAP using FabricPool, see Install a FabricPool license on an ONTAP cluster.
Product area NetApp service or feature Console agent required
Storage systems management
This table shows which storage systems you can manage from the NetApp Console. It does not list backup destinations for NetApp Backup and Recovery.
Alerts
Yes
Amazon FSx for ONTAP
Yes for discovery and management. You can use direct discovery without a Console agent, but you need an agent to use management features.
Amazon S3
Yes
Azure Blob
No
Azure NetApp Files
No
Cloud Volumes ONTAP
Yes
E-Series
Yes
Google Cloud NetApp Volumes
No
Google Cloud Storage
Yes
Keystone subscription access
Yes
On-premises ONTAP clusters
Required for discovery and management. You can use direct discovery without a Console agent, but you need an agent to use management features.
StorageGRID
Yes
Workloads
No
Data Services
NetApp AI Data Engine
Yes
Yes
NetApp Classification
Yes
NetApp Copy and Sync
Yes
NetApp Disaster Recovery
Yes
NetApp Ransomware Resilience
Yes
NetApp Replication
No
Yes
NetApp Volume Caching
Yes
NetApp support contract features
Digital advisor
Yes
Economic efficiency
Yes
Lifecycle Planning
Yes
Software updates
No
Sustainability
Yes
Administrative features
Audit
No
Automation hub
No
Federation
No
Identity and access management
Yes
Licenses and subscriptions management
  • Marketplace subscriptions and BYOL are supported with standard mode; however, the supported licensing options depend on which NetApp data service you are using. Review the documentation for each service to learn more about the available licensing options.
No
Manage cloud provider credentials
No
Multi-factor authentication (local users)
No
Notifications
No
NSS accounts
No
Organization Partnerships
No
Read-only mode
No
How NetApp Console works in standard mode
The Console works as follows in standard mode:
Outbound communication
Connectivity is required from an agent to the Console SaaS application, to your cloud provider's publicly available resources, and to other essential components for day-to-day operations.
Supported location for a Console agent
In standard mode, you can install a Console agent in the cloud or on your premises.
Note Installing an agent in the cloud incurs cloud usage charges.
NetApp automatically upgrades agent software monthly.
User interface access
You access the user interface from the Console SaaS application, which is available over the public internet.
API endpoint
API calls are made to the following endpoint:
https://api.bluexp.netapp.com
Authentication
NetApp Console provides authentication with auth0 or NetApp Support Site (NSS) logins. Identity federation is available.
How to get started with standard mode
Go to the NetApp Console and sign up.
NetApp Console in restricted mode (installed in your own public cloud)
You install a Console agent in the cloud (in a government, sovereign, or commercial region), and it has limited outbound connectivity to the NetApp Console API endpoints (hosted in the SaaS application).
Users access the local UI provided by the Console agent, not the SaaS application.
Depending on the data services and features that you plan to use, a Console organization admin creates additional Console agents to manage data within your hybrid cloud environment.
The following image is an example of a restricted mode deployment.
A conceptual image that shows the public internet where the SaaS application and auth0 authentication are available, a virtual network in the cloud where an agent is running and providing access to the web-based console, and is managing Cloud Volumes ONTAP and an AFF cluster in an on-premises data center.
Supported features and services for NetApp Console in restricted mode
The following table lists the storage management features, data services, and administrative features available in NetApp Console when you install it in restricted mode.
Azure NetApp Files
No
Cloud Volumes ONTAP
Yes
Data Services (restricted mode supports fewer data services than standard mode)
AI Data Engine
Yes
Backup and Recovery
Supported in Government regions and commercial regions with restricted mode. Not supported in sovereign regions with restricted mode.
In restricted mode, NetApp Backup and Recovery supports back up and restore of ONTAP volume data only. View the list of supported backup destinations for ONTAP data
  • Supported in Government regions with restricted mode. Not supported in commercial regions or in sovereign regions with restricted mode.
Yes
NetApp Replication
Yes* (not needed if replicating from ONTAP on-premises to ONTAP on-premises)
None
N/A
Audit
No
Automation hub
No
Federation
No
Yes
Note the following:
  • Marketplace subscriptions (hourly and annual contracts)
    • For Cloud Volumes ONTAP, only capacity-based licensing is supported.
    • In Azure, annual contracts are not supported with government regions.
  • BYOL
    For Cloud Volumes ONTAP, both capacity-based licensing and node-based licensing are supported with BYOL.
No
No
No
Notifications
No
NSS accounts
No
No
Read-only mode
Yes
How NetApp Console works in restricted mode
The Console works as follows in restricted mode:
An agent requires outbound connectivity to the NetApp cloud-based APIs for support of data services, software upgrades, authentication, and metadata transmission.
NetApp does not initiate communication to an agent. The agent initiates all communication and can pull or push data from or to the NetApp APIs and services as required.
A connection is also required to cloud provider resources from within the region.
Supported location for an agent
In restricted mode, you install agents in the cloud: in a government region, sovereign region, or commercial region.
NetApp Console upgrades agent software automatically each month.
Users access the Console from an agent virtual machine that's deployed in your cloud region.
