Security and privacy
The DII MCP Server gives an AI client access to tenant infrastructure context. Treat that context with the same care as the DII user interface and APIs.
The DII MCP is a Preview feature and is therefore subject to change. |
Least-privilege access
Use an identity dedicated to the person, application, or automation connecting to MCP.
Grant only the DII read permissions needed for the intended workflows.
Review access when a user's role or operational responsibility changes.
Use a separate service identity for unattended automation.
The current DII product toolset documented here is read-only. Read-only access can still disclose sensitive names, topology, configuration, telemetry, and operational state.
Authentication
Prefer interactive OAuth or another short-lived authentication flow supported by your deployment. If non-interactive credentials are required:
Store them in an approved secret manager.
Scope and rotate them according to organizational policy.
Never place them in project files, shell history, prompts, screenshots, or documentation.
Sensitive fields
Potentially sensitive DII data includes:
IP addresses, hostnames, tenant-specific resource names, and UUIDs
Infrastructure topology and configuration
Alert descriptions and log payloads
User, owner, label, and annotation values
Webhook endpoint addresses
Webhook URLs commonly embed routing keys, signatures, tokens, or unique paths. Do not ask an agent to return a complete webhook address. Request only:
Target name
Integration or engine type
Enabled or delivery status
Applications integrating the MCP server should redact webhook addresses before displaying, storing, or forwarding tool results.
Prompt and output hygiene
Use fictional identifiers in reusable prompts and examples.
Ask the agent to omit IP addresses, UUIDs, endpoint addresses, and raw log payloads unless they are necessary.
Summarize findings instead of copying large raw responses.
Review generated content before placing it in tickets, chat channels, or external documents.
Follow organizational data-handling requirements for the selected AI client.
Tenant isolation
MCP results are tenant-scoped to the authenticated DII context. Do not combine results from multiple tenants unless the workflow and authorization explicitly permit it.
Audit and retention
Audit-event coverage and retention depend on the DII deployment and connected AI client. Before production use, administrators should confirm:
Whether MCP authentication and tool calls are logged
Which request arguments and result metadata are retained
Who can review those records
How long the AI client retains prompts and tool results
Do not assume that MCP-specific audit events or retention guarantees exist unless they are documented for your deployment.
Incident response
If a credential or credential-bearing endpoint appears in an MCP result, prompt, transcript, or published document:
Stop sharing the affected content.
Revoke or rotate the credential or integration secret.
Remove the value from stored artifacts where possible.
Review access and audit records.
Report the exposure through your organization's security process.
