NetApp Console local deployment
Alert remediation actions in NetApp Console local deployment
Contributors netapp-ml94669 netapp-tonias
Use this reference to understand the remediation actions available from Fix It in NetApp Console local deployment. For each action, the table describes what the action does and the related alert. Review the action details in the confirmation dialog before you run it. This reference describes actions in the Alerts workflow; it does not identify which actions the Console assistant can suggest.
Remediation actions
Remediation action Alert name Alert description Impact area Remediation summary
Enable automatic volume growth
Volume full
The volume is running low on space and is nearing full capacity.
Capacity
Automatically increases a volume's size (up to a configured limit) to reduce the risk of running out of space.
Resize volume
Volume full
Capacity
Increases a volume's size to provide more space immediately.
Bring volume online
Volume offline
The volume is offline and not serving data.
Availability
Brings an offline volume online so it can resume serving data.
Bring aggregate online
Aggregate offline
The aggregate is not online and volumes hosted on it may be unavailable.
Availability
Brings an offline aggregate online to restore access to the volumes it hosts.
Bring LUN online
LUN offline
The LUN is offline and host access is unavailable.
Availability
Brings an offline LUN online so hosts can resume access and I/O.
Unrestrict volume
Volume restricted
The volume is in a restricted state and may not serve I/O normally.
Availability
Returns a restricted volume to an online state so clients can access it again.
Bring NVMe namespace online
NVMe namespace is offline
The NVMe namespace is offline and host access is unavailable.
Availability
Brings an offline NVMe namespace online to restore host access.
Bring intercluster LIF up
Intercluster LIF down
An intercluster LIF is down and cluster-to-cluster communication may be impacted.
Connectivity
Brings an intercluster LIF up to restore cluster-to-cluster connectivity used for replication.
Re-enable MetroCluster AUSO
MetroCluster automatic unplanned switchover disabled
Automatic unplanned switchover is disabled on this cluster.
Availability
Re-enables automatic unplanned switchover (AUSO) so MetroCluster protection works as intended.
Configure Service Processor network
Service Processor is not configured
The Service Processor (SP) network is not configured.
Manageability
Configures the Service Processor (SP) network settings to enable out-of-band management access.
Assign unassigned disks
Unassigned disks detected
Unassigned disks are present and available capacity may be unused. Assign the disks to a node so they can be used for storage.
Availability
Assigns currently unassigned disks to a node so they can be used for storage.
Root volume space recovery
Node root volume space low
Available space on the node root volume is low and may affect normal system operation.
System health
Frees space on the node root volume by deleting the largest snapshot or the largest core dump file. Deletions are permanent.