API endpoint
API calls are made to an agent virtual machine.
Authentication
Authentication is provided through NetApp Console's cloud service using auth0. Identity federation is also available.
How to get started with restricted mode
You need to enable restricted mode when you create your NetApp Console account.
If you do not have an organization, you are prompted to create one and enable restricted mode when you first log in to your installed Console agent.
Note that the restricted mode setting is fixed after you create the organization. You cannot enable or disable restricted mode later.
Learn how to get started with restricted mode.
NetApp Console in private mode
In private mode, you install a Console agent either on-premises or in the cloud and then use NetApp Console to manage data across your hybrid cloud. There is no connectivity to the NetApp Console API endpoints or the NetApp Console SaaS application, so you access the Console from the local UI provided by the Console agent.
The following image shows an example of a private mode deployment where the Console agent is installed in the cloud and manages both Cloud Volumes ONTAP and an on-premises ONTAP cluster.
A conceptual image that shows a virtual network in the cloud where an agent is running and providing access to the web-based console, and is managing Cloud Volumes ONTAP and an AFF cluster in an on-premises data center.
The second image shows an example of a private mode deployment where the agent is installed on-premises, manages an on-premises ONTAP cluster, and provides access to supported NetApp Console data services.
A conceptual image that shows an on-premises data center where an agent is running and providing access to the web-based console, NetApp Console data services, and is managing an AFF cluster in an on-premises data center.
Supported features and services for NetApp Console in private mode
The following table lists the storage management features, data services, and administrative features available in NetApp Console when you install it in private mode. Features differ when you install the NetApp Console in the cloud versus your premises.
Private mode installed in the cloud
This portion of the table lists support for managing storage systems from the NetApp Console. It does not indicate the supported backup destinations for NetApp Backup and Recovery.
Cloud Volumes ONTAP
Yes, but because there's no internet access, the following features aren't available: automated software upgrades and AutoSupport.
  • Requires connectivity from the cloud (where the Console agent is installed) to the on-premises environment.
    You must have an installed Console agent to discover on-premises ONTAP clusters.
Data Services
Backup and Recovery
Yes
Yes
NetApp Replication
None
Audit
No
  • Only BYOL is supported with private mode.
    For Cloud Volumes ONTAP BYOL, only node-based licensing is supported. Capacity-based licensing is not supported. Because an outbound internet connection isn't available, you need to manually upload your Cloud Volumes ONTAP licensing file in the Console.
No
Yes
No
Read-only mode
No
Notifications
No
Private mode installed on-premises
Data Services
Backup and Recovery
Yes
Yes
NetApp Replication
None
N/A
Audit
No
No
Yes
No
Read-only mode
No
Notifications
No
How NetApp Console works in private mode
NetApp Console works as follows in private mode:
No outbound connectivity is required to the Console SaaS application (where additional API endpoints reside). All packages, dependencies, and essential components are packaged with the Console agent and served from the local machine. Connectivity to your cloud provider's publicly available resources is required only if you are deploying Cloud Volumes ONTAP.
Supported location for the Console agent
In private mode, the Console agent is supported in the cloud or on-premises.
You must manually upgrade the Console agent software. NetApp publishes the Console agent software to the NetApp Support Site at undefined intervals.
Users access the Console from the Console agent that's deployed in your cloud region or on-premises.
API endpoint
API calls are made to the Console agent virtual machine.
Authentication
Authentication is provided through local user management and access. Authentication is not provided through NetApp Console's cloud service.
How to get started with private mode
Private mode is available by downloading the "offline" installer from the NetApp Support Site.
Note If you want to use NetApp Console in the AWS Secret Cloud or the AWS Top Secret Cloud, then you should follow separate instructions to get started in those environments. Learn how to get started with Cloud Volumes ONTAP in the AWS Secret Cloud or Top Secret Cloud
NetApp Console service and feature comparison
This table shows which services and features are supported in restricted and private modes.
Note Standard mode (NetApp Console SaaS application) supports all features.
Note that some services might be supported with limitations. For more details about how these services are supported with restricted mode and private mode, refer to the sections above.
Product area NetApp service or feature Restricted mode Private mode
Alerts
No
No
No
No
Amazon S3
No
No
Azure Blob
No
No
Azure NetApp Files
Yes
No
Cloud Volumes ONTAP
Yes
Yes
No
No
No
No
Yes
Yes
E-Series
No
No
StorageGRID
No
No
Workloads
No
No
Data Services
AI Data Engine
Yes
No
Backup and Recovery
Yes
View the list of supported backup destinations for ONTAP volume data
Yes
Yes
Yes
No
No
No
No
No
No
NetApp Replication
Yes
Yes
NetApp Cloud Tiering*
No
No
No
No
Digital advisor
No
No
Lifecycle Planning
No
No
Software updates
No
No
Sustainability
No
No
Dashboard metrics for storage and data services
No
No
Yes
Yes
Yes
Yes
Federation
Yes
No
Yes
Yes
Yes
No
NSS accounts
Yes
No
Yes
No
Read-only mode
Yes
No
Notifications
Yes
No
Audit
Yes
Yes
