Cloud Volumes ONTAP
Plan your Cloud Volumes ONTAP configuration in AWS
Contributors netapp-manini netapp-ahibbard
When you deploy Cloud Volumes ONTAP in AWS, you can choose a preconfigured system that matches your workload requirements, or you can create your own configuration. If you choose your own configuration, you should understand the options available to you.
Choose a Cloud Volumes ONTAP license
Several licensing options are available for Cloud Volumes ONTAP. Each option enables you to choose a consumption model that meets your needs.
Choose a supported region
Cloud Volumes ONTAP is supported in most AWS regions. View the full list of supported regions.
Newer AWS regions must be enabled before you can create and manage resources in those regions. AWS documentation: Learn how to enable a region.
Choose a supported Local Zone
Selecting a Local Zone is optional. Cloud Volumes ONTAP is supported in some AWS Local Zones including Singapore. Cloud Volumes ONTAP in AWS supports only high availability (HA) mode in a single availability zone. Single node deployments are not supported.
Note Cloud Volumes ONTAP does not have support for data tiering and cloud tiering in AWS Local Zones. Additionally, Local Zones with instances that have not been qualified for Cloud Volumes ONTAP are not supported. An example of this is Miami, that is not available as a Local Zone, because it has only Gen6 instances that are unsupported and unqualified.
AWS Documentation: View the full list of Local Zones.
Local Zones must be enabled before you can create and manage resources in those zones.
Choose a supported instance
Cloud Volumes ONTAP supports several instance types, depending on the license type that you choose.
Understand storage limits
The raw capacity limit for a Cloud Volumes ONTAP system is tied to the license. Additional limits impact the size of aggregates and volumes. You should be aware of these limits as you plan your configuration.
Size your system in AWS
Sizing your Cloud Volumes ONTAP system can help you meet requirements for performance and capacity. You should be aware of a few key points when choosing an instance type, disk type, and disk size:
Instance type
EBS disk type
At a high level, the differences between EBS disk types are as follows. To learn more about the use cases for EBS disks, refer to AWS Documentation: EBS Volume Types.
  • General Purpose SSD (gp3) disks are the lowest-cost SSDs that balance cost and performance for a broad range of workloads. Performance is defined in terms of IOPS and throughput. gp3 disks are supported with Cloud Volumes ONTAP 9.7 and later.
    When you select a gp3 disk, the NetApp Console fills in default IOPS and throughput values that provide performance that is equivalent to a gp2 disk based on the selected disk size. You can increase the values to get better performance at a higher cost, but we do not support lower values because it can result in inferior performance. In short, stick with the default values or increase them. Don't lower them. AWS Documentation: Learn more about gp3 disks and their performance.
    Note that Cloud Volumes ONTAP supports the Amazon EBS Elastic Volumes feature with gp3 disks. Learn more about Elastic Volumes support.
  • General Purpose SSD (gp2) disks balance cost and performance for a broad range of workloads. Performance is defined in terms of IOPS.
  • Provisioned IOPS SSD (io1) disks are for critical applications that require the highest performance at a higher cost.
    Note that Cloud Volumes ONTAP supports the Amazon EBS Elastic Volumes feature with io1 disks. Learn more about Elastic Volumes support.
  • Throughput Optimized HDD (st1) disks are for frequently accessed workloads that require fast and consistent throughput at a lower price.
    Note Data tiering to Amazon Simple Storage Service (Amazon S3) is not supported if your Cloud Volumes ONTAP system is in an AWS Local Zone, because accessing the Amazon S3 buckets outside of the Local Zone involves higher latency and impacts Cloud Volumes ONTAP activities.
EBS disk size
If you choose a configuration that doesn't support the Amazon EBS Elastic Volumes feature, then you need to choose an initial disk size when you launch a Cloud Volumes ONTAP system. After that, you can let the Console manage a system's capacity for you, but if you want to create aggregates yourself, be aware of the following:
  • All disks in an aggregate must be the same size.
  • The performance of EBS disks is tied to disk size. The size determines the baseline IOPS and maximum burst duration for SSD disks and the baseline and burst throughput for HDD disks.
  • Ultimately, you should choose the disk size that gives you the sustained performance that you need.
  • Even if you do choose larger disks (for example, six 4 TiB disks), you might not get all of the IOPS because the EC2 instance can reach its bandwidth limit.
    For more details about EBS disk performance, refer to AWS Documentation: EBS Volume Types.
    As noted above, choosing a disk size is not supported with Cloud Volumes ONTAP configurations that support the Amazon EBS Elastic Volumes feature. Learn more about Elastic Volumes support.
View default system disks
In addition to the storage for user data, the Console also purchases cloud storage for Cloud Volumes ONTAP system data (boot data, root data, core data, and NVRAM). For planning purposes, it might help for you to review these details before you deploy Cloud Volumes ONTAP.
Tip The Console agent also requires a system disk. View details about the Console agent's default configuration.
Prepare to deploy Cloud Volumes ONTAP in an AWS Outpost
If you have an AWS Outpost, you can deploy Cloud Volumes ONTAP in that Outpost by selecting the Outpost VPC during the deployment process. The experience is the same as any other VPC that resides in AWS. Note that you will need to first deploy a Console agent in your AWS Outpost.
There are a few limitations to point out:
  • Only single node Cloud Volumes ONTAP systems are supported at this time
  • The EC2 instances that you can use with Cloud Volumes ONTAP are limited to what's available in your Outpost
  • Only General Purpose SSDs (gp2) are supported at this time
Collect networking information
When you launch Cloud Volumes ONTAP in AWS, you need to specify details about your VPC network. You can use a worksheet to collect the information from your administrator.
Single node or HA pair in a single AZ
AWS information Your value
Region
VPC
Subnet
Security group (if using your own)
HA pair in multiple AZs
Region
VPC
Node 1 availability zone
Node 1 subnet
Node 2 availability zone
Node 2 subnet
Mediator availability zone
Mediator subnet
Key pair for the mediator
Floating IP address for cluster management port
Floating IP address for data on node 1
Floating IP address for data on node 2
Route tables for floating IP addresses
Choose a write speed
The Console enables you to choose a write speed setting for Cloud Volumes ONTAP. Before you choose a write speed, you should understand the differences between the normal and high settings and risks and recommendations when using high write speed. Learn more about write speed.
Choose a volume usage profile
ONTAP includes several storage efficiency features that can reduce the total amount of storage that you need. When you create a volume in the Console, you can choose a profile that enables these features or a profile that disables them. You should learn more about these features to help you decide which profile to use.
NetApp storage efficiency features provide the following benefits:
Thin provisioning
Presents more logical storage to hosts or users than you actually have in your physical storage pool. Instead of preallocating storage space, storage space is allocated dynamically to each volume as data is written.
Deduplication
Improves efficiency by locating identical blocks of data and replacing them with references to a single shared block. This technique reduces storage capacity requirements by eliminating redundant blocks of data that reside in the same volume.
Compression
Reduces the physical capacity required to store data by compressing data within a volume on primary, secondary, and archive storage.
