NetApp Console setup and administration
Federate NetApp Console with Microsoft Entra ID
Contributors netapp-tonias
Federate with your Microsoft Entra ID IdP provider to enable single sign-on (SSO) for the NetApp Console. This allows users to log in using their corporate credentials.
Required roles
The Federation admin role is required to create and manage federations. Federation viewer can view the Federation page. Learn more about access roles.
Note You can federate with your corporate IdP or with the NetApp Support Site. NetApp recommends choosing one or the other, but not both.
NetApp supports service provider-initiated (SP-initiated) SSO only. You need to first configure the identity provider to trust NetApp as a service provider. Then, you can create a connection in the Console that uses the identity provider's configuration.
You can set up a federated connection with Microsoft Entra ID to enable single sign-on (SSO) for the Console. The process involves configuring your Microsoft Entra ID to trust the Console as a service provider and then creating the connection in the Console.
Before you begin
  • An IdP account with administrative privileges is required. Coordinate with your IdP administrator to complete the steps.
  • Identify the domain you want to use for federation. You can use your email domain or a different domain that you own. If you want to use a domain other than your email domain, you must first verify the domain in the Console. For instructions, see Verify your domain in NetApp Console.
Steps
  1. Select Administration > Identity and access.
  2. Select Federation to view the Federations page.
  3. Select Configure new federation.
Domain details
  1. Enter your domain details:
    1. Choose whether you want to use a verified domain or your email domain. The email domain is the domain associated with the account you are logged in with.
    2. Enter the name of the federation you are configuring.
    3. If you choose a verified domain, select the domain from the list.
  2. Select Next.
Connection method
  1. For your connection method, choose Provider and then select Microsoft Entra ID.
  2. Select Next.
Configuration instructions
  1. Configure your Microsoft Entra ID to trust NetApp as a service provider. You need to do this step on your Microsoft Entra ID server.
    1. Use the following values when registering your Microsoft Entra ID app to trust the Console:
    2. Create a client secret for your Microsoft Entra ID app. You'll need to provide the client ID, the client secret, and the Entra ID domain name to complete the federation.
  2. Return to the Console, and select Next to create the connection.
Create connection
  1. Create the connection with Microsoft Entra ID.
    1. Enter the client ID and client secret that you created in the previous step.
    2. Enter the Microsoft Entra ID domain name.
  2. Select Create connection. The system creates the connection in a few seconds.
Test and enable the connection
  1. Select Next.
  2. Select Test connection to test your connection. You are directed to a login page for your IdP server. Log in with your IdP credentials. After you log in, go back to the Console to enable the connection.
    Note When using the Console in restricted mode, copy the URL to either an incognito browser window or a separate browser to log in to your IdP.
  3. In the Console, select Next to review the summary page.
  4. Set up notifications.
    Choose between seven days and 30 days. The system emails expiry notifications and shows them in the Console to any user with the following roles: Super admin, Org admin, Federation admin, and Federation viewer.
  5. Review the federation details and then select Enable federation.
  6. Select Finish to complete the process.
After you enable the federation, users log in to the NetApp Console using their corporate credentials.
