NetApp Console setup and administration
Get started using the NetApp Console assistant
Contributors netapp-tonias
If you are a first-time user of the NetApp Console (SaaS) with the Organization admin role, you can use the Console assistant to guide you through the initial setup process. The assistant helps you add a NetApp Support Site (NSS) account, add a Console agent, add a cluster, and add a license or subscription, making it easier to get started with managing your data.
Required roles to access the Console assistant
The Console assistant is only available to users with the Organization admin role.
By default, the NetApp Console displays the Console assistant on the Home page for first-time users who have the Organization admin role. It remains available until you complete the mandatory tasks of creating a Console agent and adding a system.
Use the assistant to complete these tasks, which provide the minimum setup for your NetApp Console environment:
