Getting started workflow for NetApp Console (SaaS application)
Get started with the NetApp Console (SaaS) by preparing networking for the Console, signing up and creating an account, and using the Console assistant to set up initial functionality.
You access a web-based console that is hosted as a Software-as-a-service (SaaS) product from NetApp. You can use the Console to manage your hybrid cloud storage environment and use NetApp data services.
Ensure computers accessing the NetApp console have network access to the required endpoints.
Go to the NetApp console and sign up. If prompted to create an organization and you think an organization already exists for your company, close the dialog box and tell your organization administrator. If there isn't currently an Organization administrator for your company, you can claim this role. Learn how to contact an organization administrator.
At this point, you're logged in and can use the NetApp assistant to start configuring the Console. To begin, associate your NetApp Support account and a Console agent to enable full functionality.
If you choose not to use the NetApp assistant or install a Console agent, you can start managing storage and using services like Digital Advisor, Amazon FSx for ONTAP, Azure NetApp Files, and more. Learn what you can do without a Console agent.
Associate your NetApp Support Site (NSS) accountAssociating your NetApp Support Site (NSS) account with the Console enables you to manage your licenses and subscriptions more easily as well as access support resources directly from the Console.
Create a Console agentAdvanced storage management features and some NetApp data services require that you install a Console agent. The Console agent enables the Console to manage resources and processes within your hybrid cloud environment.
You can create a Console agent in your cloud or on-premises network.
Add a storage system to the ConsoleWithin the NetApp Console, you can add or discover storage systems to manage your hybrid cloud storage environment. Use the NetApp assistant to add your first storage system.
If you install a Console agent in AWS, Microsoft Azure, or Google Cloud, then the Console automatically discovers information about the Amazon S3 buckets, Azure Blob storage, or Google Cloud Storage buckets in the location where the agent is installed. These systems are automatically added to the Systems page. |
Sign up for NetApp Intelligent Services through your cloud provider for hourly (PAYGO) or annual billing. A subscription includes NetApp Backup and Recovery, Cloud Volumes ONTAP, NetApp Ransomware Resilience, NetApp Disaster Recovery, and NetApp Data Classification.
NetApp Cloud Tiering is no longer available for purchase or license renewal as of April 26, 2026. Existing customers can continue to use and receive support for NetApp Cloud Tiering until their subscription or license contract expires. After the subscription expires, customers will no longer have access to NetApp Cloud Tiering features or support. NetApp recommends that customers work with their NetApp representative to transition their existing tiering licenses to ONTAP FabricPool licenses, which provide the functionality for data tiering in ONTAP. For more information on how to set up data tiering in ONTAP using FabricPool, see Install a FabricPool license on an ONTAP cluster. |
