Learn about NetApp Console agents
A Console agent runs in your cloud network or on-premises network. You use a Console agent to connect NetApp Console services to your storage environments.
What you can do without a Console agent
Some Console features and services are available if you don't deploy a Console agent:
Amazon FSx for NetApp ONTAP
Some actions require a Console agent or a NetApp Workloads link. Learn which actions require a Console agent or link
Automation hub
Azure NetApp Files
You don't need a Console agent to manage Azure NetApp Files, but one is required to use NetApp Data Classification to scan Azure NetApp Files.
Google Cloud NetApp Volumes
NetApp Copy and Sync
Digital advisor
Monitor license usage, subscription monitoring requires a Console agent
You can usually add a license to the NetApp Console without a Console agent.
An agent is required to add Cloud Volumes ONTAP node-based licenses because the data comes from the licenses installed on Cloud Volumes ONTAP systems.
Direct discovery of on-premises ONTAP clusters
You don't need a Console agent to add an on-premises ONTAP cluster to the Console, but one is required for additional Console features and data services.
Software updates
Sustainability
NetApp Workloads
When a Console agent is required
In standard mode, the Console requires a Console agent for:
Alerts
Amazon FSx for ONTAP management features
Amazon S3 storage
Azure Blob storage
NetApp Backup and Recovery
Data Classification
Cloud Volumes ONTAP
NetApp Disaster Recovery
E-Series systems
Economic efficiency 1
Google Cloud Storage buckets
On-premises ONTAP cluster integration with NetApp data services
NetApp Ransomware resilience
StorageGRID systems
NetApp Cloud Tiering
NetApp Volume Caching
1 You can access these services without a Console agent, but a Console agent is required to initiate actions.
You always need a Console agent to use the Console in restricted mode.
Console agents must be operational at all times
Console agents are a fundamental part of the NetApp Console. It's your responsibility (the customer) to ensure that relevant agents are up, operational, and accessible at all times. The Console can handle short agent outages, but you must fix infrastructure failures quickly.
This documentation is governed by the EULA. Operating the product outside the documentation may impact its functionality and your EULA rights.
Supported locations
You can install agents in the following locations:
Amazon Web Services
Microsoft Azure
Deploy a Console agent in Azure in the same region as the Cloud Volumes ONTAP systems it manages. Alternatively, deploy it in the Azure region pair. This ensures that an Azure Private Link connection is used between Cloud Volumes ONTAP and its associated storage accounts. Learn how Cloud Volumes ONTAP uses an Azure Private Link
Google Cloud
To use the Console and data services with Google Cloud, deploy your agent in Google Cloud.
On your premises
Communication with cloud providers
The agent uses TLS 1.3 for all communication to AWS, Azure, and Google Cloud.
Restricted mode
To use the Console in restricted mode, you install a Console agent and access the Console interface that's running locally on the Console agent.
How to install a Console agent
You can install a Console agent directly from the Console, from your cloud provider's marketplace, or by manually installing the software on your own Linux host or in your VCenter environment. How you get started depends on whether you're using the Console in standard mode or restricted mode.
Cloud Permissions
You need specific permissions to create the Console agent directly from the NetApp Console and another set of permissions for the Console agent instance itself. If you create the Console agent in AWS or Azure directly from the Console, then the Console creates the Console agent with the permissions that it needs.
When using the Console in standard mode, how you provide permissions depends on how you plan to create the Console agent.
To learn how to set up permissions, refer to the following:
Standard mode
To view the exact permissions that the Console agent needs for day-to-day operations, refer to the following pages:
It's your responsibility to update the Console agent policies as new permissions are added in subsequent releases. The release notes list new permissions.
Agent upgrades
NetApp updates agent software monthly to add features and improve stability. Some Console features, like Cloud Volumes ONTAP and on-premises ONTAP cluster management, rely on the Console agent version and settings.
In standard or restricted mode, the Console agent updates automatically if it has internet access.
Operating system and VM maintenance
Maintaining the operating system on the Console agent host is your (customer's) responsibility. For example, you (customer) should apply security updates to the operating system on the Console agent host by following your company's standard procedures for operating system distribution.
Note that you (customer) don't need to stop any services on the Console gent host when applying minor security updates.
If you (customer) need to stop and then start the Console agent VM, you should do so from your cloud provider's console or by using the standard procedures for on-premises management.
Multiple systems and agents
An agent can manage multiple systems and support data services in the Console. You can use a single agent to manage multiple systems based on deployment size and the data services you use.
For large-scale deployments, work with your NetApp representative to size your environment. Contact NetApp Support if you experience issues.
Here are a few examples of agent deployments:
You have a multicloud environment (for example, AWS and Azure) and you prefer to have one agent in AWS and another in Azure. Each manages the Cloud Volumes ONTAP systems running in those environments.
A service provider might use one Console organization to provide services for their customers, while using another organization to provide disaster recovery for one of their business units. Each organization needs its own agent.
