Identify capacity risk
Use this recipe to identify storage pools or equivalent capacity domains approaching pressure and to find potential rebalance candidates.
The DII MCP is a Preview feature and is therefore subject to change. |
Prerequisites
A storage scope or permission to review all visible storage pools.
A lookback window of 30 days or less.
Agreement on organizational warning and critical thresholds.
Tools used
ObjectService_getObjectTypes
ObjectService_getMetadataForObjectType
ObjectService_query
ObjectService_groupObjects
ObjectService_queryPerformanceMetricsForObjects
AlertsService_getMetadata
AlertsService_queryForAlerts
Starter prompt
Assess storage capacity risk over the last 30 days. Discover the correct storage-pool object type and metadata, then rank pools using available used-capacity ratio, free capacity, growth, and time-to-full signals. Identify critical, warning, and watch-list pools, and suggest evidence-based rebalance candidates. State the thresholds and aggregation functions used.
Agent workflow
List object types and select the appropriate normalized or product-specific pool type.
Retrieve metadata.
Identify valid:
Pool and storage-system names
Total, used, and free capacity metrics
Used-ratio metric
Time-to-full or forecast metric
Groupable storage, tier, location, or service-level attributes
Query a current ranked snapshot using compatible aggregations.
Retrieve time series for growth-sensitive metrics over the requested lookback.
Where supported, group capacity by storage system, tier, or location.
Query active capacity-related alerts for corroboration.
Classify risk using the agreed thresholds.
Identify potential rebalance sources and destinations based on both capacity and operational constraints.
Example risk model
Use tenant policy when available. Otherwise, label the following as an illustrative model:
Critical: used ratio at or above 90%, or time to full under 30 days
Warning: used ratio at or above 80%, or time to full under 90 days
Watch: sustained positive growth with time to full under 180 days
Lower risk: none of the above conditions
Do not infer time to full from only two samples when DII supplies a forecast metric. If no forecast is available, describe the trend without presenting a precise exhaustion date.
Rebalance guidance
A destination is not suitable solely because it has free capacity. Consider:
Storage system and protocol compatibility
Service level and performance headroom
Data-protection and replication relationships
Workload placement constraints
Thin provisioning and overcommitment
Operational change windows
Suggested output
Capacity-risk summary
Critical and warning pools
Growth narrative
Active capacity alerts
Candidate source and destination pairs
Assumptions and missing data
Limits and privacy
Object windows cannot exceed 30 days per call. Use consecutive non-overlapping windows for longer trends.
Filters apply to raw metric values before aggregation.
Only group by attributes marked groupable in metadata.
Capacity values can use different units; normalize before comparing.
Follow-up prompts
Show the 30-day used-capacity trend for the five highest-risk pools.
Group pool capacity by storage system and identify systems with both a critical pool and a viable lower-risk destination.
Correlate the highest-risk pools with active capacity monitors and alerts.
