Licenses and subscriptions
Manage billing preferences
Contributors netapp-ahibbard joan-ing netapp-tonias netapp-ml94669
You can configure and manage billing preferences in the NetApp Console to control how capacity usage, renewals, and invoices are applied to your organization's accounts.
Billing preferences determine whether usage charges come from NetApp licenses, cloud marketplace contracts, or Keystone agreements.
Before you begin
  • All relevant marketplace subscriptions are linked to your organization.
  • You reviewed the existing configuration for licenses and subscriptions.
Required Console role
To perform this task, you need the Licenses and subscriptions admin role.Learn about Licenses and subscriptions roles for NetApp Console.
Set billing preferences
You can select how the Console applies usage charges across billing sources. This determines which accounts are charged first and how renewals are handled.
Steps
  1. In NetApp Console, select Administration > Licenses and subscriptions.
  2. Select Billing preferences.
  3. Choose one of the following billing modes:
    • NetApp licenses first – Use NetApp licenses first, then marketplace subscriptions for additional usage.
    • Marketplace subscriptions only – Bill all usage directly through marketplace subscriptions.
  4. Under Marketplace subscriptions, select the subscription for each cloud provider (AWS, Azure, and Google Cloud).
  5. If you use multiple subscriptions under a single cloud provider, enable Custom CVO configuration.
  6. Optionally, update Invoice contacts and Notification contacts.
  7. Optionally, enter a Cost center tag to associate billing with internal accounting codes.
  8. Select Save changes.
  9. When prompted, review the confirmation dialog then select Confirm.
Result
NetApp Console updates the billing mappings. Future service charges and renewals now use the selected configuration.
Note Changing the billing mode redistributes how service charges are applied. New Cloud Volumes ONTAP instances automatically inherit the selected configuration.
Enable custom Cloud Volumes ONTAP configuration
You can now assign specific marketplace subscriptions to individual Cloud Volumes ONTAP instances under the same cloud provider.
Use this mode if your organization maintains different billing accounts for separate business units or environments.
Steps
  3. Under Marketplace subscriptions, enable Custom CVO configuration.
  4. Select Save changes.
Result
Warning After this is enabled, custom Cloud Volumes ONTAP configuration cannot be reverted from the Billing preferences. Disabling this resets all Cloud Volumes ONTAP billing to the standard billing configuration for your data services.
Edit marketplace configuration
You can edit marketplace configuration details to associate subscriptions with cloud projects or to update contract information.
Steps
  1. Open Licenses and subscriptions.
  3. Select the view for the following:
    • Marketplace subscription name
    • Cloud project
    • Subscription type (Annual or PAYGO)
Result
The new configuration takes effect immediately, and billing data synchronizes with the cloud provider.
Tip To map one subscription to multiple cloud projects, ensure that Custom CVO configuration is enabled first.
Confirm or revert billing changes
Every update to billing preferences requires confirmation to prevent accidental changes.
Confirm changes
  1. After editing billing preferences, select Save changes.
  2. Review the summary in the confirmation dialog.
  3. Select Save to apply updates, or Cancel to discard them.
Revert to standard billing
  1. Open Billing preferences.
  2. Disable Custom CVO configuration.
  3. When prompted, confirm that you want to revert to the standard configuration.
Result
Cloud Volumes ONTAP instances return to the default standard billing method used for the other data services.
