Sign up or log in to NetApp Console
To use the Console, sign up or log in with your NetApp Support Site credentials, or create a NetApp Console login. If you are the first from your company to sign up, you create a new organization as the administrator. If your company already has an organization, sign up or log in with your existing NetApp Support Site credentials or company single-sign-on (SSO).
Sign up for NetApp Console as the initial organization administrator
If your company doesn't have a NetApp Console organization, sign up to create one. The first user becomes the organization administrator and manages user accounts and permissions. You can update roles and add more administrators later.
Open a web browser and go to the NetApp Console.
If you have a NetApp Support Site account, enter the email address associated with your account directly on the Log in page.
The Console signs you up as part of this initial login with your NetApp Support Site credentials.
If you want to sign up by creating a Console login, select Sign up.
On the Sign up page, enter the required information and select Next.
Only English characters are allowed in the sign up form. -
Check your inbox for an email from NetApp that includes instructions to verify your email address.
Verify your email address to complete sign up.
After you log in, review and accept the End User License Agreement.
On the Welcome page, create an organization.
Select Let's Start.
+ As a first-time user and organization administrator, you follow a guided process to add storage resources, create a Console agent, and more. Learn about using the Console Assistant.
As an administrator, after you complete the steps included in the Console Assistant, you should plan your identity and access strategy, add users to your organization, and assign roles. Learn about identity and access management for NetApp Console
Sign up or login to NetApp Console when an organization already exists
If your company already has a NetApp Console organization, sign up or log in to access it. Your sign-up or log-in method depends on whether your company uses identity federation or has NetApp Support Site credentials. If not, create a NetApp Console log-in.
If you have a NetApp Support Site account or if your company has set up single sign-on (SSO), enter your associated email address or SSO credentials on the Log in page. Follow the prompts to complete login.
In both of these cases, you are signed up for the Console as part of this initial login.
If the system prompts you to create an organization, close the dialog box and tell a Console admin so they can add you to your Console organization and give you access. Learn how to contact an organization administrator.
After you are given access to your organization, you can start managing storage and using the data services that you are assigned.
