Data Infrastructure Insights
Assess storage health
Contributors netapp-alavoie
Use this recipe to prioritize storage issues by combining active alerts, monitor intent, corrective guidance, relevant platform logs, and object context.
Note The DII MCP is a Preview feature and is therefore subject to change.
Prerequisites
  • A time range of 30 days or less.
  • Optional storage-system, cluster, pool, or volume scope.
  • Access to alert, monitor, log, and object tools.
Tools used
  • AlertsService_getMetadata
  • AlertsService_queryForAlerts
  • AlertsService_getAlertByName
  • MonitorsService_getMonitorById
  • LogService_getLogTypes
  • LogService_getLogTypeMetadata
  • LogService_queryLogEvents
  • ObjectService_getObjectTypes
  • ObjectService_getMetadataForObjectType
  • ObjectService_query
Starter prompt
Assess storage health for the last 24 hours. Identify critical and warning active alerts for storage systems, nodes, pools, and volumes. For the highest-impact alerts, explain the monitor condition and corrective guidance, then inspect relevant EMS or storage-platform logs around the trigger time. Separate confirmed evidence from likely causes.
Agent workflow
  1. Get alert metadata.
  2. Identify valid fields for severity, status, monitor, related object, and trigger time.
  3. Query active storage-related alerts in the requested window.
  4. Rank alerts using:
    • Severity
    • Affected object type
    • Number of affected objects
    • Recency and recurrence
    • Availability, data-protection, performance, or capacity impact
  5. Retrieve full details for the highest-priority alerts.
  6. Retrieve their monitor definitions and corrective guidance.
  7. List log types and select the platform-native stream relevant to each alert, such as ONTAP EMS or StorageGRID events.
  8. Retrieve log metadata, then query a narrow interval around the alert.
  9. Retrieve object attributes or metrics needed to confirm current state.
  10. Produce a health summary with evidence, likely cause, impact, and next check.
Interpretation
Do not treat one signal as a complete health assessment:
  • Alerts show detected conditions.
  • Monitors explain the detection rule and intended corrective action.
  • Logs provide platform-native event context.
  • Objects and metrics show current inventory or measured state.
An active alert can remain open after the underlying condition changes. Use fresh object and metric data where possible.
Suggested output
For each priority issue:
  • Affected resource
  • Severity and alert state
  • Trigger time
  • Monitor and condition
  • Corroborating logs or metrics
  • Confirmed evidence
  • Likely cause, labeled as an inference
  • Corrective guidance
  • Confidence and missing evidence
Limits and privacy
  • Keep alert and log windows below 30 days.
  • Use narrow log windows to reduce unrelated events.
  • Omit unnecessary UUIDs, addresses, annotations, and raw payloads.
  • Corrective guidance is informational; validate commands against the relevant product documentation and change process.
Follow-up prompts
For alert AL-123456, show the monitor guidance and related EMS events within 30 minutes before and after the trigger.
Group active storage alerts by affected system and impact area. Which system needs attention first, and why?
Check whether the highest-priority alert is still supported by current object metrics.
