Cloud Volumes ONTAP
Learn more about capacity-based licenses for Cloud Volumes ONTAP
Contributors netapp-manini netapp-ahibbard
Cloud Volumes ONTAP capacity-based licensing determines how storage capacity, packages, and overages are billed. Use this information to understand charging and capacity consumption, especially for standard-mode deployments.
Private-mode deployments can use capacity-based Essentials packages only in a Bring-Your-Own License (BYOL) model. For licensing details for private-mode deployments, refer to Learn about Cloud Volumes ONTAP BYOL.
Consumption models and purchase options
Capacity-based licensing packages are available with the following consumption models or purchase options:
  • Marketplace subscriptions/Annual contract: An annual contract from your cloud provider's marketplace. Private-mode deployments do not support marketplace subscriptions.
  • PAYGO: A pay-as-you-go (PAYGO) subscription is an hourly subscription from your cloud provider's marketplace.
  • BYOL: Bring-Your-Own License (BYOL). A license purchased from NetApp that can be used to deploy Cloud Volumes ONTAP in any cloud provider.
    Note NetApp has restricted the purchase, extension, and renewal of BYOL licensing, and has limited availability in specific scenarios, such as in private-mode deployments. For more information, refer to Restricted availability of BYOL licensing for Cloud Volumes ONTAP.
Note the following:
  • If you purchase a BYOL license from NetApp, you also need to subscribe to the PAYGO offering in your cloud provider's marketplace. NetApp has restricted BYOL licensing for standard mode deployments. When your BYOL license expires, replace it with a cloud marketplace subscription.
    Your license is always charged first, but you'll be charged from the hourly rate in the marketplace in these cases:
    • If you exceed your licensed capacity
    • If the term of your license expires
  • If you have a BYOL license and an annual contract from a marketplace, your consumption and overages are charged according to the billing preference you set. To understand how you are charged, refer to Billing preferences and overages.
  • Only single-node systems with BYOL are supported in China regions. China region deployments are exempt from BYOL licensing restrictions.
How you are charged for supported storage types and packages
Charging in Cloud Volumes ONTAP is based on a number of factors, such as packages and volume types. Capacity-based licensing packages are available with Cloud Volumes ONTAP 9.7 and later.
The following sections explain what gets charged, where minimums apply, and how overages are billed.
For details about pricing, go to the NetApp Console website.
Storage VMs
  • There are no extra licensing costs for additional data-serving storage VMs (SVMs), but there is a four TiB minimum capacity charge per data-serving SVM.
  • Disaster recovery SVMs are charged according to the provisioned capacity.
HA pairs
For HA pairs, you're only charged for the provisioned capacity on a node. You aren't charged for data that is synchronously mirrored to the partner node.
FlexClone and FlexCache volumes
  • You won't be charged for the capacity used by FlexClone volumes.
  • Source and destination FlexCache volumes are considered primary data and charged according to the provisioned space.
Read/write volumes
A writable (read/write) volume is a primary volume. The system charges the provisioned capacity based on the minimum charge per storage VM (SVM). Examples include FlexVol read/write volumes, SnapLock audit volumes, and CIFS/NFS audit volumes. All user-created data volumes are charged according to your subscription and package type. ONTAP internal volumes, such as SVM root volumes, are not charged because they are created automatically and cannot store data.
Essentials packages
The Essentials package bills by deployment type (HA or single node) and volume type (primary or secondary). Pricing from highest to lowest is Essentials Primary HA, Essentials Primary Single Node, Essentials Secondary HA, and Essentials Secondary Single Node. If you purchase a marketplace contract or accept a private offer, the capacity charge is the same for any deployment or volume type.
Licensing is based entirely on the volume type created within Cloud Volumes ONTAP systems:
  • Essentials Single Node: Read/write volumes created on a Cloud Volumes ONTAP system using one ONTAP node only.
  • Essentials HA: Read/write volumes using two ONTAP nodes that can fail over to each other for non-disruptive data access.
  • Essentials Secondary Single Node: Data Protection (DP) type volumes (typically SnapMirror or SnapVault destination volumes that are read-only) created on a Cloud Volumes ONTAP system using one ONTAP node only.
    Note If a read-only DP volume becomes a primary volume, the Console treats it as primary data and calculates charges based on the time that the volume remains in read/write mode. If the volume becomes read-only again, the Console treats it as secondary data and charges it according to the best-matching license in the Console.
  • Essentials Secondary HA: Data Protection (DP) type volumes (typically SnapMirror or SnapVault destination volumes that are read-only) created on a Cloud Volumes ONTAP system using two ONTAP nodes that can fail over to each other for non-disruptive data access.
Minimum charge
There is a 4 TiB minimum charge for each data-serving storage VM that has least one primary (read-write) volume. If the sum of the primary volumes is less than 4 TiB, then the Console applies the 4 TiB minimum charge to that storage VM.
If you haven't provisioned any volumes yet, then the minimum charge doesn't apply.
