Data Infrastructure Insights
DII MCP operational recipes
Contributors netapp-alavoie
Recipes combine multiple read-only DII tools into repeatable infrastructure workflows. Use them as starting points and replace fictional resource names with values from your tenant.
Note The DII MCP is a Preview feature and is therefore subject to change.
Choose a workflow
Goal Recipe Primary DII surfaces
Validate collection coverage and freshness
Inventory environment and collection health
Acquisition units, data sources
Prioritize active infrastructure issues
Assess storage health
Alerts, monitors, logs, objects
Find pools approaching capacity pressure
Identify capacity risk
Object metadata, grouping, time series
Check Kubernetes collection component versions
Check Kubernetes collector currency
Kubernetes collectors
Investigate a slow volume or workload
Troubleshoot performance
Object metrics, alerts, logs
Review routing and suppression safely
Review notification posture
Rules, targets, maintenance windows
Standard investigation pattern
  1. Clarify the resource scope and time range.
  2. Discover available types.
  3. Retrieve metadata before using dynamic fields.
  4. Query a bounded time window.
  5. Correlate independent signals.
  6. Distinguish observed facts from inferences.
  7. Report limitations and recommended follow-up.
Safety
  • These recipes use read-only tools.
  • Keep time windows to 30 days or less.
  • Omit credentials, private addresses, UUIDs, raw webhook endpoints, and unnecessary log payloads.
  • Confirm high-impact operational actions outside the MCP workflow.
