Tier inactive Cloud Volumes ONTAP data to a low-cost object storage
You can reduce storage costs for Cloud Volumes ONTAP by combining an SSD or HDD performance tier for hot data with an object storage capacity tier for inactive data. Data tiering is powered by FabricPool technology. For a high-level overview, refer to Data tiering overview.
To set up data tiering, you need to do the following:
Choose a supported configurationMost configurations are supported. If you have a Cloud Volumes ONTAP system running the most recent version, then you are good to go. Learn more.
Ensure connectivity between Cloud Volumes ONTAP and object storage-
For Azure, you won't need to do anything as long as the NetApp Console has the required permissions. Learn more.
For Google Cloud, you need to configure the subnet for Private Google Access and set up a service account. Learn more.
Ensure that you have an aggregate with tiering enabledData tiering should be enabled on an aggregate to enable it on a volume. You should be aware of the requirements for new volumes and for existing volumes. Learn more.
Choose a tiering policy when creating, modifying, or replicating a volumeThe NetApp Console prompts you to choose a tiering policy when you create, modify, or replicate a volume.
What's not required for data tiering?
Configurations that support data tiering
You can enable data tiering when using specific configurations and features.
Support in AWS
Data tiering is supported in AWS beginning with Cloud Volumes ONTAP 9.2.
The performance tier can be General Purpose SSDs (gp3 or gp2) or Provisioned IOPS SSDs (io1).
We do not recommend tiering data to object storage when using Throughput Optimized HDDs (st1). -
The inactive data is tiered to Amazon S3 buckets. Tiering to other providers is not supported.
Support in Azure
Data tiering is supported in Azure as follows:
Version 9.4 in with single-node systems
Version 9.6 in with HA pairs
The performance tier can be Premium SSD managed disks, Standard SSD managed disks, or Standard HDD managed disks.
The inactive data is tiered to Microsoft Azure Blob. Tiering to other providers is not supported.
Support in Google Cloud
Data tiering is supported in Google Cloud beginning with Cloud Volumes ONTAP 9.6.
The performance tier can be either SSD persistent disks, balanced persistent disks, or standard persistent disks.
The inactive data is tiered to Google Cloud Storage. Tiering to other providers is not supported.
Feature interoperability
Data tiering is supported with encryption technologies.
Thin provisioning must be enabled on volumes.
Requirements
Depending on your cloud provider, certain connections and permissions must be set up so that Cloud Volumes ONTAP can tier cold data to object storage.
Requirements to tier cold data to Amazon S3
Ensure that Cloud Volumes ONTAP has a connection to Amazon S3. The best way to provide that connection is by creating a VPC Endpoint to the S3 service. For instructions, refer to the AWS Documentation: Creating a Gateway Endpoint.
When you create the VPC Endpoint, be sure to select the region, VPC, and route table that corresponds to the Cloud Volumes ONTAP instance. You must also modify the security group to add an outbound HTTPS rule that enables traffic to the S3 endpoint. Otherwise, Cloud Volumes ONTAP cannot connect to the S3 service.
If you experience any issues, refer to AWS Support Knowledge Center: Why can’t I connect to an S3 bucket using a gateway VPC endpoint?.
Requirements to tier cold data to Azure Blob storage
You don't need to set up a connection between the performance tier and the capacity tier as long as the Console has the required permissions. The Console enables a VNet service endpoint for you if the custom role for the Console agent has these permissions:
"Microsoft.Network/virtualNetworks/subnets/write",
"Microsoft.Network/routeTables/join/action",
The custom role includes the permissions by default. View Azure permission for the Console agent
Requirements to tier cold data to a Google Cloud Storage bucket
The subnet in which Cloud Volumes ONTAP resides must be configured for Private Google Access. For instructions, refer to Google Cloud Documentation: Configuring Private Google Access.
A service account must be attached to Cloud Volumes ONTAP.
You're prompted to select this service account when you create a Cloud Volumes ONTAP system.
If you don't select a service account during deployment, you'll need to shut down Cloud Volumes ONTAP, go to the Google Cloud Console, and then attach the service account to the Cloud Volumes ONTAP instances. You can then enable data tiering as described in the next section.
To encrypt the bucket with customer-managed encryption keys, enable the Google Cloud storage bucket to use the key.
Enable data tiering after implementing the requirements
The Console creates an object store for cold data when the system is created, as long as there are no connectivity or permissions issues. If you didn't implement the requirements listed above until after you created the system, then you'll need to manually enable tiering through the API or ONTAP System Manager, which creates the object store.
The ability to enable tiering through the Console will be available in a future Cloud Volumes ONTAP release. |
Ensure that tiering is enabled on aggregates
Data tiering must be enabled on an aggregate in order to enable data tiering on a volume. You should be aware of the requirements for new volumes and for existing volumes.
New volumes
If you're enabling data tiering on a new volume, then you don't need to worry about enabling data tiering on an aggregate. The Console creates the volume on an existing aggregate that has tiering enabled, or it creates a new aggregate for the volume if a data tiering-enabled aggregate doesn't already exist.
Existing volumes
To enable data tiering on an existing volume, ensure it is enabled on the underlying aggregate. If data tiering isn't enabled on the existing aggregate, then you'll need to use ONTAP System Manager to attach an existing aggregate to the object store.
From the left navigation menu, select Storage > Management.
Open the Cloud Volumes ONTAP system.
Select select the Aggregates tab and check if tiering is enabled or disabled on the aggregate.
In ONTAP System Manager, select Storage > Tiers.
Select the action menu for the aggregate and select Attach Cloud Tiers.
Select the cloud tier to attach and select Save.
You can now enable data tiering on new and existing volumes, as explained in the next section.
Tier data from read-write volumes
Cloud Volumes ONTAP can tier inactive data on read-write volumes to cost-effective object storage, freeing up the performance tier for hot data.
In the Volumes tab under the system, create a new volume or change the tier of an existing volume:
Task Action Create a new volume
Select Add New Volume.
Modify an existing volume
Select the desired volume tile, select Manage volume to access the Manage Volumes right-side panel, and then select Advanced actions and Change tiering policy under the right panel.
Select a tiering policy.
For a description of these policies, refer to Data tiering overview.
Example
The Console creates a new aggregate for the volume if a data tiering-enabled aggregate does not already exist.
Tier data from data protection volumes
Cloud Volumes ONTAP can tier data from a data protection volume to a capacity tier. If you activate the destination volume, the data gradually moves to the performance tier as it is read.
On the Systems page, select the Cloud Volumes ONTAP system that contains the source volume, and then drag it to the system to which you want to replicate the volume.
Follow the prompts until you reach the tiering page and enable data tiering to object storage.
Example
For help with replicating data, refer to Replicating data to and from the cloud.
Change the storage class for tiered data
After you deploy Cloud Volumes ONTAP, you can reduce your storage costs by changing the storage class for inactive data that hasn't been accessed for 30 days. The access costs are higher if you do access the data, so you must take that into consideration before you change the storage class.
The storage class for tiered data is system wide—it's not per volume.
For information about supported storage classes, refer to Data tiering overview.
On the Cloud Volumes ONTAP system, select the menu icon and then select Storage Classes or Blob Storage Tiering.
Choose a storage class and then select Save.
Change the free space ratio for data tiering
The free space ratio for data tiering defines how much free space is required on Cloud Volumes ONTAP SSDs/HDDs when tiering data to object storage. The default setting is 10% free space, but you can tweak the setting based on your requirements.
For example, you might choose less than 10% free space to ensure that you are utilizing the purchased capacity. The Console can then purchase additional disks for you when additional capacity is required (up until you reach the disk limit for the aggregate).
If there isn't sufficient space, then Cloud Volumes ONTAP can't move the data and you might experience performance degradation. Any change should be done with caution. If you're unsure, reach out to NetApp Support for guidance. |
The ratio is important for disaster recovery scenarios because as data is read from the object store, Cloud Volumes ONTAP moves the data to SSDs/HDDs to provide better performance. If there isn't sufficient space, then Cloud Volumes ONTAP can't move the data. Take this into consideration when changing the ratio so that you can meet your business requirements.
From the left navigation pane, go to Administration > Agents.
Select the
icon for the Console agent that manages your Cloud Volumes ONTAP system. -
Select Cloud Volumes ONTAP Settings.
Under Capacity, select Aggregate Capacity Thresholds - Free Space Ratio for Data Tiering.
Change the free space ratio based on your requirements and select Save.
Change the cooling period for the auto tiering policy
If you enabled data tiering on a Cloud Volumes ONTAP volume using the auto tiering policy, you can adjust the default cooling period based on your business needs. This action is supported using ONTAP CLI and API only.
The cooling period is the number of days that user data in a volume must remain inactive before it is considered "cold" and moved to object storage.
The default cooling period for the auto tiering policy is 31 days. You can change the cooling period as follows:
9.8 or later: 2 days to 183 days
9.7 or earlier: 2 days to 63 days
Use the minimumCoolingDays parameter with your API request when creating a volume or modifying an existing volume.
Remove an S3 bucket on decommissioning a system
You can delete an S3 bucket with the data tiered from a Cloud Volumes ONTAP system when you decommission the environment.
You can delete the S3 bucket only if:
The Cloud Volume ONTAP system is deleted from the Console.
All objects are deleted from the bucket and the S3 bucket is empty.
When you decommission a Cloud Volumes ONTAP system, the S3 bucket that was created for the environment is not deleted automatically. Instead, it remains in an orphaned state to prevent any accidental data loss. You can delete the objects in the bucket, then remove the S3 bucket itself, or keep it for later use.
Refer to ONTAP CLI: vserver object-store-server bucket delete.
