Data Infrastructure Insights
DII MCP tool reference
Contributors netapp-alavoie
The DII MCP Server currently exposes 26 read-only product tools across nine domains. A separate mcp_auth helper may appear when the connected client needs to authenticate.
Note The DII MCP is a Preview feature and is therefore subject to change.
Tool availability and results depend on the authenticated tenant, enabled DII features, configured collectors, and user permissions.
Query conventions
  • Discover types and metadata before querying dynamic fields.
  • Use exact, case-sensitive attribute and metric names returned by metadata.
  • Use ISO-8601 timestamps and IANA timezone names where required.
  • Keep query windows to 30 days or less.
  • Use limit and offset for object and alert pagination.
  • Use the returned cursor for log-event pagination.
  • Do not display complete webhook endpoint addresses.
Acquisition units
List acquisition units
AcquisitionUnitsService_getAcquisitionUnits
Returns all acquisition units with connection status, reporting freshness, operating system, version, IP address, and assigned data-source count.
Example:
List acquisition units. Summarize connected, failed, and never-reported units without displaying IP addresses or UUIDs.
Get an acquisition unit
AcquisitionUnitsService_getAcquisitionUnitByUuid
Retrieves full details for one acquisition unit. If the user supplies a name, list acquisition units first to resolve its UUID.
Required input: uuid
Alerts
Get alert metadata
AlertsService_getMetadata
Returns valid alert field names and data types. Call this before querying alerts.
Query alerts
AlertsService_queryForAlerts
Queries active or inactive alerts with selected attributes, filters, sorting, time bounds, and offset pagination.
Required inputs:
  • active
  • attributeNames
  • fromTime
  • toTime
  • timezone
Optional inputs include filter, sortField, sortAscending, limit, and offset. limit is 1-500; offset is 0-1000. Keep the time window below 30 days.
Example:
Retrieve critical active storage alerts from the last seven days. Return alert ID, monitor name, severity, status, and related storage name.
Get an alert by name
AlertsService_getAlertByName
Retrieves one alert using an alert ID in the AL-123456 format.
Required input: name
Get an alert by UUID
AlertsService_getAlertByUUID
Retrieves one alert using its UUID.
Data collectors
List data sources
CollectorService_getDataSources
Lists configured collectors with name, status, vendor, model, acquisition unit, version, and last successful acquisition. Optionally filter by an AU UUID.
Example:
Group configured data sources by status and vendor. Highlight failures and stale successful acquisitions.
Get a data source
CollectorService_getDataSourceById
Retrieves one collector with configuration, collection-package status, poll activity, discovered devices, patch information, and acquisition-unit context.
Required input: id
Use this tool for poll intervals, configured metrics, collection settings, or failure investigation.
List supported data source types
CollectorService_getDataSourceTypes
Lists product types supported by the DII collector catalog. This is not a list of collectors configured in the tenant.
Logs
List log types
LogService_getLogTypes
Lists log types currently available in the tenant.
Get log type metadata
LogService_getLogTypeMetadata
Returns valid attributes for a log type. Call it before searching or grouping events.
Required input: type
Query log events
LogService_queryLogEvents
Returns log events in descending timestamp order.
Required inputs:
  • type
  • fromTime
  • toTime
  • timezone
Optional inputs include attributes, filter, limit, and cursor. limit is 1-200. The event window cannot exceed 30 days. Pass the previous response's cursor to retrieve the next page.
Count log events over time
LogService_queryLogEventsCountHistogram
Returns fixed-size time buckets of event counts. Optionally group each bucket by a valid groupable attribute; grouped results return the top segments and an __other__ segment.
Required inputs:
  • type
  • fromTime
  • toTime
  • timezone
Optional inputs: filter, groupBy
Maintenance windows
List maintenance windows
MaintenanceWindowService_getMaintenanceWindows
Lists active, non-expired alert-suppression windows. Set includeExpired to true to include expired windows.
A successful empty response means no matching maintenance windows exist.
Get a maintenance window
MaintenanceWindowService_getMaintenanceWindowById
Retrieves one maintenance window.
Required input: id
Monitors
List monitors
MonitorsService_queryMonitors
Lists DII monitors. Use isSystem to return only system monitors, exclude system monitors, or return all monitors.
Get a monitor
MonitorsService_getMonitorById
Retrieves one monitor, including its description and corrective guidance when available.
Required input: id
Notifications
List notification rules
NotificationService_getNotificationRules
Lists rules that route matching alerts to notification targets. A successful empty response means no matching rules exist.
Get a notification rule
NotificationService_getNotificationRuleById
Retrieves one routing rule.
Required input: id
List webhook targets
NotificationService_getWebhooks
Lists webhook target metadata for Slack, Microsoft Teams, Discord, PagerDuty, and custom HTTP integrations. Optionally filter by comma-separated engine types.
Security requirement: complete endpoint addresses can contain credentials. Applications and agents must omit or redact the address field from displayed or forwarded results.
Safe example:
Count webhook targets by engine type and list only target names and status. Do not return endpoint addresses.
Objects and metrics
List object types
ObjectService_getObjectTypes
Lists object types currently available in the tenant.
Get object metadata
ObjectService_getMetadataForObjectType
Returns valid attributes, metrics, types, and grouping capabilities for one object type.
Required input: objectType
Query objects
ObjectService_query
Retrieves objects, selected attributes, and optional metrics. Filters referencing metrics apply to raw values before time-window aggregation.
Required inputs:
  • objectType
  • attributeNames
Optional inputs include metricNames, filter, sortFieldName, isSortAscending, fromTime, toTime, aggregateFunctions, limit, and offset.
Supported query aggregations: MAX, MIN, AVG, SUM, LAST. limit is 1-500. If time bounds are omitted, the tool defaults to a recent three-hour window.
Group objects
ObjectService_groupObjects
Groups objects by one valid groupable attribute and aggregates selected metrics. Filters apply to raw values before aggregation.
Required inputs:
  • objectType
  • groupByAttribute
  • metricNames
Optional inputs include aggregateFunctions, filter, sorting, time bounds, limit, and offset.
Supported group aggregations: MAX, MIN, AVG, SUM, FIRST, CHANGE, CHANGE_RATIO.
Query performance time series
ObjectService_queryPerformanceMetricsForObjects
Returns bucketed time-series data for one metric and matching objects.
Required inputs:
  • objectType
  • metricName
  • fromTime
  • toTime
  • timezone
Optional inputs include filter, aggregationFunction, limit, and isSortAscending. limit controls the number of returned series and must be 1-50.
Supported bucket aggregations: MAX, MIN, AVG, SUM, FIRST, CHANGE, CHANGE_RATIO.
Kubernetes collectors
List Kubernetes collectors
OperatorsManagement_getKubernetesCollectors
Returns cluster name, overall currency status, operator version, Network Performance and Map component version, Change Analysis component version, and last-reported timestamp.
Example:
Identify outdated Kubernetes collectors and summarize which components need attention.
Filter operators
Alert, log, and object queries support nested conditions:
  • EQ, NE
  • GT, LT, GE, LE
  • WILDCARD using * and ?
  • EXISTS
  • Nested and, or, and not
The connected server validates fields against metadata. If a query is rejected, refresh the relevant metadata and reconstruct the filter.
