Lifecycle planning
Review capacity status in Lifecycle planning
Contributors netapp-bcammett amgrissino
If storage assets in your environment are currently below or forecasted to be below the threshold of 90% capacity, Lifecycle planning identifies those as low-capacity resources and alerts you. Additionally, Lifecycle planning provides recommendations on whether you should tier data.
You can review the following types of data to assist in the capacity issue resolution.
  • Platform
  • Country where asset is located
  • Current and forecasted capacity by month
Steps
  1. Log in to the NetApp Console.
  2. From the left navigation, select Capacity.
    Capacity page showing a list of systems
  3. From the Capacity page, select a system.
    Capacity page in Lifecycle planning
  4. Select Evaluate Storage Options for the asset.
  5. Choose one of the options:
