Get started with identity and access in NetApp Console
When you sign up for the NetApp Console, you're prompted to create a new organization. The organization includes one member (an Organization admin) and one default project. To set up identity and access management (IAM) to meet your business needs, you'll need to customize your organization's hierarchy, add additional members, add or discover resources, and associate those resources across your hierarchy.
You need Org admin or Super admin permissions to manage identity and access for your organization. With Folder or project admin permissions, you can manage only the folders and projects you have access to.
Follow these steps to set up a new organization. The order may vary based on your organization's needs.
Edit the default project or add to your organization's hierarchyUse the default project or create additional projects and folders matching your business hierarchy.
Associate members with your organizationAfter users sign up for NetApp Console, you must explicitly add them to your Console organization. You also have the option to add service accounts to your organization.
Add or discover resourcesAdd or discover resources (systems) to the Console. Organization members manage systems from within a project.
Learn how to create or discover resources:
Associate resources with additional projectsAdding or discovering a system in the Console automatically associates the resource with the currently selected project. To make that resource available to another project in your organization, associate it with the respective project. If a Console agent is used to manage the resource, associate the Console agent with the respective project.
