NetApp Console setup and administration
Learn about NetApp Console agents
Contributors netapp-tonias netapp-ahibbard
A Console agent is a lightweight software component that you install in your network to connect your storage infrastructure to the NetApp Console. It enables advanced storage orchestration, data services, and secure cloud integration.
What a Console agent does
A Console agent bridges the connectivity gap between your storage systems and NetApp Console. It securely connects your infrastructure to the NetApp APIs and the Console, allowing you to:
  • Discover and monitor storage systems across AWS, Azure, Google Cloud, and on-premises environments from the NetApp Console.
  • Orchestrate storage provisioning and configuration tasks on storage systems from the NetApp Console.
  • Use intelligent data protection and management workflows.
  • Securely track cloud service usage and connect deployments to the correct subscription for accurate billing and cost management.
Console agent architecture
Agents operate with lightweight processes that:
  • Pull or push data to and from the Console SaaS application (standard and restricted modes)
  • Initiate all communication—the Console never initiates outbound calls to agents
  • Connect to your storage systems using standard management protocols
  • Use TLS 1.3 for secure communication with cloud providers and the NetApp Console APIs
Console agent availability and operational requirements
Console agents are critical for NetApp Console. Agents must stay operational and reachable for uninterrupted management and data services. You are responsible for ensuring:
  • Agents remain up and running
  • Agents have network connectivity to required endpoints
  • Infrastructure failures are resolved quickly
  • Agent VMs are maintained and upgraded according to NetApp recommendations
When you need a Console agent
You need to deploy at least one Console agent when you want to:
  • Use restricted or private deployment modes (Console installed in your own environment). Additional agents may be required to enable some services.
  • Access advanced data services (NetApp Backup and Recovery, NetApp Disaster Recovery, NetApp Ransomware Resilience, NetApp Data Classification and more).
  • Manage Cloud Volumes ONTAP systems.
  • Perform advanced management tasks on on-premises ONTAP clusters.
  • Track licenses, monitor storage health, and plan lifecycle upgrades.
Without an agent, you can perform basic storage discovery and access a limited set of monitoring and storage management features. However, most enterprise use cases require one or more operational agents.
The following table shows which storage systems and services are available with and without a Console agent.
Available with agent Available without agent
Supported storage systems:
Amazon FSx for ONTAP
Yes (discovery and management features)
Yes (discovery only)
Amazon S3 storage
Yes
No
Azure Blob storage
Yes
Yes
Azure NetApp Files
Yes
Yes
Cloud Volumes ONTAP
Yes
No
E-Series systems
Yes
No
Google Cloud NetApp Volumes
Yes
Yes
Google Cloud storage buckets
Yes
No
StorageGRID systems
Yes
No
On-premises ONTAP cluster
Yes (advanced management and discovery)
No (basic discovery only)
Storage management and health services:
Alerts
Yes
No
Automation hub
Yes
Yes
Digital Advisor (Active IQ)
Yes
Yes
License and subscription management
Yes
No
Economic efficiency
Yes
No
Home page dashboard metrics
Yes. Accurate home page metrics require appropriately sized and configured Console agents.
No
Lifecycle planning
Yes
No. You can view Lifecycle planning without a Console agent, but a Console agent is required to initiate actions.
Sustainability
Yes
No
Software updates
Yes
Yes
NetApp Workloads
Yes
Yes
Available data services:
Yes
No
Yes
No
NetApp Cloud Tiering*
Yes
No
NetApp Copy and Sync
Yes
No
Yes
No
Yes
No
NetApp Volume Caching
Yes
No
Note
NetApp Cloud Tiering is no longer available for purchase or license renewal as of April 26, 2026.
Existing customers can continue to use and receive support for NetApp Cloud Tiering until their subscription or license contract expires. After the subscription expires, customers will no longer have access to NetApp Cloud Tiering features or support.
NetApp recommends that customers work with their NetApp representative to transition their existing tiering licenses to ONTAP FabricPool licenses, which provide the functionality for data tiering in ONTAP. For more information on how to set up data tiering in ONTAP using FabricPool, see Install a FabricPool license on an ONTAP cluster.
Learn about NetApp Console deployment modes to understand when you need an agent and the capabilities agents enable.
Deployment options for Console agents
You can deploy Console agents in:
  • Amazon Web Services
  • Microsoft Azure
  • Google Cloud
    To manage Google Cloud resources, deploy your agent in Google Cloud. An on-premises agent cannot manage Google Cloud resources.
  • On your premises (standard or private modes only)
Your Console deployment mode, storage environment, and data sovereignty needs determine where you deploy agents. Deploy multiple agents across environments for organizational separation or business needs.
You can deploy agents directly from the Console, from your cloud marketplace, or manually in vCenter or on your premises. Compare deployment methods to choose the right one for your environment.
Agents for the NetApp Console SaaS application (standard mode)
Deploy agents in your cloud or on-premises to bridge connectivity to the cloud-hosted Console SaaS application. Agents enable advanced features while the Console UI remains accessible from anywhere.
You can install agents directly from the Console when using the SaaS application (standard mode). You can install in AWS, Azure, or Google Cloud, or manually on your premises on your own Linux host or in your vCenter environment.
Agents for NetApp Console in restricted mode
In restricted mode, users access the NetApp Console directly from an installed agent — not from the cloud-hosted SaaS application. You must install at least one agent to serve as the Console access point. Additional agents are needed to enable data services and manage storage systems.
Install agents from your cloud provider's marketplace or by manually installing the software on your own Linux host in the cloud, on your premises, or in your VCenter environment.
Agents for NetApp Console in private mode (on-premises or in the cloud with no outbound connectivity)
In private mode, users access the NetApp Console directly from an installed agent. You must install at least one agent to serve as the Console access point. Additional agents are needed to enable data services and manage storage systems.
Install agents in your data center or air-gapped environment. Agents have no connectivity to NetApp API endpoints, and all operations remain local, with full data sovereignty and control.
Use multiple agents when needed
Each agent operates independently and can manage multiple storage systems and data services. Deploy multiple agents when you need:
  • Isolation by storage type or organizational function
  • Geographic or network segmentation requirements
For example:
  • In a multicloud environment, you might deploy one agent in AWS and another in Azure. Each agent manages the Cloud Volumes ONTAP systems in its respective environment.
  • A service provider might use one Console organization to provide services for customers and another organization for disaster recovery for a business unit. Each organization needs its own agent.
Console agent upgrades
Agents in the cloud upgrade automatically when they have outbound internet access. For agents without internet access (private mode), see Manage Console agent upgrades for manual upgrade instructions.
