NetApp Console setup and administration
Known limitations of NetApp Console
Contributors netapp-tonias
Known limitations identify platforms, devices, or functions that are not supported by this release of the product, or that do not interoperate correctly with it. Review these limitations carefully.
These limitations are specific to the set up for the NetApp Console and administration: the agent, the software as a service (SaaS) platform, and more.
Console agent limitations
Possible conflict with IP addresses in the 172 range
The NetApp Console deploys an agent with two interfaces that have IP addresses in the 172.17.0.0/16 and 172.18.0.0/16 ranges.
If your network has a subnet configured with either of these ranges, then you might experience connectivity failures from the Console. For example, discovering on-premises ONTAP clusters in the Console might fail.
See Knowledge Base article Agent IP conflict with existing network for instructions on how to change the IP address of the agent’s interfaces.
SSL decryption supported only for Cloud Volumes ONTAP
Transparent proxy servers are supported for agents associated with Cloud Volumes ONTAP only. You cannot use a transparent proxy for an agent if it is used with other NetApp data services. If you use NetApp data services with Cloud Volumes ONTAP, create a dedicated agent for Cloud Volumes ONTAP where you can use a transparent proxy server.
For enhanced security, you have the option to install an HTTPS certificate signed by a certificate authority (CA).
Blank page when loading the local UI
If you load the web-based console that's running on an agent, the interface might fail to display sometimes, and you just get a blank page.
This issue is related to a caching problem. The workaround is to use an incognito or private web browser session.
Shared Linux hosts are not supported
The agent isn't supported on a VM that is shared with other applications. The VM must be dedicated to the agent software.
Third-party agents and extensions
Third-party agents or VM extensions are not supported on the agent VM.
