Data Infrastructure Insights
Troubleshoot performance
Contributors netapp-alavoie
Use this recipe to investigate a slow volume, datastore, virtual machine, Kubernetes workload, or other DII object by correlating performance metrics, alerts, and platform logs.
Note The DII MCP is a Preview feature and is therefore subject to change.
Prerequisites
  • The affected resource name and approximate incident time.
  • A time range of 30 days or less.
  • A comparison period or known healthy baseline when possible.
Tools used
  • ObjectService_getObjectTypes
  • ObjectService_getMetadataForObjectType
  • ObjectService_query
  • ObjectService_queryPerformanceMetricsForObjects
  • ObjectService_groupObjects
  • AlertsService_getMetadata
  • AlertsService_queryForAlerts
  • LogService_getLogTypes
  • LogService_getLogTypeMetadata
  • LogService_queryLogEvents
Starter prompt
Investigate why the volume example-volume was slow between 09:00 and 11:00 UTC. Discover the correct object type and valid metrics, compare latency, IOPS, and throughput over the incident window, inspect related active alerts and platform logs, and compare with a healthy period. Separate evidence from hypotheses and identify the next measurement needed.
Agent workflow
  1. Resolve the resource to an exact object type and identity.
  2. Retrieve metadata for that object type.
  3. Identify valid latency, operations, throughput, utilization, and capacity metrics.
  4. Query current object attributes to establish placement and relationships.
  5. Retrieve time series over:
    • The incident window
    • A comparable healthy window
  6. Align timestamps and aggregation functions across metrics.
  7. Retrieve alerts related to the resource, containing system, host, node, or storage pool.
  8. Select relevant log streams, retrieve metadata, and search a narrow interval around metric changes.
  9. Test plausible hypotheses:
    • Demand spike
    • Resource saturation
    • Storage or fabric errors
    • Capacity pressure
    • Host or VM contention
    • Collection gap
  10. Report the most supported explanation and unresolved alternatives.
Evidence standards
Label findings:
  • Observed: directly returned by a tool.
  • Correlated: independent signals changed in the same interval.
  • Inferred: a plausible explanation not yet proven.
  • Unknown: required evidence is unavailable.
Correlation is not causation. A simultaneous alert should be treated as supporting evidence, not proof, unless the mechanism is established.
Metric guidance
  • Use AVG for broad behavior, but inspect MAX when short spikes matter.
  • Use SUM only for additive metrics.
  • Use CHANGE or CHANGE_RATIO for counters or growth where metadata supports it.
  • Avoid comparing series with different bucket boundaries or units.
  • Filters apply before time-bucket aggregation.
Suggested output
  1. Incident scope and timeline
  2. Metric evidence
  3. Alert and log evidence
  4. Healthy-period comparison
  5. Most likely explanation
  6. Alternative hypotheses
  7. Confidence and missing evidence
  8. Recommended next check
Limits and privacy
  • Time-series windows cannot exceed 30 days.
  • The performance tool returns a limited number of series; narrow the filter before increasing the limit.
  • Omit sensitive raw log fields that do not contribute to the diagnosis.
  • Do not propose disruptive remediation without validating it through normal operational controls.
Follow-up prompts
Compare maximum and average latency during the incident to the same hour on the previous healthy day.
Group related workloads by host or storage pool and identify whether the slowdown was isolated or shared.
Show the platform events within 15 minutes of the first latency increase.