For the Essentials package, the 4 TiB minimum capacity charge doesn't apply to storage VMs that contain secondary (data protection) volumes only. For example, if you have a storage VM with 1 TiB of secondary data, then you're charged just for that 1 TiB of data. With the Professional package type, the minimum capacity charging of 4 TiB applies regardless of the volume type.
You can choose how you want to be charged in the Licenses and subscriptions section in the Console. Overages occur when your usage exceeds the capacity specified in your license package or annual subscription.
  • NetApp licenses first: In this model, your usage is first charged against the capacity of your license package (BYOL). If you exceed your license capacity, overages are charged based on your annual marketplace subscription or marketplace on-demand hourly rates (PAYGO). If your BYOL license expires, you must transition to a capacity-based licensing model through the cloud marketplaces. For information, refer to Convert a Cloud Volumes ONTAP node-based license to a capacity-based license.
  • Marketplace subscriptions only: In this model, your usage is first charged against your annual marketplace subscription. Any additional usage is charged at marketplace on-demand hourly rates (PAYGO). Any unused license capacity is disregarded for billing.
For more information about billing preferences, refer to Learn about billing preferences for licenses and subscriptions.
How overages are charged for Essentials licenses
If you purchase an Essentials license from NetApp (BYOL) and you exceed the licensed capacity for a specific Essentials package, the Console charges overages against a higher-priced Essentials license (if you have one with available capacity). The Console first uses the available capacity that you've paid for before charging against the marketplace. If there is no available capacity with your BYOL license, the exceeded capacity is charged at marketplace on-demand hourly rates (PAYGO) and added to your monthly bill.
Similarly, if you have an annual marketplace contract or a private offer with multiple Essentials packages, and your usage exceeds the committed capacity for a specific deployment and volume type, the Console charges overages against a higher-priced Essentials package that has available capacity. After that capacity is exhausted, the remaining overage is billed at marketplace on-demand (PAYGO) hourly rates and added to your monthly bill.
For information about Essentials licenses charging, refer to Essentials packages.
Here's an example. Let's say you have the following licenses for the Essentials package:
  • A 500 TiB Essentials Secondary HA license that has 500 TiB of committed capacity
  • A 500 TiB Essentials Single Node license that only has 100 TiB of committed capacity
Another 50 TiB is provisioned on an HA pair with secondary volumes. Instead of charging that 50 TiB to PAYGO, the Console charges the 50 TiB overage against the Essentials Single Node license. That license is priced higher than Essentials Secondary HA, but it's making use of a license you have already purchased, and it will not add costs to your monthly bill.
In Administration > Licenses and subscriptions, you can see 50 TiB charged against the Essentials Single Node license.
Here's another example. Let's say you have the following licenses for the Essentials package:
Another 100 TiB is provisioned on an HA pair with primary volumes. The license you purchased doesn't have Essentials Primary HA committed capacity. The Essentials Primary HA license is priced higher than both the Essentials Primary Single Node and Essentials Secondary HA licenses.
In this example, the Console charges overages at the marketplace rate for the additional 100 TiB. The overage charges will appear on your monthly bill.
Change license packages
After deployment, you can change the package for a Cloud Volumes ONTAP system that uses capacity-based licensing. For example, if you deployed a Cloud Volumes ONTAP system with the Essentials package, you can change it to the Professional package if your business needs change. Learn how to change charging methods.
NetApp is phasing out node-based licensing in favor of capacity-based licensing. Node-based licenses remain available in a few older systems, such as USPS customers and deployments in China. If you have a node-based license, you can convert it to capacity-based licensing. For information about converting node-based licenses to capacity-based licensing, refer to Convert a node-based license to a capacity-based license.
Capacity limit
In the capacity-based licensing model, each Cloud Volumes ONTAP system supports tiering to object storage, and the total tiered capacity can scale up to the cloud provider's bucket limit. Although the license does not impose capacity restrictions, follow the FabricPool Best Practices to ensure optimal performance, reliability, and cost efficiency when configuring and managing tiering.
For information about the capacity limits of each cloud provider, refer to their documentation:
Max number of systems
Capacity-based licensing limits each NetApp Console organization to 24 Cloud Volumes ONTAP systems. A system can be a Cloud Volumes ONTAP HA pair, a Cloud Volumes ONTAP single-node system, or an additional storage VM that you create. The default storage VM does not count against the limit. This limit applies to all licensing models.
For example, let's say you have three systems:
  • A single node Cloud Volumes ONTAP system with one storage VM (this is the default storage VM that's created when you deploy Cloud Volumes ONTAP)
    This system counts as one system.
  • A single node Cloud Volumes ONTAP system with two storage VMs (the default storage VM, plus one additional storage VM that you created)
    This system counts as two systems: one for the single-node system and one for the additional storage VM.
  • A Cloud Volumes ONTAP HA pair with three storage VMs (the default storage VM, plus two additional storage VMs that you created)
    This system counts as three systems: one for the HA pair and two for the additional storage VMs.
That's six systems in total. You would then have room for an additional 14 systems in your organization.
If you have a large deployment that requires more than 24 systems, contact your accounts representative or sales team.
Learn about storage limits for:
