Console agent default configuration in NetApp Console
Learn about Console agent default configurations for standard deployments (with internet access) across AWS, Azure, and Google Cloud, as well as restricted deployments (without internet access) for on-premises environments.
Default configuration with internet access
The following configuration details apply if you deployed a Console agent from the NetApp Console, from your cloud provider's marketplace, or if you manually installed a Console agent on an on-premises Linux host that has internet access.
Console agent VM details for AWS
If you deployed a Console agent from the Console or from the AWS marketplace, note the following:
The EC2 instance type is t3.2xlarge.
The operating system for the image is Ubuntu 24.04 LTS.
The operating system does not include a GUI. You must use a terminal to access the system.
The installation includes Docker Engine, which is the required container orchestration tool.
The user name for the EC2 Linux instance is ubuntu (for agents created prior to May 2023, the user name is ec2-user).
The default system disk is a 100 GiB gp2 disk.
Console agent VM details for Azure
If you deployed a Console agent from the Console or from the Azure marketplace, note the following:
The VM type is Standard_D8s_v3.
The default system disk is a 100 GiB premium SSD disk.
Console agent VM details for Google Cloud
If you deployed a Console agent from the Console or from the Google Cloud marketplace, note the following:
The VM instance is n2-standard-8.
The default system disk is a 100 GiB SSD persistent disk.
Installation folder
The agent installation folder is in the following location:
/opt/application/netapp/cloudmanager
Log files
Log files are contained in the following folders:
/opt/application/netapp/cloudmanager/log
or -
/opt/application/netapp/service-manager-2/logs(starting with new 3.9.23 installations)The logs in these folders provide details about the Console agent.
/opt/application/netapp/cloudmanager/docker_occm/data/logThe logs in this folder provide details about cloud services and the Console service that runs on the Console agent.
Console agent service
The Console agent service is named
occm. -
The
occmservice is dependent on the MySQL service.If the MySQL service is down, then the
occmservice is down too.
Ports
The agent uses the following ports on the Linux host:
80 for HTTP access
443 for HTTPS access
Default configuration without internet access
The following configuration applies if you manually installed the Console agent on an on-premises Linux host that doesn't have internet access. Learn more about this installation option.
/opt/application/netapp/ds -
/var/lib/docker/volumes/ds_occmdata/_data/logThe logs in this folder provide details about the Console agent and docker images.
All services are running inside docker containers
The services are dependent on the docker runtime service running
80 for HTTP access
