Known issues
Known issues identify problems that might prevent you from using the service successfully. If a Bugs Online report is available, the bug ID contains a hyperlink to the report.
| Bug ID | Description |
Converged Systems Advisor does not remediate the DNS configuration for more than four SVMs. |
After creating multiple remediation jobs with collection enabled, collection is triggered only for the first remediation job. |
The "Storage failover state" CA rule was removed from Converged Systems Advisor. |
The version numbers of the Nexus and MDS switches are shown incorrectly under "Upgrade Advisor". |
