Data Infrastructure Insights
Troubleshoot DII MCP
Contributors netapp-alavoie
Note The DII MCP is a Preview feature and is therefore subject to change.
The server does not connect
Check:
  1. The configured URL matches the endpoint supplied for your DII environment.
  2. The client supports remote HTTP MCP servers and the required authentication flow.
  3. Authentication completed successfully.
  4. Network policy allows access to the endpoint.
  5. The connected identity can access the DII tenant.
Restart or reload the MCP server after changing client configuration.
Authentication is required
Complete the client's login flow, then retry the original request. If a service identity is used, verify that its credential is valid and stored through an approved secret mechanism.
Do not repeatedly retry a confirmed authorization denial. Ask a DII administrator to review the user's tenant and resource permissions.
An object query rejects a field
Object attributes and metrics vary by type.
  1. Call ObjectService_getObjectTypes.
  2. Confirm the exact object type.
  3. Call ObjectService_getMetadataForObjectType.
  4. Copy field names exactly from the metadata.
  5. Verify that the value type and aggregation function are compatible.
Only attributes marked as groupable can be used to group objects.
A log query rejects an attribute
  1. Call LogService_getLogTypes.
  2. Confirm the exact log type.
  3. Call LogService_getLogTypeMetadata.
  4. Use only attributes returned for that log type.
Log event queries use cursor-based pagination. Pass the cursor returned by the previous page rather than an offset.
An alert query rejects a field
Call AlertsService_getMetadata immediately before constructing the query. Alert metadata can be broad and tenant-dependent; use exact field names.
The time range is invalid
  • Ensure fromTime is earlier than or equal to toTime.
  • Use ISO-8601 timestamps with an offset or Z.
  • Keep the requested window below 30 days.
  • Split longer investigations into consecutive, non-overlapping windows and summarize the results.
  • Supply a valid IANA timezone when the tool requires one.
Runtime enforcement is authoritative if it is stricter than a client-cached tool description.
A query returns too many results
  • Add a valid filter.
  • Reduce the time range.
  • Sort by the most relevant metric.
  • Lower the result limit.
  • Use grouping or a histogram when individual records are unnecessary.
  • Continue with offset or a log cursor only when more detail is needed.
A successful call returns no rows
An empty result is often a valid answer. It can mean:
  • No resources match the filter.
  • No events occurred in the selected time range.
  • No maintenance windows or notification rules are configured.
  • The selected data type is not populated by the tenant's collectors.
Do not describe a successful empty result as missing data unless other evidence indicates a collection problem.
An acquisition unit is connected but has never reported
Connection state and successful reporting are separate. Check:
  • lastReported
  • Assigned data-source count
  • Data-source acquisition status
  • AU host connectivity and version
  • Poll activity for an assigned data source
A collector is failed
Use CollectorService_getDataSourceById for the affected collector. Review recent poll activity, active patch information, package status, configuration, and the last successful acquisition time. Avoid displaying credentials or private configuration values.
Webhook results include complete addresses
Do not repeat the values. Summarize only target names, integration types, counts, and status. Follow Security and privacy if secret material was displayed or shared.
The AI assistant selected the wrong tool
Use a more explicit prompt:
First list the available object types. Retrieve metadata for the selected type. Then query only valid fields and explain which DII tools you used.
For common investigations, start from an operational recipe.
