Configure notification rules for alerts in NetApp Console local deployment
Configure notification rules in NetApp Console local deployment to control which alerts raise notifications, who receives them, and how they are delivered.
Super admin, Organization admin, Storage admin, Operations support analyst, or any of the admin roles for NetApp Backup and Recovery. Learn about access roles.
Use notification rules to route the right alerts to the right people through the channels that fit your environment, while reducing noise from alerts that aren't relevant to you. Notification rules complement the Alerts page: you investigate or remediate the alert in the Alerts workflow, then use rules to control how similar alerts are delivered in the future.
A notification rule matches alerts based on conditions you define—such as service, severity, and impact area—and then delivers a notification through the channels you select. The Console local deployment includes a default notification rule that you can view and adjust, and you can create your own custom rules. You can also mute rules to temporarily suppress notifications during planned events like maintenance windows.
Before you begin
To deliver notifications by email, your Organization admin must configure an email server in the Console local deployment. To deliver notifications to an external system, your Organization admin must configure a webhook. Learn how configuring webhooks.
The Console local deployment Notification Center displays notifications by default, so no additional setup is required for in-console notifications.
Console UI notifications are retained for 24 hours. |
View notification rules
The notification rules page is the central place to review and manage every rule that applies to your organization. Each rule shows its key attributes so that you can quickly assess and adjust your alerting behavior.
From the left navigation, select Health > Alerts.
Select Notification rules.
Review the rules in the list. Each rule shows its active status, name, the services and severity levels it monitors, the roles authorized to receive notifications, the enabled delivery channels, when it was last modified, and any scheduled mute period.
To find a specific rule, use the filter and search controls to filter by active status, service, severity, role, channel, or mute status.
Create a notification rule
Create a notification rule to define the conditions that trigger a notification and how that notification is delivered.
Notification rules apply to all systems in the organization. |
Suppose you want to ensure no critical alert goes unnoticed, regardless of which system it originates from. You can create a broad rule that routes all critical alerts to the Console UI notifications for storage admins.
In this example, you create a rule with the following settings:
Services: All
Severity levels: Critical
Roles: Storage admin
Delivery channels: Console UI notifications
With this rule in place, storage admins see a notification in the Console for every critical alert across all systems. This rule acts as a baseline that you can supplement with more targeted rules.
Suppose your storage admins need to respond immediately to critical capacity issues on a specific production system, but you don't want lower-severity alerts to flood their inboxes. You can create a targeted rule that emails storage admins only when a critical capacity alert fires on that system.
Services: ONTAP Management
Impact areas: Capacity
Delivery channels: Email
With this rule in place, Console local deployment emails all storage admins for the specified system when a critical capacity alert occurs. Alerts with a lower severity, such as warning or informational, don't generate an email, so the team can focus on the issues that require urgent attention.
Select Notification rules, and then select Add rule.
Define the conditions that the rule matches:
Rule name: enter a concise, descriptive name. This field is required.
Rule description: optionally, enter additional context about the rule's purpose.
Services: select one or more ONTAP or platform services that the rule applies to.
Roles: select the access roles that users must have to receive notifications when the rule is triggered.
Severity levels: select which severity levels the rule monitors, such as Critical, Warning, Error, or Information.
Impact areas: select the operational areas to match, such as Capacity or Performance.
Alerts: indicates that all alerts will be notified as per the policy.
Systems: indicates that alerts reported on all systems in the organization will be notified as per the policy.
Select the delivery channels for the notification:
Email notifications: sends alert emails to users who have the selected roles. Requires a configured email server.
Webhook integrations: sends alert data to an external system. Requires selecting a configured webhook integration.
Console UI notifications: displays real-time notifications for users who have the selected roles.
Optionally, to suppress notifications from this rule during a planned period, such as a maintenance window, set a Mute notifications schedule, and choose a recurrence if you want the mute period to repeat. You can add multiple mute windows per rule, which is useful for recurring maintenance cycles such as weekly patching.
Select Create.
Enable or disable a notification rule
Enable or disable individual notification rules to control which conditions raise notifications. Disable rules that aren't relevant to your environment to reduce noise, and enable rules to start receiving their notifications again.
Locate the rule you want to change.
Toggle the rule's Active switch on or off. The change takes effect immediately.
Mute a notification rule
Mute a notification rule to suppress alert delivery during a planned event, such as a maintenance window, without disabling the rule. Alerts continue to appear in the Alerts page during the mute period—only the email, webhook, and in-console notifications are suppressed. When the mute window expires, notifications resume automatically.
You can add multiple mute windows to a single rule and configure each one to recur on a schedule.
One-off maintenance window: You're running a firmware upgrade on a storage system Saturday night and want to suppress the expected alerts during that window. Set a mute window for Saturday 10:00 PM to Sunday 2:00 AM with no recurrence. When the window expires, notifications resume automatically.
Recurring weekly patching window: Your team patches systems every Sunday from midnight to 4:00 AM. Add a mute window with weekly recurrence so notifications are suppressed automatically each week without manual intervention. If a second system has its own patching schedule at a different time, add a second mute window to the same rule with its own start time and recurrence.
In the rules list, locate the rule you want to mute and select the action menu for that rule.
Select Edit.
In the Mute notifications section, set the start and end date and time for the mute window.
Optionally, select a recurrence to repeat the window on a schedule.
To add additional mute windows, select Add mute window and repeat the previous steps.
Select Save.
Delete a notification rule
Delete a notification rule if you no longer need it. Deleting a rule permanently removes it, so you can't recover it.
In the rules list, locate the rule you want to delete and select the action menu for that rule.
Select Delete from the action menu.
