Converged Systems Advisor
What's new in Converged Systems Advisor
Contributors netapp-rlithman netapp-bcammett netapp-thomi netapp-aherbin RSS
NetApp periodically updates Converged Systems Advisor to bring you new features, enhancements, and bug fixes.
To confirm FlexPod components are supported by the CSA agent, reference the NetApp Interoperability Matrix Tool (IMT).
New functionality for storage change detection (diffs)
Now you can detect changes that have occurred on the storage system. To check for change, from the Storage Inventory pages, click View Configuration Difference. Then, select a previous configuration data and time, which will be compared to the most recent storage configuration. Any changes that have occurred will be highlighted for quick review.
Expanded configuration assurance for cluster interconnect switches
In the Converged Systems Advisor portal, the configuration assurance checks have been expanded to monitor the supportability of ONTAP cluster interconnect switching for the following models:
  • Cisco Nexus 3132Q-V
  • Cisco Nexus 3232C
  • Cisco Nexus 92300YC
Initial coverage of NVMe designs
Initial configuration assurance checks have been added to monitor supportability of NVMe ONTAP storage designs in FlexPod.
