Inventory environment and collection health
Use this recipe to understand whether DII's acquisition units and configured data sources are connected, reporting, and collecting successfully.
The DII MCP is a Preview feature and is therefore subject to change. |
Prerequisites
Access to acquisition-unit and collector tools.
An optional acquisition-unit or collector name to narrow the investigation.
Tools used
AcquisitionUnitsService_getAcquisitionUnits
AcquisitionUnitsService_getAcquisitionUnitByUuid
CollectorService_getDataSources
CollectorService_getDataSourceById
CollectorService_getDataSourceTypes
Starter prompt
Review my DII collection environment. Summarize acquisition units by connection status and reporting freshness, then summarize configured data sources by acquisition status and vendor. Highlight acquisition units that never reported, units with no assigned collectors, failed collectors, and stale successful acquisitions. Do not display IP addresses, UUIDs, or credentials.
Agent workflow
List all acquisition units.
Classify each AU using both connection status and
lastReported. -
Count assigned data sources per AU.
List all configured data sources.
Group collectors by status, vendor, model, and AU.
Identify:
Disconnected or heartbeat-failed AUs
Connected AUs that never reported
AUs with zero data sources
Failed collectors
Collectors with no successful acquisition
Successful collectors whose last acquisition is unexpectedly old
Retrieve full AU or collector details only for the exceptions.
Return a prioritized summary and clearly state the freshness threshold used.
Interpretation
Use these distinctions:
Connected and reporting: the AU is connected and has a recent
lastReportedvalue. -
Connected but never reported: connectivity exists, but successful telemetry reporting is not established.
Heartbeat failed: investigate the AU host, network path, and service.
Collector failed: inspect the collector's recent poll activity, package status, configuration, and last successful acquisition.
No assigned collectors: this can be intentional; verify before treating it as a fault.
The supported data source type catalog describes products DII can collect. It does not prove that those products are configured in the tenant.
Suggested output
Executive summary
Acquisition-unit status counts
Collector status counts
Exceptions ranked by operational impact
Recommended checks
Data limitations
Limits and privacy
Avoid returning AU UUIDs, IP addresses, private hostnames, or collector credentials.
A status value alone does not establish data freshness.
Retrieve detailed configuration only for named exceptions.
Follow-up prompts
Inspect the failed collector named example-array. Summarize recent poll activity and collection-package failures without showing credentials or private addresses.
Which acquisition units have not reported within the last 30 minutes, and which collectors depend on them?
Compare configured collector vendors with the DII supported data source type catalog.
