NetApp Console local deployment
Learn about secure access to NetApp Console local deployment
Contributors netapp-tonias netapp-ml94669
NetApp Console local deployment provides multiple layers of security to protect your storage management environment and control who can access it.
Active Directory integration
Connect NetApp Console local deployment to your Active Directory so users can sign in with their existing corporate credentials. This eliminates the need for separate passwords in Console local deployment and supports directory-backed sign-in for the users that you add to your organization.
Multi-factor authentication
Users can enable multi-factor authentication (MFA) for an additional layer of verification to prevent unauthorized access, even if credentials are compromised.
Identity and access management
After authenticating users, control and monitor what they can do inside NetApp Console local deployment.
Use role-based access control to define what each member can see and manage. Assign members to specific fleets so they access only the storage resources relevant to their responsibilities.
Audit logging
Track all user activity (including API and service account users) in NetApp Console local deployment for compliance and security investigations.
