NetApp Console setup and administration
Associate a NetApp Console agent with other folders and projects
Contributors netapp-tonias
Associate Console agents with specific projects to enable resource management and data service access. Resources discovered through a Console agent require both the resource and agent to be associated with the same respective projects for team access.
Super admins and Org admins can create agents and associate any agent with any project or folder. Folder or project admins can only associate existing agents with folders and projects that they have permissions for.
Learn more about the actions that a Folder or project admin can complete.
Note Users with the Org admin role can add resources to a folder to delegate the task of associating the resource with projects to Folder or project admins of the respective folder. Learn about associating a resource with a folder.
Steps
  1. Select Administration > Identity and access > Agents.
  2. From the table, find the Console agent that you want to associate.
    Use the search above the table to find a specific Console agent or filter the table by resource hierarchy.
  3. To view the folders and projects linked to the Console agent, select Three dot icon and then select View details.
    The page displays details about the folders and projects that are associated with the Console agent.
  4. Select Associate to folder or project.
  5. Select a folder or project and then select Accept.
  6. To associate the Console agent with an additional folder or project, select Add a folder or project and then select the folder or project.
  7. Select Associate Agent.
After you finish
Associate the Console agent's resources with the same folders and projects from the Resources page.
